rtems-4.11.3
libnetworking
dev
mii
mii.h
1
/* $NetBSD: mii.h,v 1.9 2001/05/31 03:07:14 thorpej Exp $ */
2
3
4
* Copyright (c) 1997 Manuel Bouyer. All rights reserved.
5
6
* Modification to match BSD/OS 3.0 MII interface by Jason R. Thorpe,
7
* Numerical Aerospace Simulation Facility, NASA Ames Research Center.
8
9
10
* modification, are permitted provided that the following conditions
11
* are met:
12
* 1. Redistributions of source code must retain the above copyright
13
* notice, this list of conditions and the following disclaimer.
14
* 2. Redistributions in binary form must reproduce the above copyright
15
* notice, this list of conditions and the following disclaimer in the
16
* documentation and/or other materials provided with the distribution.
17
* 3. All advertising materials mentioning features or use of this software
18
* must display the following acknowledgement:
19
* This product includes software developed by Manuel Bouyer.
20
* 4. The name of the author may not be used to endorse or promote products
21
* derived from this software without specific prior written permission.
22
23
* THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR
24
* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
25
* OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
26
* IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT,
27
* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT
28
* NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
29
* DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
30
* THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
31
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF
32
* THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
33
34
* $FreeBSD: /repoman/r/ncvs/src/sys/dev/mii/mii.h,v 1.4 2002/04/29 11:57:28 phk Exp $
35
36
37
#ifndef _DEV_MII_MII_H_
38
#define _DEV_MII_MII_H_
39
40
41
* Registers common to all PHYs.
42
43
44
#define MII_NPHY 32
/* max # of PHYs per MII */
45
46
47
* MII commands, used if a device must drive the MII lines
48
* manually.
49
50
#define MII_COMMAND_START 0x01
51
#define MII_COMMAND_READ 0x02
52
#define MII_COMMAND_WRITE 0x01
53
#define MII_COMMAND_ACK 0x02
54
55
#define MII_BMCR 0x00
/* Basic mode control register (rw) */
56
#define BMCR_RESET 0x8000
/* reset */
57
#define BMCR_LOOP 0x4000
/* loopback */
58
#define BMCR_SPEED0 0x2000
/* speed selection (LSB) */
59
#define BMCR_AUTOEN 0x1000
/* autonegotiation enable */
60
#define BMCR_PDOWN 0x0800
/* power down */
61
#define BMCR_ISO 0x0400
/* isolate */
62
#define BMCR_STARTNEG 0x0200
/* restart autonegotiation */
63
#define BMCR_FDX 0x0100
/* Set duplex mode */
64
#define BMCR_CTEST 0x0080
/* collision test */
65
#define BMCR_SPEED1 0x0040
/* speed selection (MSB) */
66
67
#define BMCR_S10 0x0000
/* 10 Mb/s */
68
#define BMCR_S100 BMCR_SPEED0
/* 100 Mb/s */
69
#define BMCR_S1000 BMCR_SPEED1
/* 1000 Mb/s */
70
71
#define BMCR_SPEED(x) ((x) & (BMCR_SPEED0|BMCR_SPEED1))
72
73
#define MII_BMSR 0x01
/* Basic mode status register (ro) */
74
#define BMSR_100T4 0x8000
/* 100 base T4 capable */
75
#define BMSR_100TXFDX 0x4000
/* 100 base Tx full duplex capable */
76
#define BMSR_100TXHDX 0x2000
/* 100 base Tx half duplex capable */
77
#define BMSR_10TFDX 0x1000
/* 10 base T full duplex capable */
78
#define BMSR_10THDX 0x0800
/* 10 base T half duplex capable */
79
#define BMSR_100T2FDX 0x0400
/* 100 base T2 full duplex capable */
80
#define BMSR_100T2HDX 0x0200
/* 100 base T2 half duplex capable */
81
#define BMSR_EXTSTAT 0x0100
/* Extended status in register 15 */
82
#define BMSR_MFPS 0x0040
/* MII Frame Preamble Suppression */
83
#define BMSR_ACOMP 0x0020
/* Autonegotiation complete */
84
#define BMSR_RFAULT 0x0010
/* Link partner fault */
85
#define BMSR_ANEG 0x0008
/* Autonegotiation capable */
86
#define BMSR_LINK 0x0004
/* Link status */
87
#define BMSR_JABBER 0x0002
/* Jabber detected */
88
#define BMSR_EXTCAP 0x0001
/* Extended capability */
89
90
91
* Note that the EXTSTAT bit indicates that there is extended status
92
* info available in register 15, but 802.3 section 22.2.4.3 also
93
* states that that all 1000 Mb/s capable PHYs will set this bit to 1.
