AT90PWM216 Definitions
#define PINB   _SFR_IO8(0x03)
#define PINB0   0
#define PINB1   1
#define PINB2   2
#define PINB3   3
#define PINB4   4
#define PINB5   5
#define PINB6   6
#define PINB7   7
#define DDRB   _SFR_IO8(0x04)
#define DDB0   0
#define DDB1   1
#define DDB2   2
#define DDB3   3
#define DDB4   4
#define DDB5   5
#define DDB6   6
#define DDB7   7
#define PORTB   _SFR_IO8(0x05)
#define PB0   0
#define PB1   1
#define PB2   2
#define PB3   3
#define PB4   4
#define PB5   5
#define PB6   6
#define PB7   7
#define PINC   _SFR_IO8(0x06)
#define PINC0   0
#define PINC1   1
#define PINC2   2
#define PINC3   3
#define PINC4   4
#define PINC5   5
#define PINC6   6
#define PINC7   7
#define DDRC   _SFR_IO8(0x07)
#define DDC0   0
#define DDC1   1
#define DDC2   2
#define DDC3   3
#define DDC4   4
#define DDC5   5
#define DDC6   6
#define DDC7   7
#define PORTC   _SFR_IO8(0x08)
#define PC0   0
#define PC1   1
#define PC2   2
#define PC3   3
#define PC4   4
#define PC5   5
#define PC6   6
#define PC7   7
#define PIND   _SFR_IO8(0x09)
#define PIND0   0
#define PIND1   1
#define PIND2   2
#define PIND3   3
#define PIND4   4
#define PIND5   5
#define PIND6   6
#define PIND7   7
#define DDRD   _SFR_IO8(0x0A)
#define DDD0   0
#define DDD1   1
#define DDD2   2
#define DDD3   3
#define DDD4   4
#define DDD5   5
#define DDD6   6
#define DDD7   7
#define PORTD   _SFR_IO8(0x0B)
#define PD0   0
#define PD1   1
#define PD2   2
#define PD3   3
#define PD4   4
#define PD5   5
#define PD6   6
#define PD7   7
#define PINE   _SFR_IO8(0x0C)
#define PINE0   0
#define PINE1   1
#define PINE2   2
#define DDRE   _SFR_IO8(0x0D)
#define DDE0   0
#define DDE1   1
#define DDE2   2
#define PORTE   _SFR_IO8(0x0E)
#define PE0   0
#define PE1   1
#define PE2   2
#define TIFR0   _SFR_IO8(0x15)
#define TOV0   0 /* Overflow Flag */
#define OCF0A   1 /* Output Compare Flag 0A */
#define OCF0B   2 /* Output Compare Flag 0B */
#define TIFR1   _SFR_IO8(0x16)
#define TOV1   0 /* Overflow Flag */
#define OCF1A   1 /* Output Compare Flag 1A*/
#define OCF1B   2 /* Output Compare Flag 1B*/
#define ICF1   5 /* Input Capture Flag 1 */
#define GPIOR1   _SFR_IO8(0x19)
#define GPIOR10   0
#define GPIOR11   1
#define GPIOR12   2
#define GPIOR13   3
#define GPIOR14   4
#define GPIOR15   5
#define GPIOR16   6
#define GPIOR17   7
#define GPIOR2   _SFR_IO8(0x1A)
#define GPIOR20   0
#define GPIOR21   1
#define GPIOR22   2
#define GPIOR23   3
#define GPIOR24   4
#define GPIOR25   5
#define GPIOR26   6
#define GPIOR27   7
#define GPIOR3   _SFR_IO8(0x1B)
#define GPIOR30   0
#define GPIOR31   1
#define GPIOR32   2
#define GPIOR33   3
#define GPIOR34   4
#define GPIOR35   5
#define GPIOR36   6
#define GPIOR37   7
#define EIFR   _SFR_IO8(0x1C)
#define INTF0   0
#define INTF1   1
#define INTF2   2
#define INTF3   3
#define EIMSK   _SFR_IO8(0x1D)
#define INT0   0 /* External Interrupt Request 0 Enable */
#define INT1   1 /* External Interrupt Request 1 Enable */
#define INT2   2 /* External Interrupt Request 2 Enable */
#define INT3   3 /* External Interrupt Request 3 Enable */
#define GPIOR0   _SFR_IO8(0x1E)
#define GPIOR00   0
#define GPIOR01   1
#define GPIOR02   2
#define GPIOR03   3
#define GPIOR04   4
#define GPIOR05   5
#define GPIOR06   6
#define GPIOR07   7
#define EECR   _SFR_IO8(0x1F)
#define EERE   0 /* EEPROM Read Enable */
#define EEWE   1 /* EEPROM Write Enable */
#define EEMWE   2 /* EEPROM Master Write Enable */
#define EERIE   3 /* EEPROM Ready Interrupt Enable */
#define EEDR   _SFR_IO8(0x20)
#define EEDR0   0
#define EEDR1   1
#define EEDR2   2
#define EEDR3   3
#define EEDR4   4
#define EEDR5   5
#define EEDR6   6
#define EEDR7   7
#define EEAR   _SFR_IO16(0x21)
#define EEARL   _SFR_IO8(0x21)
