AT90S4414 Definitions
#define ACSR   _SFR_IO8(0x08)
#define UBRR   _SFR_IO8(0x09)
#define UCR   _SFR_IO8(0x0A)
#define USR   _SFR_IO8(0x0B)
#define UDR   _SFR_IO8(0x0C)
#define SPCR   _SFR_IO8(0x0D)
#define SPSR   _SFR_IO8(0x0E)
#define SPDR   _SFR_IO8(0x0F)
#define PIND   _SFR_IO8(0x10)
#define DDRD   _SFR_IO8(0x11)
#define PORTD   _SFR_IO8(0x12)
#define PINC   _SFR_IO8(0x13)
#define DDRC   _SFR_IO8(0x14)
#define PORTC   _SFR_IO8(0x15)
#define PINB   _SFR_IO8(0x16)
#define DDRB   _SFR_IO8(0x17)
#define PORTB   _SFR_IO8(0x18)
#define PINA   _SFR_IO8(0x19)
#define DDRA   _SFR_IO8(0x1A)
#define PORTA   _SFR_IO8(0x1B)
#define EECR   _SFR_IO8(0x1C)
#define EEDR   _SFR_IO8(0x1D)
#define EEAR   _SFR_IO8(0x1E)
#define EEARL   _SFR_IO8(0x1E)
#define WDTCR   _SFR_IO8(0x21)
#define ICR1   _SFR_IO16(0x24)
#define ICR1L   _SFR_IO8(0x24)
#define ICR1H   _SFR_IO8(0x25)
#define OCR1B   _SFR_IO16(0x28)
#define OCR1BL   _SFR_IO8(0x28)
#define OCR1BH   _SFR_IO8(0x29)
#define OCR1A   _SFR_IO16(0x2A)
#define OCR1AL   _SFR_IO8(0x2A)
#define OCR1AH   _SFR_IO8(0x2B)
#define TCNT1   _SFR_IO16(0x2C)
#define TCNT1L   _SFR_IO8(0x2C)
#define TCNT1H   _SFR_IO8(0x2D)
#define TCCR1B   _SFR_IO8(0x2E)
#define TCCR1A   _SFR_IO8(0x2F)
#define TCNT0   _SFR_IO8(0x32)
#define TCCR0   _SFR_IO8(0x33)
#define MCUCR   _SFR_IO8(0x35)
#define TIFR   _SFR_IO8(0x38)
#define TIMSK   _SFR_IO8(0x39)
#define GIFR   _SFR_IO8(0x3A)
#define GIMSK   _SFR_IO8(0x3B)
#define INT0_vect   _VECTOR(1)
#define SIG_INTERRUPT0   _VECTOR(1)
#define INT1_vect   _VECTOR(2)
#define SIG_INTERRUPT1   _VECTOR(2)
#define TIMER1_CAPT_vect   _VECTOR(3)
#define SIG_INPUT_CAPTURE1   _VECTOR(3)
#define TIMER1_COMPA_vect   _VECTOR(4)
#define SIG_OUTPUT_COMPARE1A   _VECTOR(4)
#define TIMER1_COMPB_vect   _VECTOR(5)
#define SIG_OUTPUT_COMPARE1B   _VECTOR(5)
#define TIMER1_OVF_vect   _VECTOR(6)
#define SIG_OVERFLOW1   _VECTOR(6)
#define TIMER0_OVF_vect   _VECTOR(7)
#define SIG_OVERFLOW0   _VECTOR(7)
#define SPI_STC_vect   _VECTOR(8)
#define SIG_SPI   _VECTOR(8)
#define UART_RX_vect   _VECTOR(9)
#define SIG_UART_RECV   _VECTOR(9)
#define UART_UDRE_vect   _VECTOR(10)
#define SIG_UART_DATA   _VECTOR(10)
#define UART_TX_vect   _VECTOR(11)
#define SIG_UART_TRANS   _VECTOR(11)
#define ANA_COMP_vect   _VECTOR(12)
#define SIG_COMPARATOR   _VECTOR(12)
#define _VECTORS_SIZE   26
#define INT1   7
#define INT0   6
#define INTF1   7
#define INTF0   6
#define TOIE1   7
#define OCIE1A   6
#define OCIE1B   5
#define TICIE1   3
#define TOIE0   1
#define TOV1   7
#define OCF1A   6
#define OCF1B   5
#define ICF1   3
#define TOV0   1
#define SRE   7
#define SRW   6
#define SE   5
#define SM   4
#define ISC11   3
#define ISC10   2
#define ISC01   1
#define ISC00   0
#define CS02   2
#define CS01   1
#define CS00   0
#define COM1A1   7
#define COM1A0   6
#define COM1B1   5
#define COM1B0   4
#define PWM11   1
#define PWM10   0
