rtems-4.11.3
score
cpu
m32r
asm.h
1
17
18
* COPYRIGHT:
19
20
* This file is based on similar code found in newlib available
21
* from ftp.cygnus.com. The file which was used had no copyright
22
* notice. This file is freely distributable as long as the source
23
* of the file is noted. This file is:
24
25
* COPYRIGHT (c) 1994-2006.
26
* On-Line Applications Research Corporation (OAR).
27
28
29
#ifndef _RTEMS_ASM_H
30
#define _RTEMS_ASM_H
31
32
33
* Indicate we are in an assembly file and get the basic CPU definitions.
34
35
36
#ifndef ASM
37
#define ASM
38
#endif
39
40
rtems/score/m32r.h
41
42
#ifndef __USER_LABEL_PREFIX__
43
51
#define __USER_LABEL_PREFIX__ _
52
#endif
53
54
#ifndef __REGISTER_PREFIX__
55
63
#define __REGISTER_PREFIX__
64
#endif
65
66
rtems/concat.h
67
69
#define SYM(x) CONCAT1 (__USER_LABEL_PREFIX__, x)
70
72
#define REG(x) CONCAT1 (__REGISTER_PREFIX__, x)
73
74
75
* define macros for all of the registers on this CPU
76
77
* EXAMPLE: #define d0 REG (d0)
78
79
80
81
* Define macros to handle section beginning and ends.
82
83
84
86
#define BEGIN_CODE_DCL .text
87
88
#define END_CODE_DCL
89
90
#define BEGIN_DATA_DCL .data
91
92
#define END_DATA_DCL
93
94
#define BEGIN_CODE .text
95
96
#define END_CODE
97
98
#define BEGIN_DATA
99
100
#define END_DATA
101
105
#define BEGIN_BSS
106
107
#define END_BSS
108
109
#define END
110
117
#define PUBLIC(sym) .globl SYM (sym)
118
125
#define EXTERN(sym) .globl SYM (sym)
126
127
#endif
m32r.h
Set up Basic CPU Dependency Settings Based on Compiler Settings.
concat.h
This include file defines ANSI concatenation macros.