#define EEAR0   0
#define EEAR1   1
#define EEAR2   2
#define EEAR3   3
#define EEAR4   4
#define EEAR5   5
#define EEAR6   6
#define EEAR7   7
#define EEARH   _SFR_IO8(0x22)
#define EEAR8   0
#define EEAR9   1
#define EEAR10   2
#define EEAR11   3
#define __EEPROM_REG_LOCATIONS__   1F2021
#define GTCCR   _SFR_IO8(0x23)
#define PSR10   0 /* Prescaler Reset Timer/Counter1 and Timer/Counter0 */
#define ICPSEL1   6 /* Timer1 Input Capture Selection Bit */
#define TSM   7 /* Timer/Counter Synchronization Mode */
#define TCCR0A   _SFR_IO8(0x24)
#define WGM00   0 /* Waveform Generation Mode */
#define WGM01   1 /* Waveform Generation Mode */
#define COM0B0   4 /* Compare Output Mode, Fast PWm */
#define COM0B1   5 /* Compare Output Mode, Fast PWm */
#define COM0A0   6 /* Compare Output Mode, Phase Correct PWM Mode */
#define COM0A1   7 /* Compare Output Mode, Phase Correct PWM Mode */
#define TCCR0B   _SFR_IO8(0x25)
#define CS00   0 /* Clock Select */
#define CS01   1 /* Clock Select */
#define CS02   2 /* Clock Select */
#define WGM02   3 /* Waveform Generation Mode */
#define FOC0B   6 /* Force Output Compare B */
#define FOC0A   7 /* Force Output Compare A */
#define TCNT0   _SFR_IO8(0x26)
#define TCNT00   0
#define TCNT01   1
#define TCNT02   2
#define TCNT03   3
#define TCNT04   4
#define TCNT05   5
#define TCNT06   6
#define TCNT07   7
#define OCR0A   _SFR_IO8(0x27)
#define OCR0A0   0
#define OCR0A1   1
#define OCR0A2   2
#define OCR0A3   3
#define OCR0A4   4
#define OCR0A5   5
#define OCR0A6   6
#define OCR0A7   7
#define OCR0B   _SFR_IO8(0x28)
#define OCR0B0   0
#define OCR0B1   1
#define OCR0B2   2
#define OCR0B3   3
#define OCR0B4   4
#define OCR0B5   5
#define OCR0B6   6
#define OCR0B7   7
#define PLLCSR   _SFR_IO8(0x29)
#define PLOCK   0 /* PLL Lock Detector */
#define PLLE   1 /* PLL Enable */
#define PLLF   2 /* PLL Factor */
#define SPCR   _SFR_IO8(0x2C)
#define SPR0   0 /* SPI Clock Rate Select 0 */
#define SPR1   1 /* SPI Clock Rate Select 1 */
#define CPHA   2 /* Clock Phase */
#define CPOL   3 /* Clock polarity */
#define MSTR   4 /* Master/Slave Select */
#define DORD   5 /* Data Order */
#define SPE   6 /* SPI Enable */
#define SPIE   7 /* SPI Interrupt Enable */
#define SPSR   _SFR_IO8(0x2D)
#define SPI2X   0 /* Double SPI Speed Bit */
#define WCOL   6 /* Write Collision Flag */
#define SPIF   7 /* SPI Interrupt Flag */
#define SPDR   _SFR_IO8(0x2E)
#define SPD0   0
#define SPD1   1
#define SPD2   2
#define SPD3   3
#define SPD4   4
#define SPD5   5
#define SPD6   6
#define SPD7   7
#define ACSR   _SFR_IO8(0x30)
#define AC0O   0 /* Analog Comparator 0 Output Bit */
#define AC1O   1 /* Analog Comparator 1 Output Bit */
#define AC2O   2 /* Analog Comparator 2 Output Bit */
#define AC0IF   4 /* Analog Comparator 0 Interrupt Flag Bit */
#define AC1IF   5 /* Analog Comparator 1 Interrupt Flag Bit */
#define AC2IF   6 /* Analog Comparator 2 Interrupt Flag Bit */
#define ACCKDIV   7 /* Analog Comparator Clock Divider */
#define SMCR   _SFR_IO8(0x33)
#define SE   0 /* Sleep Enable */
#define SM0   1 /* Sleep Mode Select bit0 */
#define SM1   2 /* Sleep Mode Select bit1 */
#define SM2   3 /* Sleep Mode Select bit2 */
#define MCUSR   _SFR_IO8(0x34)
#define PORF   0 /* Power-on reset flag */
#define EXTRF   1 /* External Reset Flag */
#define BORF   2 /* Brown-out Reset Flag */
#define WDRF   3 /* Watchdog Reset Flag */
#define MCUCR   _SFR_IO8(0x35)
#define IVCE   0 /* Interrupt Vector Change Enable */
#define IVSEL   1 /* Interrupt Vector Select */
#define PUD   4 /* Pull-up disable */
#define SPIPS   7 /* SPI Pin Select */
#define SPMCSR   _SFR_IO8(0x37)
#define SPMEN   0 /* Store Program Memory Enable */
#define PGERS   1 /* Page Erase */
