rtems-4.11.3
score
cpu
avr
avr
io8535.h
1
9
10
* Copyright (c) 2002, Marek Michalkiewicz
11
* All rights reserved.
12
13
14
* modification, are permitted provided that the following conditions are met:
15
16
* * Redistributions of source code must retain the above copyright
17
* notice, this list of conditions and the following disclaimer.
18
19
* * Redistributions in binary form must reproduce the above copyright
20
* notice, this list of conditions and the following disclaimer in
21
* the documentation and/or other materials provided with the
22
* distribution.
23
24
* * Neither the name of the copyright holders nor the names of
25
* contributors may be used to endorse or promote products derived
26
* from this software without specific prior written permission.
27
28
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
29
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
30
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
31
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
32
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
33
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
34
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
35
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
36
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
37
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
38
* POSSIBILITY OF SUCH DAMAGE.
39
40
41
#ifndef _AVR_IO8535_H_
42
#define _AVR_IO8535_H_ 1
43
44
#ifndef _AVR_IO_H_
45
# error "Include <avr/io.h> instead of this file."
46
#endif
47
48
#ifndef _AVR_IOXXX_H_
49
# define _AVR_IOXXX_H_ "io8535.h"
50
#else
51
# error "Attempt to include more than one <avr/ioXXX.h> file."
52
#endif
53
62
/* I/O registers */
63
64
/* ADC Data register */
65
#ifndef __ASSEMBLER__
66
#define ADC _SFR_IO16(0x04)
67
#endif
68
#define ADCW _SFR_IO16(0x04)
69
#define ADCL _SFR_IO8(0x04)
70
#define ADCH _SFR_IO8(0x05)
71
72
/* ADC Control and Status Register */
73
#define ADCSR _SFR_IO8(0x06)
74
75
/* ADC MUX */
76
#define ADMUX _SFR_IO8(0x07)
77
78
/* Analog Comparator Control and Status Register */
79
#define ACSR _SFR_IO8(0x08)
80
81
/* UART Baud Rate Register */
82
#define UBRR _SFR_IO8(0x09)
83
84
/* UART Control Register */
85
#define UCR _SFR_IO8(0x0A)
86
87
/* UART Status Register */
88
#define USR _SFR_IO8(0x0B)
89
90
/* UART I/O Data Register */
91
#define UDR _SFR_IO8(0x0C)
92
93
/* SPI Control Register */
94
#define SPCR _SFR_IO8(0x0D)
95
96
/* SPI Status Register */
97
#define SPSR _SFR_IO8(0x0E)
98
99
/* SPI I/O Data Register */
100
#define SPDR _SFR_IO8(0x0F)
101
102
/* Input Pins, Port D */
103
#define PIND _SFR_IO8(0x10)
104
105
/* Data Direction Register, Port D */
106
#define DDRD _SFR_IO8(0x11)
107
108
/* Data Register, Port D */
109
#define PORTD _SFR_IO8(0x12)
110
111
/* Input Pins, Port C */
112
#define PINC _SFR_IO8(0x13)
113
114
/* Data Direction Register, Port C */
115
#define DDRC _SFR_IO8(0x14)
116
117
/* Data Register, Port C */
118
#define PORTC _SFR_IO8(0x15)
119
120
/* Input Pins, Port B */
121
#define PINB _SFR_IO8(0x16)
122
123
