18 #ifndef __RTEMS_FRAMEBUFFER_h__ 19 #define __RTEMS_FRAMEBUFFER_h__ 31 #define FRAMEBUFFER_DEVICE_NAME "/dev/fb" 39 #define FRAMEBUFFER_DEVICE_0_NAME "/dev/fb0" 45 #define FRAME_BUFFER_DRIVER_TABLE_ENTRY \ 46 { frame_buffer_initialize, frame_buffer_open, frame_buffer_close, \ 47 frame_buffer_read, frame_buffer_write, frame_buffer_control } 62 rtems_device_major_number major,
63 rtems_device_minor_number minor,
81 rtems_device_major_number major,
82 rtems_device_minor_number minor,
100 rtems_device_major_number major,
101 rtems_device_minor_number minor,
119 rtems_device_major_number major,
120 rtems_device_minor_number minor,
138 rtems_device_major_number major,
139 rtems_device_minor_number minor,
158 rtems_device_major_number major,
159 rtems_device_minor_number minor,
Classic Input/Output Manager API.
rtems_device_driver frame_buffer_control(rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
Frame Buffer IO Control Entry Point.
rtems_device_driver frame_buffer_write(rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
Frame Buffer Write Entry Point.
rtems_device_driver frame_buffer_open(rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
Frame Buffer Open Entry Point.
rtems_device_driver frame_buffer_read(rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
Frame Buffer Read Entry Point.
rtems_status_code
Classic API Status.
Definition: status.h:46
rtems_device_driver frame_buffer_close(rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
Frame Buffer Close Entry Point.
rtems_device_driver frame_buffer_initialize(rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
Frame Buffer Initialization Entry Point.
