#define | NFS_PORT 2049 |
#define | NFS_PROG 100003 |
#define | NFS_VER2 2 |
#define | NFS_VER3 3 |
#define | NFS_V2MAXDATA 8192 |
#define | NFS_MAXDGRAMDATA 16384 |
#define | NFS_MAXDATA 32768 |
#define | NFS_MAXPATHLEN 1024 |
#define | NFS_MAXNAMLEN 255 |
#define | NFS_MAXPKTHDR 404 |
#define | NFS_MAXPACKET (NFS_MAXPKTHDR + NFS_MAXDATA) |
#define | NFS_MINPACKET 20 |
#define | NFS_FABLKSIZE 512 /* Size in bytes of a block wrt fa_blocks */ |
#define | NFS_OK 0 |
#define | NFSERR_PERM 1 |
#define | NFSERR_NOENT 2 |
#define | NFSERR_IO 5 |
#define | NFSERR_NXIO 6 |
#define | NFSERR_ACCES 13 |
#define | NFSERR_EXIST 17 |
#define | NFSERR_XDEV 18 /* Version 3 only */ |
#define | NFSERR_NODEV 19 |
#define | NFSERR_NOTDIR 20 |
#define | NFSERR_ISDIR 21 |
#define | NFSERR_INVAL 22 /* Version 3 only */ |
#define | NFSERR_FBIG 27 |
#define | NFSERR_NOSPC 28 |
#define | NFSERR_ROFS 30 |
#define | NFSERR_MLINK 31 /* Version 3 only */ |
#define | NFSERR_NAMETOL 63 |
#define | NFSERR_NOTEMPTY 66 |
#define | NFSERR_DQUOT 69 |
#define | NFSERR_STALE 70 |
#define | NFSERR_REMOTE 71 /* Version 3 only */ |
#define | NFSERR_WFLUSH 99 /* Version 2 only */ |
#define | NFSERR_BADHANDLE 10001 /* The rest Version 3, 4 only */ |
#define | NFSERR_NOT_SYNC 10002 |
#define | NFSERR_BAD_COOKIE 10003 |
#define | NFSERR_NOTSUPP 10004 |
#define | NFSERR_TOOSMALL 10005 |
#define | NFSERR_SERVERFAULT 10006 |
#define | NFSERR_BADTYPE 10007 |
#define | NFSERR_JUKEBOX 10008 |
#define | NFSERR_TRYLATER NFSERR_JUKEBOX |
#define | NFSERR_STALEWRITEVERF 30001 /* Fake return for nfs_commit() */ |
#define | NFSERR_RETVOID 0x20000000 /* Return void, not error */ |
#define | NFSERR_AUTHERR 0x40000000 /* Mark an authentication error */ |
#define | NFSERR_RETERR 0x80000000 /* Mark an error return for V3 */ |
#define | NFSX_UNSIGNED 4 |
#define | NFSX_V2FH 32 |
#define | NFSX_V2FATTR 68 |
#define | NFSX_V2SATTR 32 |
#define | NFSX_V2COOKIE 4 |
#define | NFSX_V2STATFS 20 |
#define | NFSX_V3FH (sizeof (fhandle_t)) /* size this server uses */ |
#define | NFSX_V3FHMAX 64 /* max. allowed by protocol */ |
#define | NFSX_V3FATTR 84 |
#define | NFSX_V3SATTR 60 /* max. all fields filled in */ |
#define | NFSX_V3SRVSATTR (sizeof (struct nfsv3_sattr)) |
#define | NFSX_V3POSTOPATTR (NFSX_V3FATTR + NFSX_UNSIGNED) |