/* Data Direction Register, Port B */
124
#define DDRB _SFR_IO8(0x17)
125
126
/* Data Register, Port B */
127
#define PORTB _SFR_IO8(0x18)
128
129
/* Input Pins, Port A */
130
#define PINA _SFR_IO8(0x19)
131
132
/* Data Direction Register, Port A */
133
#define DDRA _SFR_IO8(0x1A)
134
135
/* Data Register, Port A */
136
#define PORTA _SFR_IO8(0x1B)
137
138
/* EEPROM Control Register */
139
#define EECR _SFR_IO8(0x1C)
140
141
/* EEPROM Data Register */
142
#define EEDR _SFR_IO8(0x1D)
143
144
/* EEPROM Address Register */
145
#define EEAR _SFR_IO16(0x1E)
146
#define EEARL _SFR_IO8(0x1E)
147
#define EEARH _SFR_IO8(0x1F)
148
149
/* Watchdog Timer Control Register */
150
#define WDTCR _SFR_IO8(0x21)
151
152
/* Asynchronous mode Status Register */
153
#define ASSR _SFR_IO8(0x22)
154
155
/* Timer/Counter2 Output Compare Register */
156
#define OCR2 _SFR_IO8(0x23)
157
158
/* Timer/Counter 2 */
159
#define TCNT2 _SFR_IO8(0x24)
160
161
/* Timer/Counter 2 Control Register */
162
#define TCCR2 _SFR_IO8(0x25)
163
164
/* T/C 1 Input Capture Register */
165
#define ICR1 _SFR_IO16(0x26)
166
#define ICR1L _SFR_IO8(0x26)
167
#define ICR1H _SFR_IO8(0x27)
168
169
/* Timer/Counter1 Output Compare Register B */
170
#define OCR1B _SFR_IO16(0x28)
171
#define OCR1BL _SFR_IO8(0x28)
172
#define OCR1BH _SFR_IO8(0x29)
173
174
/* Timer/Counter1 Output Compare Register A */
175
#define OCR1A _SFR_IO16(0x2A)
176
#define OCR1AL _SFR_IO8(0x2A)
177
#define OCR1AH _SFR_IO8(0x2B)
178
179
/* Timer/Counter 1 */
180
#define TCNT1 _SFR_IO16(0x2C)
181
#define TCNT1L _SFR_IO8(0x2C)
182
#define TCNT1H _SFR_IO8(0x2D)
183
184
/* Timer/Counter 1 Control and Status Register */
185
#define TCCR1B _SFR_IO8(0x2E)
186
187
/* Timer/Counter 1 Control Register */
188
#define TCCR1A _SFR_IO8(0x2F)
189
190
/* Timer/Counter 0 */
191
#define TCNT0 _SFR_IO8(0x32)
192
193
/* Timer/Counter 0 Control Register */
194
#define TCCR0 _SFR_IO8(0x33)
195
196
/* MCU general Status Register */
197
#define MCUSR _SFR_IO8(0x34)
198
199
/* MCU general Control Register */
200
#define MCUCR _SFR_IO8(0x35)
201
202
/* Timer/Counter Interrupt Flag register */
203
#define TIFR _SFR_IO8(0x38)
204
205
/* Timer/Counter Interrupt MaSK register */
206
#define TIMSK _SFR_IO8(0x39)
207
208
/* General Interrupt Flag Register */
209
#define GIFR _SFR_IO8(0x3A)
210
211
/* General Interrupt MaSK register */
212
#define GIMSK _SFR_IO8(0x3B)
213
214
/* 0x3D..0x3E SP */
215
216
/* 0x3F SREG */
217
218
/* Interrupt vectors */
219
220
/* External Interrupt 0 */
221
#define INT0_vect _VECTOR(1)
222
#define SIG_INTERRUPT0 _VECTOR(1)
223
224
/* External Interrupt 1 */
225
#define INT1_vect _VECTOR(2)
226
#define SIG_INTERRUPT1 _VECTOR(2)
227
228
/* Timer/Counter2 Compare Match */
229
#define TIMER2_COMP_vect _VECTOR(3)
230
#define SIG_OUTPUT_COMPARE2 _VECTOR(3)
231
232
/* Timer/Counter2 Overflow */
233
#define TIMER2_OVF_vect _VECTOR(4)
234
#define SIG_OVERFLOW2 _VECTOR(4)
235
236
/* Timer/Counter1 Capture Event */
237
#define TIMER1_CAPT_vect _VECTOR(5)
238
#define SIG_INPUT_CAPTURE1 _VECTOR(5)
239
