rtems-4.11.3
librpc
include
rpc
clnt.h
1
/* $NetBSD: clnt.h,v 1.14 2000/06/02 22:57:55 fvdl Exp $ */
2
3
4
* The contents of this file are subject to the Sun Standards
5
* License Version 1.0 the (the "License";) You may not use
6
* this file except in compliance with the License. You may
7
* obtain a copy of the License at lib/libc/rpc/LICENSE
8
9
* Software distributed under the License is distributed on
10
* an "AS IS" basis, WITHOUT WARRANTY OF ANY KIND, either
11
* express or implied. See the License for the specific
12
* language governing rights and limitations under the License.
13
14
* The Original Code is Copyright 1998 by Sun Microsystems, Inc
15
16
* The Initial Developer of the Original Code is: Sun
17
* Microsystems, Inc.
18
19
* All Rights Reserved.
20
21
* Sun RPC is a product of Sun Microsystems, Inc. and is provided for
22
* unrestricted use provided that this legend is included on all tape
23
* media and as a part of the software program in whole or part. Users
24
* may copy or modify Sun RPC without charge, but are not authorized
25
* to license or distribute it to anyone else except as part of a product or
26
* program developed by the user.
27
28
* SUN RPC IS PROVIDED AS IS WITH NO WARRANTIES OF ANY KIND INCLUDING THE
29
* WARRANTIES OF DESIGN, MERCHANTABILITY AND FITNESS FOR A PARTICULAR
30
* PURPOSE, OR ARISING FROM A COURSE OF DEALING, USAGE OR TRADE PRACTICE.
31
32
* Sun RPC is provided with no support and without any obligation on the
33
* part of Sun Microsystems, Inc. to assist in its use, correction,
34
* modification or enhancement.
35
36
* SUN MICROSYSTEMS, INC. SHALL HAVE NO LIABILITY WITH RESPECT TO THE
37
* INFRINGEMENT OF COPYRIGHTS, TRADE SECRETS OR ANY PATENTS BY SUN RPC
38
* OR ANY PART THEREOF.
39
40
* In no event will Sun Microsystems, Inc. be liable for any lost revenue
41
* or profits or other special, indirect and consequential damages, even if
42
* Sun has been advised of the possibility of such damages.
43
44
* Sun Microsystems, Inc.
45
* 2550 Garcia Avenue
46
* Mountain View, California 94043
47
48
49
50
* $FreeBSD: src/include/rpc/clnt.h,v 1.21 2003/01/24 01:47:55 fjoe Exp $
51
52
53
54
* clnt.h - Client side remote procedure call interface.
55
56
* Copyright (c) 1986-1991,1994-1999 by Sun Microsystems, Inc.
57
* All rights reserved.
58
59
60
61
#ifndef _RPC_CLNT_H_
62
#define _RPC_CLNT_H_
63
rpc/clnt_stat.h
64
#include <sys/cdefs.h>
65
sys/un.h
66
rpc/auth.h
/* auth_stat */
67
68
69
* Error info.
70
71
struct
rpc_err
72
enum
clnt_stat re_status;
73
union
74
int
RE_errno;
/* related system error */
75
enum
auth_stat RE_why;
/* why the auth error occurred */
76
struct
77
rpcvers_t low;
/* lowest version supported */
78
rpcvers_t high;
/* highest version supported */
79
} RE_vers;
80
struct
/* maybe meaningful if RPC_FAILED */
81
int32_t s1;
82
int32_t s2;
83
} RE_lb;
/* life boot & debugging only */
84
} ru;
85
#define re_errno ru.RE_errno
86
#define re_why ru.RE_why
87
#define re_vers ru.RE_vers
88
#define re_lb ru.RE_lb
89
90
91
92
93
* Client rpc handle.
94
* Created by individual implementations
95
* Client is responsible for initializing auth, see e.g. auth_none.c.
