rtems-4.11.3
score
cpu
avr
avr
iom323.h
1
9
10
* Copyright (c) 2002 Marek Michalkiewicz
11
* All rights reserved.
12
13
14
* modification, are permitted provided that the following conditions are met:
15
16
* * Redistributions of source code must retain the above copyright
17
* notice, this list of conditions and the following disclaimer.
18
19
* * Redistributions in binary form must reproduce the above copyright
20
* notice, this list of conditions and the following disclaimer in
21
* the documentation and/or other materials provided with the
22
* distribution.
23
24
* * Neither the name of the copyright holders nor the names of
25
* contributors may be used to endorse or promote products derived
26
* from this software without specific prior written permission.
27
28
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
29
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
30
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
31
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
32
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
33
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
34
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
35
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
36
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
37
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
38
* POSSIBILITY OF SUCH DAMAGE.
39
40
41
#ifndef _AVR_IOM323_H_
42
#define _AVR_IOM323_H_ 1
43
51
#ifndef _AVR_IO_H_
52
# error "Include <avr/io.h> instead of this file."
53
#endif
54
55
#ifndef _AVR_IOXXX_H_
56
# define _AVR_IOXXX_H_ "iom323.h"
57
#else
58
# error "Attempt to include more than one <avr/ioXXX.h> file."
59
#endif
60
61
/* I/O registers */
62
63
/* TWI stands for "Two Wire Interface" or "TWI Was I2C(tm)" */
64
#define TWBR _SFR_IO8(0x00)
65
#define TWSR _SFR_IO8(0x01)
66
#define TWAR _SFR_IO8(0x02)
67
#define TWDR _SFR_IO8(0x03)
68
69
/* ADC */
70
#ifndef __ASSEMBLER__
71
#define ADC _SFR_IO16(0x04)
72
#endif
73
#define ADCW _SFR_IO16(0x04)
74
#define ADCL _SFR_IO8(0x04)
75
#define ADCH _SFR_IO8(0x05)
76
#define ADCSR _SFR_IO8(0x06)
77
#define ADMUX _SFR_IO8(0x07)
78
79
/* analog comparator */
80
#define ACSR _SFR_IO8(0x08)
81
82
/* UART */
83
#define UBRR _SFR_IO8(0x09)
84
#define UBRRL UBRR
85
#define UCSRB _SFR_IO8(0x0A)
86
#define UCSRA _SFR_IO8(0x0B)
87
#define UDR _SFR_IO8(0x0C)
88
89
/* SPI */
90
#define SPCR _SFR_IO8(0x0D)
91
#define SPSR _SFR_IO8(0x0E)
92
#define SPDR _SFR_IO8(0x0F)
93
94
/* Port D */
95
#define PIND _SFR_IO8(0x10)
96
#define DDRD _SFR_IO8(0x11)
97
#define PORTD _SFR_IO8(0x12)
98
99
/* Port C */
100
#define PINC _SFR_IO8(0x13)
101
#define DDRC _SFR_IO8(0x14)
102
#define PORTC _SFR_IO8(0x15)
103
104
/* Port B */
105
#define PINB _SFR_IO8(0x16)
106
#define DDRB _SFR_IO8(0x17)
107
#define PORTB _SFR_IO8(0x18)
108
109
/* Port A */
110
#define PINA _SFR_IO8(0x19)
111
#define DDRA _SFR_IO8(0x1A)
112
#define PORTA _SFR_IO8(0x1B)
