API Extensions Handler. More...
| struct | API_extensions_Control |
| The control structure which defines the points at which an API can add an extension to the system initialization thread. More... | |
Typedefs | |
| typedef void(* | API_extensions_Postdriver_hook) (void) |
| This type defines the prototype of the Postdriver Hook. | |
| void | _API_extensions_Initialization (void) |
| Initialize the API extensions handler. More... | |
| void | _API_extensions_Add (API_extensions_Control *the_extension) |
| Add extension set to the active set. More... | |
| void | _API_extensions_Run_postdriver (void) |
| Execute all post-driver extensions. More... | |
| SCORE_EXTERN Chain_Control | _API_extensions_List |
| This is the list of API extensions to the system initialization. | |
This is the API Extensions Handler.
