AT90S4434 Definitions
#define _AVR_IOXXX_H_   "io4434.h"
#define ADC   _SFR_IO16(0x04)
#define ADCW   _SFR_IO16(0x04)
#define ADCL   _SFR_IO8(0x04)
#define ADCH   _SFR_IO8(0x05)
#define ADCSR   _SFR_IO8(0x06)
#define ADMUX   _SFR_IO8(0x07)
#define ACSR   _SFR_IO8(0x08)
#define UBRR   _SFR_IO8(0x09)
#define UCR   _SFR_IO8(0x0A)
#define USR   _SFR_IO8(0x0B)
#define UDR   _SFR_IO8(0x0C)
#define SPCR   _SFR_IO8(0x0D)
#define SPSR   _SFR_IO8(0x0E)
#define SPDR   _SFR_IO8(0x0F)
#define PIND   _SFR_IO8(0x10)
#define DDRD   _SFR_IO8(0x11)
#define PORTD   _SFR_IO8(0x12)
#define PINC   _SFR_IO8(0x13)
#define DDRC   _SFR_IO8(0x14)
#define PORTC   _SFR_IO8(0x15)
#define PINB   _SFR_IO8(0x16)
#define DDRB   _SFR_IO8(0x17)
#define PORTB   _SFR_IO8(0x18)
#define PINA   _SFR_IO8(0x19)
#define DDRA   _SFR_IO8(0x1A)
#define PORTA   _SFR_IO8(0x1B)
#define EECR   _SFR_IO8(0x1C)
#define EEDR   _SFR_IO8(0x1D)
#define EEAR   _SFR_IO8(0x1E)
#define EEARL   _SFR_IO8(0x1E)
#define WDTCR   _SFR_IO8(0x21)
#define ASSR   _SFR_IO8(0x22)
#define OCR2   _SFR_IO8(0x23)
#define TCNT2   _SFR_IO8(0x24)
#define TCCR2   _SFR_IO8(0x25)
#define ICR1   _SFR_IO16(0x26)
#define ICR1L   _SFR_IO8(0x26)
#define ICR1H   _SFR_IO8(0x27)
#define OCR1B   _SFR_IO16(0x28)
#define OCR1BL   _SFR_IO8(0x28)
#define OCR1BH   _SFR_IO8(0x29)
#define OCR1A   _SFR_IO16(0x2A)
#define OCR1AL   _SFR_IO8(0x2A)
#define OCR1AH   _SFR_IO8(0x2B)
#define TCNT1   _SFR_IO16(0x2C)
#define TCNT1L   _SFR_IO8(0x2C)
#define TCNT1H   _SFR_IO8(0x2D)
#define TCCR1B   _SFR_IO8(0x2E)
#define TCCR1A   _SFR_IO8(0x2F)
#define TCNT0   _SFR_IO8(0x32)
#define TCCR0   _SFR_IO8(0x33)
#define MCUSR   _SFR_IO8(0x34)
#define MCUCR   _SFR_IO8(0x35)
#define TIFR   _SFR_IO8(0x38)
#define TIMSK   _SFR_IO8(0x39)
#define GIFR   _SFR_IO8(0x3A)
#define GIMSK   _SFR_IO8(0x3B)
#define INT0_vect   _VECTOR(1)
#define SIG_INTERRUPT0   _VECTOR(1)
#define INT1_vect   _VECTOR(2)
#define SIG_INTERRUPT1   _VECTOR(2)
#define TIMER2_COMP_vect   _VECTOR(3)
#define SIG_OUTPUT_COMPARE2   _VECTOR(3)
#define TIMER2_OVF_vect   _VECTOR(4)
#define SIG_OVERFLOW2   _VECTOR(4)
#define TIMER1_CAPT_vect   _VECTOR(5)
#define SIG_INPUT_CAPTURE1   _VECTOR(5)
#define TIMER1_COMPA_vect   _VECTOR(6)
#define SIG_OUTPUT_COMPARE1A   _VECTOR(6)
#define TIMER1_COMPB_vect   _VECTOR(7)
#define SIG_OUTPUT_COMPARE1B   _VECTOR(7)
#define TIMER1_OVF_vect   _VECTOR(8)
#define SIG_OVERFLOW1   _VECTOR(8)
#define TIMER0_OVF_vect   _VECTOR(9)
#define SIG_OVERFLOW0   _VECTOR(9)
#define SPI_STC_vect   _VECTOR(10)
#define SIG_SPI   _VECTOR(10)
#define UART_RX_vect   _VECTOR(11)
#define SIG_UART_RECV   _VECTOR(11)
#define UART_UDRE_vect   _VECTOR(12)
#define SIG_UART_DATA   _VECTOR(12)
#define UART_TX_vect   _VECTOR(13)