#define ICNC1   7
#define ICES1   6
#define CTC1   3
#define CS12   2
#define CS11   1
#define CS10   0
#define WDTOE   4
#define WDE   3
#define WDP2   2
#define WDP1   1
#define WDP0   0
#define PA7   7
#define PA6   6
#define PA5   5
#define PA4   4
#define PA3   3
#define PA2   2
#define PA1   1
#define PA0   0
#define DDA7   7
#define DDA6   6
#define DDA5   5
#define DDA4   4
#define DDA3   3
#define DDA2   2
#define DDA1   1
#define DDA0   0
#define PINA7   7
#define PINA6   6
#define PINA5   5
#define PINA4   4
#define PINA3   3
#define PINA2   2
#define PINA1   1
#define PINA0   0
#define PB7   7
#define PB6   6
#define PB5   5
#define PB4   4
#define PB3   3
#define PB2   2
#define PB1   1
#define PB0   0
#define DDB7   7
#define DDB6   6
#define DDB5   5
#define DDB4   4
#define DDB3   3
#define DDB2   2
#define DDB1   1
#define DDB0   0
#define PINB7   7
#define PINB6   6
#define PINB5   5
#define PINB4   4
#define PINB3   3
#define PINB2   2
#define PINB1   1
#define PINB0   0
#define PC7   7
#define PC6   6
#define PC5   5
#define PC4   4
#define PC3   3
#define PC2   2
#define PC1   1
#define PC0   0
#define DDC7   7
#define DDC6   6
#define DDC5   5
#define DDC4   4
#define DDC3   3
#define DDC2   2
#define DDC1   1
#define DDC0   0
#define PINC7   7
#define PINC6   6
#define PINC5   5
#define PINC4   4
#define PINC3   3
#define PINC2   2
#define PINC1   1
#define PINC0   0
#define PD7   7
#define PD6   6
#define PD5   5
#define PD4   4
#define PD3   3
#define PD2   2
#define PD1   1
#define PD0   0
#define DDD7   7
#define DDD6   6
#define DDD5   5
#define DDD4   4
#define DDD3   3
#define DDD2   2
#define DDD1   1
#define DDD0   0
#define PIND7   7
#define PIND6   6
#define PIND5   5
#define PIND4   4
#define PIND3   3
#define PIND2   2
#define PIND1   1
#define PIND0   0
#define SPIF   7
#define WCOL   6
#define SPIE   7
#define SPE   6
#define DORD   5
#define MSTR   4
#define CPOL   3
#define CPHA   2
#define SPR1   1
#define SPR0   0
#define RXC   7
#define TXC   6
#define UDRE   5
#define FE   4
#define DOR   3
#define RXCIE   7
#define TXCIE   6
#define UDRIE   5
#define RXEN   4
#define TXEN   3
#define CHR9   2
#define RXB8   1
#define TXB8   0
#define ACD   7
#define ACO   5
#define ACI   4
#define ACIE   3
#define ACIC   2
#define ACIS1   1
#define ACIS0   0
#define EERIE   3
#define EEMWE   2
#define EEWE   1
#define EERE   0
#define RAMEND   0x15F /* Last On-Chip SRAM Location */
#define XRAMEND   0xFFFF
#define E2END   0xFF
#define E2PAGESIZE   0
#define FLASHEND   0xFFF
#define FUSE_MEMORY_SIZE   1
#define FUSE_SPIEN   (unsigned char)~_BV(1) /* Serial Program Downloading Enabled */
#define FUSE_FSTRT   (unsigned char)~_BV(2) /* Short Start-up time selected */
#define LFUSE_DEFAULT   (0xFF)
#define __LOCK_BITS_EXIST
#define SIGNATURE_0   0x1E
#define SIGNATURE_1   0x92
#define SIGNATURE_2   0x01
