33 #define PCI_VENDOR_ID 0x00 34 #define PCI_DEVICE_ID 0x02 36 #define PCI_INVALID_VENDORDEVICEID 0xffffffff 38 #define PCI_COMMAND 0x04 39 #define PCI_COMMAND_IO 0x0001 40 #define PCI_COMMAND_MEMORY 0x0002 41 #define PCI_COMMAND_MASTER 0x0004 42 #define PCI_COMMAND_SPECIAL 0x0008 43 #define PCI_COMMAND_INVALIDATE 0x0010 44 #define PCI_COMMAND_VGA_PALETTE 0x0020 45 #define PCI_COMMAND_PARITY 0x0040 46 #define PCI_COMMAND_WAIT 0x0080 47 #define PCI_COMMAND_SERR 0x0100 48 #define PCI_COMMAND_FAST_BACK 0x0200 50 #define PCI_STATUS 0x06 51 #define PCI_STATUS_66MHZ 0x0020 52 #define PCI_STATUS_UDF 0x0040 53 #define PCI_STATUS_FAST_BACK 0x0080 54 #define PCI_STATUS_PARITY 0x0100 55 #define PCI_STATUS_DEVSEL_MASK 0x0600 56 #define PCI_STATUS_DEVSEL_FAST 0x0000 57 #define PCI_STATUS_DEVSEL_MEDIUM 0x0200 58 #define PCI_STATUS_DEVSEL_SLOW 0x0400 59 #define PCI_STATUS_SIG_TARGET_ABORT 0x0800 60 #define PCI_STATUS_REC_TARGET_ABORT 0x1000 61 #define PCI_STATUS_REC_MASTER_ABORT 0x2000 62 #define PCI_STATUS_SIG_SYSTEM_ERROR 0x4000 63 #define PCI_STATUS_DETECTED_PARITY 0x8000 65 #define PCI_CLASS_REVISION 0x08 66 #define PCI_REVISION_ID 0x08 67 #define PCI_CLASS_PROG 0x09 68 #define PCI_CLASS_DEVICE 0x0a 69 #define PCI_CACHE_LINE_SIZE 0x0c 70 #define PCI_LATENCY_TIMER 0x0d 72 #define PCI_HEADER_TYPE 0x0e 73 #define PCI_HEADER_TYPE_NORMAL 0x00 74 #define PCI_HEADER_TYPE_BRIDGE 0x01 75 #define PCI_HEADER_TYPE_CARDBUS 0x02 76 #define PCI_HEADER_TYPE_MULTI_FUNCTION 0x80 79 #define PCI_BIST_CODE_MASK 0x0f 80 #define PCI_BIST_START 0x40 81 #define PCI_BIST_CAPABLE 0x80 89 #define PCI_BASE_ADDRESS_0 0x10 90 #define PCI_BASE_ADDRESS_1 0x14 91 #define PCI_BASE_ADDRESS_2 0x18 92 #define PCI_BASE_ADDRESS_3 0x1c 93 #define PCI_BASE_ADDRESS_4 0x20 94 #define PCI_BASE_ADDRESS_5 0x24 95 #define PCI_BASE_ADDRESS_SPACE 0x01 96 #define PCI_BASE_ADDRESS_SPACE_IO 0x01 97 #define PCI_BASE_ADDRESS_SPACE_MEMORY 0x00 98 #define PCI_BASE_ADDRESS_MEM_TYPE_MASK 0x06 99 #define PCI_BASE_ADDRESS_MEM_TYPE_32 0x00 100 #define PCI_BASE_ADDRESS_MEM_TYPE_1M 0x02 101 #define PCI_BASE_ADDRESS_MEM_TYPE_64 0x04 102 #define PCI_BASE_ADDRESS_MEM_PREFETCH 0x08 103 #define PCI_BASE_ADDRESS_MEM_MASK (~0x0fUL) 104 #define PCI_BASE_ADDRESS_IO_MASK (~0x03UL) 108 #define PCI_CARDBUS_CIS 0x28 109 #define PCI_SUBSYSTEM_VENDOR_ID 0x2c 110 #define PCI_SUBSYSTEM_ID 0x2e 111 #define PCI_ROM_ADDRESS 0x30 112 #define PCI_ROM_ADDRESS_ENABLE 0x01 113 #define PCI_ROM_ADDRESS_MASK (~0x7ffUL) 116 #define PCI_CAPABILITY_LIST_POINTER 0x34 119 #define PCI_INTERRUPT_LINE 0x3c 120 #define PCI_INTERRUPT_PIN 0x3d 121 #define PCI_MIN_GNT 0x3e 122 #define PCI_MAX_LAT 0x3f 125 #define PCI_PRIMARY_BUS 0x18 126 #define PCI_SECONDARY_BUS 0x19 127 #define PCI_SUBORDINATE_BUS 0x1a 128 #define PCI_SEC_LATENCY_TIMER 0x1b 129 #define PCI_IO_BASE 0x1c 130 #define PCI_IO_LIMIT 0x1d 131 #define PCI_IO_RANGE_TYPE_MASK 0x0f 132 #define PCI_IO_RANGE_TYPE_16 0x00 133 #define PCI_IO_RANGE_TYPE_32 0x01 134 #define PCI_IO_RANGE_MASK ~0x0f 136 #define PCI_SEC_STATUS 0x1e 138 #define PCI_MEMORY_BASE 0x20 139 #define PCI_MEMORY_LIMIT 0x22 140 #define PCI_MEMORY_RANGE_TYPE_MASK 0x0f 141 #define PCI_MEMORY_RANGE_MASK ~0x0f 142 #define PCI_PREF_MEMORY_BASE 0x24 143 #define PCI_PREF_MEMORY_LIMIT 0x26 144 #define PCI_PREF_RANGE_TYPE_MASK 0x0f 145 #define PCI_PREF_RANGE_TYPE_32 0x00 146 #define PCI_PREF_RANGE_TYPE_64 0x01 147 #define PCI_PREF_RANGE_MASK ~0x0f 148 #define PCI_PREF_BASE_UPPER32 0x28 149 #define PCI_PREF_LIMIT_UPPER32 0x2c 150 #define PCI_IO_BASE_UPPER16 0x30 151 #define PCI_IO_LIMIT_UPPER16 0x32 153 #define PCI_ROM_ADDRESS1 0x38 155 #define PCI_BRIDGE_CONTROL 0x3e 156 #define PCI_BRIDGE_CTL_PARITY 0x01 157 #define PCI_BRIDGE_CTL_SERR 0x02 158 #define PCI_BRIDGE_CTL_NO_ISA 0x04 159 #define PCI_BRIDGE_CTL_VGA 0x08 160 #define PCI_BRIDGE_CTL_MASTER_ABORT 0x20 161 #define PCI_BRIDGE_CTL_BUS_RESET 0x40 162 #define PCI_BRIDGE_CTL_FAST_BACK 0x80 167 #define PCI_CB_SEC_STATUS 0x16 168 #define PCI_CB_PRIMARY_BUS 0x18 169 #define PCI_CB_CARD_BUS 0x19 170 #define PCI_CB_SUBORDINATE_BUS 0x1a 171 #define PCI_CB_LATENCY_TIMER 0x1b 172 #define PCI_CB_MEMORY_BASE_0 0x1c 173 #define PCI_CB_MEMORY_LIMIT_0 0x20 174 #define PCI_CB_MEMORY_BASE_1 0x24 175 #define PCI_CB_MEMORY_LIMIT_1 0x28 176 #define PCI_CB_IO_BASE_0 0x2c 177 #define PCI_CB_IO_BASE_0_HI 0x2e 178 #define PCI_CB_IO_LIMIT_0 0x30 179 #define PCI_CB_IO_LIMIT_0_HI 0x32 180 #define PCI_CB_IO_BASE_1 0x34 181 #define PCI_CB_IO_BASE_1_HI 0x36 182 #define PCI_CB_IO_LIMIT_1 0x38 183 #define PCI_CB_IO_LIMIT_1_HI 0x3a 184 #define PCI_CB_IO_RANGE_MASK ~0x03 187 #define PCI_CB_BRIDGE_CONTROL 0x3e 188 #define PCI_CB_BRIDGE_CTL_PARITY 0x01 190 #define PCI_CB_BRIDGE_CTL_SERR 0x02 191 #define PCI_CB_BRIDGE_CTL_ISA 0x04 192 #define PCI_CB_BRIDGE_CTL_VGA 0x08 193 #define PCI_CB_BRIDGE_CTL_MASTER_ABORT 0x20 194 #define PCI_CB_BRIDGE_CTL_CB_RESET 0x40 195 #define PCI_CB_BRIDGE_CTL_16BIT_INT 0x80 197 #define PCI_CB_BRIDGE_CTL_PREFETCH_MEM0 0x100 199 #define PCI_CB_BRIDGE_CTL_PREFETCH_MEM1 0x200 200 #define