RTEMS Port of Linux I2C Device API. More...
#include <stdint.h>
| struct | i2c_smbus_ioctl_data |
| Argument type for I2C_SMBUS IO control call. More... | |
| struct | i2c_rdwr_ioctl_data |
| Argument type for I2C_RDWR IO control call. More... | |
| #define | I2C_RDRW_IOCTL_MAX_MSGS 42 |
| Maximum count of messages for one IO control call. | |
I2C IO Control Commands | |
| #define | I2C_RETRIES 0x701 |
| Sets the count of transfer retries in case a slave device does not acknowledge a transaction. More... | |
| #define | I2C_TIMEOUT 0x702 |
| Sets the transfer timeout in 10ms units. More... | |
| #define | I2C_SLAVE 0x703 |
| Sets the slave address. More... | |
| #define | I2C_SLAVE_FORCE 0x706 |
| Forces setting the slave address. More... | |
| #define | I2C_TENBIT 0x704 |
| Enables 10-bit addresses if argument is non-zero, otherwise disables 10-bit addresses. More... | |
| #define | I2C_FUNCS 0x705 |
| Gets the I2C controller functionality information. More... | |
| #define | I2C_RDWR 0x707 |
| Performs a combined read/write transfer. More... | |
| #define | I2C_PEC 0x708 |
| Enables System Management Bus (SMBus) Packet Error Checking (PEC) if argument is non-zero, otherwise disables PEC. More... | |
| #define | I2C_SMBUS 0x720 |
| Performs an SMBus transfer. More... | |