94
95
#if 0
96
#define BMSR_MEDIAMASK (BMSR_100T4|BMSR_100TXFDX|BMSR_100TXHDX|BMSR_10TFDX| \
97
BMSR_10THDX|BMSR_ANEG)
98
99
#else
100
/* NetBSD uses: */
101
#define BMSR_MEDIAMASK (BMSR_100T4|BMSR_100TXFDX|BMSR_100TXHDX| \
102
BMSR_10TFDX|BMSR_10THDX|BMSR_100T2FDX|BMSR_100T2HDX)
103
#endif
104
105
106
* Convert BMSR media capabilities to ANAR bits for autonegotiation.
107
* Note the shift chopps off the BMSR_ANEG bit.
108
109
#define BMSR_MEDIA_TO_ANAR(x) (((x) & BMSR_MEDIAMASK) >> 6)
110
111
#define MII_PHYIDR1 0x02
/* ID register 1 (ro) */
112
113
#define MII_PHYIDR2 0x03
/* ID register 2 (ro) */
114
#define IDR2_OUILSB 0xfc00
/* OUI LSB */
115
#define IDR2_MODEL 0x03f0
/* vendor model */
116
#define IDR2_REV 0x000f
/* vendor revision */
117
118
#define MII_OUI(id1, id2) (((id1) << 6) | ((id2) >> 10))
119
#define MII_MODEL(id2) (((id2) & IDR2_MODEL) >> 4)
120
#define MII_REV(id2) ((id2) & IDR2_REV)
121
122
#define MII_ANAR 0x04
/* Autonegotiation advertisement (rw) */
123
/* section 28.2.4.1 and 37.2.6.1 */
124
#define ANAR_NP 0x8000
/* Next page (ro) */
125
#define ANAR_ACK 0x4000
/* link partner abilities acknowledged (ro) */
126
#define ANAR_RF 0x2000
/* remote fault (ro) */
127
#define ANAR_FC 0x0400
/* local device supports PAUSE */
128
#define ANAR_T4 0x0200
/* local device supports 100bT4 */
129
#define ANAR_TX_FD 0x0100
/* local device supports 100bTx FD */
130
#define ANAR_TX 0x0080
/* local device supports 100bTx */
131
#define ANAR_10_FD 0x0040
/* local device supports 10bT FD */
132
#define ANAR_10 0x0020
/* local device supports 10bT */
133
#define ANAR_CSMA 0x0001
/* protocol selector CSMA/CD */
134
135
#define ANAR_X_FD 0x0020
/* local device supports 1000BASE-X FD */
136
#define ANAR_X_HD 0x0040
/* local device supports 1000BASE-X HD */
137
#define ANAR_X_PAUSE_NONE (0 << 7)
138
#define ANAR_X_PAUSE_SYM (1 << 7)
139
#define ANAR_X_PAUSE_ASYM (2 << 7)
140
#define ANAR_X_PAUSE_TOWARDS (3 << 7)
141
142
#define MII_ANLPAR 0x05
/* Autonegotiation lnk partner abilities (rw) */
143
144
#define ANLPAR_NP 0x8000
145
#define ANLPAR_ACK 0x4000
/* link partner accepted ACK (ro) */
146
#define ANLPAR_RF 0x2000
147
#define ANLPAR_FC 0x0400
/* link partner supports PAUSE */
148
#define ANLPAR_T4 0x0200
/* link partner supports 100bT4 */
149
#define ANLPAR_TX_FD 0x0100
/* link partner supports 100bTx FD */
150
#define ANLPAR_TX 0x0080
/* link partner supports 100bTx */
151
#define ANLPAR_10_FD 0x0040
/* link partner supports 10bT FD */
152
#define ANLPAR_10 0x0020