#define SIG_UART_TRANS   _VECTOR(13)
#define ADC_vect   _VECTOR(14)
#define SIG_ADC   _VECTOR(14)
#define EE_RDY_vect   _VECTOR(15)
#define SIG_EEPROM_READY   _VECTOR(15)
#define ANA_COMP_vect   _VECTOR(16)
#define SIG_COMPARATOR   _VECTOR(16)
#define _VECTORS_SIZE   34
#define EXTRF   1
#define PORF   0
#define INT1   7
#define INT0   6
#define INTF1   7
#define INTF0   6
#define OCIE2   7
#define TOIE2   6
#define TICIE1   5
#define OCIE1A   4
#define OCIE1B   3
#define TOIE1   2
#define TOIE0   0
#define OCF2   7
#define TOV2   6
#define ICF1   5
#define OCF1A   4
#define OCF1B   3
#define TOV1   2
#define TOV0   0
#define SE   6
#define SM1   5
#define SM0   4
#define ISC11   3
#define ISC10   2
#define ISC01   1
#define ISC00   0
#define CS02   2
#define CS01   1
#define CS00   0
#define COM1A1   7
#define COM1A0   6
#define COM1B1   5
#define COM1B0   4
#define PWM11   1
#define PWM10   0
#define ICNC1   7
#define ICES1   6
#define CTC1   3
#define CS12   2
#define CS11   1
#define CS10   0
#define PWM2   6
#define COM21   5
#define COM20   4
#define CTC2   3
#define CS22   2
#define CS21   1
#define CS20   0
#define AS2   3
#define TCN2UB   2
#define OCR2UB   1
#define TCR2UB   0
#define WDTOE   4
#define WDE   3
#define WDP2   2
#define WDP1   1
#define WDP0   0
#define PA7   7
#define PA6   6
#define PA5   5
#define PA4   4
#define PA3   3
#define PA2   2
#define PA1   1
#define PA0   0
#define DDA7   7
#define DDA6   6
#define DDA5   5
#define DDA4   4
#define DDA3   3
#define DDA2   2
#define DDA1   1
#define DDA0   0
#define PINA7   7
#define PINA6   6
#define PINA5   5
#define PINA4   4
#define PINA3   3
#define PINA2   2
#define PINA1   1
#define PINA0   0
#define PB7   7
#define PB6   6
#define PB5   5
#define PB4   4
#define PB3   3
#define PB2   2
#define PB1   1
#define PB0   0
#define DDB7   7
#define DDB6   6
#define DDB5   5
#define DDB4   4
#define DDB3   3
#define DDB2   2
#define DDB1   1
#define DDB0   0
#define PINB7   7
#define PINB6   6
#define PINB5   5
#define PINB4   4
#define PINB3   3
#define PINB2   2
#define PINB1   1
#define PINB0   0
#define PC7   7
#define PC6   6
#define PC5   5
#define PC4   4
#define PC3   3
#define PC2   2
#define PC1   1
#define PC0   0
#define DDC7   7
#define DDC6   6
#define DDC5   5
#define DDC4   4
#define DDC3   3
#define DDC2   2
#define DDC1   1
#define DDC0   0
#define PINC7   7
#define PINC6   6
#define PINC5   5
#define PINC4   4
#define PINC3   3
#define PINC2   2
#define PINC1   1
#define PINC0   0
#define PD7   7
#define PD6   6
#define PD5   5
#define PD4   4
#define PD3   3
#define PD2   2
#define PD1   1
#define PD0   0
#define DDD7   7
#define DDD6   6
#define DDD5   5
#define DDD4   4