PCI_CB_BRIDGE_CTL_POST_WRITES 0x400 202 #define PCI_CB_SUBSYSTEM_VENDOR_ID 0x40 203 #define PCI_CB_SUBSYSTEM_ID 0x42 206 #define PCI_CB_LEGACY_MODE_BASE 0x44 212 #define PCI_CLASS_NOT_DEFINED 0x0000 213 #define PCI_CLASS_NOT_DEFINED_VGA 0x0001 215 #define PCI_BASE_CLASS_STORAGE 0x01 216 #define PCI_CLASS_STORAGE_SCSI 0x0100 217 #define PCI_CLASS_STORAGE_IDE 0x0101 218 #define PCI_CLASS_STORAGE_FLOPPY 0x0102 219 #define PCI_CLASS_STORAGE_IPI 0x0103 220 #define PCI_CLASS_STORAGE_RAID 0x0104 221 #define PCI_CLASS_STORAGE_OTHER 0x0180 223 #define PCI_BASE_CLASS_NETWORK 0x02 224 #define PCI_CLASS_NETWORK_ETHERNET 0x0200 225 #define PCI_CLASS_NETWORK_TOKEN_RING 0x0201 226 #define PCI_CLASS_NETWORK_FDDI 0x0202 227 #define PCI_CLASS_NETWORK_ATM 0x0203 228 #define PCI_CLASS_NETWORK_OTHER 0x0280 230 #define PCI_BASE_CLASS_DISPLAY 0x03 231 #define PCI_CLASS_DISPLAY_VGA 0x0300 232 #define PCI_CLASS_DISPLAY_XGA 0x0301 233 #define PCI_CLASS_DISPLAY_OTHER 0x0380 235 #define PCI_BASE_CLASS_MULTIMEDIA 0x04 236 #define PCI_CLASS_MULTIMEDIA_VIDEO 0x0400 237 #define PCI_CLASS_MULTIMEDIA_AUDIO 0x0401 238 #define PCI_CLASS_MULTIMEDIA_OTHER 0x0480 240 #define PCI_BASE_CLASS_MEMORY 0x05 241 #define PCI_CLASS_MEMORY_RAM 0x0500 242 #define PCI_CLASS_MEMORY_FLASH 0x0501 243 #define PCI_CLASS_MEMORY_OTHER 0x0580 245 #define PCI_BASE_CLASS_BRIDGE 0x06 246 #define PCI_CLASS_BRIDGE_HOST 0x0600 247 #define PCI_CLASS_BRIDGE_ISA 0x0601 248 #define PCI_CLASS_BRIDGE_EISA 0x0602 249 #define PCI_CLASS_BRIDGE_MC 0x0603 250 #define PCI_CLASS_BRIDGE_PCI 0x0604 251 #define PCI_CLASS_BRIDGE_PCMCIA 0x0605 252 #define PCI_CLASS_BRIDGE_NUBUS 0x0606 253 #define PCI_CLASS_BRIDGE_CARDBUS 0x0607 254 #define PCI_CLASS_BRIDGE_OTHER 0x0680 256 #define PCI_BASE_CLASS_COMMUNICATION 0x07 257 #define PCI_CLASS_COMMUNICATION_SERIAL 0x0700 258 #define PCI_CLASS_COMMUNICATION_PARALLEL 0x0701 259 #define PCI_CLASS_COMMUNICATION_OTHER 0x0780 261 #define PCI_BASE_CLASS_SYSTEM 0x08 262 #define PCI_CLASS_SYSTEM_PIC 0x0800 263 #define PCI_CLASS_SYSTEM_DMA 0x0801 264 #define PCI_CLASS_SYSTEM_TIMER 0x0802 265 #define PCI_CLASS_SYSTEM_RTC 0x0803 266 #define PCI_CLASS_SYSTEM_OTHER 0x0880 268 #define PCI_BASE_CLASS_INPUT 0x09 269 #define PCI_CLASS_INPUT_KEYBOARD 0x0900 270 #define PCI_CLASS_INPUT_PEN 0x0901 271 #define PCI_CLASS_INPUT_MOUSE 0x0902 272 #define PCI_CLASS_INPUT_OTHER 0x0980 274 #define PCI_BASE_CLASS_DOCKING 0x0a 275 #define PCI_CLASS_DOCKING_GENERIC 0x0a00 276 #define PCI_CLASS_DOCKING_OTHER 0x0a01 278 #define PCI_BASE_CLASS_PROCESSOR 0x0b 279 #define PCI_CLASS_PROCESSOR_386 0x0b00 280 #define PCI_CLASS_PROCESSOR_486 0x0b01 281 #define PCI_CLASS_PROCESSOR_PENTIUM 0x0b02 282 #define PCI_CLASS_PROCESSOR_ALPHA 0x0b10 283 #define PCI_CLASS_PROCESSOR_POWERPC 0x0b20 284 #define PCI_CLASS_PROCESSOR_CO 0x0b40 286 #define PCI_BASE_CLASS_SERIAL 0x0c 287 #define PCI_CLASS_SERIAL_FIREWIRE 0x0c00 288 #define PCI_CLASS_SERIAL_ACCESS 0x0c01 289 #define PCI_CLASS_SERIAL_SSA 0x0c02 290 #define PCI_CLASS_SERIAL_USB 0x0c03 291 #define PCI_CLASS_SERIAL_FIBER 0x0c04 293 #define PCI_CLASS_OTHERS 0xff 300 #define PCI_VENDOR_ID_COMPAQ 0x0e11 301 #define PCI_DEVICE_ID_COMPAQ_1280 0x3033 302 #define PCI_DEVICE_ID_COMPAQ_TRIFLEX 0x4000 303 #define PCI_DEVICE_ID_COMPAQ_SMART2P 0xae10 304 #define PCI_DEVICE_ID_COMPAQ_NETEL100 0xae32 305 #define PCI_DEVICE_ID_COMPAQ_NETEL10 0xae34 306 #define PCI_DEVICE_ID_COMPAQ_NETFLEX3I 0xae35 307 #define PCI_DEVICE_ID_COMPAQ_NETEL100D 0xae40 308 #define PCI_DEVICE_ID_COMPAQ_NETEL100PI 0xae43 309 #define PCI_DEVICE_ID_COMPAQ_NETEL100I 0xb011 310 #define PCI_DEVICE_ID_COMPAQ_THUNDER 0xf130 311 #define PCI_DEVICE_ID_COMPAQ_NETFLEX3B 0xf150 313 #define PCI_VENDOR_ID_NCR 0x1000 314 #define PCI_DEVICE_ID_NCR_53C810 0x0001 315 #define PCI_DEVICE_ID_NCR_53C820 0x0002 316 #define PCI_DEVICE_ID_NCR_53C825 0x0003 317 #define PCI_DEVICE_ID_NCR_53C815 0x0004 318 #define PCI_DEVICE_ID_NCR_53C860 0x0006 319 #define PCI_DEVICE_ID_NCR_53C896 0x000b 320 #define PCI_DEVICE_ID_NCR_53C895 0x000c 321 #define PCI_DEVICE_ID_NCR_53C885 0x000d 322 #define PCI_DEVICE_ID_NCR_53C875 0x000f 323 #define PCI_DEVICE_ID_NCR_53C875J 0x008f 325 #define PCI_VENDOR_ID_ATI 0x1002 326 #define PCI_DEVICE_ID_ATI_68800 0x4158 327 #define PCI_DEVICE_ID_ATI_215CT222 0x4354 328 #define PCI_DEVICE_ID_ATI_210888CX 0x4358 329 #define PCI_DEVICE_ID_ATI_215GB 0x4742 330 #define PCI_DEVICE_ID_ATI_215GD 0x4744 331 #define PCI_DEVICE_ID_ATI_215GI 0x4749 332 #define PCI_DEVICE_ID_ATI_215GP 0x4750 333 #define PCI_DEVICE_ID_ATI_215GQ 0x4751 334 #define PCI_DEVICE_ID_ATI_215GT 0x4754 335 #define PCI_DEVICE_ID_ATI_215GTB 0x4755 336 #define PCI_DEVICE_ID_ATI_210888GX 0x4758 337 #define PCI_DEVICE_ID_ATI_215LG 0x4c47 338 #define PCI_DEVICE_ID_ATI_264LT 0x4c54 339 #define PCI_DEVICE_ID_ATI_264VT 0x5654 341 #define PCI_VENDOR_ID_VLSI 0x1004 342 #define PCI_DEVICE_ID_VLSI_82C592 0x0005 343 #define PCI_DEVICE_ID_VLSI_82C593 0x0006 344 #define PCI_DEVICE_ID_VLSI_82C594 0x0007 345 #define PCI_DEVICE_ID_VLSI_82C597 0x0009 346 #define PCI_DEVICE_ID_VLSI_82C541 0x000c 347 #define PCI_DEVICE_ID_VLSI_82C543 0x000d 348 #define PCI_DEVICE_ID_VLSI_82C532 0x0101 349 #define PCI_DEVICE_ID_VLSI_82C534 0x0102 350 #define PCI_DEVICE_ID_VLSI_82C535 0x0104 351 #define PCI_DEVICE_ID_VLSI_82C147 0x0105 352 #define PCI_DEVICE_ID_VLSI_VAS96011 0x0702 354 #define PCI_VENDOR_ID_ADL 0x1005 355 #define PCI_DEVICE_ID_ADL_2301 0x2301 357 #define PCI_VENDOR_ID_NS 0x100b 358 #define PCI_DEVICE_ID_NS_87415 0x0002 359 #define PCI_DEVICE_ID_NS_87410 0xd001 361 #define PCI_VENDOR_ID_TSENG 0x100c 362 #define PCI_DEVICE_ID_TSENG_W32P_2 0x3202 363 #define PCI_DEVICE_ID_TSENG_W32P_b 0x3205 364 #define PCI_DEVICE_ID_TSENG_W32P_c 0x3206 365 #define PCI_DEVICE_ID_TSENG_W32P_d 0x3207 366 #define PCI_DEVICE_ID_TSENG_ET6000 0x3208 368 #define PCI_VENDOR_ID_WEITEK 0x100e 369 #define PCI_DEVICE_ID_WEITEK_P9000 0x9001 370 #define PCI_DEVICE_ID_WEITEK_P9100 0x9100 372 #define PCI_VENDOR_ID_DEC 0x1011 373 #define PCI_DEVICE_ID_DEC_BRD 0x0001 374 #define PCI_DEVICE_ID_DEC_TULIP 0x0002 375 #define PCI_DEVICE_ID_DEC_TGA 0x0004 376 #define PCI_DEVICE_ID_DEC_TULIP_FAST 0x0009 377 #define PCI_DEVICE_ID_DEC_TGA2 0x000D 378 #define PCI_DEVICE_ID_DEC_FDDI 0x000F 379 #define PCI_DEVICE_ID_DEC_TULIP_PLUS 0x0014 380 #define PCI_DEVICE_ID_DEC_21142 0x0019 381 #define PCI_DEVICE_ID_DEC_21143 0x0019 382 #define PCI_DEVICE_ID_DEC_21052 0x0021 383 #define PCI_DEVICE_ID_DEC_21150 0x0022 384 #define PCI_DEVICE_ID_DEC_21152 0x0024 386 #define PCI_VENDOR_ID_CIRRUS 0x1013 387 #define PCI_DEVICE_ID_CIRRUS_7548 0x0038 388 #define PCI_DEVICE_ID_CIRRUS_5430 0x00a0 389 #define PCI_DEVICE_ID_CIRRUS_5434_4 0x00a4 390 #define PCI_DEVICE_ID_CIRRUS_5434_8 0x00a8 391 #define PCI_DEVICE_ID_CIRRUS_5436 0x00ac 392 #define PCI_DEVICE_ID_CIRRUS_5446 0x00b8 393 #define PCI_DEVICE_ID_CIRRUS_5480 0x00bc 394 #define PCI_DEVICE_ID_CIRRUS_5464 0x00d4 395 #define PCI_DEVICE_ID_CIRRUS_5465 0x00d6 396 #define PCI_DEVICE_ID_CIRRUS_6729 0x1100 397 #define PCI_DEVICE_ID_CIRRUS_6832 0x1110 398 #define PCI_DEVICE_ID_CIRRUS_7542 0x1200 399 #define PCI_DEVICE_ID_CIRRUS_7543 0x1202 400 #define PCI_DEVICE_ID_CIRRUS_7541 0x1204 402 #define PCI_VENDOR_ID_IBM 0x1014 403 #define PCI_DEVICE_ID_IBM_FIRE_CORAL 0x000a 404 #define PCI_DEVICE_ID_IBM_TR 0x0018 405 #define PCI_DEVICE_ID_IBM_82G2675 0x001d 406 #define PCI_DEVICE_ID_IBM_MCA 0x0020 407 #define PCI_DEVICE_ID_IBM_82351 0x0022 408 #define PCI_DEVICE_ID_IBM_SERVERAID 0x002e 409 #define PCI_DEVICE_ID_IBM_TR_WAKE 0x003e 410 #define PCI_DEVICE_ID_IBM_MPIC 0x0046 411 #define PCI_DEVICE_ID_IBM_3780IDSP 0x007d 412 #define PCI_DEVICE_ID_IBM_MPIC_2 0xffff 414 #define PCI_VENDOR_ID_WD 0x101c 415 #define PCI_DEVICE_ID_WD_7197 0x3296 417 #define PCI_VENDOR_ID_AMD 0x1022 418 #define PCI_DEVICE_ID_AMD_LANCE 0x2000 419 #define PCI_DEVICE_ID_AMD_SCSI 0x2020 421 #define PCI_VENDOR_ID_TRIDENT 0x1023 422 #define PCI_DEVICE_ID_TRIDENT_9397 0x9397 423 #define PCI_DEVICE_ID_TRIDENT_9420 0x9420 424 #define PCI_DEVICE_ID_TRIDENT_9440 0x9440 425 #define PCI_DEVICE_ID_TRIDENT_9660 0x9660 426 #define PCI_DEVICE_ID_TRIDENT_9750 0x9750 428 #define PCI_VENDOR_ID_AI 0x1025 429 #define PCI_DEVICE_ID_AI_M1435 0x1435 431 #define PCI_VENDOR_ID_MATROX 0x102B 432 #define PCI_DEVICE_ID_MATROX_MGA_2 0x0518 433 #define PCI_DEVICE_ID_MATROX_MIL 0x0519 434 #define PCI_DEVICE_ID_MATROX_MYS 0x051A 435 #define PCI_DEVICE_ID_MATROX_MIL_2 0x051b 436 #define PCI_DEVICE_ID_MATROX_MIL_2_AGP 0x051f 437 #define PCI_DEVICE_ID_MATROX_MGA_IMP 0x0d10 439 #define PCI_VENDOR_ID_CT 0x102c 440 #define PCI_DEVICE_ID_CT_65545 0x00d8 441 #define PCI_DEVICE_ID_CT_65548 0x00dc 442 #define PCI_DEVICE_ID_CT_65550 0x00e0 443 #define PCI_DEVICE_ID_CT_65554 0x00e4 444 #define PCI_DEVICE_ID_CT_65555 0x00e5 446 #define PCI_VENDOR_ID_MIRO 0x1031 447 #define PCI_DEVICE_ID_MIRO_36050 0x5601 449 #define PCI_VENDOR_ID_NEC 0x1033 450 #define PCI_DEVICE_ID_NEC_PCX2 0x0046 452 #define PCI_VENDOR_ID_FD 0x1036 453 #define PCI_DEVICE_ID_FD_36C70 0x0000 455 #define PCI_VENDOR_ID_SI 0x1039 456 #define PCI_DEVICE_ID_SI_5591_AGP 0x0001 457 #define PCI_DEVICE_ID_SI_6202 0x0002 458 #define PCI_DEVICE_ID_SI_503 0x0008 459 #define PCI_DEVICE_ID_SI_ACPI 0x0009 460 #define PCI_DEVICE_ID_SI_5597_VGA 0x0200 461 #define PCI_DEVICE_ID_SI_6205 0x0205 462 #define PCI_DEVICE_ID_SI_501 0x0406 463 #define PCI_DEVICE_ID_SI_496 0x0496 464 #define PCI_DEVICE_ID_SI_601 0x0601 465 #define PCI_DEVICE_ID_SI_5107 0x5107 466 #define PCI_DEVICE_ID_SI_5511 0x5511 467 #define PCI_DEVICE_ID_SI_5513 0x5513 468 #define PCI_DEVICE_ID_SI_5571 0x5571 469 #define PCI_DEVICE_ID_SI_5591 0x5591 470 #define PCI_DEVICE_ID_SI_5597 0x5597 471 #define PCI_DEVICE_ID_SI_7001 0x7001 473 #define PCI_VENDOR_ID_HP 0x103c 474 #define PCI_DEVICE_ID_HP_J2585A 0x1030 475 #define PCI_DEVICE_ID_HP_J2585B 0x1031 477 #define PCI_VENDOR_ID_PCTECH 0x1042 478 #define PCI_DEVICE_ID_PCTECH_RZ1000 0x1000 479 #define PCI_DEVICE_ID_PCTECH_RZ1001 0x1001 480 #define PCI_DEVICE_ID_PCTECH_SAMURAI_0 0x3000 481 #define PCI_DEVICE_ID_PCTECH_SAMURAI_1 0x3010 482 #define PCI_DEVICE_ID_PCTECH_SAMURAI_IDE 0x3020 484 #define PCI_VENDOR_ID_DPT 0x1044 485 #define PCI_DEVICE_ID_DPT 0xa400 487 #define PCI_VENDOR_ID_OPTI 0x1045 488 #define PCI_DEVICE_ID_OPTI_92C178 0xc178 489 #define PCI_DEVICE_ID_OPTI_82C557 0xc557 490 #define PCI_DEVICE_ID_OPTI_82C558 0xc558 491 #define PCI_DEVICE_ID_OPTI_82C621 0xc621 492 #define PCI_DEVICE_ID_OPTI_82C700 0xc700 493 #define PCI_DEVICE_ID_OPTI_82C701 0xc701 494 #define PCI_DEVICE_ID_OPTI_82C814 0xc814 495 #define PCI_DEVICE_ID_OPTI_82C822 0xc822 496 #define PCI_DEVICE_ID_OPTI_82C825 0xd568 498 #define PCI_VENDOR_ID_SGS 0x104a 499 #define PCI_DEVICE_ID_SGS_2000 0x0008 500 #define PCI_DEVICE_ID_SGS_1764 0x0009 502 #define PCI_VENDOR_ID_BUSLOGIC 0x104B 503 #define PCI_DEVICE_ID_BUSLOGIC_MULTIMASTER_NC 0x0140 504 #define PCI_DEVICE_ID_BUSLOGIC_MULTIMASTER 0x1040 505 #define PCI_DEVICE_ID_BUSLOGIC_FLASHPOINT 0x8130 507 #define PCI_VENDOR_ID_TI 0x104c 508 #define PCI_DEVICE_ID_TI_TVP4010 0x3d04 509 #define PCI_DEVICE_ID_TI_TVP4020 0x3d07 510 #define PCI_DEVICE_ID_TI_PCI1130 0xac12 511 #define PCI_DEVICE_ID_TI_PCI1031 0xac13 512 #define PCI_DEVICE_ID_TI_PCI1131 0xac15 513 #define PCI_DEVICE_ID_TI_PCI1250 0xac16 514 #define PCI_DEVICE_ID_TI_PCI1220 0xac17 516 #define PCI_VENDOR_ID_OAK 0x104e 517 #define PCI_DEVICE_ID_OAK_OTI107 0x0107 519 #define PCI_VENDOR_ID_WINBOND2 0x1050 520 #define PCI_DEVICE_ID_WINBOND2_89C940 0x0940 522 #define PCI_VENDOR_ID_MOTOROLA 0x1057 523 #define PCI_DEVICE_ID_MOTOROLA_MPC105 0x0001 524 #define PCI_DEVICE_ID_MOTOROLA_MPC106 0x0002 525 #define PCI_DEVICE_ID_MOTOROLA_RAVEN 0x4801 526 #define PCI_DEVICE_ID_MOTOROLA_HAWK 0x4803 528 #define PCI_VENDOR_ID_PROMISE 0x105a 529 #define PCI_DEVICE_ID_PROMISE_20246 0x4d33 530 #define PCI_DEVICE_ID_PROMISE_5300 0x5300 532 #define PCI_VENDOR_ID_N9 0x105d 533 #define PCI_DEVICE_ID_N9_I128 0x2309 534 #define PCI_DEVICE_ID_N9_I128_2 0x2339 535 #define PCI_DEVICE_ID_N9_I128_T2R 0x493d 537 #define PCI_VENDOR_ID_UMC 0x1060 538 #define PCI_DEVICE_ID_UMC_UM8673F 0x0101 539 #define PCI_DEVICE_ID_UMC_UM8891A 0x0891 540 #define PCI_DEVICE_ID_UMC_UM8886BF 0x673a 541 #define PCI_DEVICE_ID_UMC_UM8886A 0x886a 542 #define PCI_DEVICE_ID_UMC_UM8881F 0x8881 543 #define PCI_DEVICE_ID_UMC_UM8886F 0x8886 544 #define PCI_DEVICE_ID_UMC_UM9017F 0x9017 545 #define PCI_DEVICE_ID_UMC_UM8886N 0xe886 546 #define PCI_DEVICE_ID_UMC_UM8891N 0xe891 548 #define PCI_VENDOR_ID_X 0x1061 549 #define PCI_DEVICE_ID_X_AGX016 0x0001 551 #define PCI_VENDOR_ID_PICOP 0x1066 552 #define PCI_DEVICE_ID_PICOP_PT86C52X 0x0001 553 #define PCI_DEVICE_ID_PICOP_PT80C524 0x8002 555 #define PCI_VENDOR_ID_APPLE 0x106b 556 #define PCI_DEVICE_ID_APPLE_BANDIT 0x0001 557 #define PCI_DEVICE_ID_APPLE_GC 0x0002 558 #define PCI_DEVICE_ID_APPLE_HYDRA 0x000e 560 #define PCI_VENDOR_ID_NEXGEN 0x1074 561 #define PCI_DEVICE_ID_NEXGEN_82C501 0x4e78 563 #define PCI_VENDOR_ID_QLOGIC 0x1077 564 #define PCI_DEVICE_ID_QLOGIC_ISP1020 0x1020 565 #define PCI_DEVICE_ID_QLOGIC_ISP1022 0x1022 567 #define PCI_VENDOR_ID_CYRIX 0x1078 568 #define PCI_DEVICE_ID_CYRIX_5510 0x0000 569 #define PCI_DEVICE_ID_CYRIX_PCI_MASTER 0x0001 570 #define PCI_DEVICE_ID_CYRIX_5520 0x0002 571 #define PCI_DEVICE_ID_CYRIX_5530_LEGACY 0x0100 572 #define PCI_DEVICE_ID_CYRIX_5530_SMI 0x0101 573 #define PCI_DEVICE_ID_CYRIX_5530_IDE 0x0102 574 #define PCI_DEVICE_ID_CYRIX_5530_AUDIO 0x0103 575 #define PCI_DEVICE_ID_CYRIX_5530_VIDEO 0x0104 577 #define PCI_VENDOR_ID_LEADTEK 0x107d 578 #define PCI_DEVICE_ID_LEADTEK_805 0x0000 580 #define PCI_VENDOR_ID_CONTAQ 0x1080 581 #define PCI_DEVICE_ID_CONTAQ_82C599 0x0600 582 #define PCI_DEVICE_ID_CONTAQ_82C693 0xc693 584 #define PCI_VENDOR_ID_FOREX 0x1083 586 #define PCI_VENDOR_ID_OLICOM 0x108d 587 #define PCI_DEVICE_ID_OLICOM_OC3136 0x0001 588 #define PCI_DEVICE_ID_OLICOM_OC2315 0x0011 589 #define PCI_DEVICE_ID_OLICOM_OC2325 0x0012 590 #define PCI_DEVICE_ID_OLICOM_OC2183 0x0013 591 #define PCI_DEVICE_ID_OLICOM_OC2326 0x0014 592 #define PCI_DEVICE_ID_OLICOM_OC6151 0x0021 594 #define PCI_VENDOR_ID_SUN 0x108e 595 #define PCI_DEVICE_ID_SUN_EBUS 0x1000 596 #define PCI_DEVICE_ID_SUN_HAPPYMEAL 0x1001 597 #define PCI_DEVICE_ID_SUN_SIMBA 0x5000 598 #define PCI_DEVICE_ID_SUN_PBM 0x8000 599 #define PCI_DEVICE_ID_SUN_SABRE 0xa000 601 #define PCI_VENDOR_ID_CMD 0x1095 602 #define PCI_DEVICE_ID_CMD_640 0x0640 603 #define PCI_DEVICE_ID_CMD_643 0x0643 604 #define PCI_DEVICE_ID_CMD_646 0x0646 605 #define PCI_DEVICE_ID_CMD_647 0x0647 606 #define PCI_DEVICE_ID_CMD_670 0x0670 608 #define PCI_VENDOR_ID_VISION 0x1098 609 #define PCI_DEVICE_ID_VISION_QD8500 0x0001 610 #define PCI_DEVICE_ID_VISION_QD8580 0x0002 612 #define PCI_VENDOR_ID_BROOKTREE 0x109e 613 #define PCI_DEVICE_ID_BROOKTREE_848 0x0350 614 #define PCI_DEVICE_ID_BROOKTREE_849A 0x0351 615 #define PCI_DEVICE_ID_BROOKTREE_8474 0x8474 617 #define PCI_VENDOR_ID_SIERRA 0x10a8 618 #define PCI_DEVICE_ID_SIERRA_STB 0x0000 620 #define PCI_VENDOR_ID_ACC 0x10aa 621 #define PCI_DEVICE_ID_ACC_2056 0x0000 623 #define PCI_VENDOR_ID_WINBOND 0x10ad 624 #define PCI_DEVICE_ID_WINBOND_83769 0x0001 625 #define PCI_DEVICE_ID_WINBOND_82C105 