#define PGWRT   2 /* Page Write */
#define BLBSET   3 /* Boot Lock Bit Set */
#define RWWSRE   4 /* Read While Write section read enable */
#define RWWSB   6 /* Read While Write Section Busy */
#define SPMIE   7 /* SPM Interrupt Enable */
#define WDTCSR   _SFR_MEM8(0x60)
#define WDP0   0 /* Watchdog Timer Prescaler bit0 */
#define WDP1   1 /* Watchdog Timer Prescaler bit1 */
#define WDP2   2 /* Watchdog Timer Prescaler bit2 */
#define WDE   3 /* Watchdog Enable */
#define WDCE   4 /* Watchdog Change Enable */
#define WDP3   5 /* Watchdog Timer Prescaler bit3 */
#define WDIE   6 /* Watchdog Timeout Interrupt Enable */
#define WDIF   7 /* Watchdog Timeout Interrupt Flag */
#define CLKPR   _SFR_MEM8(0x61)
#define CLKPS0   0 /* Clock Prescaler Select bit0 */
#define CLKPS1   1 /* Clock Prescaler Select bit1 */
#define CLKPS2   2 /* Clock Prescaler Select bit2 */
#define CLKPS3   3 /* Clock Prescaler Select bit3 */
#define CLKPCE   7 /* Clock Prescaler Change Enable */
#define PRR   _SFR_MEM8(0x64)
#define PRADC   0 /* Power Reduction ADC */
#define PRUSART   1 /* Power Reduction USART */
#define PRSPI   2 /* Power Reduction Serial Peripheral Interface */
#define PRTIM0   3 /* Power Reduction Timer/Counter0 */
#define PRTIM1   4 /* Power Reduction Timer/Counter1 */
#define PRPSC0   5 /* Power Reduction PSC0 */
#define PRPSC1   6 /* Power Reduction PSC1 */
#define PRPSC2   7 /* Power Reduction PSC2 */
#define OSCCAL   _SFR_MEM8(0x66)
#define CAL0   0
#define CAL1   1
#define CAL2   2
#define CAL3   3
#define CAL4   4
#define CAL5   5
#define CAL6   6
#define EICRA   _SFR_MEM8(0x69)
#define ISC00   0
#define ISC01   1
#define ISC10   2
#define ISC11   3
#define ISC20   4
#define ISC21   5
#define ISC30   6
#define ISC31   7
#define TIMSK0   _SFR_MEM8(0x6E)
#define TOIE0   0 /* Overflow Interrupt Enable */
#define OCIE0A   1 /* Output Compare Match A Interrupt Enable */
#define OCIE0B   2 /* Output Compare Match B Interrupt Enable */
#define TIMSK1   _SFR_MEM8(0x6F)
#define TOIE1   0 /* Overflow Interrupt Enable */
#define OCIE1A   1 /* Output Compare Match A Interrupt Enable */
#define OCIE1B   2 /* Output Compare Match B Interrupt Enable */
#define ICIE1   5 /* Input Capture Interrupt Enable */
#define AMP0CSR   _SFR_MEM8(0x76)
#define AMP0TS0   0
#define AMP0TS1   1
#define AMP0G0   4
#define AMP0G1   5
#define AMP0IS   6
#define AMP0EN   7
#define AMP1CSR   _SFR_MEM8(0x77)
#define AMP1TS0   0
#define AMP1TS1   1
#define AMP1G0   4
#define AMP1G1   5
#define AMP1IS   6
#define AMP1EN   7
#define ADC   _SFR_MEM16(0x78)
#define ADCW   _SFR_MEM16(0x78)
#define ADCL   _SFR_MEM8(0x78)
#define ADCH   _SFR_MEM8(0x79)
#define ADCSRA   _SFR_MEM8(0x7A)
#define ADPS0   0 /* ADC Prescaler Select bit0 */
#define ADPS1   1 /* ADC Prescaler Select bit1 */
#define ADPS2   2 /* ADC Prescaler Select bit2 */
#define ADIE   3 /* ADC Interrupt Enable */
#define ADIF   4 /* ADC Interrupt Flag */
#define ADATE   5 /* ADC Auto Trigger Enable */
#define ADSC   6 /* ADC Start Conversion */
#define ADEN   7 /* ADC Enable */
#define ADCSRB   _SFR_MEM8(0x7B)
#define ADTS0   0 /* ADC Auto Trigger Source 0 */
#define ADTS1   1 /* ADC Auto Trigger Source 1 */
#define ADTS2   2 /* ADC Auto Trigger Source 2 */
#define ADTS3   3 /* ADC Auto Trigger Source 3 */
#define ADHSM   7 /* ADC High Speed Mode */
#define ADMUX   _SFR_MEM8(0x7C)
#define MUX0   0 /* Analog Channel and Gain Selection bit0 */
#define MUX1   1 /* Analog Channel and Gain Selection bit1 */
#define MUX2   2 /* Analog Channel and Gain Selection bit2 */
#define MUX3   3 /* Analog Channel and Gain Selection bit3 */
#define ADLAR   5 /* Left Adjust Result */
#define REFS0   6 /* Reference Selection bit0 */
#define REFS1   7 /* Reference Selection bit1 */
