15 #ifndef RTEMS_SCORE_ARMV4_H 16 #define RTEMS_SCORE_ARMV4_H 18 #include <rtems/score/cpu.h> 24 #ifdef ARM_MULTILIB_ARCH_V4 26 void bsp_interrupt_dispatch(
void );
28 void _ARMV4_Exception_interrupt(
void );
32 void _ARMV4_Exception_data_abort_set_handler(
33 ARMV4_Exception_abort_handler handler
36 void _ARMV4_Exception_data_abort(
void );
38 void _ARMV4_Exception_prefetch_abort_set_handler(
39 ARMV4_Exception_abort_handler handler
42 void _ARMV4_Exception_prefetch_abort(
void );
44 void _ARMV4_Exception_undef_default(
void );
46 void _ARMV4_Exception_swi_default(
void );
48 void _ARMV4_Exception_data_abort_default(
void );
50 void _ARMV4_Exception_pref_abort_default(
void );
52 void _ARMV4_Exception_reserved_default(
void );
54 void _ARMV4_Exception_irq_default(
void );
56 void _ARMV4_Exception_fiq_default(
void );
58 static inline uint32_t _ARMV4_Status_irq_enable(
void )
60 uint32_t arm_switch_reg;
68 "bic %[arm_switch_reg], %[psr], #0x80\n" 69 "msr cpsr, %[arm_switch_reg]\n" 71 : [arm_switch_reg]
"=&r" (arm_switch_reg), [psr]
"=&r" (psr)
77 static inline void _ARMV4_Status_restore( uint32_t psr )
register struct Per_CPU_Control *_SPARC_Per_CPU_current __asm__("g6")
The pointer to the current per-CPU control is available via register g6.
The set of registers that specifies the complete processor state.
Definition: cpu.h:671
#define RTEMS_COMPILER_MEMORY_BARRIER()
The following macro is a compiler specific way to ensure that memory writes are not reordered around ...
Definition: basedefs.h:146