0x0105 626 #define PCI_DEVICE_ID_WINBOND_83C553 0x0565 628 #define PCI_VENDOR_ID_DATABOOK 0x10b3 629 #define PCI_DEVICE_ID_DATABOOK_87144 0xb106 631 #define PCI_VENDOR_ID_PLX 0x10b5 632 #define PCI_DEVICE_ID_PLX_9050 0x9050 633 #define PCI_DEVICE_ID_PLX_9060 0x9060 634 #define PCI_DEVICE_ID_PLX_9060ES 0x906E 635 #define PCI_DEVICE_ID_PLX_9060SD 0x906D 636 #define PCI_DEVICE_ID_PLX_9080 0x9080 638 #define PCI_VENDOR_ID_PLX2 0x3388 639 #define PCI_DEVICE_ID_PLX2_PCI6154_HB2 0x0026 641 #define PCI_VENDOR_ID_MADGE 0x10b6 642 #define PCI_DEVICE_ID_MADGE_MK2 0x0002 643 #define PCI_DEVICE_ID_MADGE_C155S 0x1001 645 #define PCI_VENDOR_ID_3COM 0x10b7 646 #define PCI_DEVICE_ID_3COM_3C339 0x3390 647 #define PCI_DEVICE_ID_3COM_3C590 0x5900 648 #define PCI_DEVICE_ID_3COM_3C595TX 0x5950 649 #define PCI_DEVICE_ID_3COM_3C595T4 0x5951 650 #define PCI_DEVICE_ID_3COM_3C595MII 0x5952 651 #define PCI_DEVICE_ID_3COM_3C900TPO 0x9000 652 #define PCI_DEVICE_ID_3COM_3C900COMBO 0x9001 653 #define PCI_DEVICE_ID_3COM_3C905TX 0x9050 654 #define PCI_DEVICE_ID_3COM_3C905T4 0x9051 655 #define PCI_DEVICE_ID_3COM_3C905B_TX 0x9055 657 #define PCI_VENDOR_ID_SMC 0x10b8 658 #define PCI_DEVICE_ID_SMC_EPIC100 0x0005 660 #define PCI_VENDOR_ID_AL 0x10b9 661 #define PCI_DEVICE_ID_AL_M1445 0x1445 662 #define PCI_DEVICE_ID_AL_M1449 0x1449 663 #define PCI_DEVICE_ID_AL_M1451 0x1451 664 #define PCI_DEVICE_ID_AL_M1461 0x1461 665 #define PCI_DEVICE_ID_AL_M1489 0x1489 666 #define PCI_DEVICE_ID_AL_M1511 0x1511 667 #define PCI_DEVICE_ID_AL_M1513 0x1513 668 #define PCI_DEVICE_ID_AL_M1521 0x1521 669 #define PCI_DEVICE_ID_AL_M1523 0x1523 670 #define PCI_DEVICE_ID_AL_M1531 0x1531 671 #define PCI_DEVICE_ID_AL_M1533 0x1533 672 #define PCI_DEVICE_ID_AL_M3307 0x3307 673 #define PCI_DEVICE_ID_AL_M4803 0x5215 674 #define PCI_DEVICE_ID_AL_M5219 0x5219 675 #define PCI_DEVICE_ID_AL_M5229 0x5229 676 #define PCI_DEVICE_ID_AL_M5237 0x5237 677 #define PCI_DEVICE_ID_AL_M7101 0x7101 679 #define PCI_VENDOR_ID_MITSUBISHI 0x10ba 681 #define PCI_VENDOR_ID_SURECOM 0x10bd 682 #define PCI_DEVICE_ID_SURECOM_NE34 0x0e34 684 #define PCI_VENDOR_ID_NEOMAGIC 0x10c8 685 #define PCI_DEVICE_ID_NEOMAGIC_MAGICGRAPH_NM2070 0x0001 686 #define PCI_DEVICE_ID_NEOMAGIC_MAGICGRAPH_128V 0x0002 687 #define PCI_DEVICE_ID_NEOMAGIC_MAGICGRAPH_128ZV 0x0003 688 #define PCI_DEVICE_ID_NEOMAGIC_MAGICGRAPH_NM2160 0x0004 690 #define PCI_VENDOR_ID_ASP 0x10cd 691 #define PCI_DEVICE_ID_ASP_ABP940 0x1200 692 #define PCI_DEVICE_ID_ASP_ABP940U 0x1300 693 #define PCI_DEVICE_ID_ASP_ABP940UW 0x2300 695 #define PCI_VENDOR_ID_MACRONIX 0x10d9 696 #define PCI_DEVICE_ID_MACRONIX_MX98713 0x0512 697 #define PCI_DEVICE_ID_MACRONIX_MX987x5 0x0531 699 #define PCI_VENDOR_ID_CERN 0x10dc 700 #define PCI_DEVICE_ID_CERN_SPSB_PMC 0x0001 701 #define PCI_DEVICE_ID_CERN_SPSB_PCI 0x0002 702 #define PCI_DEVICE_ID_CERN_HIPPI_DST 0x0021 703 #define PCI_DEVICE_ID_CERN_HIPPI_SRC 0x0022 705 #define PCI_VENDOR_ID_NVIDIA 0x10de 707 #define PCI_VENDOR_ID_IMS 0x10e0 708 #define PCI_DEVICE_ID_IMS_8849 0x8849 710 #define PCI_VENDOR_ID_TEKRAM2 0x10e1 711 #define PCI_DEVICE_ID_TEKRAM2_690c 0x690c 713 #define PCI_VENDOR_ID_TUNDRA 0x10e3 714 #define PCI_DEVICE_ID_TUNDRA_CA91C042 0x0000 716 #define PCI_VENDOR_ID_AMCC 0x10e8 717 #define PCI_DEVICE_ID_AMCC_MYRINET 0x8043 718 #define PCI_DEVICE_ID_AMCC_PARASTATION 0x8062 719 #define PCI_DEVICE_ID_AMCC_S5933 0x807d 720 #define PCI_DEVICE_ID_AMCC_S5933_HEPC3 0x809c 722 #define PCI_VENDOR_ID_INTERG 0x10ea 723 #define PCI_DEVICE_ID_INTERG_1680 0x1680 724 #define PCI_DEVICE_ID_INTERG_1682 0x1682 726 #define PCI_VENDOR_ID_REALTEK 0x10ec 727 #define PCI_DEVICE_ID_REALTEK_8029 0x8029 728 #define PCI_DEVICE_ID_REALTEK_8129 0x8129 729 #define PCI_DEVICE_ID_REALTEK_8139 0x8139 731 #define PCI_VENDOR_ID_TRUEVISION 0x10fa 732 #define PCI_DEVICE_ID_TRUEVISION_T1000 0x000c 734 #define PCI_VENDOR_ID_INIT 0x1101 735 #define PCI_DEVICE_ID_INIT_320P 0x9100 736 #define PCI_DEVICE_ID_INIT_360P 0x9500 738 #define PCI_VENDOR_ID_TTI 0x1103 739 #define PCI_DEVICE_ID_TTI_HPT343 0x0003 741 #define PCI_VENDOR_ID_VIA 0x1106 742 #define PCI_DEVICE_ID_VIA_82C505 0x0505 743 #define PCI_DEVICE_ID_VIA_82C561 0x0561 744 #define PCI_DEVICE_ID_VIA_82C586_1 0x0571 745 #define PCI_DEVICE_ID_VIA_82C576 0x0576 746 #define PCI_DEVICE_ID_VIA_82C585 0x0585 747 #define PCI_DEVICE_ID_VIA_82C586_0 0x0586 748 #define PCI_DEVICE_ID_VIA_82C595 0x0595 749 #define PCI_DEVICE_ID_VIA_82C597_0 0x0597 750 #define PCI_DEVICE_ID_VIA_82C926 0x0926 751 #define PCI_DEVICE_ID_VIA_82C416 0x1571 752 #define PCI_DEVICE_ID_VIA_82C595_97 0x1595 753 #define PCI_DEVICE_ID_VIA_82C586_2 0x3038 754 #define PCI_DEVICE_ID_VIA_82C586_3 0x3040 755 #define PCI_DEVICE_ID_VIA_86C100A 0x6100 756 #define PCI_DEVICE_ID_VIA_82C597_1 0x8597 758 #define PCI_VENDOR_ID_VORTEX 0x1119 759 #define PCI_DEVICE_ID_VORTEX_GDT60x0 0x0000 760 #define PCI_DEVICE_ID_VORTEX_GDT6000B 0x0001 761 #define PCI_DEVICE_ID_VORTEX_GDT6x10 0x0002 762 #define PCI_DEVICE_ID_VORTEX_GDT6x20 0x0003 763 #define PCI_DEVICE_ID_VORTEX_GDT6530 0x0004 764 #define