rtems-4.11.3
libfs
src
jffs2
src
acl.h
1
2
* JFFS2 -- Journalling Flash File System, Version 2.
3
4
* Copyright © 2006 NEC Corporation
5
6
* Created by KaiGai Kohei <kaigai@ak.jp.nec.com>
7
8
* For licensing information, see the file 'LICENCE' in this directory.
9
10
11
12
struct
jffs2_acl_entry
13
jint16_t
e_tag;
14
jint16_t
e_perm;
15
jint32_t
e_id;
16
17
18
struct
jffs2_acl_entry_short
19
jint16_t
e_tag;
20
jint16_t
e_perm;
21
22
23
struct
jffs2_acl_header
24
jint32_t
a_version;
25
26
27
#ifdef CONFIG_JFFS2_FS_POSIX_ACL
28
29
struct
posix_acl *jffs2_get_acl(
struct
inode *inode,
int
type);
30
extern
int
jffs2_acl_chmod(
struct
inode *);
31
extern
int
jffs2_init_acl_pre(
struct
inode *,
struct
inode *, umode_t *);
32
extern
int
jffs2_init_acl_post(
struct
inode *);
33
34
extern
const
struct
xattr_handler jffs2_acl_access_xattr_handler;
35
extern
const
struct
xattr_handler jffs2_acl_default_xattr_handler;
36
37
#else
38
39
#define jffs2_get_acl (NULL)
40
#define jffs2_acl_chmod(inode) (0)
41
#define jffs2_init_acl_pre(dir_i,inode,mode) (0)
42
#define jffs2_init_acl_post(inode) (0)
43
44
#endif
/* CONFIG_JFFS2_FS_POSIX_ACL */
jint16_t
Definition:
jffs2.h:104
Definition:
acl.h:19
jffs2_acl_entry
Definition:
acl.h:13
jint32_t
Definition:
jffs2.h:96
jffs2_acl_header
Definition:
acl.h:24
