rtems-4.11.3
score
cpu
m32c
score
m32c.h
1
12
13
* COPYRIGHT (c) 1989-1999.
14
* On-Line Applications Research Corporation (OAR).
15
16
* The license and distribution terms for this file may be
17
* found in the file LICENSE in this distribution or at
18
* http://www.rtems.org/license/LICENSE.
19
20
21
#ifndef _RTEMS_SCORE_NO_CPU_H
22
#define _RTEMS_SCORE_NO_CPU_H
23
24
#ifdef __cplusplus
25
extern
"C"
26
#endif
27
28
29
* This file contains the information required to build
30
* RTEMS for a particular member of the NO CPU family.
31
* It does this by setting variables to indicate which
32
* implementation dependent features are present in a particular
33
* member of the family.
34
35
* This is a good place to list all the known CPU models
36
* that this port supports and which RTEMS CPU model they correspond
37
* to.
38
39
40
#if defined(rtems_multilib)
41
42
* Figure out all CPU Model Feature Flags based upon compiler
43
* predefines.
44
45
46
#define CPU_MODEL_NAME "rtems_multilib"
47
#define NOCPU_HAS_FPU 1
48
49
#elif defined(__m32c__)
50
51
#define CPU_MODEL_NAME "m32c"
52
#define M32C_HAS_FPU 0
53
54
#else
55
56
#error "Unsupported CPU Model"
57
58
#endif
59
60
61
* Define the name of the CPU family.
62
63
64
#define CPU_NAME "m32c"
65
66
#define m32c_get_flg( _flg ) \
67
__asm__ volatile( "stc flg, %0" : "=r" (_flg))
68
69
#define m32c_set_flg( _flg ) \
70
__asm__ volatile( "ldc %1, flg" : "=r" (_flg) : "r" (_flg) )
71
72
#ifdef __cplusplus
73
74
#endif
75
76
#endif
/* _RTEMS_SCORE_NO_CPU_H */