#define DIDR0   _SFR_MEM8(0x7E)
#define ADC0D   0 /* ADC0 Digital input Disable */
#define ADC1D   1 /* ADC1 Digital input Disable */
#define ADC2D   2 /* ADC2 Digital input Disable */
#define ADC3D   3 /* ADC3 Digital input Disable */
#define ADC4D   4 /* ADC4 Digital input Disable */
#define ADC5D   5 /* ADC5 Digital input Disable */
#define ADC6D   6 /* ADC6 Digital input Disable */
#define ADC7D   7 /* ADC7 Digital input Disable */
#define DIDR1   _SFR_MEM8(0x7F)
#define ADC8D   0 /* ADC8 Digital input Disable */
#define ADC9D   1 /* ADC9 Digital input Disable */
#define ADC10D   2 /* ADC10 Digital input Disable */
#define AMP0ND   3
#define AMP0PD   4
#define ACMP0D   5
#define TCCR1A   _SFR_MEM8(0x80)
#define WGM10   0 /* Waveform Generation Mode */
#define WGM11   1 /* Waveform Generation Mode */
#define COM1B0   4 /* Compare Output Mode 1B, bit 0 */
#define COM1B1   5 /* Compare Output Mode 1B, bit 1 */
#define COM1A0   6 /* Comparet Ouput Mode 1A, bit 0 */
#define COM1A1   7 /* Comparet Ouput Mode 1A, bit 1 */
#define TCCR1B   _SFR_MEM8(0x81)
#define CS10   0 /* Prescaler source of Timer/Counter 1 */
#define CS11   1 /* Prescaler source of Timer/Counter 1 */
#define CS12   2 /* Prescaler source of Timer/Counter 1 */
#define WGM12   3 /* Waveform Generation Mode */
#define WGM13   4 /* Waveform Generation Mode */
#define ICES1   6 /* Input Capture 1 Edge Select */
#define ICNC1   7 /* Input Capture 1 Noise Canceler */
#define TCCR1C   _SFR_MEM8(0x82)
#define FOC1B   6 /* Force Output Compare for Channel B */
#define FOC1A   7 /* Force Output Compare for Channel A */
#define TCNT1   _SFR_MEM16(0x84)
#define TCNT1L   _SFR_MEM8(0x84)
#define TCNT10   0
#define TCNT11   1
#define TCNT12   2
#define TCNT13   3
#define TCNT14   4
#define TCNT15   5
#define TCNT16   6
#define TCNT17   7
#define TCNT1H   _SFR_MEM8(0x85)
#define TCNT18   0
#define TCNT19   1
#define TCNT110   2
#define TCNT111   3
#define TCNT112   4
#define TCNT113   5
#define TCNT114   6
#define TCNT115   7
#define ICR1   _SFR_MEM16(0x86)
#define ICR1L   _SFR_MEM8(0x86)
#define ICR17   7
#define ICR16   6
#define ICR15   5
#define ICR14   4
#define ICR13   3
#define ICR12   2
#define ICR11   1
#define ICR10   0
#define ICR1H   _SFR_MEM8(0x87)
#define ICR115   7
#define ICR114   6
#define ICR113   5
#define ICR112   4
#define ICR111   3
#define ICR110   2
#define ICR19   1
#define ICR18   0
#define OCR1A   _SFR_MEM16(0x88)
#define OCR1AL   _SFR_MEM8(0x88)
#define OCR1A0   0
#define OCR1A1   1
#define OCR1A2   2
#define OCR1A3   3
#define OCR1A4   4
#define OCR1A5   5
#define OCR1A6   6
#define OCR1A7   7
#define OCR1AH   _SFR_MEM8(0x89)
#define OCR1A8   0
#define OCR1A9   1
#define OCR1A10   2
#define OCR1A11   3
#define OCR1A12   4
#define OCR1A13   5
#define OCR1A14   6
#define OCR1A15   7
#define OCR1B   _SFR_MEM16(0x8A)
#define OCR1BL   _SFR_MEM8(0x8A)
#define OCR1B0   0
#define OCR1B1   1
#define OCR1B2   2
#define OCR1B3   3
#define OCR1B4   4
#define OCR1B5   5
#define OCR1B6   6
#define OCR1B7   7
#define OCR1BH   _SFR_MEM8(0x8B)
#define OCR1B8   0
#define OCR1B9   1
#define OCR1B10   2
#define OCR1B11   3
#define OCR1B12   4
#define OCR1B13   5
#define OCR1B14   6
#define OCR1B15   7
#define PIFR0   _SFR_MEM8(0xA0)
#define PEOP0   0 /* End Of PSC0 Interrupt */
#define PRN00   1 /* PSC0 Ramp Number bit0 */
#define PRN01   2 /* PSC0 Ramp Number bit1 */
#define PEV0A   3 /* PSC0 External Event A Interrupt */
#define PEV0B   4 /* PSC0 External Event B Interrupt */
#define PSEI0   5 /* PSC0 Synchro Error Interrupt */
#define POAC0A   6 /* PSC0 Output A Activity */
#define POAC0B   7 /* PSC0 Output B Activity */
#define PIM0   _SFR_MEM8(0xA1)
#define PEOPE0   0 /* PSC0 End Of Cycle Interrupt Enable */
