rtems-4.11.3
score
cpu
avr
avr
iom32.h
1
9
10
* Copyright (c) 2002, Steinar Haugen
11
* All rights reserved.
12
13
14
* modification, are permitted provided that the following conditions are met:
15
16
* * Redistributions of source code must retain the above copyright
17
* notice, this list of conditions and the following disclaimer.
18
19
* * Redistributions in binary form must reproduce the above copyright
20
* notice, this list of conditions and the following disclaimer in
21
* the documentation and/or other materials provided with the
22
* distribution.
23
24
* * Neither the name of the copyright holders nor the names of
25
* contributors may be used to endorse or promote products derived
26
* from this software without specific prior written permission.
27
28
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
29
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
30
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
31
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
32
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
33
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
34
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
35
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
36
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
37
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
38
* POSSIBILITY OF SUCH DAMAGE.
39
40
41
#ifndef _AVR_IOM32_H_
42
#define _AVR_IOM32_H_ 1
43
51
#ifndef _AVR_IO_H_
52
# error "Include <avr/io.h> instead of this file."
53
#endif
54
55
#ifndef _AVR_IOXXX_H_
56
# define _AVR_IOXXX_H_ "iom32.h"
57
#else
58
# error "Attempt to include more than one <avr/ioXXX.h> file."
59
#endif
60
61
/* I/O registers */
62
63
/* TWI stands for "Two Wire Interface" or "TWI Was I2C(tm)" */
64
#define TWBR _SFR_IO8(0x00)
65
#define TWSR _SFR_IO8(0x01)
66
#define TWAR _SFR_IO8(0x02)
67
#define TWDR _SFR_IO8(0x03)
68
69
/* ADC */
70
#ifndef __ASSEMBLER__
71
#define ADC _SFR_IO16(0x04)
72
#endif
73
#define ADCW _SFR_IO16(0x04)
74
#define ADCL _SFR_IO8(0x04)
75
#define ADCH _SFR_IO8(0x05)
76
#define ADCSRA _SFR_IO8(0x06)
77
#define ADMUX _SFR_IO8(0x07)
78
79
/* analog comparator */
80
#define ACSR _SFR_IO8(0x08)
81
82
/* USART */
83
#define UBRRL _SFR_IO8(0x09)
84
#define UCSRB _SFR_IO8(0x0A)
85
#define UCSRA _SFR_IO8(0x0B)
86
#define UDR _SFR_IO8(0x0C)
87
88
/* SPI */
89
#define SPCR _SFR_IO8(0x0D)
90
#define SPSR _SFR_IO8(0x0E)
91
#define SPDR _SFR_IO8(0x0F)
92
93
/* Port D */
94
#define PIND _SFR_IO8(0x10)
95
#define DDRD _SFR_IO8(0x11)
96
#define PORTD _SFR_IO8(0x12)
97
98
/* Port C */
99
#define PINC _SFR_IO8(0x13)
100
#define DDRC _SFR_IO8(0x14)
101
#define PORTC _SFR_IO8(0x15)
102
103
/* Port B */
104
#define PINB _SFR_IO8(0x16)
105
#define DDRB _SFR_IO8(0x17)
106
#define PORTB _SFR_IO8(0x18)
107
108
/* Port A */
109
#define PINA _SFR_IO8(0x19)
110
#define DDRA _SFR_IO8(0x1A)
111
#define PORTA _SFR_IO8(0x1B)
112
113
/* EEPROM Control Register */
114
#define EECR _SFR_IO8(0x1C)
115
116
/* EEPROM Data Register */
117
