rtems-4.11.3
score
cpu
arm
score
arm.h
1
7
8
* COPYRIGHT (c) 2000 Canon Research Centre France SA.
9
* Emmanuel Raguet, mailto:raguet@crf.canon.fr
10
11
* Copyright (c) 2002 Advent Networks, Inc.
12
* Jay Monkman <jmonkman@adventnetworks.com>
13
14
* The license and distribution terms for this file may be
15
* found in the file LICENSE in this distribution or at
16
* http://www.rtems.org/license/LICENSE.
17
18
19
20
#ifndef _RTEMS_SCORE_ARM_H
21
#define _RTEMS_SCORE_ARM_H
22
23
#ifdef __cplusplus
24
extern
"C"
25
#endif
26
32
#if defined(__ARM_ARCH_7M__)
33
#define CPU_MODEL_NAME "ARMv7M"
34
#define ARM_MULTILIB_ARCH_V7M
35
#elif defined(__ARM_ARCH_6M__)
36
#define CPU_MODEL_NAME "ARMv6M"
37
#define ARM_MULTILIB_ARCH_V6M
38
#else
39
#define CPU_MODEL_NAME "ARMv4"
40
#define ARM_MULTILIB_ARCH_V4
41
#endif
42
43
#if defined(__ARM_ARCH_7A__) \
44
|| defined(__ARM_ARCH_7R__) \
45
46
#define ARM_MULTILIB_HAS_WFI
47
#define ARM_MULTILIB_HAS_LOAD_STORE_EXCLUSIVE
48
#define ARM_MULTILIB_HAS_BARRIER_INSTRUCTIONS
49
#endif
50
51
52
53
#define ARM_MULTILIB_HAS_THREAD_ID_REGISTER
54
#endif
55
56
57
#define ARM_MULTILIB_CACHE_LINE_MAX_64
58
#endif
59
60
#if !defined(__SOFTFP__)
61
#if defined(__ARM_NEON__)
62
#define ARM_MULTILIB_VFP_D32
63
#elif defined(__VFP_FP__)
64
#define ARM_MULTILIB_VFP_D16
65
#else
66
#error "FPU support not implemented"
67
#endif
68
#endif
69
70
#if defined(ARM_MULTILIB_VFP_D16) \
71
|| defined(ARM_MULTILIB_VFP_D32)
72
73
#endif
74
75
76
* Define the name of the CPU family.
77
78
79
#define CPU_NAME "ARM"
80
83
#ifdef __cplusplus
84
85
#endif
86
87
#endif
/* _RTEMS_SCORE_ARM_H */
