#define | OSCCAL _SFR_IO8(0x00) |
#define | WDTCR _SFR_IO8(0x01) |
#define | MODCR _SFR_IO8(0x02) |
#define | TCNT0 _SFR_IO8(0x03) |
#define | TCCR0 _SFR_IO8(0x04) |
#define | IFR _SFR_IO8(0x05) |
#define | ICR _SFR_IO8(0x06) |
#define | MCUCS _SFR_IO8(0x07) |
#define | ACSR _SFR_IO8(0x08) |
#define | PIND _SFR_IO8(0x10) |
#define | DDRD _SFR_IO8(0x11) |
#define | PORTD _SFR_IO8(0x12) |
#define | PINB _SFR_IO8(0x16) |
#define | PINA _SFR_IO8(0x19) |
#define | PACR _SFR_IO8(0x1A) |
#define | PORTA _SFR_IO8(0x1B) |
#define | INT0_vect _VECTOR(1) |
#define | SIG_INTERRUPT0 _VECTOR(1) |
#define | INT1_vect _VECTOR(2) |
#define | SIG_INTERRUPT1 _VECTOR(2) |
#define | LOWLEVEL_IO_PINS_vect _VECTOR(3) |
#define | SIG_PIN _VECTOR(3) |
#define | TIMER0_OVF_vect _VECTOR(4) |
#define | SIG_OVERFLOW0 _VECTOR(4) |
#define | ANA_COMP_vect _VECTOR(5) |
#define | SIG_COMPARATOR _VECTOR(5) |
#define | _VECTORS_SIZE 12 |
#define | INT1 7 |
#define | INT0 6 |
#define | LLIE 5 |
#define | TOIE0 4 |
#define | ISC11 3 |
#define | ISC10 2 |
#define | ISC01 1 |
#define | ISC00 |
#define | INTF1 7 |
#define | INTF0 6 |
#define | TOV0 4 |
#define | PLUPB 7 |
#define | SE 5 |
#define | SM 4 |
#define | WDRF 3 |
#define | EXTRF 1 |
#define | PORF 0 |
#define | FOV0 7 |
#define | OOM01 4 |
#define | OOM00 3 |
#define | CS02 2 |
#define | CS01 1 |
#define | CS00 0 |
#define | ONTIM4 7 |
#define | ONTIM3 6 |
#define | ONTIM2 5 |
#define | ONTIM1 4 |
#define | ONTIM0 3 |
#define | MCONF2 2 |
#define | MCONF1 1 |
#define | MCONF0 0 |
#define | WDTOE 4 |
#define | WDE 3 |
#define | WDP2 2 |
#define | WDP1 1 |
#define | WDP0 0 |
#define | PA3 3 |
#define | PA2 2 |
#define | PA1 1 |
#define | PA0 0 |
#define | DDA3 3 |
#define | PA2HC 2 |
#define | DDA1 1 |
#define | DDA0 0 |
#define | PINA3 3 |
#define | PINA1 1 |
#define | PINA0 0 |
#define | PINB7 7 |
#define | PINB6 6 |
#define | PINB5 5 |
#define | PINB4 4 |
#define | PINB3 3 |
#define | PINB2 2 |
#define | PINB1 1 |
#define | PINB0 0 |
#define | PD7 7 |
#define | PD6 6 |
#define | PD5 5 |
#define | PD4 4 |
#define | PD3 3 |
#define | PD2 2 |
#define | PD1 1 |
#define | PD0 0 |
#define | DDD7 7 |
#define | DDD6 6 |
#define | DDD5 5 |
#define | DDD4 4 |
#define | DDD3 3 |
#define | DDD2 2 |
#define | DDD1 1 |
#define | DDD0 0 |
#define | PIND7 7 |
#define | PIND6 6 |
#define | PIND5 5 |
#define | PIND4 4 |
#define | PIND3 3 |
#define | PIND2 2 |
#define | PIND1 1 |
#define | PIND0 0 |
#define | ACD 7 |
#define | ACO 5 |
#define | ACI 4 |
#define | ACIE 3 |
#define | ACIS1 1 |
#define | ACIS0 0 |
#define | RAMEND 0x1F |
#define | XRAMEND 0x0 |
#define | E2END 0x0 |
#define | E2PAGESIZE 0 |
#define | FLASHEND 0x7FF |
#define | FUSE_MEMORY_SIZE 1 |
#define | FUSE_CKSEL0 (unsigned char)~_BV(0) |
#define | FUSE_CKSEL1 (unsigned char)~_BV(1) |
#define | FUSE_CKSEL2 (unsigned char)~_BV(2) |
#define | FUSE_CKSEL3 (unsigned char)~_BV(3) |
#define | FUSE_INTCAP (unsigned char)~_BV(4) |
#define | FUSE_DEFAULT (FUSE_CKSEL0 & FUSE_CKSEL2 & FUSE_CKSEL3) |
#define | __LOCK_BITS_EXIST |
#define | SIGNATURE_0 0x1E |
#define | SIGNATURE_1 0x91 |
#define | SIGNATURE_2 0x07 |