#define PEVE0A   3 /* PSC0 External Event A Interrupt Enable */
#define PEVE0B   4 /* PSC0 External Event B Interrupt Enable */
#define PSEIE0   5 /* PSC0 Synchro Error Interrupt Enable */
#define PIFR1   _SFR_MEM8(0xA2)
#define PIM1   _SFR_MEM8(0xA3)
#define PIFR2   _SFR_MEM8(0xA4)
#define PEOP2   0 /* End Of PSC2 Interrupt */
#define PRN20   1 /* PSC2 Ramp Number bit0 */
#define PRN21   2 /* PSC2 Ramp Number bit1 */
#define PEV2A   3 /* PSC2 External Event A Interrupt */
#define PEV2B   4 /* PSC2 External Event B Interrupt */
#define PSEI2   5 /* PSC2 Synchro Error Interrupt */
#define POAC2A   6 /* PSC2 Output A Activity */
#define POAC2B   7 /* PSC2 Output B Activity */
#define PIM2   _SFR_MEM8(0xA5)
#define PEOPE2   0 /* PSC2 End Of Cycle Interrupt Enable */
#define PEVE2A   3 /* PSC2 External Event A Interrupt Enable */
#define PEVE2B   4 /* PSC2 External Event B Interrupt Enable */
#define PSEIE2   5 /* PSC2 Synchro Error Interrupt Enable */
#define DACON   _SFR_MEM8(0xAA)
#define DAEN   0 /* Digital to Analog Enable bit */
#define DAOE   1 /* Digital to Analog Output Enable bit */
#define DALA   2 /* Digital to Analog Left Adjust */
#define DATS0   4 /* DAC Trigger Selection bit0 */
#define DATS1   5 /* DAC Trigger Selection bit1 */
#define DATS2   6 /* DAC Trigger Selection bit2 */
#define DAATE   7 /* DAC Auto Trigger Enable bit */
#define DAC   _SFR_MEM16(0xAB)
#define DACL   _SFR_MEM8(0xAB)
#define DACH   _SFR_MEM8(0xAC)
#define AC0CON   _SFR_MEM8(0xAD)
#define AC0M0   0 /* Analog Comparator 0 Multiplexer register bit0 */
#define AC0M1   1 /* Analog Comparator 0 Multiplexer register bit1 */
#define AC0M2   2 /* Analog Comparator 0 Multiplexer register bit2 */
#define AC0IS0   4 /* Analog Comparator 0 Interrupt Select bit0 */
#define AC0IS1   5 /* Analog Comparator 0 Interrupt Select bit1 */
#define AC0IE   6 /* Analog Comparator 0 Interrupt Enable bit */
#define AC0EN   7 /* Analog Comparator 0 Enable Bit */
#define AC1CON   _SFR_MEM8(0xAE)
#define AC1M0   0 /* Analog Comparator 1 Multiplexer register bit0 */
#define AC1M1   1 /* Analog Comparator 1 Multiplexer register bit1 */
#define AC1M2   2 /* Analog Comparator 1 Multiplexer register bit2 */
#define AC1ICE   3 /* Analog Comparator 1 Interrupt Capture Enable bit */
#define AC1IS0   4 /* Analog Comparator 1 Interrupt Select bit0 */
#define AC1IS1   5 /* Analog Comparator 1 Interrupt Select bit1 */
#define AC1IE   6 /* Analog Comparator 1 Interrupt Enable bit */
#define AC1EN   7 /* Analog Comparator 1 Enable Bit */
#define AC2CON   _SFR_MEM8(0xAF)
#define AC2M0   0 /* Analog Comparator 2 Multiplexer register bit0 */
#define AC2M1   1 /* Analog Comparator 2 Multiplexer register bit1 */
#define AC2M2   2 /* Analog Comparator 2 Multiplexer register bit2 */
#define AC2IS0   4 /* Analog Comparator 2 Interrupt Select bit0 */
#define AC2IS1   5 /* Analog Comparator 2 Interrupt Select bit1 */
#define AC2IE   6 /* Analog Comparator 2 Interrupt Enable bit */
#define AC2EN   7 /* Analog Comparator 2 Enable Bit */
#define UCSRA   _SFR_MEM8(0xC0)
#define MPCM   0 /* Multi-processor Communication Mode */
#define U2X   1 /* Double the USART Transmission Speed */
#define UPE   2 /* USART Parity Error */
#define DOR   3 /* Data OverRun */
#define FE   4 /* Frame Error */
#define UDRE   5 /* USART Data Register Empty */
#define TXC   6 /* USART Transmit Complete */
#define RXC   7 /* USART Receive Complete */
#define UCSRB   _SFR_MEM8(0xC1)
#define TXB8   0 /* Transmit Data Bit 8 */
#define RXB8   1 /* Receive Data Bit 8 */
#define UCSZ2   2 /* Character Size */
#define TXEN   3 /* Transmitter Enable */
#define RXEN   4 /* Receiver Enable */
#define UDRIE   5 /* USART Data Register Empty Interrupt Enable */