#define DDD3   3
#define DDD2   2
#define DDD1   1
#define DDD0   0
#define PIND7   7
#define PIND6   6
#define PIND5   5
#define PIND4   4
#define PIND3   3
#define PIND2   2
#define PIND1   1
#define PIND0   0
#define SPIE   7
#define SPE   6
#define DORD   5
#define MSTR   4
#define CPOL   3
#define CPHA   2
#define SPR1   1
#define SPR0   0
#define SPIF   7
#define WCOL   6
#define RXC   7
#define TXC   6
#define UDRE   5
#define FE   4
#define DOR   3
#define RXCIE   7
#define TXCIE   6
#define UDRIE   5
#define RXEN   4
#define TXEN   3
#define CHR9   2
#define RXB8   1
#define TXB8   0
#define ACD   7
#define ACO   5
#define ACI   4
#define ACIE   3
#define ACIC   2
#define ACIS1   1
#define ACIS0   0
#define MUX2   2
#define MUX1   1
#define MUX0   0
#define ADEN   7
#define ADSC   6
#define ADFR   5
#define ADIF   4
#define ADIE   3
#define ADPS2   2
#define ADPS1   1
#define ADPS0   0
#define EERIE   3
#define EEMWE   2
#define EEWE   1
#define EERE   0
#define RAMEND   0x15F /*Last On-Chip SRAM location*/
#define XRAMEND   RAMEND
#define E2END   0xFF
#define E2PAGESIZE   0
#define FLASHEND   0xFFF
#define FUSE_MEMORY_SIZE   1
#define FUSE_SPIEN   ~_BV(1) /* Serial Program Downloading Enabled */
#define FUSE_FSTRT   ~_BV(2) /* Short Start-up time selected */
#define LFUSE_DEFAULT   (0xFF)
#define __LOCK_BITS_EXIST
#define SIGNATURE_0   0x1E
#define SIGNATURE_1   0x93
#define SIGNATURE_2   0x03
#define DIDR   _SFR_IO8(0x001)
#define AIN0D   0
#define AIN1D   1
#define UBRRH   _SFR_IO8(0x002)
#define UBRR8   0
#define UBRR9   1
#define UBRR10   2
#define UBRR11   3
#define UCSRC   _SFR_IO8(0x003)
#define UCPOL   0
#define UCSZ0   1
#define UCSZ1   2
#define USBS   3
#define UPM0   4
#define UPM1   5
#define UMSEL   6
#define PCMSK1   _SFR_IO8(0x004)
#define PCINT8   0
#define PCINT9   1
#define PCINT10   2
#define PCMSK2   _SFR_IO8(0x005)
#define PCINT11   0
#define PCINT12   1
#define PCINT13   2
#define PCINT14   3
#define PCINT15   4
#define PCINT16   5
#define PCINT17   6
#define PRR   _SFR_IO8(0x006)
#define PRUSART   0
#define PRUSI   1
#define PRTIM0   2
#define PRTIM1   3
#define BODCR   _SFR_IO8(0x007)
#define BPDSE   0
#define BPDS   1
#define ACSR   _SFR_IO8(0x008)
#define ACIS0   0
#define ACIS1   1
#define ACIC   2
#define ACIE   3
#define ACI   4
#define ACO   5
#define ACBG   6
#define ACD   7
#define UBRRL   _SFR_IO8(0x009)
#define UBRR0   0
#define UBRR1   1
#define UBRR2   2
#define UBRR3   3
#define UBRR4   4
#define UBRR5   5
#define UBRR6   6
#define UBRR7   7
#define UCSRB   _SFR_IO8(0x00A)
#define TXB8   0
#define RXB8   1
#define UCSZ2   2
#define TXEN   3
#define RXEN   4
#define UDRIE   5
#define TXCIE   6
#define RXCIE   7