113
114
/* EEPROM Control Register */
115
#define EECR _SFR_IO8(0x1C)
116
117
/* EEPROM Data Register */
118
#define EEDR _SFR_IO8(0x1D)
119
120
/* EEPROM Address Register */
121
#define EEAR _SFR_IO16(0x1E)
122
#define EEARL _SFR_IO8(0x1E)
123
#define EEARH _SFR_IO8(0x1F)
124
125
#define UBRRH _SFR_IO8(0x20)
126
#define UCSRC UBRRH
127
128
#define WDTCR _SFR_IO8(0x21)
129
130
#define ASSR _SFR_IO8(0x22)
131
132
/* Timer 2 */
133
#define OCR2 _SFR_IO8(0x23)
134
#define TCNT2 _SFR_IO8(0x24)
135
#define TCCR2 _SFR_IO8(0x25)
136
137
/* Timer 1 */
138
#define ICR1 _SFR_IO16(0x26)
139
#define ICR1L _SFR_IO8(0x26)
140
#define ICR1H _SFR_IO8(0x27)
141
#define OCR1B _SFR_IO16(0x28)
142
#define OCR1BL _SFR_IO8(0x28)
143
#define OCR1BH _SFR_IO8(0x29)
144
#define OCR1A _SFR_IO16(0x2A)
145
#define OCR1AL _SFR_IO8(0x2A)
146
#define OCR1AH _SFR_IO8(0x2B)
147
#define TCNT1 _SFR_IO16(0x2C)
148
#define TCNT1L _SFR_IO8(0x2C)
149
#define TCNT1H _SFR_IO8(0x2D)
150
#define TCCR1B _SFR_IO8(0x2E)
151
#define TCCR1A _SFR_IO8(0x2F)
152
153
#define SFIOR _SFR_IO8(0x30)
154
155
#define OSCCAL _SFR_IO8(0x31)
156
157
/* Timer 0 */
158
#define TCNT0 _SFR_IO8(0x32)
159
#define TCCR0 _SFR_IO8(0x33)
160
161
#define MCUSR _SFR_IO8(0x34)
162
#define MCUCSR MCUSR
163
#define MCUCR _SFR_IO8(0x35)
164
165
#define TWCR _SFR_IO8(0x36)
166
167
#define SPMCR _SFR_IO8(0x37)
168
169
#define TIFR _SFR_IO8(0x38)
170
#define TIMSK _SFR_IO8(0x39)
171
172
#define GIFR _SFR_IO8(0x3A)
173
#define GIMSK _SFR_IO8(0x3B)
174
#define GICR GIMSK
175
176
#define OCR0 _SFR_IO8(0x3C)
177
178
/* 0x3D..0x3E SP */
179
180
/* 0x3F SREG */
181
182
/* Interrupt vectors */
183
184
/* External Interrupt Request 0 */
185
#define INT0_vect _VECTOR(1)
186
#define SIG_INTERRUPT0 _VECTOR(1)
187
188
/* External Interrupt Request 1 */
189
#define INT1_vect _VECTOR(2)
190
#define SIG_INTERRUPT1 _VECTOR(2)
191
192
/* External Interrupt Request 2 */
193
#define INT2_vect _VECTOR(3)
194
#define SIG_INTERRUPT2 _VECTOR(3)
195
196
/* Timer/Counter2 Compare Match */
197
#define TIMER2_COMP_vect _VECTOR(4)
198
#define SIG_OUTPUT_COMPARE2 _VECTOR(4)
199
200
/* Timer/Counter2 Overflow */
201
#define TIMER2_OVF_vect _VECTOR(5)
202
#define SIG_OVERFLOW2 _VECTOR(5)
203
204
/* Timer/Counter1 Capture Event */
205
#define TIMER1_CAPT_vect _VECTOR(6)
206
#define SIG_INPUT_CAPTURE1 _VECTOR(6)
207
208
/* Timer/Counter1 Compare Match A */
209
#define TIMER1_COMPA_vect _VECTOR(7)
210
#define SIG_OUTPUT_COMPARE1A _VECTOR(7)
211
212
/* Timer/Counter1 Compare Match B */
213
#define TIMER1_COMPB_vect _VECTOR(8)
214
#define SIG_OUTPUT_COMPARE1B _VECTOR(8)
215
216
/* Timer/Counter1 Overflow */
217
#define TIMER1_OVF_vect _VECTOR(9)
218
#define SIG_OVERFLOW1 _VECTOR(9)
219
220
/* Timer/Counter0 Compare Match */
221
#define TIMER0_COMP_vect _VECTOR(10)
222
#define SIG_OUTPUT_COMPARE0 _VECTOR(10)
223
224
/* Timer/Counter0 Overflow */
225
#define TIMER0_OVF_vect _VECTOR(11)
226