#define TXCIE   6 /* TX Complete Interrupt Enable */
#define RXCIE   7 /* RX Complete Interrupt Enable */
#define UCSRC   _SFR_MEM8(0xC2)
#define UCPOL   0 /* Clock Polarity */
#define UCSZ0   1 /* Character Size bit0 */
#define UCSZ1   2 /* Character Size bit1 */
#define USBS   3 /* Stop Bit Select */
#define UPM0   4 /* Parity Mode bit0 */
#define UPM1   5 /* Parity Mode bit1 */
#define UMSEL   6 /* USART Mode Select */
#define UBRR   _SFR_MEM16(0xC4)
#define UBRRL   _SFR_MEM8(0xC4)
#define UBRRH   _SFR_MEM8(0xC5)
#define UDR   _SFR_MEM8(0xC6)
#define EUCSRA   _SFR_MEM8(0xC8)
#define URxS0   0 /* EUSART Receive Character Size bit0 */
#define URxS1   1 /* EUSART Receive Character Size bit1 */
#define URxS2   2 /* EUSART Receive Character Size bit2 */
#define URxS3   3 /* EUSART Receive Character Size bit3 */
#define UTxS0   4 /* EUSART Transmit Character Size bit0 */
#define UTxS1   5 /* EUSART Transmit Character Size bit1 */
#define UTxS2   6 /* EUSART Transmit Character Size bit2 */
#define UTxS3   7 /* EUSART Transmit Character Size bit3 */
#define EUCSRB   _SFR_MEM8(0xC9)
#define BODR   0 /* Bit Order */
#define EMCH   1 /* Manchester mode */
#define EUSBS   3 /* EUSBS Enable Bit */
#define EUSART   4 /* EUSART Enable Bit */
#define EUCSRC   _SFR_MEM8(0xCA)
#define STP0   0 /* Stop bits values bit0 */
#define STP1   1 /* Stop bits values bit1 */
#define F1617   2
#define FEM   3 /* Frame Error Manchester */
#define MUBRR   _SFR_MEM16(0xCC)
#define MUBRRL   _SFR_MEM8(0xCC)
#define MUBRRH   _SFR_MEM8(0xCD)
#define EUDR   _SFR_MEM8(0xCE)
#define PSOC0   _SFR_MEM8(0xD0)
#define POEN0A   0 /* PSC 0 OUT Part A Output Enable */
#define POEN0B   2 /* PSC 0 OUT Part B Output Enable */
#define PSYNC00   4 /* Synchronization Out for ADC Selection bit0 */
#define PSYNC01   5 /* Synchronization Out for ADC Selection bit1 */
#define OCR0SA   _SFR_MEM16(0xD2)
#define OCR0SAL   _SFR_MEM8(0xD2)
#define OCR0SAH   _SFR_MEM8(0xD3)
#define OCR0RA   _SFR_MEM16(0xD4)
#define OCR0RAL   _SFR_MEM8(0xD4)
#define OCR0RAH   _SFR_MEM8(0xD5)
#define OCR0SB   _SFR_MEM16(0xD6)
#define OCR0SBL   _SFR_MEM8(0xD6)
#define OCR0SBH   _SFR_MEM8(0xD7)
#define OCR0RB   _SFR_MEM16(0xD8)
#define OCR0RBL   _SFR_MEM8(0xD8)
#define OCR0RBH   _SFR_MEM8(0xD9)
#define PCNF0   _SFR_MEM8(0xDA)
#define PCLKSEL0   1 /* PSC 0 Input Clock Select */
#define POP0   2 /* PSC 0 Output Polarity */
#define PMODE00   3 /* PSC 0 Mode bit0 */
#define PMODE01   4 /* PSC 0 Mode bit1 */
#define PLOCK0   5 /* PSC 0 Lock */
#define PALOCK0   6 /* PSC 0 Autolock */
#define PFIFTY0   7 /* PSC 0 Fifty */
#define PCTL0   _SFR_MEM8(0xDB)
#define PRUN0   0 /* PSC 0 Run */
#define PCCYC0   1 /* PSC 0 Complete Cycle */
#define PARUN0   2 /* PSC 0 Autorun */
#define PAOC0A   3 /* PSC 0 Asynchronous Output Control A */
#define PAOC0B   4 /* PSC 0 Asynchronous Output Control B */
#define PBFM0   5 /* Balance Flank Width Modulation */
#define PPRE00   6 /* PSC 0 Prescaler Select bit0 */
#define PPRE01   7 /* PSC 0 Prescaler Select bit1 */
#define PFRC0A   _SFR_MEM8(0xDC)
#define PRFM0A0   0 /* PSC 0 Fault Mode bit0 */
#define PRFM0A1   1 /* PSC 0 Fault Mode bit1 */
#define PRFM0A2   2 /* PSC 0 Fault Mode bit2 */
#define PRFM0A3   3 /* PSC 0 Fault Mode bit3 */
#define PFLTE0A   4 /* PSC 0 Filter Enable on Input Part A */
#define PELEV0A   5 /* PSC 0 Edge Level Selector of Input Part A */
#define PISEL0A   6 /* PSC 0 Input Select for Part A */
#define PCAE0A   7 /* PSC 0 Capture Enable Input Part A */
#define PFRC0B   _SFR_MEM8(0xDD)
#define PRFM0B0   0 /* PSC 0 Fault Mode bit0 */
#define PRFM0B1   1 /* PSC 0 Fault Mode bit1 */
#define PRFM0B2   2 /* PSC 0 Fault Mode bit2 */
#define PRFM0B3   3 /* PSC 0 Fault Mode bit3 */