96
97
typedef
struct
__rpc_client
98
AUTH *cl_auth;
/* authenticator */
99
struct
clnt_ops
100
/* call remote procedure */
101
enum
clnt_stat (*cl_call)(
struct
__rpc_client
102
rpcproc_t, xdrproc_t,
void
*, xdrproc_t,
103
void
struct
timeval);
104
/* abort a call */
105
void (*cl_abort)(void);
106
/* get specific error code */
107
void (*cl_geterr)(
struct
__rpc_client
108
struct
rpc_err
109
/* frees results */
110
bool_t (*cl_freeres)(
struct
__rpc_client
111
xdrproc_t,
void
112
/* destroy this structure */
113
void (*cl_destroy)(
struct
__rpc_client
114
/* the ioctl() of rpc */
115
bool_t (*cl_control)(
struct
__rpc_client
*, int,
116
char
117
} *cl_ops;
118
void
*cl_private;
/* private stuff */
119
CLIENT
120
121
#define RPCSMALLMSGSIZE 400
/* a more reasonable packet size */
122
123
124
* client side rpc interface ops
125
126
* Parameter types are:
127
128
129
130
131
* enum clnt_stat
132
* CLNT_CALL(rh, proc, xargs, argsp, xres, resp, timeout)
133
* CLIENT *rh;
134
* rpcproc_t proc;
135
* xdrproc_t xargs;
136
* void *argsp;
137
* xdrproc_t xres;
138
* void *resp;
139
* struct timeval timeout;
140
141
#define CLNT_CALL(rh, proc, xargs, argsp, xres, resp, secs) \
142
((*(rh)->cl_ops->cl_call)(rh, proc, xargs, \
143
argsp, xres, resp, secs))
144
#define clnt_call(rh, proc, xargs, argsp, xres, resp, secs) \
145
146
147
148
149
* void
150
* CLNT_ABORT(rh);
151
* CLIENT *rh;
152
153
#define CLNT_ABORT(rh) ((*(rh)->cl_ops->cl_abort)(rh))
154
#define clnt_abort(rh) ((*(rh)->cl_ops->cl_abort)(rh))
155
156
157
* struct rpc_err
158
* CLNT_GETERR(rh);
159
* CLIENT *rh;
160
161
#define CLNT_GETERR(rh,errp) ((*(rh)->cl_ops->cl_geterr)(rh, errp))
162
#define clnt_geterr(rh,errp) ((*(rh)->cl_ops->cl_geterr)(rh, errp))
163
164
165
166
* bool_t
167
* CLNT_FREERES(rh, xres, resp);
168
* CLIENT *rh;
169
* xdrproc_t xres;
170
* void *resp;
171
172
#define CLNT_FREERES(rh,xres,resp) ((*(rh)->cl_ops->cl_freeres)(rh,xres,resp))
173
#define clnt_freeres(rh,xres,resp) ((*(rh)->cl_ops->cl_freeres)(rh,xres,resp))
174
175
176
* bool_t
177
* CLNT_CONTROL(cl, request, info)
178
* CLIENT *cl;
179
* u_int request;
180
* char *info;
181
182
#define CLNT_CONTROL(cl,rq,in) ((*(cl)->cl_ops->cl_control)(cl,rq,in))
183
#define clnt_control(cl,rq,in) ((*(cl)->cl_ops->cl_control)(cl,rq,in))
184
185
186
* control operations that apply to udp, tcp and unix transports
187
188
* Note: options marked XXX are no-ops in this implementation of RPC.
189
* The are present in TI-RPC but can't be implemented here since they
190
* depend on the presence of STREAMS/TLI, which we don't have.
191
192
193
#define CLSET_TIMEOUT 1
/* set timeout (timeval) */
194
#define CLGET_TIMEOUT 2
/* get timeout (timeval) */
195
#define CLGET_SERVER_ADDR 3
/* get server's address (sockaddr) */
196
#define CLGET_FD 6
/* get connections file descriptor */
197
#define CLGET_SVC_ADDR 7
/* get server's address (netbuf) */
198
#define CLSET_FD_CLOSE 8
/* close fd while clnt_destroy */
199
#define CLSET_FD_NCLOSE 9
/* Do not close fd while clnt_destroy */
200
#define CLGET_XID 10
/* Get xid */
201
#define CLSET_XID 11
/* Set xid */
202
#define CLGET_VERS 12
/* Get version number */
203
#define CLSET_VERS 13
/* Set version number */
204
#define CLGET_PROG 14
/* Get program number */
205
#define CLSET_PROG 15
/* Set program number */
206
#define CLSET_SVC_ADDR 16
/* get server's address (netbuf) XXX */
207
#define CLSET_PUSH_TIMOD 17
/* push timod if not already present XXX */
208
#define CLSET_POP_TIMOD 18
/* pop timod XXX */
209
210
211
* Connectionless only control operations
212
213
#define CLSET_RETRY_TIMEOUT 4
/* set retry timeout (timeval) */
214
#define CLGET_RETRY_TIMEOUT 5
/* get retry timeout (timeval) */
215
216
217
* Operations which GSSAPI needs. (Bletch.)
