Capture Engine Component of the RTEMS Measurement and Monitoring System. More...
| struct | rtems_capture_from_s |
| Task id and mask for the from trigger. More... | |
| struct | rtems_capture_control_s |
| Capture control structure for a group of tasks. More... | |
| struct | rtems_capture_record_s |
| struct | rtems_capture_task_record_s |
| #define | RTEMS_CAPTURE_TRIGGER_TASKS (32) |
| The number of tasks in a trigger group. | |
| #define | RTEMS_CAPTURE_CONTROL_FROM_MASK(_s) (UINT32_C(1) << (RTEMS_CAPTURE_TRIGGER_TASKS - ((_s) + 1))) |
| The from_valid mask. | |
| #define | RTEMS_CAPTURE_WATCH (1U << 0) |
| Control flags. | |
| #define | RTEMS_CAPTURE_SWITCH (1 << 0) |
| Control triggers. | |
| #define | RTEMS_CAPTURE_CREATE (1 << 1) |
| #define | RTEMS_CAPTURE_START (1 << 2) |
| #define | RTEMS_CAPTURE_RESTART (1 << 3) |
| #define | RTEMS_CAPTURE_DELETE (1 << 4) |
| #define | RTEMS_CAPTURE_BEGIN (1 << 5) |
| #define | RTEMS_CAPTURE_EXITTED (1 << 6) |
| #define | RTEMS_CAPTURE_TERMINATED (1 << 7) |
| #define | RTEMS_CAPTURE_FROM_TRIGS |
| #define | RTEMS_CAPTURE_TO_TRIGS |
| #define | RTEMS_CAPTURE_TRACED (1U << 0) |
| Task flags. | |
| #define | RTEMS_CAPTURE_INIT_TASK (1U << 1) |
| #define | RTEMS_CAPTURE_RECORD_TASK (1U << 2) |
| #define | RTEMS_CAPTURE_REAL_PRI_EVENT_MASK UINT32_C (0x000000ff) |
| The capture record event flags. | |
| #define | RTEMS_CAPTURE_CURR_PRI_EVENT_MASK UINT32_C (0x0000ff00) |
| #define | RTEMS_CAPTURE_REAL_PRIORITY_EVENT (0) |
| #define | RTEMS_CAPTURE_CURR_PRIORITY_EVENT (8) |
| #define | RTEMS_CAPTURE_EVENT_START (16) |
| #define | RTEMS_CAPTURE_CREATED_BY_EVENT UINT32_C (0x00010000) |
| #define | RTEMS_CAPTURE_CREATED_EVENT UINT32_C (0x00020000) |
| #define | RTEMS_CAPTURE_STARTED_BY_EVENT UINT32_C (0x00040000) |
| #define | RTEMS_CAPTURE_STARTED_EVENT UINT32_C (0x00080000) |
| #define | RTEMS_CAPTURE_RESTARTED_BY_EVENT UINT32_C (0x00100000) |
| #define | RTEMS_CAPTURE_RESTARTED_EVENT UINT32_C (0x00200000) |
| #define | RTEMS_CAPTURE_DELETED_BY_EVENT UINT32_C (0x00400000) |
| #define | RTEMS_CAPTURE_DELETED_EVENT UINT32_C (0x00800000) |
| #define | RTEMS_CAPTURE_TERMINATED_EVENT UINT32_C (0x01000000) |
| #define | RTEMS_CAPTURE_BEGIN_EVENT UINT32_C (0x02000000) |
| #define | RTEMS_CAPTURE_EXITTED_EVENT UINT32_C (0x04000000) |
| #define | RTEMS_CAPTURE_SWITCHED_OUT_EVENT UINT32_C (0x08000000) |
| #define | RTEMS_CAPTURE_SWITCHED_IN_EVENT UINT32_C (0x10000000) |
| #define | RTEMS_CAPTURE_TIMESTAMP UINT32_C (0x20000000) |
| #define | RTEMS_CAPTURE_EVENT_END (29) |
Typedefs | |
| typedef uint64_t | rtems_capture_time_t |
| A capture timestamp. More... | |
| typedef struct rtems_capture_from_s | rtems_capture_from_t |
| typedef struct rtems_capture_control_s | rtems_capture_control_t |
| typedef struct rtems_capture_record_s | rtems_capture_record_t |
| typedef struct rtems_capture_task_record_s | rtems_capture_task_record_t |
| typedef enum rtems_capture_trigger_mode_e | rtems_capture_trigger_mode_t |
| Capture trigger modes. More... | |
| typedef enum rtems_capture_trigger_e | rtems_capture_trigger_t |
| Capture trigger. More... | |
| typedef void(* | rtems_capture_timestamp) (rtems_capture_time_t *time) |
| Capture timestamp callout handler. More... | |
Enumerations | |
| enum | rtems_capture_trigger_mode_e { rtems_capture_to_any, rtems_capture_from_any, rtems_capture_from_to } |
| enum | rtems_capture_trigger_e { rtems_capture_switch, rtems_capture_create, rtems_capture_start, rtems_capture_restart, rtems_capture_delete, rtems_capture_begin, rtems_capture_exitted, rtems_capture_terminated } |
This is the Capture Engine component of the RTEMS Measurement and Monitoring system.
