ATmega161 Definitions
#define _AVR_IOXXX_H_   "iom161.h"
#define UBRR1   _SFR_IO8(0x00)
#define UCSR1B   _SFR_IO8(0x01)
#define UCSR1A   _SFR_IO8(0x02)
#define UDR1   _SFR_IO8(0x03)
#define PINE   _SFR_IO8(0x05)
#define DDRE   _SFR_IO8(0x06)
#define PORTE   _SFR_IO8(0x07)
#define ACSR   _SFR_IO8(0x08)
#define UBRR0   _SFR_IO8(0x09)
#define UCSR0B   _SFR_IO8(0x0A)
#define UCSR0A   _SFR_IO8(0x0B)
#define UDR0   _SFR_IO8(0x0C)
#define SPCR   _SFR_IO8(0x0D)
#define SPSR   _SFR_IO8(0x0E)
#define SPDR   _SFR_IO8(0x0F)
#define PIND   _SFR_IO8(0x10)
#define DDRD   _SFR_IO8(0x11)
#define PORTD   _SFR_IO8(0x12)
#define PINC   _SFR_IO8(0x13)
#define DDRC   _SFR_IO8(0x14)
#define PORTC   _SFR_IO8(0x15)
#define PINB   _SFR_IO8(0x16)
#define DDRB   _SFR_IO8(0x17)
#define PORTB   _SFR_IO8(0x18)
#define PINA   _SFR_IO8(0x19)
#define DDRA   _SFR_IO8(0x1A)
#define PORTA   _SFR_IO8(0x1B)
#define EECR   _SFR_IO8(0x1C)
#define EEDR   _SFR_IO8(0x1D)
#define EEAR   _SFR_IO16(0x1E)
#define EEARL   _SFR_IO8(0x1E)
#define EEARH   _SFR_IO8(0x1F)
#define UBRRH   _SFR_IO8(0x20)
#define WDTCR   _SFR_IO8(0x21)
#define OCR2   _SFR_IO8(0x22)
#define TCNT2   _SFR_IO8(0x23)
#define ICR1   _SFR_IO16(0x24)
#define ICR1L   _SFR_IO8(0x24)
#define ICR1H   _SFR_IO8(0x25)
#define ASSR   _SFR_IO8(0x26)
#define TCCR2   _SFR_IO8(0x27)
#define OCR1B   _SFR_IO16(0x28)
#define OCR1BL   _SFR_IO8(0x28)
#define OCR1BH   _SFR_IO8(0x29)
#define OCR1A   _SFR_IO16(0x2A)
#define OCR1AL   _SFR_IO8(0x2A)
#define OCR1AH   _SFR_IO8(0x2B)
#define TCNT1   _SFR_IO16(0x2C)
#define TCNT1L   _SFR_IO8(0x2C)
#define TCNT1H   _SFR_IO8(0x2D)
#define TCCR1B   _SFR_IO8(0x2E)
#define TCCR1A   _SFR_IO8(0x2F)
#define SFIOR   _SFR_IO8(0x30)
#define OCR0   _SFR_IO8(0x31)
#define TCNT0   _SFR_IO8(0x32)
#define TCCR0   _SFR_IO8(0x33)
#define MCUSR   _SFR_IO8(0x34)
#define MCUCR   _SFR_IO8(0x35)
#define EMCUCR   _SFR_IO8(0x36)
#define SPMCR   _SFR_IO8(0x37)
#define TIFR   _SFR_IO8(0x38)
#define TIMSK   _SFR_IO8(0x39)
#define GIFR   _SFR_IO8(0x3A)
#define GIMSK   _SFR_IO8(0x3B)
#define INT0_vect   _VECTOR(1)
#define SIG_INTERRUPT0   _VECTOR(1)
#define INT1_vect   _VECTOR(2)
#define SIG_INTERRUPT1   _VECTOR(2)
#define INT2_vect   _VECTOR(3)
#define SIG_INTERRUPT2   _VECTOR(3)
#define TIMER2_COMP_vect   _VECTOR(4)
#define SIG_OUTPUT_COMPARE2   _VECTOR(4)
#define TIMER2_OVF_vect   _VECTOR(5)
#define SIG_OVERFLOW2   _VECTOR(5)
#define TIMER1_CAPT_vect   _VECTOR(6)
#define SIG_INPUT_CAPTURE1   _VECTOR(6)
#define TIMER1_COMPA_vect   _VECTOR(7)
#define SIG_OUTPUT_COMPARE1A   _VECTOR(7)
#define TIMER1_COMPB_vect   _VECTOR(8)
#define SIG_OUTPUT_COMPARE1B   _VECTOR(8)
#define TIMER1_OVF_vect   _VECTOR(9)
#define SIG_OVERFLOW1   _VECTOR(9)
