#include "deflate.h"
| struct | config_s |
| struct | static_tree_desc_s |
Typedefs | |
| typedef block_state compress_func | OF((deflate_state *s, int flush)) |
| typedef struct config_s | config |
Enumerations | |
| enum | block_state { need_more, block_done, finish_started, finish_done } |
| local void fill_window | OF ((deflate_state *s)) |
| local block_state deflate_stored | OF ((deflate_state *s, int flush)) |
| local void putShortMSB | OF ((deflate_state *s, uInt b)) |
| local void flush_pending | OF ((z_streamp strm)) |
| local int read_buf | OF ((z_streamp strm, Bytef *buf, unsigned size)) |
| local uInt longest_match | OF ((deflate_state *s, IPos cur_match)) |
| int ZEXPORT | deflateInit_ (z_streamp strm, int level, const char *version, int stream_size) |
| int ZEXPORT | deflateInit2_ (z_streamp strm, int level, int method, int windowBits, int memLevel, int strategy, const char *version, int stream_size) |
| int ZEXPORT | deflateSetDictionary (z_streamp strm, const Bytef *dictionary, uInt dictLength) |
| int ZEXPORT | deflateReset (z_streamp strm) |
| int ZEXPORT | deflateSetHeader (z_streamp strm, gz_headerp head) |
| int ZEXPORT | deflatePrime (z_streamp strm, int bits, int value) |
| int ZEXPORT | deflateParams (z_streamp strm, int level, int strategy) |
| int ZEXPORT | deflateTune (z_streamp strm, int good_length, int max_lazy, int nice_length, int max_chain) |
| uLong ZEXPORT | deflateBound (z_streamp strm, uLong sourceLen) |
| local void | putShortMSB (deflate_state *s, uInt b) |
| local void | flush_pending (z_streamp strm) |
| int ZEXPORT | deflate (z_streamp strm, int flush) |
| int ZEXPORT | deflateEnd (z_streamp strm) |
| int ZEXPORT | deflateCopy (z_streamp dest, z_streamp source) |
| local int | read_buf (z_streamp strm, Bytef *buf, unsigned size) |
| local void | lm_init (deflate_state *s) |
| local uInt | longest_match (deflate_state *s, IPos cur_match) |
| local void | fill_window (deflate_state *s) |
| local block_state | deflate_stored (deflate_state *s, int flush) |
| local block_state | deflate_fast (deflate_state *s, int flush) |
| local block_state | deflate_slow (deflate_state *s, int flush) |
| local block_state | deflate_rle (deflate_state *s, int flush) |
| local block_state | deflate_huff (deflate_state *s, int flush) |
| const char | deflate_copyright [] |
| local const config | configuration_table [10] |
| #define CLEAR_HASH | ( | s | ) |
| #define FLUSH_BLOCK | ( | s, | |
| last | |||
| #define FLUSH_BLOCK_ONLY | ( | s, | |
| last | |||
| #define INSERT_STRING | ( | s, | |
| str, | |||
| match_head | |||
| local const config configuration_table[10] |
| const char deflate_copyright[] |
