zlib.h File Reference
#include "zconf.h"
Include dependency graph for zlib.h:
struct  z_stream_s
struct  gz_header_s
struct  internal_state
#define ZLIB_VERSION   "1.2.5"
#define ZLIB_VERNUM   0x1250
#define ZLIB_VER_MAJOR   1
#define ZLIB_VER_MINOR   2
#define ZLIB_VER_REVISION   5
#define ZLIB_VER_SUBREVISION   0
#define Z_NO_FLUSH   0
#define Z_PARTIAL_FLUSH   1
#define Z_SYNC_FLUSH   2
#define Z_FULL_FLUSH   3
#define Z_FINISH   4
#define Z_BLOCK   5
#define Z_TREES   6
#define Z_OK   0
#define Z_STREAM_END   1
#define Z_NEED_DICT   2
#define Z_ERRNO   (-1)
#define Z_STREAM_ERROR   (-2)
#define Z_DATA_ERROR   (-3)
#define Z_MEM_ERROR   (-4)
#define Z_BUF_ERROR   (-5)
#define Z_VERSION_ERROR   (-6)
#define Z_NO_COMPRESSION   0
#define Z_BEST_SPEED   1
#define Z_BEST_COMPRESSION   9
#define Z_DEFAULT_COMPRESSION   (-1)
#define Z_FILTERED   1
#define Z_HUFFMAN_ONLY   2
#define Z_RLE   3
#define Z_FIXED   4
#define Z_DEFAULT_STRATEGY   0
#define Z_BINARY   0
#define Z_TEXT   1
#define Z_ASCII   Z_TEXT /* for compatibility with 1.2.2 and earlier */
#define Z_UNKNOWN   2
#define Z_DEFLATED   8
#define Z_NULL   0 /* for initializing zalloc, zfree, opaque */
#define zlib_version   zlibVersion()
#define deflateInit(strm, level)   deflateInit_((strm), (level), ZLIB_VERSION, sizeof(z_stream))
#define inflateInit(strm)   inflateInit_((strm), ZLIB_VERSION, sizeof(z_stream))
#define deflateInit2(strm, level, method, windowBits, memLevel, strategy)
#define inflateInit2(strm, windowBits)   inflateInit2_((strm), (windowBits), ZLIB_VERSION, sizeof(z_stream))
#define inflateBackInit(strm, windowBits, window)
typedef voidpf alloc_func OF((voidpf opaque, uInt items, uInt size))
typedef struct z_stream_s z_stream
typedef z_stream FAR * z_streamp
typedef struct gz_header_s gz_header
typedef gz_header FAR * gz_headerp
typedef voidp gzFile
ZEXTERN const char *ZEXPORT zlibVersion OF ((void))
ZEXTERN int ZEXPORT deflate OF ((z_streamp strm, int flush))
ZEXTERN int ZEXPORT deflateEnd OF ((z_streamp strm))
ZEXTERN int ZEXPORT deflateSetDictionary OF ((z_streamp strm, const Bytef *dictionary, uInt dictLength))
ZEXTERN int ZEXPORT deflateCopy OF ((z_streamp dest, z_streamp source))
ZEXTERN int ZEXPORT deflateParams OF ((z_streamp strm, int level, int strategy))
ZEXTERN int ZEXPORT deflateTune OF ((z_streamp strm, int good_length, int max_lazy, int nice_length, int max_chain))
ZEXTERN uLong ZEXPORT deflateBound OF ((z_streamp strm, uLong sourceLen))
ZEXTERN int ZEXPORT deflatePrime OF ((z_streamp strm, int bits, int value))
ZEXTERN int ZEXPORT deflateSetHeader OF ((z_streamp strm, gz_headerp head))
ZEXTERN int ZEXPORT inflateReset2 OF ((z_streamp strm, int windowBits))
ZEXTERN int ZEXPORT inflateBack OF ((z_streamp strm, in_func in, void FAR *in_desc, out_func out, void FAR *out_desc))
ZEXTERN int ZEXPORT compress OF ((Bytef *dest, uLongf *destLen, const Bytef *source, uLong sourceLen))
ZEXTERN int ZEXPORT compress2 OF ((Bytef *dest, uLongf *destLen, const Bytef *source, uLong sourceLen, int level))
ZEXTERN uLong ZEXPORT compressBound OF ((uLong sourceLen))
ZEXTERN gzFile ZEXPORT gzdopen OF ((int fd, const char *mode))
ZEXTERN int ZEXPORT gzbuffer OF ((gzFile file, unsigned size))
ZEXTERN int ZEXPORT gzsetparams OF ((gzFile file, int level, int strategy))
ZEXTERN int ZEXPORT gzread OF ((gzFile file, voidp buf, unsigned len))
ZEXTERN int ZEXPORT gzwrite OF ((gzFile file, voidpc buf, unsigned len))
ZEXTERN int ZEXPORTVA gzprintf OF ((gzFile file, const char *format,...))
ZEXTERN int ZEXPORT gzputs OF ((gzFile file, const char *s))
ZEXTERN char *ZEXPORT gzgets OF ((gzFile file, char *buf, int len))
ZEXTERN int ZEXPORT gzputc OF ((gzFile file, int c))
ZEXTERN int ZEXPORT gzgetc OF ((gzFile file))
ZEXTERN int ZEXPORT gzungetc OF ((int c, gzFile file))
ZEXTERN int ZEXPORT gzflush OF ((gzFile file, int flush))
ZEXTERN const char *ZEXPORT gzerror OF ((gzFile file, int *errnum))
ZEXTERN uLong ZEXPORT adler32 OF ((uLong adler, const Bytef *buf, uInt len))
ZEXTERN uLong ZEXPORT crc32 OF ((uLong crc, const Bytef *buf, uInt len))
ZEXTERN int ZEXPORT deflateInit_ OF ((z_streamp strm, int level, const char *version, int stream_size))
ZEXTERN int ZEXPORT inflateInit_ OF ((z_streamp strm, const char *version, int stream_size))
ZEXTERN int ZEXPORT deflateInit2_ OF ((z_streamp strm, int level, int method, int windowBits, int memLevel, int strategy, const char *version, int stream_size))
ZEXTERN int ZEXPORT inflateInit2_ OF ((z_streamp strm, int windowBits, const char *version, int stream_size))
ZEXTERN int ZEXPORT inflateBackInit_ OF ((z_streamp strm, int windowBits, unsigned char FAR *window, const char *version, int stream_size))
ZEXTERN gzFile ZEXPORT gzopen OF ((const char *, const char *))
ZEXTERN z_off_t ZEXPORT gzseek OF ((gzFile, z_off_t, int))
ZEXTERN z_off_t ZEXPORT gztell OF ((gzFile))
ZEXTERN uLong ZEXPORT adler32_combine OF ((uLong, uLong, z_off_t))
ZEXTERN const char *ZEXPORT zError OF ((int))
ZEXTERN int ZEXPORT inflateSyncPoint OF ((z_streamp))
ZEXTERN int ZEXPORT inflateUndermine OF ((z_streamp, int))
◆ deflateInit2
#define deflateInit2 (   strm,
  level,
  method,
  windowBits,
  memLevel,
  strategy
Value:
deflateInit2_((strm),(level),(method),(windowBits),(memLevel),\
(strategy), ZLIB_VERSION, sizeof(z_stream))
Definition: zlib.h:86
◆ inflateBackInit
#define inflateBackInit (   strm,
  windowBits,
  window
Value:
inflateBackInit_((strm), (windowBits), (window), \