#define UCSRA   _SFR_IO8(0x00B)
#define MPCM   0
#define U2X   1
#define UPE   2
#define DOR   3
#define FE   4
#define UDRE   5
#define TXC   6
#define RXC   7
#define UDR   _SFR_IO8(0x00C)
#define UDR0   0
#define UDR1   1
#define UDR2   2
#define UDR3   3
#define UDR4   4
#define UDR5   5
#define UDR6   6
#define UDR7   7
#define USICR   _SFR_IO8(0x00D)
#define USITC   0
#define USICLK   1
#define USICS0   2
#define USICS1   3
#define USIWM0   4
#define USIWM1   5
#define USIOIE   6
#define USISIE   7
#define USISR   _SFR_IO8(0x00E)
#define USICNT0   0
#define USICNT1   1
#define USICNT2   2
#define USICNT3   3
#define USIDC   4
#define USIPF   5
#define USIOIF   6
#define USISIF   7
#define USIDR   _SFR_IO8(0x00F)
#define USIDR0   0
#define USIDR1   1
#define USIDR2   2
#define USIDR3   3
#define USIDR4   4
#define USIDR5   5
#define USIDR6   6
#define USIDR7   7
#define PIND   _SFR_IO8(0x010)
#define PIND0   0
#define PIND1   1
#define PIND2   2
#define PIND3   3
#define PIND4   4
#define PIND5   5
#define PIND6   6
#define DDRD   _SFR_IO8(0x011)
#define DDD0   0
#define DDD1   1
#define DDD2   2
#define DDD3   3
#define DDD4   4
#define DDD5   5
#define DDD6   6
#define PORTD   _SFR_IO8(0x012)
#define PORTD0   0
#define PORTD1   1
#define PORTD2   2
#define PORTD3   3
#define PORTD4   4
#define PORTD5   5
#define PORTD6   6
#define GPIOR0   _SFR_IO8(0x013)
#define GPIOR00   0
#define GPIOR01   1
#define GPIOR02   2
#define GPIOR03   3
#define GPIOR04   4
#define GPIOR05   5
#define GPIOR06   6
#define GPIOR07   7
#define GPIOR1   _SFR_IO8(0x014)
#define GPIOR10   0
#define GPIOR11   1
#define GPIOR12   2
#define GPIOR13   3
#define GPIOR14   4
#define GPIOR15   5
#define GPIOR16   6
#define GPIOR17   7
#define GPIOR2   _SFR_IO8(0x015)
#define GPIOR20   0
#define GPIOR21   1
#define GPIOR22   2
#define GPIOR23   3
#define GPIOR24   4
#define GPIOR25   5
#define GPIOR26   6
#define GPIOR27   7
#define PINB   _SFR_IO8(0x016)
#define PINB0   0
#define PINB1   1
#define PINB2   2
#define PINB3   3
#define PINB4   4
#define PINB5   5
#define PINB6   6
#define PINB7   7
#define DDRB   _SFR_IO8(0x017)
#define DDB0   0
#define DDB1   1
#define DDB2   2
#define DDB3   3
#define DDB4   4
#define DDB5   5
#define DDB6   6
#define DDB7   7
#define PORTB   _SFR_IO8(0x018)
#define PORTB0   0
#define PORTB1   1
#define PORTB2   2
#define PORTB3   3
#define PORTB4   4
#define PORTB5   5
#define PORTB6   6
#define PORTB7   7
#define PINA   _SFR_IO8(0x019)
#define PINA0   0
#define PINA1   1
#define PINA2   2
#define DDRA   _SFR_IO8(0x01A)
#define DDA0   0
#define DDA1   1
#define DDA2   2
#define PORTA   _SFR_IO8(0x01B)
#define PORTA0   0
#define PORTA1   1
#define PORTA2   2
