rtems-4.11.3
libpci
pci
cfg_peripheral.h
1
/* PCI Peripheral Configuration Library
2
3
* COPYRIGHT (c) 2010 Cobham Gaisler AB.
4
5
* The license and distribution terms for this file may be
6
* found in the file LICENSE in this distribution or at
7
* http://www.rtems.org/license/LICENSE.
8
9
10
#ifndef __PCI_CFG_PERIPHERAL_H__
11
#define __PCI_CFG_PERIPHERAL_H__
12
13
/* The user must provide a PCI configuration using the "struct pci_bus pci_hb"
14
* structure. Nothing else than setting pci_system_type and pci_bus_cnt is done
15
* by the peripheral library.
16
17
extern
int
pci_config_peripheral(
void
18
19
#endif