#define | NFSX_V3WCCDATA (NFSX_V3POSTOPATTR + 8 * NFSX_UNSIGNED) |
#define | NFSX_V3COOKIEVERF 8 |
#define | NFSX_V3WRITEVERF 8 |
#define | NFSX_V3CREATEVERF 8 |
#define | NFSX_V3STATFS 52 |
#define | NFSX_V3FSINFO 48 |
#define | NFSX_V3PATHCONF 24 |
#define | NFSX_FH(v3) |
#define | NFSX_SRVFH(v3) ((v3) ? NFSX_V3FH : NFSX_V2FH) |
#define | NFSX_FATTR(v3) ((v3) ? NFSX_V3FATTR : NFSX_V2FATTR) |
#define | NFSX_PREOPATTR(v3) ((v3) ? (7 * NFSX_UNSIGNED) : 0) |
#define | NFSX_POSTOPATTR(v3) ((v3) ? (NFSX_V3FATTR + NFSX_UNSIGNED) : 0) |
#define | NFSX_POSTOPORFATTR(v3) |
#define | NFSX_WCCDATA(v3) ((v3) ? NFSX_V3WCCDATA : 0) |
#define | NFSX_WCCORFATTR(v3) ((v3) ? NFSX_V3WCCDATA : NFSX_V2FATTR) |
#define | NFSX_SATTR(v3) ((v3) ? NFSX_V3SATTR : NFSX_V2SATTR) |
#define | NFSX_COOKIEVERF(v3) ((v3) ? NFSX_V3COOKIEVERF : 0) |
#define | NFSX_WRITEVERF(v3) ((v3) ? NFSX_V3WRITEVERF : 0) |
#define | NFSX_READDIR(v3) |
#define | NFSX_STATFS(v3) ((v3) ? NFSX_V3STATFS : NFSX_V2STATFS) |
#define | NFSPROC_NULL 0 |
#define | NFSPROC_GETATTR 1 |
#define | NFSPROC_SETATTR 2 |
#define | NFSPROC_LOOKUP 3 |
#define | NFSPROC_ACCESS 4 |
#define | NFSPROC_READLINK 5 |
#define | NFSPROC_READ 6 |
#define | NFSPROC_WRITE 7 |
#define | NFSPROC_CREATE 8 |
#define | NFSPROC_MKDIR 9 |
#define | NFSPROC_SYMLINK 10 |
#define | NFSPROC_MKNOD 11 |
#define | NFSPROC_REMOVE 12 |
#define | NFSPROC_RMDIR 13 |
#define | NFSPROC_RENAME 14 |
#define | NFSPROC_LINK 15 |
#define | NFSPROC_READDIR 16 |
#define | NFSPROC_READDIRPLUS 17 |
#define | NFSPROC_FSSTAT 18 |
#define | NFSPROC_FSINFO 19 |
#define | NFSPROC_PATHCONF 20 |
#define | NFSPROC_COMMIT 21 |
#define | NFSPROC_NOOP 22 |
#define | NFS_NPROCS 23 |
#define | NFSV2PROC_NULL 0 |
#define | NFSV2PROC_GETATTR 1 |
#define | NFSV2PROC_SETATTR 2 |
#define | NFSV2PROC_NOOP 3 |
#define | NFSV2PROC_ROOT NFSV2PROC_NOOP /* Obsolete */ |
#define | NFSV2PROC_LOOKUP 4 |
#define | NFSV2PROC_READLINK 5 |
#define | NFSV2PROC_READ 6 |
#define | NFSV2PROC_WRITECACHE NFSV2PROC_NOOP /* Obsolete */ |
#define | NFSV2PROC_WRITE 8 |
#define | NFSV2PROC_CREATE 9 |
#define | NFSV2PROC_REMOVE 10 |
#define | NFSV2PROC_RENAME 11 |
#define | NFSV2PROC_LINK 12 |
#define | NFSV2PROC_SYMLINK 13 |
#define | NFSV2PROC_MKDIR 14 |
#define | NFSV2PROC_RMDIR 15 |
