35 typedef unsigned char rtems_irq_prio;
38 typedef unsigned int rtems_irq_number;
39 typedef void *rtems_irq_hdl_param;
40 typedef void (*rtems_irq_hdl) (rtems_irq_hdl_param);
49 rtems_irq_number name;
57 rtems_irq_hdl_param handle;
76 rtems_irq_disable off;
81 rtems_irq_is_enabled isOn;
83 #ifdef BSP_SHARED_HANDLER_SUPPORT 108 rtems_irq_number irqBase;
116 rtems_irq_prio* irqPrioTbl;
176 #ifdef BSP_SHARED_HANDLER_SUPPORT 189 int BSP_rtems_int_connect(
192 rtems_irq_hdl_param p
195 int BSP_rtems_int_disconnect(
198 rtems_irq_hdl_param p
Definition: deflate.c:116
