CPU Usage Top. More...
#include <stdbool.h>#include <string.h>#include <stdlib.h>#include <stdio.h>#include <ctype.h>#include <inttypes.h>#include <rtems/cpuuse.h>#include <rtems/malloc.h>#include <rtems/score/objectimpl.h>#include <rtems/score/protectedheap.h>#include <rtems/score/threadimpl.h>#include <rtems/score/todimpl.h>#include <rtems/score/watchdogimpl.h>#include <rtems/score/wkspace.h>
| struct | rtems_cpu_usage_plugin |
| struct | rtems_cpu_usage_data |
| #define | RTEMS_TOP_SORT_ID (0) |
| #define | RTEMS_TOP_SORT_REAL_PRI (1) |
| #define | RTEMS_TOP_SORT_CURRENT_PRI (2) |
| #define | RTEMS_TOP_SORT_TOTAL (3) |
| #define | RTEMS_TOP_SORT_CURRENT (4) |
| #define | RTEMS_TOP_SORT_MAX (4) |
| #define | CPU_usage_Equal_to(_lhs, _rhs) _Timestamp_Equal_to( _lhs, _rhs ) |
| #define | CPU_usage_Set_to_zero(_time) _Timestamp_Set_to_zero( _time ) |
| #define | CPU_usage_Less_than(_lhs, _rhs) _Timestamp_Less_than( _lhs, _rhs ) |
Typedefs | |
| typedef void(* | rtems_per_thread_routine_2) (Thread_Control *, void *) |
| void | rtems_iterate_over_all_threads_2 (rtems_per_thread_routine_2 routine, void *arg) |
| void | rtems_cpu_usage_top_with_plugin (void *context, rtems_printk_plugin_t print) |
| CPU usage Top plugin. More... | |
| void | rtems_cpu_usage_top (void) |
| CPU usage top. More... | |
CPU Usage Top.
