rtems-4.11.3
libdl
include
arch
i386
machine
elf_machdep.h
1
/* $NetBSD: elf_machdep.h,v 1.10 2009/05/30 05:56:52 skrll Exp $ */
2
3
#define ELF32_MACHDEP_ENDIANNESS ELFDATA2LSB
4
#define ELF32_MACHDEP_ID_CASES \
5
case EM_386: \
6
case EM_486: \
7
break;
8
9
#define ELF64_MACHDEP_ENDIANNESS XXX
/* break compilation */
10
#define ELF64_MACHDEP_ID_CASES \
11
/* no 64-bit ELF machine types supported */
12
13
#define ELF32_MACHDEP_ID EM_386
14
15
#define ARCH_ELFSIZE 32
/* MD native binary size */
16
17
/* i386 relocations */
18
#define R_386_NONE 0
19
#define R_386_32 1
20
#define R_386_PC32 2
21
#define R_386_GOT32 3
22
#define R_386_PLT32 4
23
#define R_386_COPY 5
24
#define R_386_GLOB_DAT 6
25
#define R_386_JMP_SLOT 7
26
#define R_386_RELATIVE 8
27
#define R_386_GOTOFF 9
28
#define R_386_GOTPC 10
29
30
/* TLS relocations */
31
#define R_386_TLS_TPOFF 14
32
#define R_386_TLS_IE 15
33
#define R_386_TLS_GOTIE 16
34
#define R_386_TLS_LE 17
35
#define R_386_TLS_GD 18
36
#define R_386_TLS_LDM 19
37
38
/* The following relocations are GNU extensions. */
39
#define R_386_16 20
40
#define R_386_PC16 21
41
#define R_386_8 22
42
#define R_386_PC8 23
43
44
/* More TLS relocations */
45
#define R_386_TLS_GD_32 24
46
#define R_386_TLS_GD_PUSH 25
47
#define R_386_TLS_GD_CALL 26
48
#define R_386_TLS_GD_POP 27
49
#define R_386_TLS_LDM_32 28
50
#define R_386_TLS_LDM_PUSH 29
51
#define R_386_TLS_LDM_CALL 30
52
#define R_386_TLS_LDM_POP 31
53
#define R_386_TLS_LDO_32 32
54
#define R_386_TLS_IE_32 33
55
#define R_386_TLS_LE_32 34
56
#define R_386_TLS_DTPMOD32 35
57
#define R_386_TLS_DTPOFF32 36
58
#define R_386_TLS_TPOFF32 37
59
#define R_386_TLS_GOTDESC 39
60
#define R_386_TLS_DESC_CALL 40
61
#define R_386_TLS_DESC 41
62
63
#define R_TYPE(name) __CONCAT(R_386_,name)