#define SIG_OVERFLOW0 _VECTOR(11)
227
228
/* Serial Transfer Complete */
229
#define SPI_STC_vect _VECTOR(12)
230
#define SIG_SPI _VECTOR(12)
231
232
/* USART, Rx Complete */
233
#define USART_RXC_vect _VECTOR(13)
234
#define SIG_UART_RECV _VECTOR(13)
235
236
/* USART Data Register Empty */
237
#define USART_UDRE_vect _VECTOR(14)
238
#define SIG_UART_DATA _VECTOR(14)
239
240
/* USART, Tx Complete */
241
#define USART_TXC_vect _VECTOR(15)
242
#define SIG_UART_TRANS _VECTOR(15)
243
244
/* ADC Conversion Complete */
245
#define ADC_vect _VECTOR(16)
246
#define SIG_ADC _VECTOR(16)
247
248
/* EEPROM Ready */
249
#define EE_RDY_vect _VECTOR(17)
250
#define SIG_EEPROM_READY _VECTOR(17)
251
252
/* Analog Comparator */
253
#define ANA_COMP_vect _VECTOR(18)
254
#define SIG_COMPARATOR _VECTOR(18)
255
256
/* 2-wire Serial Interface */
257
#define TWI_vect _VECTOR(19)
258
#define SIG_2WIRE_SERIAL _VECTOR(19)
259
260
/* Store Program Memory Ready */
261
#define SPM_RDY_vect _VECTOR(20)
262
263
#define _VECTORS_SIZE 80
264
265
266
/* Bit numbers */
267
268
/* GIMSK */
269
#define INT1 7
270
#define INT0 6
271
#define INT2 5
272
#define IVSEL 1
273
#define IVCE 0
274
275
/* GIFR */
276
#define INTF1 7
277
#define INTF0 6
278
#define INTF2 5
279
280
/* TIMSK */
281
#define OCIE2 7
282
#define TOIE2 6
283
#define TICIE1 5
284
#define OCIE1A 4
285
#define OCIE1B 3
286
#define TOIE1 2
287
#define OCIE0 1
288
#define TOIE0 0
289
290
/* TIFR */
291
#define OCF2 7
292
#define TOV2 6
293
#define ICF1 5
294
#define OCF1A 4
295
#define OCF1B 3
296
#define TOV1 2
297
#define OCF0 1
298
#define TOV0 0
299
300
/* SPMCR */
301
#define SPMIE 7
302
#define ASB 6
303
/* bit 5 reserved */
304
#define ASRE 4
305
#define BLBSET 3
306
#define PGWRT 2
307
#define PGERS 1
308
#define SPMEN 0
309
310
/* TWCR */
311
#define TWINT 7
312
#define TWEA 6
313
#define TWSTA 5
314
#define TWSTO 4
315
#define TWWC 3
316
#define TWEN 2
317
#define TWI_TST 1
318
#define TWIE 0
319
320
/* TWAR */
321
#define TWGCE 0
322
323
/* TWSR */
324
#define TWS7 7
325
#define TWS6 6
326
#define TWS5 5
327
#define TWS4 4
328
#define TWS3 3
329
/* bits 2-0 reserved */
330
331
/* MCUCR */
332
/* bit 7 reserved (SM2?) */
333
#define SE 7
334
#define SM2 6
335
#define SM1 5
336
#define SM0 4
337
#define ISC11 3
338
#define ISC10 2
339
#define ISC01 1
340
#define ISC00 0
341
342
/* MCUCSR */
343
#define JTD 7
344
#define ISC2 6
345
#define EIH 5
346
#define JTRF 4
347
#define WDRF 3
348
#define BORF 2
349
#define EXTRF 1
350
#define PORF 0
351
352
/* SFIOR */
353
#define RPDD 7
354
#define RPDC 6
355
#define RPDB 5
356
#define RPDA 4
357
#define ACME 3
358
#define PUD 2
359
#define PSR2 1
360
#define PSR10 0
361
362
/* TCCR0 */
363
#define FOC0 7
364
#define PWM0 6
365
#define COM01 5
366
#define COM00 4
367
#define CTC0 3
368
#define CS02 2
369
#define CS01 1
370
#define CS00 0
371
372
/* TCCR2 */
373
#define FOC2 7
374
#define PWM2 6
375
#define COM21 5
376