#define EEDR _SFR_IO8(0x1D)
118
119
/* EEPROM Address Register */
120
#define EEAR _SFR_IO16(0x1E)
121
#define EEARL _SFR_IO8(0x1E)
122
#define EEARH _SFR_IO8(0x1F)
123
124
#define UBRRH _SFR_IO8(0x20)
125
#define UCSRC UBRRH
126
127
#define WDTCR _SFR_IO8(0x21)
128
129
#define ASSR _SFR_IO8(0x22)
130
131
/* Timer 2 */
132
#define OCR2 _SFR_IO8(0x23)
133
#define TCNT2 _SFR_IO8(0x24)
134
#define TCCR2 _SFR_IO8(0x25)
135
136
/* Timer 1 */
137
#define ICR1 _SFR_IO16(0x26)
138
#define ICR1L _SFR_IO8(0x26)
139
#define ICR1H _SFR_IO8(0x27)
140
#define OCR1B _SFR_IO16(0x28)
141
#define OCR1BL _SFR_IO8(0x28)
142
#define OCR1BH _SFR_IO8(0x29)
143
#define OCR1A _SFR_IO16(0x2A)
144
#define OCR1AL _SFR_IO8(0x2A)
145
#define OCR1AH _SFR_IO8(0x2B)
146
#define TCNT1 _SFR_IO16(0x2C)
147
#define TCNT1L _SFR_IO8(0x2C)
148
#define TCNT1H _SFR_IO8(0x2D)
149
#define TCCR1B _SFR_IO8(0x2E)
150
#define TCCR1A _SFR_IO8(0x2F)
151
152
#define SFIOR _SFR_IO8(0x30)
153
154
#define OSCCAL _SFR_IO8(0x31)
155
#define OCDR OSCCAL
156
157
/* Timer 0 */
158
#define TCNT0 _SFR_IO8(0x32)
159
#define TCCR0 _SFR_IO8(0x33)
160
161
#define MCUSR _SFR_IO8(0x34)
162
#define MCUCSR MCUSR
163
#define MCUCR _SFR_IO8(0x35)
164
165
#define TWCR _SFR_IO8(0x36)
166
167
#define SPMCR _SFR_IO8(0x37)
168
169
#define TIFR _SFR_IO8(0x38)
170
#define TIMSK _SFR_IO8(0x39)
171
172
#define GIFR _SFR_IO8(0x3A)
173
#define GIMSK _SFR_IO8(0x3B)
174
#define GICR GIMSK
175
176
#define OCR0 _SFR_IO8(0x3C)
177
178
/* 0x3D..0x3E SP */
179
180
/* 0x3F SREG */
181
182
/* Interrupt vectors */
183
184
/* External Interrupt Request 0 */
185
#define INT0_vect _VECTOR(1)
186
#define SIG_INTERRUPT0 _VECTOR(1)
187
188
/* External Interrupt Request 1 */
189
#define INT1_vect _VECTOR(2)
190
#define SIG_INTERRUPT1 _VECTOR(2)
191
192
/* External Interrupt Request 2 */
193
#define INT2_vect _VECTOR(3)
194
#define SIG_INTERRUPT2 _VECTOR(3)
195
196
/* Timer/Counter2 Compare Match */
197
#define TIMER2_COMP_vect _VECTOR(4)
198
#define SIG_OUTPUT_COMPARE2 _VECTOR(4)
199
200
/* Timer/Counter2 Overflow */
201
#define TIMER2_OVF_vect _VECTOR(5)
202
#define SIG_OVERFLOW2 _VECTOR(5)
203
204
/* Timer/Counter1 Capture Event */
205
#define TIMER1_CAPT_vect _VECTOR(6)
206
#define SIG_INPUT_CAPTURE1 _VECTOR(6)
207
208
/* Timer/Counter1 Compare Match A */
209
#define TIMER1_COMPA_vect _VECTOR(7)
210
#define SIG_OUTPUT_COMPARE1A _VECTOR(7)
211
212
/* Timer/Counter1 Compare Match B */
213
#define TIMER1_COMPB_vect _VECTOR(8)
214
#define SIG_OUTPUT_COMPARE1B _VECTOR(8)
215
216
/* Timer/Counter1 Overflow */
217
#define TIMER1_OVF_vect _VECTOR(9)
218
#define SIG_OVERFLOW1 _VECTOR(9)
219
220
/* Timer/Counter0 Compare Match */
221
#define TIMER0_COMP_vect _VECTOR(10)
222
#define SIG_OUTPUT_COMPARE0 _VECTOR(10)
223
224
/* Timer/Counter0 Overflow */
225
#define TIMER0_OVF_vect _VECTOR(11)
226
#define SIG_OVERFLOW0 _VECTOR(11)
227
228
/* Serial Transfer Complete */
229
#define SPI_STC_vect _VECTOR(12)
230
#define SIG_SPI _VECTOR(12)
231
232
/* USART, Rx Complete */
233