240
/* Timer/Counter1 Compare Match A */
241
#define TIMER1_COMPA_vect _VECTOR(6)
242
#define SIG_OUTPUT_COMPARE1A _VECTOR(6)
243
244
/* Timer/Counter1 Compare Match B */
245
#define TIMER1_COMPB_vect _VECTOR(7)
246
#define SIG_OUTPUT_COMPARE1B _VECTOR(7)
247
248
/* Timer/Counter1 Overflow */
249
#define TIMER1_OVF_vect _VECTOR(8)
250
#define SIG_OVERFLOW1 _VECTOR(8)
251
252
/* Timer/Counter0 Overflow */
253
#define TIMER0_OVF_vect _VECTOR(9)
254
#define SIG_OVERFLOW0 _VECTOR(9)
255
256
/* SPI Serial Transfer Complete */
257
#define SPI_STC_vect _VECTOR(10)
258
#define SIG_SPI _VECTOR(10)
259
260
/* UART, RX Complete */
261
#define UART_RX_vect _VECTOR(11)
262
#define SIG_UART_RECV _VECTOR(11)
263
264
/* UART Data Register Empty */
265
#define UART_UDRE_vect _VECTOR(12)
266
#define SIG_UART_DATA _VECTOR(12)
267
268
/* UART, TX Complete */
269
#define UART_TX_vect _VECTOR(13)
270
#define SIG_UART_TRANS _VECTOR(13)
271
272
/* ADC Conversion Complete */
273
#define ADC_vect _VECTOR(14)
274
#define SIG_ADC _VECTOR(14)
275
276
/* EEPROM Ready */
277
#define EE_RDY_vect _VECTOR(15)
278
#define SIG_EEPROM_READY _VECTOR(15)
279
280
/* Analog Comparator */
281
#define ANA_COMP_vect _VECTOR(16)
282
#define SIG_COMPARATOR _VECTOR(16)
283
284
#define _VECTORS_SIZE 34
285
286
287
The Register Bit names are represented by their bit number (0-7).
288
289
290
291
#define EXTRF 1
292
#define PORF 0
293
294
295
#define INT1 7
296
#define INT0 6
297
298
299
#define INTF1 7
300
#define INTF0 6
301
302
303
#define OCIE2 7
304
#define TOIE2 6
305
#define TICIE1 5
306
#define OCIE1A 4
307
#define OCIE1B 3
308
#define TOIE1 2
309
#define TOIE0 0
310
311
312
#define OCF2 7
313
#define TOV2 6
314
#define ICF1 5
315
#define OCF1A 4
316
#define OCF1B 3
317
#define TOV1 2
318
#define TOV0 0
319
320
321
#define SE 6
322
#define SM1 5
323
#define SM0 4
324
#define ISC11 3
325
#define ISC10 2
326
#define ISC01 1
327
#define ISC00 0
328
329
330
#define CS02 2
331
#define CS01 1
332
#define CS00 0
333
334
335
#define COM1A1 7
336
#define COM1A0 6
337
#define COM1B1 5
338
#define COM1B0 4
339
#define PWM11 1
340
#define PWM10 0
341
342
343
#define ICNC1 7
344
#define ICES1 6
345
#define CTC1 3
346
#define CS12 2
347
#define CS11 1
348
#define CS10 0
349
350
351
#define PWM2 6
352
#define COM21 5
353
#define COM20 4
354
#define CTC2 3
355
#define CS22 2
356
#define CS21 1
357
#define CS20 0
358
359
360
#define AS2 3
361
#define TCN2UB 2
362
#define OCR2UB 1
363
#define TCR2UB 0
364
365
366
#define WDTOE 4
367
#define WDE 3
368
#define WDP2 2
369
#define WDP1 1
370
#define WDP0 0
371
372
373
#define PA7 7
374
#define PA6 6
375
#define PA5 5
376
#define PA4 4
377
#define PA3 3
378
#define PA2 2
379
#define PA1 1
380
#define PA0 0
381
382
383
#define DDA7 7
384
#define DDA6 6
385
#define DDA5 5
386
#define DDA4 4
387
#define DDA3 3
388
#define DDA2 2
389
#define DDA1 1
390
#define DDA0 0
391
392
393
#define PINA7 7
394
#define PINA6 6
395
#define PINA5 5
396
#define PINA4 4
397
#define PINA3 3
398
#define PINA2 2
399
#define PINA1 1
400