#define COM20 4
377
#define CTC2 3
378
#define CS22 2
379
#define CS21 1
380
#define CS20 0
381
382
/* ASSR */
383
/* bits 7-4 reserved */
384
#define AS2 3
385
#define TCN2UB 2
386
#define OCR2UB 1
387
#define TCR2UB 0
388
389
/* TCCR1A */
390
#define COM1A1 7
391
#define COM1A0 6
392
#define COM1B1 5
393
#define COM1B0 4
394
#define FOC1A 3
395
#define FOC1B 2
396
#define PWM11 1
397
#define PWM10 0
398
399
/* TCCR1B */
400
#define ICNC1 7
401
#define ICES1 6
402
403
#define CTC11 4
404
#define CTC10 3
405
#define CS12 2
406
#define CS11 1
407
#define CS10 0
408
409
/* WDTCR */
410
/* bits 7-5 reserved */
411
#define WDTOE 4
412
#define WDE 3
413
#define WDP2 2
414
#define WDP1 1
415
#define WDP0 0
416
417
/* PA7-PA0 = ADC7-ADC0 */
418
/* PORTA */
419
#define PA7 7
420
#define PA6 6
421
#define PA5 5
422
#define PA4 4
423
#define PA3 3
424
#define PA2 2
425
#define PA1 1
426
#define PA0 0
427
428
/* DDRA */
429
#define DDA7 7
430
#define DDA6 6
431
#define DDA5 5
432
#define DDA4 4
433
#define DDA3 3
434
#define DDA2 2
435
#define DDA1 1
436
#define DDA0 0
437
438
/* PINA */
439
#define PINA7 7
440
#define PINA6 6
441
#define PINA5 5
442
#define PINA4 4
443
#define PINA3 3
444
#define PINA2 2
445
#define PINA1 1
446
#define PINA0 0
447
448
449
PB7 = SCK
450
PB6 = MISO
451
PB5 = MOSI
452
PB4 = SS#
453
PB3 = AIN1
454
PB2 = AIN0
455
PB1 = T1
456
PB0 = T0
457
458
459
/* PORTB */
460
#define PB7 7
461
#define PB6 6
462
#define PB5 5
463
#define PB4 4
464
#define PB3 3
465
#define PB2 2
466
#define PB1 1
467
#define PB0 0
468
469
/* DDRB */
470
#define DDB7 7
471
#define DDB6 6
472
#define DDB5 5
473
#define DDB4 4
474
#define DDB3 3
475
#define DDB2 2
476
#define DDB1 1
477
#define DDB0 0
478
479
/* PINB */
480
#define PINB7 7
481
#define PINB6 6
482
#define PINB5 5
483
#define PINB4 4
484
#define PINB3 3
485
#define PINB2 2
486
#define PINB1 1
487
#define PINB0 0
488
489
490
PC7 = TOSC2
491
PC6 = TOSC1
492
PC1 = SDA
493
PC0 = SCL
494
495
/* PORTC */
496
#define PC7 7
497
#define PC6 6
498
#define PC5 5
499
#define PC4 4
500
#define PC3 3
501
#define PC2 2
502
#define PC1 1
503
#define PC0 0
504
505
/* DDRC */
506
#define DDC7 7
507
#define DDC6 6
508
#define DDC5 5
509
#define DDC4 4
510
#define DDC3 3
511
#define DDC2 2
512
#define DDC1 1
513
#define DDC0 0
514
515
/* PINC */
516
#define PINC7 7
517
#define PINC6 6
518
#define PINC5 5
519
#define PINC4 4
520
#define PINC3 3
521
#define PINC2 2
522
#define PINC1 1
523
#define PINC0 0
524
525
526
PD7 = OC2
527
PD6 = ICP
528
PD5 = OC1A
529
PD4 = OC1B
530
PD3 = INT1
531
PD2 = INT0
532
PD1 = TXD
533
PD0 = RXD
534
535
536
/* PORTD */
537
#define PD7 7
538
#define PD6 6
539
#define PD5 5
540
#define PD4 4
541
#define PD3 3
542
#define PD2 2
543
#define PD1 1
544
#define PD0 0
545
546
/* DDRD */
547
#define DDD7 7
548
#define DDD6 6
549
#define DDD5 5
550
#define DDD4 4
551
#define DDD3 3
552
#define DDD2 2
553
#define DDD1 1
554
#define DDD0 0
555
556