#define EECR   _SFR_IO8(0x01C)
#define EERE   0
#define EEPE   1
#define EEMPE   2
#define EERIE   3
#define EEPM0   4
#define EEPM1   5
#define EEDR   _SFR_IO8(0x01D)
#define EEDR0   0
#define EEDR1   1
#define EEDR2   2
#define EEDR3   3
#define EEDR4   4
#define EEDR5   5
#define EEDR6   6
#define EEDR7   7
#define EEAR   _SFR_IO8(0x01E)
#define EEAR0   0
#define EEAR1   1
#define EEAR2   2
#define EEAR3   3
#define EEAR4   4
#define EEAR5   5
#define EEAR6   6
#define PCMSK   _SFR_IO8(0x020)
#define PCINT0   0
#define PCINT1   1
#define PCINT2   2
#define PCINT3   3
#define PCINT4   4
#define PCINT5   5
#define PCINT6   6
#define PCINT7   7
#define WDTCR   _SFR_IO8(0x021)
#define WDP0   0
#define WDP1   1
#define WDP2   2
#define WDE   3
#define WDCE   4
#define WDP3   5
#define WDIE   6
#define WDIF   7
#define TCCR1C   _SFR_IO8(0x022)
#define FOC1B   6
#define FOC1A   7
#define GTCCR   _SFR_IO8(0x023)
#define PSR10   0
#define ICR1   _SFR_IO16(0x024)
#define ICR1L   _SFR_IO8(0x024)
#define ICR1L0   0
#define ICR1L1   1
#define ICR1L2   2
#define ICR1L3   3
#define ICR1L4   4
#define ICR1L5   5
#define ICR1L6   6
#define ICR1L7   7
#define ICR1H   _SFR_IO8(0x025)
#define ICR1H0   0
#define ICR1H1   1
#define ICR1H2   2
#define ICR1H3   3
#define ICR1H4   4
#define ICR1H5   5
#define ICR1H6   6
#define ICR1H7   7
#define CLKPR   _SFR_IO8(0x026)
#define CLKPS0   0
#define CLKPS1   1
#define CLKPS2   2
#define CLKPS3   3
#define CLKPCE   7
#define OCR1B   _SFR_IO16(0x028)
#define OCR1BL   _SFR_IO8(0x028)
#define OCR1BL0   0
#define OCR1BL1   1
#define OCR1BL2   2
#define OCR1BL3   3
#define OCR1BL4   4
#define OCR1BL5   5
#define OCR1BL6   6
#define OCR1BL7   7
#define OCR1BH   _SFR_IO8(0x029)
#define OCR1BH0   0
#define OCR1BH1   1
#define OCR1BH2   2
#define OCR1BH3   3
#define OCR1BH4   4
#define OCR1BH5   5
#define OCR1BH6   6
#define OCR1BH7   7
#define OCR1A   _SFR_IO16(0x02A)
#define OCR1AL   _SFR_IO8(0x02A)
#define OCR1AL0   0
#define OCR1AL1   1
#define OCR1AL2   2
#define OCR1AL3   3
#define OCR1AL4   4
#define OCR1AL5   5
#define OCR1AL6   6
#define OCR1AL7   7
#define OCR1AH   _SFR_IO8(0x02B)
#define OCR1AH0   0
#define OCR1AH1   1
#define OCR1AH2   2
#define OCR1AH3   3
#define OCR1AH4   4
#define OCR1AH5   5
#define OCR1AH6   6
#define OCR1AH7   7
#define TCNT1   _SFR_IO16(0x02C)
#define TCNT1L   _SFR_IO8(0x02C)
#define TCNT1L0   0
#define TCNT1L1   1
#define TCNT1L2   2
#define TCNT1L3   3
#define TCNT1L4   4
#define TCNT1L5   5
#define TCNT1L6   6
#define TCNT1L7   7
#define TCNT1H   _SFR_IO8(0x02D)
#define TCNT1H0   0
#define TCNT1H1   1
#define TCNT1H2   2
#define TCNT1H3   3
#define TCNT1H4   4
#define TCNT1H5   5
#define TCNT1H6   6
#define TCNT1H7   7