PCI_DEVICE_ID_VORTEX_GDT6550 0x0005 765 #define PCI_DEVICE_ID_VORTEX_GDT6x17 0x0006 766 #define PCI_DEVICE_ID_VORTEX_GDT6x27 0x0007 767 #define PCI_DEVICE_ID_VORTEX_GDT6537 0x0008 768 #define PCI_DEVICE_ID_VORTEX_GDT6557 0x0009 769 #define PCI_DEVICE_ID_VORTEX_GDT6x15 0x000a 770 #define PCI_DEVICE_ID_VORTEX_GDT6x25 0x000b 771 #define PCI_DEVICE_ID_VORTEX_GDT6535 0x000c 772 #define PCI_DEVICE_ID_VORTEX_GDT6555 0x000d 773 #define PCI_DEVICE_ID_VORTEX_GDT6x17RP 0x0100 774 #define PCI_DEVICE_ID_VORTEX_GDT6x27RP 0x0101 775 #define PCI_DEVICE_ID_VORTEX_GDT6537RP 0x0102 776 #define PCI_DEVICE_ID_VORTEX_GDT6557RP 0x0103 777 #define PCI_DEVICE_ID_VORTEX_GDT6x11RP 0x0104 778 #define PCI_DEVICE_ID_VORTEX_GDT6x21RP 0x0105 779 #define PCI_DEVICE_ID_VORTEX_GDT6x17RP1 0x0110 780 #define PCI_DEVICE_ID_VORTEX_GDT6x27RP1 0x0111 781 #define PCI_DEVICE_ID_VORTEX_GDT6537RP1 0x0112 782 #define PCI_DEVICE_ID_VORTEX_GDT6557RP1 0x0113 783 #define PCI_DEVICE_ID_VORTEX_GDT6x11RP1 0x0114 784 #define PCI_DEVICE_ID_VORTEX_GDT6x21RP1 0x0115 785 #define PCI_DEVICE_ID_VORTEX_GDT6x17RP2 0x0120 786 #define PCI_DEVICE_ID_VORTEX_GDT6x27RP2 0x0121 787 #define PCI_DEVICE_ID_VORTEX_GDT6537RP2 0x0122 788 #define PCI_DEVICE_ID_VORTEX_GDT6557RP2 0x0123 789 #define PCI_DEVICE_ID_VORTEX_GDT6x11RP2 0x0124 790 #define PCI_DEVICE_ID_VORTEX_GDT6x21RP2 0x0125 792 #define PCI_VENDOR_ID_EF 0x111a 793 #define PCI_DEVICE_ID_EF_ATM_FPGA 0x0000 794 #define PCI_DEVICE_ID_EF_ATM_ASIC 0x0002 796 #define PCI_VENDOR_ID_FORE 0x1127 797 #define PCI_DEVICE_ID_FORE_PCA200PC 0x0210 798 #define PCI_DEVICE_ID_FORE_PCA200E 0x0300 800 #define PCI_VENDOR_ID_IMAGINGTECH 0x112f 801 #define PCI_DEVICE_ID_IMAGINGTECH_ICPCI 0x0000 803 #define PCI_VENDOR_ID_PHILIPS 0x1131 804 #define PCI_DEVICE_ID_PHILIPS_SAA7145 0x7145 805 #define PCI_DEVICE_ID_PHILIPS_SAA7146 0x7146 807 #define PCI_VENDOR_ID_CYCLONE 0x113c 808 #define PCI_DEVICE_ID_CYCLONE_SDK 0x0001 810 #define PCI_VENDOR_ID_ALLIANCE 0x1142 811 #define PCI_DEVICE_ID_ALLIANCE_PROMOTIO 0x3210 812 #define PCI_DEVICE_ID_ALLIANCE_PROVIDEO 0x6422 813 #define PCI_DEVICE_ID_ALLIANCE_AT24 0x6424 814 #define PCI_DEVICE_ID_ALLIANCE_AT3D 0x643d 816 #define PCI_VENDOR_ID_SK 0x1148 817 #define PCI_DEVICE_ID_SK_FP 0x4000 818 #define PCI_DEVICE_ID_SK_TR 0x4200 819 #define PCI_DEVICE_ID_SK_GE 0x4300 821 #define PCI_VENDOR_ID_VMIC 0x114a 822 #define PCI_DEVICE_ID_VMIC_VME 0x7587 824 #define PCI_VENDOR_ID_DIGI 0x114f 825 #define PCI_DEVICE_ID_DIGI_EPC 0x0002 826 #define PCI_DEVICE_ID_DIGI_RIGHTSWITCH 0x0003 827 #define PCI_DEVICE_ID_DIGI_XEM 0x0004 828 #define PCI_DEVICE_ID_DIGI_XR 0x0005 829 #define PCI_DEVICE_ID_DIGI_CX 0x0006 830 #define PCI_DEVICE_ID_DIGI_XRJ 0x0009 831 #define PCI_DEVICE_ID_DIGI_EPCJ 0x000a 832 #define PCI_DEVICE_ID_DIGI_XR_920 0x0027 834 #define PCI_VENDOR_ID_MUTECH 0x1159 835 #define PCI_DEVICE_ID_MUTECH_MV1000 0x0001 837 #define PCI_VENDOR_ID_RENDITION 0x1163 838 #define PCI_DEVICE_ID_RENDITION_VERITE 0x0001 839 #define PCI_DEVICE_ID_RENDITION_VERITE2100 0x2000 841 #define PCI_VENDOR_ID_TOSHIBA 0x1179 842 #define PCI_DEVICE_ID_TOSHIBA_601 0x0601 843 #define PCI_DEVICE_ID_TOSHIBA_TOPIC95 0x060a 844 #define PCI_DEVICE_ID_TOSHIBA_TOPIC97 0x060f 846 #define PCI_VENDOR_ID_RICOH 0x1180 847 #define PCI_DEVICE_ID_RICOH_RL5C465 0x0465 848 #define PCI_DEVICE_ID_RICOH_RL5C466 0x0466 849 #define PCI_DEVICE_ID_RICOH_RL5C475 0x0475 850 #define PCI_DEVICE_ID_RICOH_RL5C478 0x0478 852 #define PCI_VENDOR_ID_ARTOP 0x1191 853 #define PCI_DEVICE_ID_ARTOP_ATP8400 0x0004 854 #define PCI_DEVICE_ID_ARTOP_ATP850UF 0x0005 856 #define PCI_VENDOR_ID_ZEITNET 0x1193 857 #define PCI_DEVICE_ID_ZEITNET_1221 0x0001 858 #define PCI_DEVICE_ID_ZEITNET_1225 0x0002 860 #define PCI_VENDOR_ID_OMEGA 0x119b 861 #define PCI_DEVICE_ID_OMEGA_82C092G 0x1221 863 #define PCI_VENDOR_ID_MARVELL 0x11ab 864 #define PCI_DEVICE_ID_MARVELL_GT6426xAB 0x6430 866 #define PCI_VENDOR_ID_LITEON 0x11ad 867 #define PCI_DEVICE_ID_LITEON_LNE100TX 0x0002 869 #define PCI_VENDOR_ID_NP 0x11bc 870 #define PCI_DEVICE_ID_NP_PCI_FDDI 0x0001 872 #define PCI_VENDOR_ID_ATT 0x11c1 873 #define PCI_DEVICE_ID_ATT_L56XMF 0x0440 875 #define PCI_VENDOR_ID_SPECIALIX 0x11cb 876 #define PCI_DEVICE_ID_SPECIALIX_IO8 0x2000 877 #define PCI_DEVICE_ID_SPECIALIX_XIO 0x4000 878 #define PCI_DEVICE_ID_SPECIALIX_RIO 0x8000 880 #define PCI_VENDOR_ID_AURAVISION 0x11d1 881 #define PCI_DEVICE_ID_AURAVISION_VXP524 0x01f7 883 #define PCI_VENDOR_ID_IKON 0x11d5 884 #define PCI_DEVICE_ID_IKON_10115 0x0115 885 #define PCI_DEVICE_ID_IKON_10117 0x0117 887 #define PCI_VENDOR_ID_ZORAN 0x11de 888 #define PCI_DEVICE_ID_ZORAN_36057 0x6057 889 #define PCI_DEVICE_ID_ZORAN_36120 0x6120 891 #define PCI_VENDOR_ID_KINETIC 0x11f4 892 #define PCI_DEVICE_ID_KINETIC_2915 0x2915 894 #define PCI_VENDOR_ID_COMPEX 0x11f6 895 #define PCI_DEVICE_ID_COMPEX_ENET100VG4 0x0112 896 #define PCI_DEVICE_ID_COMPEX_RL2000 0x1401 898 #define PCI_VENDOR_ID_RP 0x11fe 899 #define PCI_DEVICE_ID_RP32INTF 0x0001 900 #define PCI_DEVICE_ID_RP8INTF 0x0002 901 #define PCI_DEVICE_ID_RP16INTF 0x0003 902 #define