/* PIND */
557
#define PIND7 7
558
#define PIND6 6
559
#define PIND5 5
560
#define PIND4 4
561
#define PIND3 3
562
#define PIND2 2
563
#define PIND1 1
564
#define PIND0 0
565
566
567
PE2 = ALE
568
PE1 = OC1B
569
PE0 = ICP / INT2
570
571
572
/* SPSR */
573
#define SPIF 7
574
#define WCOL 6
575
#define SPI2X 0
576
577
/* SPCR */
578
#define SPIE 7
579
#define SPE 6
580
#define DORD 5
581
#define MSTR 4
582
#define CPOL 3
583
#define CPHA 2
584
#define SPR1 1
585
#define SPR0 0
586
587
/* UCSRA */
588
#define RXC 7
589
#define TXC 6
590
#define UDRE 5
591
#define FE 4
592
#define DOR 3
593
#define PE 2
594
#define U2X 1
595
#define MPCM 0
596
597
/* UCSRB */
598
#define RXCIE 7
599
#define TXCIE 6
600
#define UDRIE 5
601
#define RXEN 4
602
#define TXEN 3
603
#define UCSZ2 2
604
#define CHR9 2
605
#define RXB8 1
606
#define TXB8 0
607
608
/* UCSRC */
609
#define URSEL 7
610
#define UMSEL 6
611
#define UPM1 5
612
#define UPM0 4
613
#define USBS 3
614
#define UCSZ1 2
615
#define UCSZ0 1
616
#define UCPOL 0
617
618
/* ACSR */
619
#define ACD 7
620
#define AINBG 6
621
#define ACO 5
622
#define ACI 4
623
#define ACIE 3
624
#define ACIC 2
625
#define ACIS1 1
626
#define ACIS0 0
627
628
/* ADCSR */
629
#define ADEN 7
630
#define ADSC 6
631
#define ADFR 5
632
#define ADIF 4
633
#define ADIE 3
634
#define ADPS2 2
635
#define ADPS1 1
636
#define ADPS0 0
637
638
/* ADMUX */
639
#define REFS1 7
640
#define REFS0 6
641
#define ADLAR 5
642
#define MUX4 4
643
#define MUX3 3
644
#define MUX2 2
645
#define MUX1 1
646
#define MUX0 0
647
648
649
#define EERIE 3
650
#define EEMWE 2
651
#define EEWE 1
652
#define EERE 0
653
654
/* Constants */
655
#define SPM_PAGESIZE 128
656
#define RAMEND 0x85F
657
#define XRAMEND RAMEND
658
#define E2END 0x3FF
659
#define E2PAGESIZE 0
660
#define FLASHEND 0x7FFF
661
662
663
/* Fuses */
664
665
#define FUSE_MEMORY_SIZE 2
666
667
/* Low Fuse Byte */
668
#define FUSE_CKSEL0 (unsigned char)~_BV(0)
669
#define FUSE_CKSEL1 (unsigned char)~_BV(1)
670
#define FUSE_CKSEL2 (unsigned char)~_BV(2)
671
#define FUSE_CKSEL3 (unsigned char)~_BV(3)
672
#define FUSE_BODEN (unsigned char)~_BV(6)
673
#define FUSE_BODLEVEL (unsigned char)~_BV(7)
674
#define LFUSE_DEFAULT (FUSE_CKSEL0 & FUSE_CKSEL2 & FUSE_CKSEL3)
675
676
/* High Fuse Byte */
677
#define FUSE_BOOTRST (unsigned char)~_BV(0)
678
#define FUSE_BOOTSZ0 (unsigned char)~_BV(1)
679
#define FUSE_BOOTSZ1 (unsigned char)~_BV(2)
680
#define FUSE_EESAVE (unsigned char)~_BV(3)
681
#define FUSE_SPIEN (unsigned char)~_BV(5)
682
#define FUSE_JTAGEN (unsigned char)~_BV(6)
683
#define FUSE_OCDEN (unsigned char)~_BV(7)
684
#define HFUSE_DEFAULT (FUSE_SPIEN & FUSE_JTAGEN)
685
686
687
/* Lock Bits */
688
#define __LOCK_BITS_EXIST
689
#define __BOOT_LOCK_BITS_0_EXIST
690
#define __BOOT_LOCK_BITS_1_EXIST
691
692
693
/* Signature */
694
#define SIGNATURE_0 0x1E
695
#define SIGNATURE_1 0x95
696
#define SIGNATURE_2 0x01
697
699
#endif
/* _AVR_IOM323_H_ */