#define | NFSV2PROC_READDIR 16 |
#define | NFSV2PROC_STATFS 17 |
#define | NFSV3SATTRTIME_DONTCHANGE 0 |
#define | NFSV3SATTRTIME_TOSERVER 1 |
#define | NFSV3SATTRTIME_TOCLIENT 2 |
#define | NFSV3ACCESS_READ 0x01 |
#define | NFSV3ACCESS_LOOKUP 0x02 |
#define | NFSV3ACCESS_MODIFY 0x04 |
#define | NFSV3ACCESS_EXTEND 0x08 |
#define | NFSV3ACCESS_DELETE 0x10 |
#define | NFSV3ACCESS_EXECUTE 0x20 |
#define | NFSV3WRITE_UNSTABLE 0 |
#define | NFSV3WRITE_DATASYNC 1 |
#define | NFSV3WRITE_FILESYNC 2 |
#define | NFSV3CREATE_UNCHECKED 0 |
#define | NFSV3CREATE_GUARDED 1 |
#define | NFSV3CREATE_EXCLUSIVE 2 |
#define | NFSV3FSINFO_LINK 0x01 |
#define | NFSV3FSINFO_SYMLINK 0x02 |
#define | NFSV3FSINFO_HOMOGENEOUS 0x08 |
#define | NFSV3FSINFO_CANSETTIME 0x10 |
#define | NFS_SMALLFH 64 |
#define | fa2_size fa_un.fa_nfsv2.nfsv2fa_size |
#define | fa2_blocksize fa_un.fa_nfsv2.nfsv2fa_blocksize |
#define | fa2_rdev fa_un.fa_nfsv2.nfsv2fa_rdev |
#define | fa2_blocks fa_un.fa_nfsv2.nfsv2fa_blocks |
#define | fa2_fsid fa_un.fa_nfsv2.nfsv2fa_fsid |
#define | fa2_fileid fa_un.fa_nfsv2.nfsv2fa_fileid |
#define | fa2_atime fa_un.fa_nfsv2.nfsv2fa_atime |
#define | fa2_mtime fa_un.fa_nfsv2.nfsv2fa_mtime |
#define | fa2_ctime fa_un.fa_nfsv2.nfsv2fa_ctime |
#define | fa3_size fa_un.fa_nfsv3.nfsv3fa_size |
#define | fa3_used fa_un.fa_nfsv3.nfsv3fa_used |
#define | fa3_rdev fa_un.fa_nfsv3.nfsv3fa_rdev |
#define | fa3_fsid fa_un.fa_nfsv3.nfsv3fa_fsid |
#define | fa3_fileid fa_un.fa_nfsv3.nfsv3fa_fileid |
#define | fa3_atime fa_un.fa_nfsv3.nfsv3fa_atime |
#define | fa3_mtime fa_un.fa_nfsv3.nfsv3fa_mtime |
#define | fa3_ctime fa_un.fa_nfsv3.nfsv3fa_ctime |
#define | sf_tsize sf_un.sf_nfsv2.nfsv2sf_tsize |
#define | sf_bsize sf_un.sf_nfsv2.nfsv2sf_bsize |
#define | sf_blocks sf_un.sf_nfsv2.nfsv2sf_blocks |
#define | sf_bfree sf_un.sf_nfsv2.nfsv2sf_bfree |
#define | sf_bavail sf_un.sf_nfsv2.nfsv2sf_bavail |
#define | sf_tbytes sf_un.sf_nfsv3.nfsv3sf_tbytes |
#define | sf_fbytes sf_un.sf_nfsv3.nfsv3sf_fbytes |
#define | sf_abytes sf_un.sf_nfsv3.nfsv3sf_abytes |
#define | sf_tfiles sf_un.sf_nfsv3.nfsv3sf_tfiles |
#define | sf_ffiles sf_un.sf_nfsv3.nfsv3sf_ffiles |
#define | sf_afiles sf_un.sf_nfsv3.nfsv3sf_afiles |
#define | sf_invarsec sf_un.sf_nfsv3.nfsv3sf_invarsec |