PCI_DEVICE_ID_RP4QUAD 0x0004 903 #define PCI_DEVICE_ID_RP8OCTA 0x0005 904 #define PCI_DEVICE_ID_RP8J 0x0006 905 #define PCI_DEVICE_ID_RPP4 0x000A 906 #define PCI_DEVICE_ID_RPP8 0x000B 907 #define PCI_DEVICE_ID_RP8M 0x000C 909 #define PCI_VENDOR_ID_CYCLADES 0x120e 910 #define PCI_DEVICE_ID_CYCLOM_Y_Lo 0x0100 911 #define PCI_DEVICE_ID_CYCLOM_Y_Hi 0x0101 912 #define PCI_DEVICE_ID_CYCLOM_Z_Lo 0x0200 913 #define PCI_DEVICE_ID_CYCLOM_Z_Hi 0x0201 915 #define PCI_VENDOR_ID_ESSENTIAL 0x120f 916 #define PCI_DEVICE_ID_ESSENTIAL_ROADRUNNER 0x0001 918 #define PCI_VENDOR_ID_O2 0x1217 919 #define PCI_DEVICE_ID_O2_6729 0x6729 920 #define PCI_DEVICE_ID_O2_6730 0x673a 921 #define PCI_DEVICE_ID_O2_6832 0x6832 922 #define PCI_DEVICE_ID_O2_6836 0x6836 924 #define PCI_VENDOR_ID_3DFX 0x121a 925 #define PCI_DEVICE_ID_3DFX_VOODOO 0x0001 926 #define PCI_DEVICE_ID_3DFX_VOODOO2 0x0002 928 #define PCI_VENDOR_ID_SIGMADES 0x1236 929 #define PCI_DEVICE_ID_SIGMADES_6425 0x6401 931 #define PCI_VENDOR_ID_CCUBE 0x123f 933 #define PCI_VENDOR_ID_DIPIX 0x1246 935 #define PCI_VENDOR_ID_STALLION 0x124d 936 #define PCI_DEVICE_ID_STALLION_ECHPCI832 0x0000 937 #define PCI_DEVICE_ID_STALLION_ECHPCI864 0x0002 938 #define PCI_DEVICE_ID_STALLION_EIOPCI 0x0003 940 #define PCI_VENDOR_ID_OPTIBASE 0x1255 941 #define PCI_DEVICE_ID_OPTIBASE_FORGE 0x1110 942 #define PCI_DEVICE_ID_OPTIBASE_FUSION 0x1210 943 #define PCI_DEVICE_ID_OPTIBASE_VPLEX 0x2110 944 #define PCI_DEVICE_ID_OPTIBASE_VPLEXCC 0x2120 945 #define PCI_DEVICE_ID_OPTIBASE_VQUEST 0x2130 947 #define PCI_VENDOR_ID_SATSAGEM 0x1267 948 #define PCI_DEVICE_ID_SATSAGEM_PCR2101 0x5352 949 #define PCI_DEVICE_ID_SATSAGEM_TELSATTURBO 0x5a4b 951 #define PCI_VENDOR_ID_HUGHES 0x1273 952 #define PCI_DEVICE_ID_HUGHES_DIRECPC 0x0002 954 #define PCI_VENDOR_ID_ENSONIQ 0x1274 955 #define PCI_DEVICE_ID_ENSONIQ_AUDIOPCI 0x5000 957 #define PCI_VENDOR_ID_ALTEON 0x12ae 958 #define PCI_DEVICE_ID_ALTEON_ACENIC 0x0001 960 #define PCI_VENDOR_ID_PICTUREL 0x12c5 961 #define PCI_DEVICE_ID_PICTUREL_PCIVST 0x0081 963 #define PCI_VENDOR_ID_NVIDIA_SGS 0x12d2 964 #define PCI_DEVICE_ID_NVIDIA_SGS_RIVA128 0x0018 966 #define PCI_VENDOR_ID_CBOARDS 0x1307 967 #define PCI_DEVICE_ID_CBOARDS_DAS1602_16 0x0001 969 #define PCI_VENDOR_ID_SYMPHONY 0x1c1c 970 #define PCI_DEVICE_ID_SYMPHONY_101 0x0001 972 #define PCI_VENDOR_ID_TEKRAM 0x1de1 973 #define PCI_DEVICE_ID_TEKRAM_DC290 0xdc29 975 #define PCI_VENDOR_ID_3DLABS 0x3d3d 976 #define PCI_DEVICE_ID_3DLABS_300SX 0x0001 977 #define PCI_DEVICE_ID_3DLABS_500TX 0x0002 978 #define PCI_DEVICE_ID_3DLABS_DELTA 0x0003 979 #define PCI_DEVICE_ID_3DLABS_PERMEDIA 0x0004 980 #define PCI_DEVICE_ID_3DLABS_MX 0x0006 982 #define PCI_VENDOR_ID_AVANCE 0x4005 983 #define PCI_DEVICE_ID_AVANCE_ALG2064 0x2064 984 #define PCI_DEVICE_ID_AVANCE_2302 0x2302 986 #define PCI_VENDOR_ID_NETVIN 0x4a14 987 #define PCI_DEVICE_ID_NETVIN_NV5000SC 0x5000 989 #define PCI_VENDOR_ID_S3 0x5333 990 #define PCI_DEVICE_ID_S3_PLATO_PXS 0x0551 991 #define PCI_DEVICE_ID_S3_ViRGE 0x5631 992 #define PCI_DEVICE_ID_S3_TRIO 0x8811 993 #define PCI_DEVICE_ID_S3_AURORA64VP 0x8812 994 #define PCI_DEVICE_ID_S3_TRIO64UVP 0x8814 995 #define PCI_DEVICE_ID_S3_ViRGE_VX 0x883d 996 #define PCI_DEVICE_ID_S3_868 0x8880 997 #define PCI_DEVICE_ID_S3_928 0x88b0 998 #define PCI_DEVICE_ID_S3_864_1 0x88c0 999 #define PCI_DEVICE_ID_S3_864_2 0x88c1 1000 #define PCI_DEVICE_ID_S3_964_1 0x88d0 1001 #define PCI_DEVICE_ID_S3_964_2 0x88d1 1002 #define PCI_DEVICE_ID_S3_968 0x88f0 1003 #define PCI_DEVICE_ID_S3_TRIO64V2 0x8901 1004 #define PCI_DEVICE_ID_S3_PLATO_PXG 0x8902 1005 #define PCI_DEVICE_ID_S3_ViRGE_DXGX 0x8a01 1006 #define PCI_DEVICE_ID_S3_ViRGE_GX2 0x8a10 1007 #define PCI_DEVICE_ID_S3_ViRGE_MX 0x8c01 1008 #define PCI_DEVICE_ID_S3_ViRGE_MXP 0x8c02 1009 #define PCI_DEVICE_ID_S3_ViRGE_MXPMV 0x8c03 1010 #define PCI_DEVICE_ID_S3_SONICVIBES 0xca00 1012 #define PCI_VENDOR_ID_INTEL 0x8086 1013 #define PCI_DEVICE_ID_INTEL_82375 0x0482 1014 #define PCI_DEVICE_ID_INTEL_82424 0x0483 1015 #define PCI_DEVICE_ID_INTEL_82378 0x0484 1016 #define PCI_DEVICE_ID_INTEL_82430 0x0486 1017 #define PCI_DEVICE_ID_INTEL_82434 0x04a3 1018 #define PCI_DEVICE_ID_INTEL_82544EI_COPPER 0x1008 1019 #define PCI_DEVICE_ID_INTEL_82092AA_0 0x1221 1020 #define PCI_DEVICE_ID_INTEL_82092AA_1 0x1222 1021 #define PCI_DEVICE_ID_INTEL_7116 0x1223 1022 #define PCI_DEVICE_ID_INTEL_82596 0x1226 1023 #define PCI_DEVICE_ID_INTEL_82865 0x1227 1024 #define PCI_DEVICE_ID_INTEL_82557 0x1229 1025 #define PCI_DEVICE_ID_INTEL_82437 0x122d 1026 #define PCI_DEVICE_ID_INTEL_82371FB_0 0x122e 1027 #define PCI_DEVICE_ID_INTEL_82371FB_1 0x1230 1028 #define PCI_DEVICE_ID_INTEL_82371MX 0x1234 1029 #define PCI_DEVICE_ID_INTEL_82437MX 0x1235 1030 #define PCI_DEVICE_ID_INTEL_82441 0x1237 1031 #define PCI_DEVICE_ID_INTEL_82380FB 0x124b 1032 #define PCI_DEVICE_ID_INTEL_82439 0x1250 1033 #define PCI_DEVICE_ID_INTEL_82371SB_0 0x7000 1034 #define PCI_DEVICE_ID_INTEL_82371SB_1 0x7010 1035 #define PCI_DEVICE_ID_INTEL_82371SB_2 0x7020 1036 #define PCI_DEVICE_ID_INTEL_82437VX 0x7030 