#define USART_RXC_vect _VECTOR(13)
234
#define SIG_USART_RECV _VECTOR(13)
235
#define SIG_UART_RECV _VECTOR(13)
236
237
/* USART Data Register Empty */
238
#define USART_UDRE_vect _VECTOR(14)
239
#define SIG_USART_DATA _VECTOR(14)
240
#define SIG_UART_DATA _VECTOR(14)
241
242
/* USART, Tx Complete */
243
#define USART_TXC_vect _VECTOR(15)
244
#define SIG_USART_TRANS _VECTOR(15)
245
#define SIG_UART_TRANS _VECTOR(15)
246
247
/* ADC Conversion Complete */
248
#define ADC_vect _VECTOR(16)
249
#define SIG_ADC _VECTOR(16)
250
251
/* EEPROM Ready */
252
#define EE_RDY_vect _VECTOR(17)
253
#define SIG_EEPROM_READY _VECTOR(17)
254
255
/* Analog Comparator */
256
#define ANA_COMP_vect _VECTOR(18)
257
#define SIG_COMPARATOR _VECTOR(18)
258
259
/* 2-wire Serial Interface */
260
#define TWI_vect _VECTOR(19)
261
#define SIG_2WIRE_SERIAL _VECTOR(19)
262
263
/* Store Program Memory Ready */
264
#define SPM_RDY_vect _VECTOR(20)
265
#define SIG_SPM_READY _VECTOR(20)
266
267
#define _VECTORS_SIZE 84
268
269
/* Bit numbers */
270
271
/* GICR */
272
#define INT1 7
273
#define INT0 6
274
#define INT2 5
275
#define IVSEL 1
276
#define IVCE 0
277
278
/* GIFR */
279
#define INTF1 7
280
#define INTF0 6
281
#define INTF2 5
282
283
/* TIMSK */
284
#define OCIE2 7
285
#define TOIE2 6
286
#define TICIE1 5
287
#define OCIE1A 4
288
#define OCIE1B 3
289
#define TOIE1 2
290
#define OCIE0 1
291
#define TOIE0 0
292
293
/* TIFR */
294
#define OCF2 7
295
#define TOV2 6
296
#define ICF1 5
297
#define OCF1A 4
298
#define OCF1B 3
299
#define TOV1 2
300
#define OCF0 1
301
#define TOV0 0
302
303
/* SPMCR */
304
#define SPMIE 7
305
#define RWWSB 6
306
/* bit 5 reserved */
307
#define RWWSRE 4
308
#define BLBSET 3
309
#define PGWRT 2
310
#define PGERS 1
311
#define SPMEN 0
312
313
/* TWCR */
314
#define TWINT 7
315
#define TWEA 6
316
#define TWSTA 5
317
#define TWSTO 4
318
#define TWWC 3
319
#define TWEN 2
320
/* bit 1 reserved */
321
#define TWIE 0
322
323
/* TWAR */
324
#define TWA6 7
325
#define TWA5 6
326
#define TWA4 5
327
#define TWA3 4
328
#define TWA2 3
329
#define TWA1 2
330
#define TWA0 1
331
#define TWGCE 0
332
333
/* TWSR */
334
#define TWS7 7
335
#define TWS6 6
336
#define TWS5 5
337
#define TWS4 4
338
#define TWS3 3
339
/* bit 2 reserved */
340
#define TWPS1 1
341
#define TWPS0 0
342
343
/* MCUCR */
344
#define SE 7
345
#define SM2 6
346
#define SM1 5
347
#define SM0 4
348
#define ISC11 3
349
#define ISC10 2
350
#define ISC01 1
351
#define ISC00 0
352
353
/* MCUCSR */
354
#define JTD 7
355
#define ISC2 6
356
357
#define JTRF 4
358
#define WDRF 3
359
#define BORF 2
360
#define EXTRF 1
361
#define PORF 0
362
363
/* SFIOR */
364
#define ADTS2 7
365
#define ADTS1 6
366
#define ADTS0 5
367
/* bit 4 reserved */
368
#define ACME 3
369
#define PUD 2
370
#define PSR2 1
371
#define PSR10 0
372
373
/* TCCR0 */
374
#define FOC0 7
375
#define WGM00 6
376
#define COM01 5
377
#define COM00 4
378
#define WGM01 3
379
#define CS02 2
380
#define CS01 1
381
#define CS00 0
382
383
/* TCCR2 */
384
#define FOC2 7
385
#define WGM20 6
