rtems-4.11.3
libnetworking
netinet
in_systm.h
1
2
* Copyright (c) 1982, 1986, 1993
3
* The Regents of the University of California. All rights reserved.
4
5
6
* modification, are permitted provided that the following conditions
7
* are met:
8
* 1. Redistributions of source code must retain the above copyright
9
* notice, this list of conditions and the following disclaimer.
10
* 2. Redistributions in binary form must reproduce the above copyright
11
* notice, this list of conditions and the following disclaimer in the
12
* documentation and/or other materials provided with the distribution.
13
* 4. Neither the name of the University nor the names of its contributors
14
* may be used to endorse or promote products derived from this software
15
* without specific prior written permission.
16
17
* THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
18
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
19
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
20
* ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
21
* FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
22
* DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
23
* OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
24
* HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
25
* LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
26
* OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
27
* SUCH DAMAGE.
28
29
* @(#)in_systm.h 8.1 (Berkeley) 6/10/93
30
* $FreeBSD: src/sys/netinet/in_systm.h,v 1.13 2009/02/13 15:14:43 luigi Exp $
31
32
33
#ifndef _NETINET_IN_SYSTM_H_
34
#define _NETINET_IN_SYSTM_H_
35
36
37
* Miscellaneous internetwork
38
* definitions for kernel.
39
40
41
42
* Network types.
43
44
* Internally the system keeps counters in the headers with the bytes
45
* swapped so that VAX instructions will work on them. It reverses
46
* the bytes before transmission at each protocol level. The n_ types
47
* represent the types with the bytes in ``high-ender'' order.
48
49
typedef
u_int16_t n_short;
/* short as received from the net */
50
typedef
u_int32_t n_long;
/* long as received from the net */
51
52
typedef
u_int32_t n_time;
/* ms since 00:00 GMT, byte rev */
53
54
#ifdef _KERNEL
55
uint32_t iptime(
void
56
#endif
57
58
#endif