/* link partner supports 10bT */
153
#define ANLPAR_CSMA 0x0001
154
155
#define ANLPAR_X_FD 0x0020
156
#define ANLPAR_X_HD 0x0040
157
#define ANLPAR_X_PAUSE_MASK (3 << 7)
158
#define ANLPAR_X_PAUSE_NONE (0 << 7)
159
#define ANLPAR_X_PAUSE_SYM (1 << 7)
160
#define ANLPAR_X_PAUSE_ASYM (2 << 7)
161
#define ANLPAR_X_PAUSE_TOWARDS (3 << 7)
162
163
#define MII_ANER 0x06
/* Autonegotiation expansion (ro) */
164
165
#define ANER_MLF 0x0010
/* multiple link detection fault */
166
#define ANER_LPNP 0x0008
/* link parter next page-able */
167
#define ANER_NP 0x0004
/* next page-able */
168
#define ANER_PAGE_RX 0x0002
/* Page received */
169
#define ANER_LPAN 0x0001
/* link parter autoneg-able */
170
171
#define MII_ANNP 0x07
/* Autonegotiation next page */
172
173
174
#define MII_ANLPRNP 0x08
/* Autonegotiation link partner rx next page */
175
/* section 32.5.1 and 37.2.6.1 */
176
177
/* This is also the 1000baseT control register */
178
#define MII_100T2CR 0x09
/* 100base-T2 control register */
179
#define GTCR_TEST_MASK 0xe000
/* see 802.3ab ss. 40.6.1.1.2 */
180
#define GTCR_MAN_MS 0x1000
/* enable manual master/slave control */
181
#define GTCR_ADV_MS 0x0800
/* 1 = adv. master, 0 = adv. slave */
182
#define GTCR_PORT_TYPE 0x0400
/* 1 = DCE, 0 = DTE (NIC) */
183
#define GTCR_ADV_1000TFDX 0x0200
/* adv. 1000baseT FDX */
184
#define GTCR_ADV_1000THDX 0x0100
/* adv. 1000baseT HDX */
185
186
/* This is also the 1000baseT status register */
187
#define MII_100T2SR 0x0a
/* 100base-T2 status register */
188
#define GTSR_MAN_MS_FLT 0x8000
/* master/slave config fault */
189
#define GTSR_MS_RES 0x4000
/* result: 1 = master, 0 = slave */
190
#define GTSR_LRS 0x2000
/* local rx status, 1 = ok */
191
#define GTSR_RRS 0x1000
/* remove rx status, 1 = ok */
192
#define GTSR_LP_1000TFDX 0x0800
/* link partner 1000baseT FDX capable */
193
#define GTSR_LP_1000THDX 0x0400
/* link partner 1000baseT HDX capable */
194
#define GTSR_LP_ASM_DIR 0x0200
/* link partner asym. pause dir. capable */
195
#define GTSR_IDLE_ERR 0x00ff
/* IDLE error count */
196
197
#define MII_EXTSR 0x0f
/* Extended status register */
198
#define EXTSR_1000XFDX 0x8000
/* 1000X full-duplex capable */
199
#define EXTSR_1000XHDX 0x4000
/* 1000X half-duplex capable */
200
#define EXTSR_1000TFDX 0x2000
/* 1000T full-duplex capable */
201
#define EXTSR_1000THDX 0x1000
/* 1000T half-duplex capable */
202
203
#define EXTSR_MEDIAMASK (EXTSR_1000XFDX|EXTSR_1000XHDX| \
204
EXTSR_1000TFDX|EXTSR_1000THDX)
205
206
#endif
/* _DEV_MII_MII_H_ */
