rtems-4.11.3
libnetworking
net
if_llc.h
1
2
* Copyright (c) 1988, 1993
3
* The Regents of the University of California. All rights reserved.
4
5
6
* modification, are permitted provided that the following conditions
7
* are met:
8
* 1. Redistributions of source code must retain the above copyright
9
* notice, this list of conditions and the following disclaimer.
10
* 2. Redistributions in binary form must reproduce the above copyright
11
* notice, this list of conditions and the following disclaimer in the
12
* documentation and/or other materials provided with the distribution.
13
* 4. Neither the name of the University nor the names of its contributors
14
* may be used to endorse or promote products derived from this software
15
* without specific prior written permission.
16
17
* THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
18
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
19
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
20
* ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
21
* FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
22
* DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
23
* OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
24
* HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
25
* LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
26
* OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
27
* SUCH DAMAGE.
28
29
* @(#)if_llc.h 8.1 (Berkeley) 6/10/93
30
* $FreeBSD: src/sys/net/if_llc.h,v 1.13 2006/12/01 17:50:11 imp Exp $
31
32
33
34
#ifndef _NET_IF_LLC_H_
35
#define _NET_IF_LLC_H_
36
37
#ifndef __packed
38
#if defined(__GNUC__)
39
#define __packed __attribute__((packed))
40
#else
41
#define __packed
42
#endif
43
#endif
44
45
46
* IEEE 802.2 Link Level Control headers, for use in conjunction with
47
* 802.{3,4,5} media access control methods.
48
49
* Headers here do not use bit fields due to shortcomings in many
50
* compilers.
51
52
53
struct
llc
54
u_int8_t llc_dsap;
55
u_int8_t llc_ssap;
56
union
57
struct
58
u_int8_t control;
59
u_int8_t format_id;
60
u_int8_t
class
61
u_int8_t window_x2;
62
} __packed type_u;
63
struct
64
u_int8_t num_snd_x2;
65
u_int8_t num_rcv_x2;
66
} __packed type_i;
67
struct
68
u_int8_t control;
69
70
} __packed type_s;
71
struct
72
u_int8_t control;
73
74
* We cannot put the following fields in a structure because
75
* the structure rounding might cause padding.
76
77
u_int8_t frmr_rej_pdu0;
78
u_int8_t frmr_rej_pdu1;
79
u_int8_t frmr_control;
80
u_int8_t frmr_control_ext;
81
u_int8_t frmr_cause;
82
} __packed type_frmr;
83
struct
84
u_int8_t control;
85
u_int8_t org_code[3];
86
u_int16_t ether_type;
87
} __packed type_snap;
88
struct
89
u_int8_t control;
90
u_int8_t control_ext;
91
} __packed type_raw;
92
} __packed llc_un;
93
} __packed;
94
95
struct
frmrinfo
96
97
98
99
100
101
} __packed;
102
103
#define llc_control llc_un.type_u.control
104
#define llc_control_ext llc_un.type_raw.control_ext
105
#define llc_fid llc_un.type_u.format_id
106
#define llc_class llc_un.type_u.class
107
#define llc_window llc_un.type_u.window_x2
108
#define llc_frmrinfo llc_un.type_frmr.frmr_rej_pdu0
109
#define llc_frmr_pdu0 llc_un.type_frmr.frmr_rej_pdu0
110
#define llc_frmr_pdu1 llc_un.type_frmr.frmr_rej_pdu1
111
#define llc_frmr_control llc_un.type_frmr.frmr_control
112
#define llc_frmr_control_ext llc_un.type_frmr.frmr_control_ext
113
#define llc_frmr_cause llc_un.type_frmr.frmr_cause
114
#define llc_snap llc_un.type_snap
115
116
117
* Don't use sizeof(struct llc_un) for LLC header sizes
118
119
#define LLC_ISFRAMELEN 4
120
#define LLC_UFRAMELEN 3
121
#define LLC_FRMRLEN 7
122
#define LLC_SNAPFRAMELEN 8
123
124
125
* Unnumbered LLC format commands
126
127
#define LLC_UI 0x3
128
#define LLC_UI_P 0x13
129
#define LLC_DISC 0x43
130
#define LLC_DISC_P 0x53
131
#define LLC_UA 0x63
132
#define LLC_UA_P 0x73
133
#define LLC_TEST 0xe3
134
#define LLC_TEST_P 0xf3
135
#define LLC_FRMR 0x87
136
#define LLC_FRMR_P 0x97
137
#define LLC_DM 0x0f
138
#define LLC_DM_P 0x1f
139
#define LLC_XID 0xaf
140
#define LLC_XID_P 0xbf
141
#define LLC_SABME 0x6f
142
#define LLC_SABME_P 0x7f
143
144
145
* Supervisory LLC commands
146
147
#define LLC_RR 0x01
148
#define LLC_RNR 0x05
149
#define LLC_REJ 0x09
150
151
152
* Info format - dummy only
153
154
#define LLC_INFO 0x00
155
156
157
* ISO PDTR 10178 contains among others
158
159
#define LLC_X25_LSAP 0x7e
160
#define LLC_SNAP_LSAP 0xaa
161
#define LLC_ISO_LSAP 0xfe
162
163
#endif
/* _NET_IF_LLC_H_ */
frmrinfo
Definition:
if_llc.h:96
llc
Definition:
if_llc.h:54