#define TCCR1B   _SFR_IO8(0x02E)
#define CS10   0
#define CS11   1
#define CS12   2
#define WGM12   3
#define WGM13   4
#define ICES1   6
#define ICNC1   7
#define TCCR1A   _SFR_IO8(0x02F)
#define WGM10   0
#define WGM11   1
#define COM1B0   4
#define COM1B1   5
#define COM1A0   6
#define COM1A1   7
#define TCCR0A   _SFR_IO8(0x030)
#define WGM00   0
#define WGM01   1
#define COM0B0   4
#define COM0B1   5
#define COM0A0   6
#define COM0A1   7
#define OSCCAL   _SFR_IO8(0x031)
#define CAL0   0
#define CAL1   1
#define CAL2   2
#define CAL3   3
#define CAL4   4
#define CAL5   5
#define CAL6   6
#define TCNT0   _SFR_IO8(0x032)
#define TCNT0_0   0
#define TCNT0_1   1
#define TCNT0_2   2
#define TCNT0_3   3
#define TCNT0_4   4
#define TCNT0_5   5
#define TCNT0_6   6
#define TCNT0_7   7
#define TCCR0B   _SFR_IO8(0x033)
#define CS00   0
#define CS01   1
#define CS02   2
#define WGM02   3
#define FOC0B   6
#define FOC0A   7
#define MCUSR   _SFR_IO8(0x034)
#define PORF   0
#define EXTRF   1
#define BORF   2
#define WDRF   3
#define MCUCR   _SFR_IO8(0x035)
#define ISC00   0
#define ISC01   1
#define ISC10   2
#define ISC11   3
#define SM0   4
#define SE   5
#define SM1   6
#define PUD   7
#define OCR0A   _SFR_IO8(0x036)
#define OCR0A_0   0
#define OCR0A_1   1
#define OCR0A_2   2
#define OCR0A_3   3
#define OCR0A_4   4
#define OCR0A_5   5
#define OCR0A_6   6
#define OCR0A_7   7
#define SPMCSR   _SFR_IO8(0x037)
#define SPMEN   0
#define PGERS   1
#define PGWRT   2
#define RFLB   3
#define CTPB   4
#define TIFR   _SFR_IO8(0x038)
#define OCF0A   0
#define TOV0   1
#define OCF0B   2
#define ICF1   3
#define OCF1B   5
#define OCF1A   6
#define TOV1   7
#define TIMSK   _SFR_IO8(0x039)
#define OCIE0A   0
#define TOIE0   1
#define OCIE0B   2
#define ICIE1   3
#define OCIE1B   5
#define OCIE1A   6
#define TOIE1   7
#define EIFR   _SFR_IO8(0x03A)
#define PCIF   5
#define INTF0   6
#define INTF1   7
#define GIMSK   _SFR_IO8(0x03B)
#define PCIE   5
#define INT0   6
#define INT1   7
#define OCR0B   _SFR_IO8(0x03C)
#define OCR0_0   0
#define OCR0_1   1
#define OCR0_2   2
#define OCR0_3   3
#define OCR0_4   4
#define OCR0_5   5
#define OCR0_6   6
#define OCR0_7   7
#define INT0_vect_num   1
#define INT0_vect   _VECTOR(1) /* External Interrupt Request 0 */
#define INT1_vect_num   2
#define INT1_vect   _VECTOR(2) /* External Interrupt Request 1 */
#define TIMER1_CAPT_vect_num   3
#define TIMER1_CAPT_vect   _VECTOR(3) /* Timer/Counter1 Capture Event */
#define TIMER1_COMPA_vect_num   4
#define TIMER1_COMPA_vect   _VECTOR(4) /* Timer/Counter1 Compare Match A */
#define TIMER1_OVF_vect_num   5
#define TIMER1_OVF_vect   _VECTOR(5) /* Timer/Counter1 Overflow */
#define TIMER0_OVF_vect_num   6