#define TIMER0_COMP_vect   _VECTOR(10)
#define SIG_OUTPUT_COMPARE0   _VECTOR(10)
#define TIMER0_OVF_vect   _VECTOR(11)
#define SIG_OVERFLOW0   _VECTOR(11)
#define SPI_STC_vect   _VECTOR(12)
#define SIG_SPI   _VECTOR(12)
#define UART0_RX_vect   _VECTOR(13)
#define SIG_UART0_RECV   _VECTOR(13)
#define UART1_RX_vect   _VECTOR(14)
#define SIG_UART1_RECV   _VECTOR(14)
#define UART0_UDRE_vect   _VECTOR(15)
#define SIG_UART0_DATA   _VECTOR(15)
#define UART1_UDRE_vect   _VECTOR(16)
#define SIG_UART1_DATA   _VECTOR(16)
#define UART0_TX_vect   _VECTOR(17)
#define SIG_UART0_TRANS   _VECTOR(17)
#define UART1_TX_vect   _VECTOR(18)
#define SIG_UART1_TRANS   _VECTOR(18)
#define EE_RDY_vect   _VECTOR(19)
#define SIG_EEPROM_READY   _VECTOR(19)
#define ANA_COMP_vect   _VECTOR(20)
#define SIG_COMPARATOR   _VECTOR(20)
#define _VECTORS_SIZE   84
#define INT1   7
#define INT0   6
#define INT2   5
#define INTF1   7
#define INTF0   6
#define INTF2   5
#define TOIE1   7
#define OCIE1A   6
#define OCIE1B   5
#define TOIE2   4
#define TICIE1   3
#define OCIE2   2
#define TOIE0   1
#define OCIE0   0
#define TOV1   7
#define OCF1A   6
#define OCF1B   5
#define TOV2   4
#define ICF1   3
#define OCF2   2
#define TOV0   1
#define OCF0   0
#define SRE   7
#define SRW10   6
#define SE   5
#define SM1   4
#define ISC11   3
#define ISC10   2
#define ISC01   1
#define ISC00   0
#define SM0   7
#define SRL2   6
#define SRL1   5
#define SRL0   4
#define SRW01   3
#define SRW00   2
#define SRW11   1
#define ISC2   0
#define BLBSET   3
#define PGWRT   2
#define PGERS   1
#define SPMEN   0
#define PSR2   1
#define PSR10   0
#define FOC0   7
#define PWM0   6
#define COM01   5
#define COM00   4
#define CTC0   3
#define CS02   2
#define CS01   1
#define CS00   0
#define FOC2   7
#define PWM2   6
#define COM21   5
#define COM20   4
#define CTC2   3
#define CS22   2
#define CS21   1
#define CS20   0
#define AS2   3
#define TCN2UB   2
#define OCR2UB   1
#define TCR2UB   0
#define COM1A1   7
#define COM1A0   6
#define COM1B1   5
#define COM1B0   4
#define FOC1A   3
#define FOC1B   2
#define PWM11   1
#define PWM10   0
#define ICNC1   7
#define ICES1   6
#define CTC1   3
#define CS12   2
#define CS11   1
#define CS10   0
#define WDTOE   4
#define WDE   3
#define WDP2   2
#define WDP1   1
#define WDP0   0
#define PA7   7
#define PA6   6
#define PA5   5
#define PA4   4
#define PA3   3
#define PA2   2
#define PA1   1
#define PA0   0
#define DDA7   7
#define DDA6   6
#define DDA5   5
#define DDA4   4
#define DDA3   3
#define DDA2   2
#define DDA1   1
#define DDA0   0
#define PINA7   7
#define PINA6   6
#define PINA5   5
#define PINA4   4
#define PINA3   3
#define PINA2   2
#define PINA1   1
#define PINA0   0