386
#define COM21 5
387
#define COM20 4
388
#define WGM21 3
389
#define CS22 2
390
#define CS21 1
391
#define CS20 0
392
393
/* ASSR */
394
/* bits 7-4 reserved */
395
#define AS2 3
396
#define TCN2UB 2
397
#define OCR2UB 1
398
#define TCR2UB 0
399
400
/* TCCR1A */
401
#define COM1A1 7
402
#define COM1A0 6
403
#define COM1B1 5
404
#define COM1B0 4
405
#define FOC1A 3
406
#define FOC1B 2
407
#define WGM11 1
408
#define WGM10 0
409
410
/* TCCR1B */
411
#define ICNC1 7
412
#define ICES1 6
413
414
#define WGM13 4
415
#define WGM12 3
416
#define CS12 2
417
#define CS11 1
418
#define CS10 0
419
420
/* WDTCR */
421
/* bits 7-5 reserved */
422
#define WDTOE 4
423
#define WDE 3
424
#define WDP2 2
425
#define WDP1 1
426
#define WDP0 0
427
428
/* PA7-PA0 = ADC7-ADC0 */
429
/* PORTA */
430
#define PA7 7
431
#define PA6 6
432
#define PA5 5
433
#define PA4 4
434
#define PA3 3
435
#define PA2 2
436
#define PA1 1
437
#define PA0 0
438
439
/* DDRA */
440
#define DDA7 7
441
#define DDA6 6
442
#define DDA5 5
443
#define DDA4 4
444
#define DDA3 3
445
#define DDA2 2
446
#define DDA1 1
447
#define DDA0 0
448
449
/* PINA */
450
#define PINA7 7
451
#define PINA6 6
452
#define PINA5 5
453
#define PINA4 4
454
#define PINA3 3
455
#define PINA2 2
456
#define PINA1 1
457
#define PINA0 0
458
459
460
PB7 = SCK
461
PB6 = MISO
462
PB5 = MOSI
463
PB4 = SS#
464
PB3 = OC0/AIN1
465
PB2 = INT2/AIN0
466
PB1 = T1
467
PB0 = XCK/T0
468
469
470
/* PORTB */
471
#define PB7 7
472
#define PB6 6
473
#define PB5 5
474
#define PB4 4
475
#define PB3 3
476
#define PB2 2
477
#define PB1 1
478
#define PB0 0
479
480
/* DDRB */
481
#define DDB7 7
482
#define DDB6 6
483
#define DDB5 5
484
#define DDB4 4
485
#define DDB3 3
486
#define DDB2 2
487
#define DDB1 1
488
#define DDB0 0
489
490
/* PINB */
491
#define PINB7 7
492
#define PINB6 6
493
#define PINB5 5
494
#define PINB4 4
495
#define PINB3 3
496
#define PINB2 2
497
#define PINB1 1
498
#define PINB0 0
499
500
501
PC7 = TOSC2
502
PC6 = TOSC1
503
PC1 = SDA
504
PC0 = SCL
505
506
/* PORTC */
507
#define PC7 7
508
#define PC6 6
509
#define PC5 5
510
#define PC4 4
511
#define PC3 3
512
#define PC2 2
513
#define PC1 1
514
#define PC0 0
515
516
/* DDRC */
517
#define DDC7 7
518
#define DDC6 6
519
#define DDC5 5
520
#define DDC4 4
521
#define DDC3 3
522
#define DDC2 2
523
#define DDC1 1
524
#define DDC0 0
525
526
/* PINC */
527
#define PINC7 7
528
#define PINC6 6
529
#define PINC5 5
530
#define PINC4 4
531
#define PINC3 3
532
#define PINC2 2
533
#define PINC1 1
534
#define PINC0 0
535
536
537
PD7 = OC2
538
PD6 = ICP
539
PD5 = OC1A
540
PD4 = OC1B
541
PD3 = INT1
542
PD2 = INT0
543
PD1 = TXD
544
PD0 = RXD
545
546
547
/* PORTD */
548
#define PD7 7
549
#define PD6 6
550
#define PD5 5
551
#define PD4 4
552
#define PD3 3
553
#define PD2 2
554
#define PD1 1
555
#define PD0 0
556
557
/* DDRD */
558
#define DDD7 7
559
#define DDD6 6
560
#define DDD5 5
561
#define DDD4 4
562
#define DDD3 3
563
#define DDD2 2
564
#define DDD1 1
565
#define DDD0 0
566
567
/* PIND */
568
#define PIND7 7
569