#define PFLTE0B   4 /* PSC 0 Filter Enable on Input Part B */
#define PELEV0B   5 /* PSC 0 Edge Level Selector of Input Part B */
#define PISEL0B   6 /* PSC 0 Input Select for Part B */
#define PCAE0B   7 /* PSC 0 Capture Enable Input Part B */
#define PICR0   _SFR_MEM16(0xDE)
#define PICR0L   _SFR_MEM8(0xDE)
#define PICR0H   _SFR_MEM8(0xDF)
#define PCST0   7 /* PSC Capture Software Trig bit */
#define PSOC1   _SFR_MEM8(0xE0)
#define OCR1SA   _SFR_MEM16(0xE2)
#define OCR1SAL   _SFR_MEM8(0xE2)
#define OCR1SAH   _SFR_MEM8(0xE3)
#define OCR1RA   _SFR_MEM16(0xE4)
#define OCR1RAL   _SFR_MEM8(0xE4)
#define OCR1RAH   _SFR_MEM8(0xE5)
#define OCR1SB   _SFR_MEM16(0xE6)
#define OCR1SBL   _SFR_MEM8(0xE6)
#define OCR1SBH   _SFR_MEM8(0xE7)
#define OCR1RB   _SFR_MEM16(0xE8)
#define OCR1RBL   _SFR_MEM8(0xE8)
#define OCR1RBH   _SFR_MEM8(0xE9)
#define PCNF1   _SFR_MEM8(0xEA)
#define PCTL1   _SFR_MEM8(0xEB)
#define PFRC1A   _SFR_MEM8(0xEC)
#define PFRC1B   _SFR_MEM8(0xED)
#define PICR1   _SFR_MEM16(0xEE)
#define PICR1L   _SFR_MEM8(0xEE)
#define PICR1H   _SFR_MEM8(0xEF)
#define PSOC2   _SFR_MEM8(0xF0)
#define POEN2A   0 /* PSC 2 OUT Part A Output Enable */
#define POEN2C   1 /* PSCOUT22 Output Enable */
#define POEN2B   2 /* PSC 2 OUT Part B Output Enable */
#define POEN2D   3 /* PSCOUT23 Output Enable */
#define PSYNC20   4 /* Synchronization Out for ADC Selection bit0 */
#define PSYNC21   5 /* Synchronization Out for ADC Selection bit1 */
#define POS22   6 /* PSCOUT22 Selection */
#define POS23   7 /* PSCOUT23 Selection */
#define POM2   _SFR_MEM8(0xF1)
#define POMV2A0   0 /* Output Matrix Output A Ramp 0 */
#define POMV2A1   1 /* Output Matrix Output A Ramp 1 */
#define POMV2A2   2 /* Output Matrix Output A Ramp 2 */
#define POMV2A3   3 /* Output Matrix Output A Ramp 3 */
#define POMV2B0   4 /* Output Matrix Output B Ramp 0 */
#define POMV2B1   5 /* Output Matrix Output B Ramp 1 */
#define POMV2B2   6 /* Output Matrix Output B Ramp 2 */
#define POMV2B3   7 /* Output Matrix Output B Ramp 3 */
#define OCR2SA   _SFR_MEM16(0xF2)
#define OCR2SAL   _SFR_MEM8(0xF2)
#define OCR2SAH   _SFR_MEM8(0xF3)
#define OCR2RA   _SFR_MEM16(0xF4)
#define OCR2RAL   _SFR_MEM8(0xF4)
#define OCR2RAH   _SFR_MEM8(0xF5)
#define OCR2SB   _SFR_MEM16(0xF6)
#define OCR2SBL   _SFR_MEM8(0xF6)
#define OCR2SBH   _SFR_MEM8(0xF7)
#define OCR2RB   _SFR_MEM16(0xF8)
#define OCR2RBL   _SFR_MEM8(0xF8)
#define OCR2RBH   _SFR_MEM8(0xF9)
#define PCNF2   _SFR_MEM8(0xFA)
#define POME2   0 /* PSC 2 Output Matrix Enable */
#define PCLKSEL2   1 /* PSC 2 Input Clock Select */
#define POP2   2 /* PSC 2 Output Polarity */
#define PMODE20   3 /* PSC 2 Mode bit0 */
#define PMODE21   4 /* PSC 2 Mode bit1 */
#define PLOCK2   5 /* PSC 2 Lock */
#define PALOCK2   6 /* PSC 2 Autolock */
#define PFIFTY2   7 /* PSC 2 Fifty */
#define PCTL2   _SFR_MEM8(0xFB)
#define PRUN2   0 /* PSC 2 Run */
#define PCCYC2   1 /* PSC 2 Complete Cycle */
#define PARUN2   2 /* PSC 2 Autorun */
#define PAOC2A   3 /* PSC 2 Asynchronous Output Control A */
#define PAOC2B   4 /* PSC 2 Asynchronous Output Control B */
#define PBFM2   5 /* Balance Flank Width Modulation */
#define PPRE20   6 /* PSC 2 Prescaler Select bit0 */
#define PPRE21   7 /* PSC 2 Prescaler Select bit1 */
#define PFRC2A   _SFR_MEM8(0xFC)
#define PRFM2A0   0 /* PSC 2 Fault Mode bit0 */
#define PRFM2A1   1 /* PSC 2 Fault Mode bit1 */
#define PRFM2A2   2 /* PSC 2 Fault Mode bit2 */
#define PRFM2A3   3 /* PSC 2 Fault Mode bit3 */
#define PFLTE2A   4 /* PSC 2 Filter Enable on Input Part A */
#define PELEV2A   5 /* PSC 2 Edge Level Selector of Input Part A */
#define PISEL2A   6 /* PSC 2 Input Select for Part A */
#define PCAE2A   7 /* PSC 2 Capture Enable Input Part A */