#define PINA0 0
401
402
403
#define PB7 7
404
#define PB6 6
405
#define PB5 5
406
#define PB4 4
407
#define PB3 3
408
#define PB2 2
409
#define PB1 1
410
#define PB0 0
411
412
413
#define DDB7 7
414
#define DDB6 6
415
#define DDB5 5
416
#define DDB4 4
417
#define DDB3 3
418
#define DDB2 2
419
#define DDB1 1
420
#define DDB0 0
421
422
423
#define PINB7 7
424
#define PINB6 6
425
#define PINB5 5
426
#define PINB4 4
427
#define PINB3 3
428
#define PINB2 2
429
#define PINB1 1
430
#define PINB0 0
431
432
433
#define PC7 7
434
#define PC6 6
435
#define PC5 5
436
#define PC4 4
437
#define PC3 3
438
#define PC2 2
439
#define PC1 1
440
#define PC0 0
441
442
443
#define DDC7 7
444
#define DDC6 6
445
#define DDC5 5
446
#define DDC4 4
447
#define DDC3 3
448
#define DDC2 2
449
#define DDC1 1
450
#define DDC0 0
451
452
453
#define PINC7 7
454
#define PINC6 6
455
#define PINC5 5
456
#define PINC4 4
457
#define PINC3 3
458
#define PINC2 2
459
#define PINC1 1
460
#define PINC0 0
461
462
463
#define PD7 7
464
#define PD6 6
465
#define PD5 5
466
#define PD4 4
467
#define PD3 3
468
#define PD2 2
469
#define PD1 1
470
#define PD0 0
471
472
473
#define DDD7 7
474
#define DDD6 6
475
#define DDD5 5
476
#define DDD4 4
477
#define DDD3 3
478
#define DDD2 2
479
#define DDD1 1
480
#define DDD0 0
481
482
483
#define PIND7 7
484
#define PIND6 6
485
#define PIND5 5
486
#define PIND4 4
487
#define PIND3 3
488
#define PIND2 2
489
#define PIND1 1
490
#define PIND0 0
491
492
493
#define SPIE 7
494
#define SPE 6
495
#define DORD 5
496
#define MSTR 4
497
#define CPOL 3
498
#define CPHA 2
499
#define SPR1 1
500
#define SPR0 0
501
502
503
#define SPIF 7
504
#define WCOL 6
505
506
507
#define RXC 7
508
#define TXC 6
509
#define UDRE 5
510
#define FE 4
511
#define DOR 3
512
513
514
#define RXCIE 7
515
#define TXCIE 6
516
#define UDRIE 5
517
#define RXEN 4
518
#define TXEN 3
519
#define CHR9 2
520
#define RXB8 1
521
#define TXB8 0
522
523
524
#define ACD 7
525
#define ACO 5
526
#define ACI 4
527
#define ACIE 3
528
#define ACIC 2
529
#define ACIS1 1
530
#define ACIS0 0
531
532
/* ADC MUX */
533
#define MUX2 2
534
#define MUX1 1
535
#define MUX0 0
536
537
538
#define ADEN 7
539
#define ADSC 6
540
#define ADFR 5
541
#define ADIF 4
542
#define ADIE 3
543
#define ADPS2 2
544
#define ADPS1 1
545
#define ADPS0 0
546
547
548
#define EERIE 3
549
#define EEMWE 2
550
#define EEWE 1
551
#define EERE 0
552
553
/* Constants */
554
#define RAMEND 0x25F
/*Last On-Chip SRAM location*/
555
#define XRAMEND RAMEND
556
#define E2END 0x1FF
557
#define E2PAGESIZE 0
558
#define FLASHEND 0x1FFF
559
560
561
/* Fuses */
562
#define FUSE_MEMORY_SIZE 1
563
564
/* Low Fuse Byte */
565
#define FUSE_SPIEN (unsigned char)~_BV(1)
/* Serial Program Downloading Enabled */
566
#define FUSE_FSTRT (unsigned char)~_BV(2)
/* Short Start-up time selected */
567
#define LFUSE_DEFAULT (0xFF)
568
569
570
/* Lock Bits */
571
#define __LOCK_BITS_EXIST
572
573
574
/* Signature */
575
#define SIGNATURE_0 0x1E
576
#define SIGNATURE_1 0x93
577
#define SIGNATURE_2 0x03
578
580
#endif
/* _AVR_IO8535_H_ */