#define TIMER0_OVF_vect   _VECTOR(6) /* Timer/Counter0 Overflow */
#define USART_RX_vect_num   7
#define USART_RX_vect   _VECTOR(7) /* USART, Rx Complete */
#define USART_UDRE_vect_num   8
#define USART_UDRE_vect   _VECTOR(8) /* USART Data Register Empty */
#define USART_TX_vect_num   9
#define USART_TX_vect   _VECTOR(9) /* USART, Tx Complete */
#define ANA_COMP_vect_num   10
#define ANA_COMP_vect   _VECTOR(10) /* Analog Comparator */
#define PCINT_B_vect_num   11
#define PCINT_B_vect   _VECTOR(11) /* Pin Change Interrupt Request B */
#define TIMER1_COMPB_vect_num   12
#define TIMER1_COMPB_vect   _VECTOR(12) /* */
#define TIMER0_COMPA_vect_num   13
#define TIMER0_COMPA_vect   _VECTOR(13) /* */
#define TIMER0_COMPB_vect_num   14
#define TIMER0_COMPB_vect   _VECTOR(14) /* */
#define USI_START_vect_num   15
#define USI_START_vect   _VECTOR(15) /* USI Start Condition */
#define USI_OVERFLOW_vect_num   16
#define USI_OVERFLOW_vect   _VECTOR(16) /* USI Overflow */
#define WDT_OVERFLOW_vect_num   18
#define WDT_OVERFLOW_vect   _VECTOR(18) /* Watchdog Timer Overflow */
#define PCINT_D_vect_num   20
#define PCINT_D_vect   _VECTOR(20) /* Pin Change Interrupt Request D */
#define EEPROM_Ready_vect_num   17
#define EEPROM_Ready_vect   _VECTOR(17) /* */
#define PCINT_A_vect_num   19
#define PCINT_A_vect   _VECTOR(19) /* Pin Change Interrupt Request A */
#define _VECTOR_SIZE   2 /* Size of individual vector. */
#define _VECTORS_SIZE   (21 * _VECTOR_SIZE)
#define SPM_PAGESIZE   (32)
#define RAMSTART   (0x60)
#define RAMSIZE   (128)
#define RAMEND   (RAMSTART + RAMSIZE - 1)
#define XRAMSTART   (NA)
#define XRAMSIZE   (0)
#define XRAMEND   (RAMEND)
#define E2END   (0x7F)
#define E2PAGESIZE   (4)
#define FLASHEND   (0x7FF)
#define FUSE_MEMORY_SIZE   3
#define FUSE_CKSEL0   (unsigned char)~_BV(0) /* Select Clock Source */
#define FUSE_CKSEL1   (unsigned char)~_BV(1) /* Select Clock Source */
#define FUSE_CKSEL2   (unsigned char)~_BV(2) /* Select Clock Source */
#define FUSE_CKSEL3   (unsigned char)~_BV(3) /* Select Clock Source */
#define FUSE_SUT0   (unsigned char)~_BV(4) /* Select start-up time */
#define FUSE_SUT1   (unsigned char)~_BV(5) /* Select start-up time */
#define FUSE_CKOUT   (unsigned char)~_BV(6) /* Clock output */
#define FUSE_CKDIV8   (unsigned char)~_BV(7) /* Divide clock by 8 */
#define LFUSE_DEFAULT   (FUSE_CKDIV8 & FUSE_SUT0 & FUSE_CKSEL3 & FUSE_CKSEL2 & FUSE_CKSEL0)
#define FUSE_BODLEVEL0   (unsigned char)~_BV(0) /* Brown-out Detector trigger level */
#define FUSE_BODLEVEL1   (unsigned char)~_BV(1) /* Brown-out Detector trigger level */
#define FUSE_BODLEVEL2   (unsigned char)~_BV(2) /* Brown-out Detector trigger level */
