ATtiny12 Definitions
#define _AVR_IOXXX_H_   "iotn12.h"
#define ACSR   _SFR_IO8(0x08)
#define PINB   _SFR_IO8(0x16)
#define DDRB   _SFR_IO8(0x17)
#define PORTB   _SFR_IO8(0x18)
#define EECR   _SFR_IO8(0x1C)
#define EEDR   _SFR_IO8(0x1D)
#define EEAR   _SFR_IO8(0x1E)
#define EEARL   _SFR_IO8(0x1E)
#define WDTCR   _SFR_IO8(0x21)
#define OSCCAL   _SFR_IO8(0x31)
#define TCNT0   _SFR_IO8(0x32)
#define TCCR0   _SFR_IO8(0x33)
#define MCUSR   _SFR_IO8(0x34)
#define MCUCR   _SFR_IO8(0x35)
#define TIFR   _SFR_IO8(0x38)
#define TIMSK   _SFR_IO8(0x39)
#define GIFR   _SFR_IO8(0x3A)
#define GIMSK   _SFR_IO8(0x3B)
#define INT0_vect   _VECTOR(1)
#define SIG_INTERRUPT0   _VECTOR(1)
#define IO_PINS_vect   _VECTOR(2)
#define SIG_PIN   _VECTOR(2)
#define SIG_PIN_CHANGE   _VECTOR(2)
#define TIMER0_OVF_vect   _VECTOR(3)
#define SIG_OVERFLOW0   _VECTOR(3)
#define EE_RDY_vect   _VECTOR(4)
#define SIG_EEPROM_READY   _VECTOR(4)
#define ANA_COMP_vect   _VECTOR(5)
#define SIG_COMPARATOR   _VECTOR(5)
#define _VECTORS_SIZE   12
#define INT0   6
#define PCIE   5
#define INTF0   6
#define PCIF   5
#define TOIE0   1
#define TOV0   1
#define PUD   6
#define SE   5
#define SM   4
#define ISC01   1
#define ISC00   0
#define CS02   2
#define CS01   1
#define CS00   0
#define WDTOE   4
#define WDE   3
#define WDP2   2
#define WDP1   1
#define WDP0   0
#define PB4   4
#define PB3   3
#define PB2   2
#define PB1   1
#define PB0   0
#define DDB5   5
#define DDB4   4
#define DDB3   3
#define DDB2   2
#define DDB1   1
#define DDB0   0
#define PINB5   5
#define PINB4   4
#define PINB3   3
#define PINB2   2
#define PINB1   1
#define PINB0   0
#define ACD   7
#define AINBG   6
#define ACO   5
#define ACI   4
#define ACIE   3
#define ACIS1   1
#define ACIS0   0
#define EERIE   3
#define EEMWE   2
#define EEWE   1
#define EERE   0
#define RAMEND   0x1F
#define XRAMEND   0x0
#define E2END   0x3F
#define E2PAGESIZE   2
#define FLASHEND   0x3FF
#define FUSE_MEMORY_SIZE   1
#define FUSE_CKSEL0   (unsigned char)~_BV(0)
#define FUSE_CKSEL1   (unsigned char)~_BV(1)
#define FUSE_CKSEL2   (unsigned char)~_BV(2)
#define FUSE_CKSEL3   (unsigned char)~_BV(3)
#define FUSE_RSTDISBL   (unsigned char)~_BV(4)
#define FUSE_SPIEN   (unsigned char)~_BV(5)
#define FUSE_BODEN   (unsigned char)~_BV(6)
#define FUSE_BODLEVEL   (unsigned char)~_BV(7)
#define FUSE_DEFAULT   (FUSE_CKSEL0 & FUSE_CKSEL2 & FUSE_CKSEL3 & FUSE_SPIEN & FUSE_BODLEVEL)
#define __LOCK_BITS_EXIST
#define SIGNATURE_0   0x1E
#define SIGNATURE_1   0x90
#define SIGNATURE_2   0x05