218
219
#define CLGET_LOCAL_ADDR 19
/* get local addr (sockaddr) */
220
221
222
223
* void
224
* CLNT_DESTROY(rh);
225
* CLIENT *rh;
226
227
#define CLNT_DESTROY(rh) ((*(rh)->cl_ops->cl_destroy)(rh))
228
#define clnt_destroy(rh) ((*(rh)->cl_ops->cl_destroy)(rh))
229
230
231
232
* RPCTEST is a test program which is accessible on every rpc
233
* transport/port. It is used for testing, performance evaluation,
234
* and network administration.
235
236
237
#define RPCTEST_PROGRAM ((rpcprog_t)1)
238
#define RPCTEST_VERSION ((rpcvers_t)1)
239
#define RPCTEST_NULL_PROC ((rpcproc_t)2)
240
#define RPCTEST_NULL_BATCH_PROC ((rpcproc_t)3)
241
242
243
* By convention, procedure 0 takes null arguments and returns them
244
245
246
#define NULLPROC ((rpcproc_t)0)
247
248
249
* Below are the client handle creation routines for the various
250
* implementations of client side rpc. They can return NULL if a
251
* creation failure occurs.
252
253
254
255
* Generic client creation routine. Supported protocols are "udp", "tcp"
256
* and "unix".
257
258
__BEGIN_DECLS
259
extern
CLIENT
*clnt_create(
const
char
const
rpcprog_t,
const
rpcvers_t,
260
const
char
261
__END_DECLS
262
263
264
* Added for compatibility to old rpc 4.0. Obsoleted by clnt_vc_create().
265
266
__BEGIN_DECLS
267
extern
CLIENT
*clntunix_create(
struct
sockaddr_un
268
u_long, u_long,
int
*, u_int, u_int);
269
__END_DECLS
270
271
272
273
* Print why creation failed
274
275
__BEGIN_DECLS
276
extern
void
clnt_pcreateerror(
const
char
/* stderr */
277
extern
char
*clnt_spcreateerror(
const
char
/* string */
278
__END_DECLS
279
280
281
* Like clnt_perror(), but is more verbose in its output
282
283
__BEGIN_DECLS
284
extern
void
clnt_perrno(
enum
clnt_stat);
/* stderr */
285
extern
char
*clnt_sperrno(
enum
clnt_stat);
/* string */
286
__END_DECLS
287
288
289
* Print an English error message, given the client error code
290
291
__BEGIN_DECLS
292
extern
void
clnt_perror(
CLIENT
const
char
/* stderr */
293
extern
char
*clnt_sperror(
CLIENT
const
char
/* string */
294
__END_DECLS
295
296
297
298
* If a creation fails, the following allows the user to figure out why.
299
300
struct
rpc_createerr {
301
enum
clnt_stat cf_stat;
302
struct
rpc_err
cf_error;
/* useful when cf_stat == RPC_PMAPFAILURE */
303
304
305
extern
struct
rpc_createerr rpc_createerr;
306
307
/* For backward compatibility */
308
rpc/clnt_soc.h
309
310
#endif
/* !_RPC_CLNT_H_ */
auth.h
__rpc_client::clnt_ops
Definition:
clnt.h:100
un.h
clnt_soc.h
sockaddr_un
Definition:
un.h:49
clnt_stat.h
__rpc_client
Definition:
clnt.h:98
rpc_err
Definition:
clnt.h:72