#define PFRC2B   _SFR_MEM8(0xFD)
#define PRFM2B0   0 /* PSC 2 Fault Mode bit0 */
#define PRFM2B1   1 /* PSC 2 Fault Mode bit1 */
#define PRFM2B2   2 /* PSC 2 Fault Mode bit2 */
#define PRFM2B3   3 /* PSC 2 Fault Mode bit3 */
#define PFLTE2B   4 /* PSC 2 Filter Enable on Input Part B */
#define PELEV2B   5 /* PSC 2 Edge Level Selector of Input Part B */
#define PISEL2B   6 /* PSC 2 Input Select for Part B */
#define PCAE2B   7 /* PSC 2 Capture Enable Input Part B */
#define PICR2   _SFR_MEM16(0xFE)
#define PICR2L   _SFR_MEM8(0xFE)
#define PICR2H   _SFR_MEM8(0xFF)
#define PCST2   7 /* PSC Capture Software Trig bit */
#define PSC2_CAPT_vect   _VECTOR(1)
#define PSC2_EC_vect   _VECTOR(2)
#define PSC1_CAPT_vect   _VECTOR(3)
#define PSC1_EC_vect   _VECTOR(4)
#define PSC0_CAPT_vect   _VECTOR(5)
#define PSC0_EC_vect   _VECTOR(6)
#define ANALOG_COMP_0_vect   _VECTOR(7)
#define ANALOG_COMP_1_vect   _VECTOR(8)
#define ANALOG_COMP_2_vect   _VECTOR(9)
#define INT0_vect   _VECTOR(10)
#define TIMER1_CAPT_vect   _VECTOR(11)
#define TIMER1_COMPA_vect   _VECTOR(12)
#define TIMER1_COMPB_vect   _VECTOR(13)
#define TIMER1_OVF_vect   _VECTOR(15)
#define TIMER0_COMP_A_vect   _VECTOR(16)
#define TIMER0_OVF_vect   _VECTOR(17)
#define ADC_vect   _VECTOR(18)
#define INT1_vect   _VECTOR(19)
#define SPI_STC_vect   _VECTOR(20)
#define USART_RX_vect   _VECTOR(21)
#define USART_UDRE_vect   _VECTOR(22)
#define USART_TX_vect   _VECTOR(23)
#define INT2_vect   _VECTOR(24)
#define WDT_vect   _VECTOR(25)
#define EE_READY_vect   _VECTOR(26)
#define TIMER0_COMPB_vect   _VECTOR(27)
#define INT3_vect   _VECTOR(28)
#define SPM_READY_vect   _VECTOR(31)
#define _VECTORS_SIZE   (4 * 32)
#define RAMEND   0x4FF
#define XRAMSIZE   0
#define XRAMEND   RAMEND
#define E2END   0x1FF
#define E2PAGESIZE   4
#define FLASHEND   0x3FFF
#define SPM_PAGESIZE   128
#define FUSE_MEMORY_SIZE   3
#define FUSE_CKSEL0   (unsigned char)~_BV(0) /* Select Clock Source */
#define FUSE_CKSEL1   (unsigned char)~_BV(1) /* Select Clock Source */
#define FUSE_CKSEL2   (unsigned char)~_BV(2) /* Select Clock Source */
#define FUSE_CKSEL3   (unsigned char)~_BV(3) /* Select Clock Source */
#define FUSE_SUT0   (unsigned char)~_BV(4) /* Select start-up time */
#define FUSE_SUT1   (unsigned char)~_BV(5) /* Select start-up time */
#define FUSE_CKOUT   (unsigned char)~_BV(6) /* Oscillator output option */
#define FUSE_CKDIV8   (unsigned char)~_BV(7) /* Divide clock by 8 */
#define LFUSE_DEFAULT   (FUSE_CKSEL0 & FUSE_CKSEL2 & FUSE_CKSEL3 & FUSE_SUT0 & FUSE_CKDIV8)
#define FUSE_BODLEVEL0   (unsigned char)~_BV(0)
#define FUSE_BODLEVEL1   (unsigned char)~_BV(1)
#define FUSE_BODLEVEL2   (unsigned char)~_BV(2)
#define FUSE_EESAVE   (unsigned char)~_BV(3) /* EEPROM memory is preserved through chip erase */
#define FUSE_WDTON   (unsigned char)~_BV(4) /* Watchdog timer always on */
#define FUSE_SPIEN   (unsigned char)~_BV(5) /* Enable Serial programming and Data Downloading */
#define FUSE_DWEN   (unsigned char)~_BV(6) /* debugWIRE Enable */
#define FUSE_RSTDISBL   (unsigned char)~_BV(7) /* External Reset Diasble */
#define HFUSE_DEFAULT   (FUSE_SPIEN)
#define FUSE_BOOTRST   (unsigned char)~_BV(0) /* Select Reset Vector */
#define FUSE_BOOTSZ0   (unsigned char)~_BV(1) /* Select Boot Size */
#define FUSE_BOOTSZ1   (unsigned char)~_BV(2) /* Select Boot Size */
#define FUSE_PSCRV   (unsigned char)~_BV(4)
#define FUSE_PSC0RB   (unsigned char)~_BV(5)
#define FUSE_PSC1RB   (unsigned char)~_BV(6)
#define FUSE_PSC2RB   (unsigned char)~_BV(7)
#define EFUSE_DEFAULT   (FUSE_BOOTSZ0 & FUSE_BOOTSZ1)
#define __LOCK_BITS_EXIST
#define __BOOT_LOCK_BITS_0_EXIST
#define __BOOT_LOCK_BITS_1_EXIST
#define SIGNATURE_0   0x1E
#define SIGNATURE_1   0x94
#define SIGNATURE_2   0x83
