#define | _SOCKLEN_T_DECLARED |
#define | _PATH_HEQUIV "/etc/hosts.equiv" |
#define | _PATH_HOSTS "/etc/hosts" |
#define | _PATH_NETWORKS "/etc/networks" |
#define | _PATH_PROTOCOLS "/etc/protocols" |
#define | _PATH_SERVICES "/etc/services" |
#define | h_addr h_addr_list[0] /* address, for backward compatibility */ |
#define | NETDB_INTERNAL -1 /* see errno */ |
#define | NETDB_SUCCESS 0 /* no problem */ |
#define | HOST_NOT_FOUND 1 /* Authoritative Answer Host not found */ |
#define | TRY_AGAIN 2 /* Non-Authoritative Host not found, or SERVERFAIL */ |
#define | NO_RECOVERY 3 /* Non recoverable errors, FORMERR, REFUSED, NOTIMP */ |
#define | NO_DATA 4 /* Valid name, no data record of requested type */ |
#define | NO_ADDRESS NO_DATA /* no address, look for MX record */ |
__BEGIN_DECLS void | endhostent (void) |
void | endnetent (void) |
void | endprotoent (void) |
void | endservent (void) |
struct hostent * | gethostbyaddr (const void *, socklen_t, int) |
struct hostent * | gethostbyname (const char *) |
struct hostent * | gethostbyname2 (const char *, int) |
struct hostent * | gethostent (void) |
struct netent * | getnetbyaddr (uint32_t, int) |
struct netent * | getnetbyname (const char *) |
struct netent * | getnetent (void) |
struct protoent * | getprotobyname (const char *) |
struct protoent * | getprotobynumber (int) |
struct protoent * | getprotoent (void) |
struct servent * | getservbyname (const char *, const char *) |
struct servent * | getservbyport (int, const char *) |
struct servent * | getservent (void) |
void | herror (const char *) |
__const char * | hstrerror (int) |
void | sethostent (int) |
void | setnetent (int) |
void | setprotoent (int) |
void | setservent (int) |
void | _sethosthtent (int) |
void | _endhosthtent (void) |
void | _sethostdnsent (int) |
void | _endhostdnsent (void) |
void | _setnethtent (int) |
void | _endnethtent (void) |
void | _setnetdnsent (int) |
void | _endnetdnsent (void) |
struct hostent * | _gethostbyhtname (const char *, int) |
struct hostent * | _gethostbydnsname (const char *, int) |
struct hostent * | _gethostbynisname (const char *, int) |
struct hostent * | _gethostbyhtaddr (const char *, int, int) |
struct hostent * | _gethostbydnsaddr (const char *, int, int) |
struct hostent * | _gethostbynisaddr (const char *, int, int) |
struct netent * | _getnetbyhtname (const char *) |
struct netent * | _getnetbydnsname (const char *) |
struct netent * | _getnetbynisname (const char *) |
struct netent * | _getnetbyhtaddr (unsigned long, int) |
struct netent * | _getnetbydnsaddr (unsigned long, int) |
struct netent * | _getnetbynisaddr (unsigned long, int) |
void | _map_v4v6_address (const char *, char *) |
void | _map_v4v6_hostent (struct hostent *, char **, int *len) |