1037 #define PCI_DEVICE_ID_INTEL_82439TX 0x7100 1038 #define PCI_DEVICE_ID_INTEL_82371AB_0 0x7110 1039 #define PCI_DEVICE_ID_INTEL_82371AB 0x7111 1040 #define PCI_DEVICE_ID_INTEL_82371AB_2 0x7112 1041 #define PCI_DEVICE_ID_INTEL_82371AB_3 0x7113 1042 #define PCI_DEVICE_ID_INTEL_82443LX_0 0x7180 1043 #define PCI_DEVICE_ID_INTEL_82443LX_1 0x7181 1044 #define PCI_DEVICE_ID_INTEL_82443BX_0 0x7190 1045 #define PCI_DEVICE_ID_INTEL_82443BX_1 0x7191 1046 #define PCI_DEVICE_ID_INTEL_82443BX_2 0x7192 1047 #define PCI_DEVICE_ID_INTEL_P6 0x84c4 1048 #define PCI_DEVICE_ID_INTEL_82450GX 0x84c5 1050 #define PCI_VENDOR_ID_KTI 0x8e2e 1051 #define PCI_DEVICE_ID_KTI_ET32P2 0x3000 1053 #define PCI_VENDOR_ID_ADAPTEC 0x9004 1054 #define PCI_DEVICE_ID_ADAPTEC_7810 0x1078 1055 #define PCI_DEVICE_ID_ADAPTEC_7850 0x5078 1056 #define PCI_DEVICE_ID_ADAPTEC_7855 0x5578 1057 #define PCI_DEVICE_ID_ADAPTEC_5800 0x5800 1058 #define PCI_DEVICE_ID_ADAPTEC_1480A 0x6075 1059 #define PCI_DEVICE_ID_ADAPTEC_7860 0x6078 1060 #define PCI_DEVICE_ID_ADAPTEC_7861 0x6178 1061 #define PCI_DEVICE_ID_ADAPTEC_7870 0x7078 1062 #define PCI_DEVICE_ID_ADAPTEC_7871 0x7178 1063 #define PCI_DEVICE_ID_ADAPTEC_7872 0x7278 1064 #define PCI_DEVICE_ID_ADAPTEC_7873 0x7378 1065 #define PCI_DEVICE_ID_ADAPTEC_7874 0x7478 1066 #define PCI_DEVICE_ID_ADAPTEC_7895 0x7895 1067 #define PCI_DEVICE_ID_ADAPTEC_7880 0x8078 1068 #define PCI_DEVICE_ID_ADAPTEC_7881 0x8178 1069 #define PCI_DEVICE_ID_ADAPTEC_7882 0x8278 1070 #define PCI_DEVICE_ID_ADAPTEC_7883 0x8378 1071 #define PCI_DEVICE_ID_ADAPTEC_7884 0x8478 1072 #define PCI_DEVICE_ID_ADAPTEC_1030 0x8b78 1074 #define PCI_VENDOR_ID_ADAPTEC2 0x9005 1075 #define PCI_DEVICE_ID_ADAPTEC2_2940U2 0x0010 1076 #define PCI_DEVICE_ID_ADAPTEC2_7890 0x001f 1077 #define PCI_DEVICE_ID_ADAPTEC2_3940U2 0x0050 1078 #define PCI_DEVICE_ID_ADAPTEC2_7896 0x005f 1080 #define PCI_VENDOR_ID_ATRONICS 0x907f 1081 #define PCI_DEVICE_ID_ATRONICS_2015 0x2015 1083 #define PCI_VENDOR_ID_HOLTEK 0x9412 1084 #define PCI_DEVICE_ID_HOLTEK_6565 0x6565 1086 #define PCI_VENDOR_ID_TIGERJET 0xe159 1087 #define PCI_DEVICE_ID_TIGERJET_300 0x0001 1089 #define PCI_VENDOR_ID_ARK 0xedd8 1090 #define PCI_DEVICE_ID_ARK_STING 0xa091 1091 #define PCI_DEVICE_ID_ARK_STINGARK 0xa099 1092 #define PCI_DEVICE_ID_ARK_2000MT 0xa0a1 1101 #define PCI_DEVFN(_slot,_func) ((((_slot) & 0x1f) << 3) | ((_func) & 0x07)) 1102 #define PCI_SLOT(_devfn) (((_devfn) >> 3) & 0x1f) 1103 #define PCI_FUNC(_devfn) ((_devfn) & 0x07) 1108 #define PCIBIOS_SUCCESSFUL 0x00 1109 #define PCIBIOS_FUNC_NOT_SUPPORTED 0x81 1110 #define PCIBIOS_BAD_VENDOR_ID 0x83 1111 #define PCIBIOS_DEVICE_NOT_FOUND 0x86 1112 #define PCIBIOS_BAD_REGISTER_NUMBER 0x87 1113 #define PCIBIOS_SET_FAILED 0x88 1114 #define PCIBIOS_BUFFER_TOO_SMALL 0x89 1119 #define PCI_MAX_DEVICES 32 1120 #define PCI_MAX_FUNCTIONS 8 1123 int (*read_config_byte)(
unsigned char,
unsigned char,
unsigned char,
1124 unsigned char, uint8_t *);
1125 int (*read_config_word)(
unsigned char,
unsigned char,
unsigned char,
1126 unsigned char, uint16_t *);
1127 int (*read_config_dword)(
unsigned char,
unsigned char,
unsigned char,
1128 unsigned char, uint32_t *);
1129 int (*write_config_byte)(
unsigned char,
unsigned char,
unsigned char,
1130 unsigned char, uint8_t);
1131 int (*write_config_word)(
unsigned char,
unsigned char,
unsigned char,
1132 unsigned char, uint16_t);
1133 int (*write_config_dword)(
unsigned char,
unsigned char,
unsigned char,
1134 unsigned char, uint32_t);
1138 #define PCIB_ERR_SUCCESS (0) 1139 #define PCIB_ERR_UNINITIALIZED (-1) 1140 #define PCIB_ERR_NOTPRESENT (-2) 1141 #define PCIB_ERR_NOFUNC (-3) 1142 #define PCIB_ERR_BADVENDOR (-4) 1143 #define PCIB_ERR_DEVNOTFOUND (-5) 1144 #define PCIB_ERR_BADREG (-6) 1146 extern int pci_initialize(
void);
1149 volatile unsigned char* pci_config_addr;
1150 volatile unsigned char* pci_config_data;
1151 const pci_config_access_functions* pci_functions;
1157 pci_read_config_byte(
1160 unsigned char function,
1161 unsigned char where,
1164 return BSP_pci_configuration.pci_functions->read_config_byte(
1165 bus, slot,
function, where, val);
1169 pci_read_config_word(
1172 unsigned char function,
1173 unsigned char where,
1176 return BSP_pci_configuration.pci_functions->read_config_word(
1177 bus, slot,
1181 pci_read_config_dword(
1184 unsigned char function,
1185 unsigned char where,
1188 return BSP_pci_configuration.pci_functions->read_config_dword(bus, slot,
1192 pci_write_config_byte(
1195 unsigned char function,
1196 unsigned char where,
1199 return BSP_pci_configuration.pci_functions->write_config_byte(
1200 bus, slot,
1204 pci_write_config_word(
1207 unsigned char function,
1208 unsigned char where,
1211 return BSP_pci_configuration.pci_functions->write_config_word(
1212 bus, slot,
1216 pci_write_config_dword(
1219 unsigned char function,
1220 unsigned char where,
1223 return BSP_pci_configuration.pci_functions->write_config_dword(
1224 bus, slot,
1235 unsigned short vendorid,
1236 unsigned short deviceid,
1246 extern unsigned char pci_bus_count(
void);
