rtems-4.11.3
score
cpu
moxie
asm.h
1
11
12
* NOTE: The spacing in the use of these macros
13
* is critical to them working as advertised.
14
15
* COPYRIGHT:
16
17
* This file is based on similar code found in newlib available
18
* from ftp.cygnus.com. The file which was used had no copyright
19
* notice. This file is freely distributable as long as the source
20
* of the file is noted. This file is:
21
22
* COPYRIGHT (c) 2011
23
* Anthony Green
24
25
* COPYRIGHT (c) 1989-1999, 2010.
26
* On-Line Applications Research Corporation (OAR).
27
28
* The license and distribution terms for this file may be
29
* found in the file LICENSE in this distribution or at
30
* http://www.rtems.org/license/LICENSE.
31
32
* $Id: asm.h,v 1.9 2010/06/29 00:31:09 joel Exp $
33
34
35
#ifndef _RTEMS_ASM_H
36
#define _RTEMS_ASM_H
37
38
39
* Indicate we are in an assembly file and get the basic CPU definitions.
40
41
42
rtems/score/moxie.h
43
44
45
* Recent versions of GNU cpp define variables which indicate the
46
* need for underscores and percents. If not using GNU cpp or
47
* the version does not support this, then you will obviously
48
* have to define these as appropriate.
49
50
51
#ifndef __USER_LABEL_PREFIX__
52
#define __USER_LABEL_PREFIX__
53
#endif
54
55
#ifndef __REGISTER_PREFIX__
56
#define __REGISTER_PREFIX__ "$"
57
#endif
58
59
rtems/concat.h
60
61
/* Use the right prefix for global labels. */
62
63
#define SYM(x) CONCAT1 (__USER_LABEL_PREFIX__, x)
64
65
/* Use the right prefix for registers. */
66
67
#define REG(x) CONCAT1 (__REGISTER_PREFIX__, x)
68
69
70
* define macros for all of the registers on this CPU
71
72
* EXAMPLE: #define d0 REG (d0)
73
74
#define fp REG(fp)
75
#define sp REG(sp)
76
#define r0 REG(r0)
77
#define r1 REG(r1)
78
#define r2 REG(r2)
79
#define r3 REG(r3)
80
#define r4 REG(r4)
81
#define r5 REG(r5)
82
#define r6 REG(r6)
83
#define r7 REG(r7)
84
#define r8 REG(r8)
85
#define r9 REG(r9)
86
#define r10 REG(r10)
87
#define r11 REG(r11)
88
#define r12 REG(r12)
89
#define r13 REG(r13)
90
91
92
* Define macros to handle section beginning and ends.
93
94
95
96
#define BEGIN_CODE_DCL .text
97
#define END_CODE_DCL
98
#define BEGIN_DATA_DCL .data
99
#define END_DATA_DCL
100
#define BEGIN_CODE asm ( ".text
101
#define END_CODE ");
102
#define BEGIN_DATA
103
#define END_DATA
104
#define BEGIN_BSS
105
#define END_BSS
106
#define END
107
108
109
* Following must be tailor for a particular flavor of the C compiler.
110
* They may need to put underscores in front of the symbols.
111
112
113
#define PUBLIC(sym) .globl SYM (sym)
114
#define EXTERN(sym) .globl SYM (sym)
115
116
#endif
concat.h
This include file defines ANSI concatenation macros.
moxie.h
