rtems-4.11.3
libmisc
capture
capture-cli.h
1
8
9
10
11
Copyright Objective Design Systems Pty Ltd, 2002
12
All rights reserved Objective Design Systems Pty Ltd, 2002
13
Chris Johns (ccj@acm.org)
14
15
COPYRIGHT (c) 1989-2014.
16
On-Line Applications Research Corporation (OAR).
17
18
The license and distribution terms for this file may be
19
found in the file LICENSE in this distribution.
20
21
This software with is provided ``as is'' and with NO WARRANTY.
22
23
24
25
RTEMS Performance Monitoring and Measurement Framework.
26
27
This is the Target Interface Command Line Interface. You need
28
start the RTEMS monitor.
29
30
31
32
#ifndef __CAPTURE_CLI_H_
33
#define __CAPTURE_CLI_H_
34
35
#ifdef __cplusplus
36
extern
"C"
37
#endif
38
39
#include <rtems/capture.h>
40
47
rtems_status_code
48
rtems_capture_cli_init
rtems_capture_timestamp
timestamp
49
50
#ifdef __cplusplus
51
52
#endif
53
54
#endif
void(* rtems_capture_timestamp)(rtems_capture_time_t *time)
Capture timestamp callout handler.
Definition:
capture.h:238
rtems_status_code rtems_capture_cli_init(rtems_capture_timestamp timestamp)
Definition:
capture-cli.c:1180
rtems_status_code
rtems_status_code
Classic API Status.
Definition:
status.h:46
timestamp
Definition:
rtems_bsdnet.h:233
