rtems-4.11.3
posix
include
sys
mman.h
1
/* $NetBSD: mman.h,v 1.36 2005/09/13 01:42:51 christos Exp $ */
2
3
4
* Copyright (c) 1982, 1986, 1993
5
* The Regents of the University of California. All rights reserved.
6
7
8
* modification, are permitted provided that the following conditions
9
* are met:
10
* 1. Redistributions of source code must retain the above copyright
11
* notice, this list of conditions and the following disclaimer.
12
* 2. Redistributions in binary form must reproduce the above copyright
13
* notice, this list of conditions and the following disclaimer in the
14
* documentation and/or other materials provided with the distribution.
15
* 3. Neither the name of the University nor the names of its contributors
16
* may be used to endorse or promote products derived from this software
17
* without specific prior written permission.
18
19
* THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
20
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
21
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
22
* ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
23
* FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
24
* DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
25
* OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
26
* HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
27
* LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
28
* OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
29
* SUCH DAMAGE.
30
31
* @(#)mman.h 8.2 (Berkeley) 1/9/95
32
33
34
#ifndef _SYS_MMAN_H_
35
#define _SYS_MMAN_H_
36
37
#ifdef __rtems__
38
39
#include <inttypes.h>
40
#include <stddef.h>
41
#include <sys/types.h>
42
43
#else
/* __rtems__ */
44
#include <sys/featuretest.h>
45
46
#include <machine/ansi.h>
47
48
#ifdef _BSD_SIZE_T_
49
typedef
_BSD_SIZE_T_ size_t;
50
#undef _BSD_SIZE_T_
51
#endif
52
53
#include <sys/ansi.h>
54
55
#ifndef mode_t
56
typedef
__mode_t mode_t;
57
#define mode_t __mode_t
58
#endif
59
60
#ifndef off_t
61
typedef
__off_t off_t;
/* file offset */
62
#define off_t __off_t
63
#endif
64
#endif
/* __rtems__ */
65
66
67
68
* Protections are chosen from these bits, or-ed together
69
70
#define PROT_NONE 0x00
/* no permissions */
71
#define PROT_READ 0x01
/* pages can be read */
72
#define PROT_WRITE 0x02
/* pages can be written */
73
#define PROT_EXEC 0x04
/* pages can be executed */
74
75
76
* Flags contain sharing type and options.
77
* Sharing types; choose one.
78
79
#define MAP_SHARED 0x0001
/* share changes */
80
#define MAP_PRIVATE 0x0002
/* changes are private */
81
82
#ifdef _KERNEL
83
84
* Deprecated flag; these are treated as MAP_PRIVATE internally by
85
* the kernel.
86
87
#define MAP_COPY 0x0004
/* "copy" region at mmap time */
88
#endif
89
90
91
* Other flags
92
93
#define MAP_FIXED 0x0010
/* map addr must be exactly as requested */
94
#define MAP_RENAME 0x0020
/* Sun: rename private pages to file */
95
#define MAP_NORESERVE 0x0040
/* Sun: don't reserve needed swap area */
96
#define MAP_INHERIT 0x0080
/* region is retained after exec */
97
#define MAP_HASSEMAPHORE 0x0200
/* region may contain semaphores */
98
#define MAP_TRYFIXED 0x0400
/* attempt hint address, even within break */
99
#define MAP_WIRED 0x0800
/* mlock() mapping when it is established */
100
101
102
* Mapping type
103
104
#define MAP_FILE 0x0000
/* map from file (default) */
105
#define MAP_ANON 0x1000
/* allocated from memory, swap space */
106
107
108
* Alignment (expressed in log2). Must be >= log2(PAGE_SIZE) and
109
* < # bits in a pointer (26 (acorn26), 32 or 64).
110
111
#define MAP_ALIGNED(n) ((n) << MAP_ALIGNMENT_SHIFT)
112
#define MAP_ALIGNMENT_SHIFT 24
113
#define MAP_ALIGNMENT_MASK MAP_ALIGNED(0xff)
114
#define MAP_ALIGNMENT_64KB MAP_ALIGNED(16)
/* 2^16 */
115
#define MAP_ALIGNMENT_16MB MAP_ALIGNED(24)
/* 2^24 */
116
#define MAP_ALIGNMENT_4GB MAP_ALIGNED(32)
/* 2^32 */
117
#define MAP_ALIGNMENT_1TB MAP_ALIGNED(40)
/* 2^40 */
118
#define MAP_ALIGNMENT_256TB MAP_ALIGNED(48)
/* 2^48 */
119
#define MAP_ALIGNMENT_64PB MAP_ALIGNED(56)
/* 2^56 */
120
121
122
* Error indicator returned by mmap(2)
123
124
#define MAP_FAILED ((void *) -1)
/* mmap() failed */
125
126
127
* Flags to msync
128
129
#define MS_ASYNC 0x01
/* perform asynchronous writes */
130
#define MS_INVALIDATE 0x02
/* invalidate cached data */
131
#define MS_SYNC 0x04
/* perform synchronous writes */
132
133
134
* Flags to mlockall
135
136
#define MCL_CURRENT 0x01
/* lock all pages currently mapped */
137
#define MCL_FUTURE 0x02
/* lock all pages mapped in the future */
138
139
#if defined(_NETBSD_SOURCE)
140
141
* Advice to madvise
142
143
#define MADV_NORMAL 0
/* no further special treatment */
144
#define MADV_RANDOM 1
/* expect random page references */
145
#define MADV_SEQUENTIAL 2
/* expect sequential page references */
146
#define MADV_WILLNEED 3
/* will need these pages */
147
#define MADV_DONTNEED 4
/* dont need these pages */
148
#define MADV_SPACEAVAIL 5
/* insure that resources are reserved */
149
#define MADV_FREE 6
/* pages are empty, free them */
150
151
* Flags to minherit
152
153
#define MAP_INHERIT_SHARE 0
/* share with child */
154
#define MAP_INHERIT_COPY 1
/* copy into child */
155
#define MAP_INHERIT_NONE 2
/* absent from child */
156
#define MAP_INHERIT_DONATE_COPY 3
/* copy and delete -- not
157
implemented in UVM */
158
#define MAP_INHERIT_DEFAULT MAP_INHERIT_COPY
159
#endif
160
161
#ifndef _KERNEL
162
163
#include <sys/cdefs.h>
164
165
__BEGIN_DECLS
166
void
*mmap(
void
size_t
int
int
int
, off_t);
167
int
munmap(
void
size_t
168
int
mprotect(
void
size_t
int
169
#ifndef __LIBC12_SOURCE__
170
#if defined(__rtems__)
171
int
msync(
void
size_t
int
172
#else
173
int
msync(
void
size_t
int
) __RENAME(__msync13);
174
#endif
175
#endif
176
int
mlock(
const
void
size_t
177
int
munlock(
const
void
size_t
178
int
mlockall(
int
179
int
munlockall(
void
180
181
int
madvise(
void
size_t
int
182
int
mincore(
void
size_t
char
183
int
minherit(
void
size_t
int
184
#endif
185
__END_DECLS
186
187
#endif
/* !_KERNEL */
188
189
#endif
/* !_SYS_MMAN_H_ */