#define PB7   7
#define PB6   6
#define PB5   5
#define PB4   4
#define PB3   3
#define PB2   2
#define PB1   1
#define PB0   0
#define DDB7   7
#define DDB6   6
#define DDB5   5
#define DDB4   4
#define DDB3   3
#define DDB2   2
#define DDB1   1
#define DDB0   0
#define PINB7   7
#define PINB6   6
#define PINB5   5
#define PINB4   4
#define PINB3   3
#define PINB2   2
#define PINB1   1
#define PINB0   0
#define PC7   7
#define PC6   6
#define PC5   5
#define PC4   4
#define PC3   3
#define PC2   2
#define PC1   1
#define PC0   0
#define DDC7   7
#define DDC6   6
#define DDC5   5
#define DDC4   4
#define DDC3   3
#define DDC2   2
#define DDC1   1
#define DDC0   0
#define PINC7   7
#define PINC6   6
#define PINC5   5
#define PINC4   4
#define PINC3   3
#define PINC2   2
#define PINC1   1
#define PINC0   0
#define PD7   7
#define PD6   6
#define PD5   5
#define PD4   4
#define PD3   3
#define PD2   2
#define PD1   1
#define PD0   0
#define DDD7   7
#define DDD6   6
#define DDD5   5
#define DDD4   4
#define DDD3   3
#define DDD2   2
#define DDD1   1
#define DDD0   0
#define PIND7   7
#define PIND6   6
#define PIND5   5
#define PIND4   4
#define PIND3   3
#define PIND2   2
#define PIND1   1
#define PIND0   0
#define PE2   2
#define PE1   1
#define PE0   0
#define DDE2   2
#define DDE1   1
#define DDE0   0
#define PINE2   2
#define PINE1   1
#define PINE0   0
#define SPIF   7
#define WCOL   6
#define SPI2X   0
#define SPIE   7
#define SPE   6
#define DORD   5
#define MSTR   4
#define CPOL   3
#define CPHA   2
#define SPR1   1
#define SPR0   0
#define RXC   7
#define TXC   6
#define UDRE   5
#define FE   4
#define DOR   3
#define U2X   1
#define MPCM   0
#define RXCIE   7
#define TXCIE   6
#define UDRIE   5
#define RXEN   4
#define TXEN   3
#define CHR9   2
#define RXB8   1
#define TXB8   0
#define ACD   7
#define AINBG   6
#define ACO   5
#define ACI   4
#define ACIE   3
#define ACIC   2
#define ACIS1   1
#define ACIS0   0
#define EERIE   3
#define EEMWE   2
#define EEWE   1
#define EERE   0
#define SPM_PAGESIZE   128
#define RAMEND   0x45F
#define XRAMEND   0xFFFF
#define E2END   0x1FF
#define E2PAGESIZE   0
#define FLASHEND   0x3FFF
#define FUSE_MEMORY_SIZE   1
#define FUSE_CKSEL0   (unsigned char)~_BV(0)
#define FUSE_CKSEL1   (unsigned char)~_BV(1)
#define FUSE_CKSEL2   (unsigned char)~_BV(2)
#define FUSE_SUT   (unsigned char)~_BV(4)
#define FUSE_SPIEN   (unsigned char)~_BV(5)
#define FUSE_BOOTRST   (unsigned char)~_BV(6)
#define FUSE_DEFAULT   (FUSE_CKSEL0 & FUSE_CKSEL2 & FUSE_SPIEN)
#define __LOCK_BITS_EXIST
#define __BOOT_LOCK_BITS_0_EXIST
#define __BOOT_LOCK_BITS_1_EXIST
#define SIGNATURE_0   0x1E
#define SIGNATURE_1   0x94
#define SIGNATURE_2   0x01
