27 extern int pci_bus_count(
void);
32 extern uint32_t pci_invalid_address;
36 PCI_CONFIG_LIB_NONE = 0,
37 PCI_CONFIG_LIB_AUTO = 1,
38 PCI_CONFIG_LIB_STATIC = 2,
39 PCI_CONFIG_LIB_READ = 3,
40 PCI_CONFIG_LIB_PERIPHERAL = 4,
42 extern const int pci_config_lib_type;
49 extern int (*pci_config_lib_init)(void);
50 extern void (*pci_config_lib_register)(
void *
config);
57 extern int pci_config_init(
void);
62 extern void pci_config_register(
void *
config);
68 extern void pci_cfg_print(
void);
78 #define SEARCH_CHILDREN 0 79 #define SEARCH_DEPTH 1 94 extern int pci_for_each_child(
96 int (*func)(
struct pci_dev *,
void *arg),
112 extern int pci_for_each_dev(
113 int (*func)(
struct pci_dev *,
void *arg),
123 extern int pci_find_dev(uint16_t ven, uint16_t dev,
int index,
132 extern int pci_get_dev(pci_dev_t pcidev,
struct pci_dev **ppdev);
136 #define PCI_RES_MEMIO 2 137 #define PCI_RES_MEM_PREFETCH 1 138 #define PCI_RES_MEM (PCI_RES_MEMIO | PCI_RES_MEM_PREFETCH) 139 #define PCI_RES_TYPE_MASK 0x3 140 #define PCI_RES_IO32 0x08 141 #define PCI_RES_FAIL 0x10 160 #define RES2DEV(res) ((struct pci_dev *) \ 161 ((uintptr_t)res - (uintptr_t)(res->bar * (sizeof(struct pci_res))))) 164 #define PCI_DEV_BRIDGE 0x01 165 #define PCI_DEV_RES_FAIL 0x02 168 #define PCI_BUS_IO 0x01 169 #define PCI_BUS_MEMIO 0x02 170 #define PCI_BUS_MEM 0x04 171 #define PCI_BUS_IO32 0x08 173 #define BRIDGE_RES_COUNT 2 174 #define BUS_RES_START BRIDGE_RES_COUNT 200 BRIDGE_RES_MEMIO = 3,
202 BRIDGE_RES_UNUSED1 = 5,
207 #define DEV_RES_CNT (DEV_RES_ROM + 1) 238 #if defined(PCI_CFG_AUTO_LIB) Definition: deflate.c:116