#define PIND6 6
570
#define PIND5 5
571
#define PIND4 4
572
#define PIND3 3
573
#define PIND2 2
574
#define PIND1 1
575
#define PIND0 0
576
577
/* SPSR */
578
#define SPIF 7
579
#define WCOL 6
580
/* bits 5-1 reserved */
581
#define SPI2X 0
582
583
/* SPCR */
584
#define SPIE 7
585
#define SPE 6
586
#define DORD 5
587
#define MSTR 4
588
#define CPOL 3
589
#define CPHA 2
590
#define SPR1 1
591
#define SPR0 0
592
593
/* UCSRA */
594
#define RXC 7
595
#define TXC 6
596
#define UDRE 5
597
#define FE 4
598
#define DOR 3
599
#define PE 2
600
#define U2X 1
601
#define MPCM 0
602
603
/* UCSRB */
604
#define RXCIE 7
605
#define TXCIE 6
606
#define UDRIE 5
607
#define RXEN 4
608
#define TXEN 3
609
#define UCSZ2 2
610
#define RXB8 1
611
#define TXB8 0
612
613
/* UCSRC */
614
#define URSEL 7
615
#define UMSEL 6
616
#define UPM1 5
617
#define UPM0 4
618
#define USBS 3
619
#define UCSZ1 2
620
#define UCSZ0 1
621
#define UCPOL 0
622
623
/* ACSR */
624
#define ACD 7
625
#define ACBG 6
626
#define ACO 5
627
#define ACI 4
628
#define ACIE 3
629
#define ACIC 2
630
#define ACIS1 1
631
#define ACIS0 0
632
633
/* ADCSRA */
634
#define ADEN 7
635
#define ADSC 6
636
#define ADATE 5
637
#define ADIF 4
638
#define ADIE 3
639
#define ADPS2 2
640
#define ADPS1 1
641
#define ADPS0 0
642
643
/* ADMUX */
644
#define REFS1 7
645
#define REFS0 6
646
#define ADLAR 5
647
#define MUX4 4
648
#define MUX3 3
649
#define MUX2 2
650
#define MUX1 1
651
#define MUX0 0
652
653
654
#define EERIE 3
655
#define EEMWE 2
656
#define EEWE 1
657
#define EERE 0
658
659
/* Constants */
660
#define SPM_PAGESIZE 128
661
#define RAMEND 0x85F
662
#define XRAMEND RAMEND
663
#define E2END 0x3FF
664
#define E2PAGESIZE 4
665
#define FLASHEND 0x7FFF
666
667
668
/* Fuses */
669
670
#define FUSE_MEMORY_SIZE 2
671
672
/* Low Fuse Byte */
673
#define FUSE_CKSEL0 (unsigned char)~_BV(0)
674
#define FUSE_CKSEL1 (unsigned char)~_BV(1)
675
#define FUSE_CKSEL2 (unsigned char)~_BV(2)
676
#define FUSE_CKSEL3 (unsigned char)~_BV(3)
677
#define FUSE_SUT0 (unsigned char)~_BV(4)
678
#define FUSE_SUT1 (unsigned char)~_BV(5)
679
#define FUSE_BODEN (unsigned char)~_BV(6)
680
#define FUSE_BODLEVEL (unsigned char)~_BV(7)
681
#define LFUSE_DEFAULT (FUSE_CKSEL1 & FUSE_CKSEL2 & FUSE_CKSEL3 & FUSE_SUT0)
682
683
/* High Fuse Byte */
684
#define FUSE_BOOTRST (unsigned char)~_BV(0)
685
#define FUSE_BOOTSZ0 (unsigned char)~_BV(1)
686
#define FUSE_BOOTSZ1 (unsigned char)~_BV(2)
687
#define FUSE_EESAVE (unsigned char)~_BV(3)
688
#define FUSE_CKOPT (unsigned char)~_BV(4)
689
#define FUSE_SPIEN (unsigned char)~_BV(5)
690
#define FUSE_JTAGEN (unsigned char)~_BV(6)
691
#define FUSE_OCDEN (unsigned char)~_BV(7)
692
#define HFUSE_DEFAULT (FUSE_BOOTSZ0 & FUSE_BOOTSZ1 & FUSE_SPIEN & FUSE_JTAGEN)
693
694
695
/* Lock Bits */
696
#define __LOCK_BITS_EXIST
697
#define __BOOT_LOCK_BITS_0_EXIST
698
#define __BOOT_LOCK_BITS_1_EXIST
699
700
701
/* Signature */
702
#define SIGNATURE_0 0x1E
703
#define SIGNATURE_1 0x95
704
#define SIGNATURE_2 0x02
705
707
#endif
/* _AVR_IOM32_H_ */