#define FUSE_EESAVE   (unsigned char)~_BV(3) /* EEPROM memory is preserved through chip erase */
#define FUSE_WDTON   (unsigned char)~_BV(4) /* Watchdog Timer Always On */
#define FUSE_SPIEN   (unsigned char)~_BV(5) /* Enable Serial programming and Data Downloading */
#define FUSE_DWEN   (unsigned char)~_BV(6) /* debugWIRE Enable */
#define FUSE_RSTDISBL   (unsigned char)~_BV(7) /* External reset disable */
#define HFUSE_DEFAULT   (FUSE_SPIEN)
#define FUSE_SELFPRGEN   (unsigned char)~_BV(0) /* Self Programming Enable */
#define EFUSE_DEFAULT   (0xFF)
#define SIGNATURE_1   0x91
#define SIGNATURE_2   0x0A
#define RXD_DDR   DDRD
#define RXD_PORT   PORTD
#define RXD_PIN   PIND
#define RXD_BIT   0
#define TXD_DDR   DDRD
#define TXD_PORT   PORTD
#define TXD_PIN   PIND
#define TXD_BIT   1
#define PA1_DDR   DDRXTAL
#define PA1_PORT   PORTXTAL
#define PA1_PIN   PINXTAL
#define PA1_BIT   XTAL2
#define PA0_DDR   DDRXTAL
#define PA0_PORT   PORTXTAL
#define PA0_PIN   PINXTAL
#define PA0_BIT   XTAL1
#define INT0_DDR   DDRD
#define INT0_PORT   PORTD
#define INT0_PIN   PIND
#define INT0_BIT   2
#define XCK_DDR   DDRD
#define XCK_PORT   PORTD
#define XCK_PIN   PIND
#define XCK_BIT   2
#define CKOUT_DDR   DDRD
#define CKOUT_PORT   PORTD
#define CKOUT_PIN   PIND
#define CKOUT_BIT   2
#define INT1_DDR   DDRD
#define INT1_PORT   PORTD
#define INT1_PIN   PIND
#define INT1_BIT   3
#define T0_DDR   DDRD
#define T0_PORT   PORTD
#define T0_PIN   PIND
#define T0_BIT   4
#define T1_DDR   DDRD
#define T1_PORT   PORTD
#define T1_PIN   PIND
#define T1_BIT   5
#define OC0B_DDR   DDRD
#define OC0B_PORT   PORTD
#define OC0B_PIN   PIND
#define OC0B_BIT   5
#define ICP_DDR   DDRD
#define ICP_PORT   PORTD
#define ICP_PIN   PIND
#define ICP_BIT   6
#define AIN0_DDR   DDRB
#define AIN0_PORT   PORTB
#define AIN0_PIN   PINB
#define AIN0_BIT   0
#define AIN1_DDR   DDRB
#define AIN1_PORT   PORTB
#define AIN1_PIN   PINB
#define AIN1_BIT   1
#define OC0A_DDR   DDRB
#define OC0A_PORT   PORTB
#define OC0A_PIN   PINB
#define OC0A_BIT   2
#define OC1A_DDR   DDRB
#define OC1A_PORT   PORTB
#define OC1A_PIN   PINB
#define OC1A_BIT   3
#define OC1B_DDR   DDRB
#define OC1B_PORT   PORTB
#define OC1B_PIN   PINB
#define OC1B_BIT   4
#define MOSI_DDR   DDRB
#define MOSI_PORT   PORTB
#define MOSI_PIN   PINB
#define MOSI_BIT   5
#define DI_DDR   DDRB
#define DI_PORT   PORTB
#define DI_PIN   PINB
#define DI_BIT   5
#define MISO_DDR   DDRB
#define MISO_PORT   PORTB
#define MISO_PIN   PINB
#define MISO_BIT   6
#define DO_DDR   DDRB
#define DO_PORT   PORTB
#define DO_PIN   PINB
#define DO_BIT   6
#define SCK_DDR   DDRB
#define SCK_PORT   PORTB
#define SCK_PIN   PINB
#define SCK_BIT   7
#define SCL_DDR   DDRB
#define SCL_PORT   PORTB
#define SCL_PIN   PINB
#define SCL_BIT   7
