yp_prot.h
1 /*
2  * Copyright (c) 1992/3 Theo de Raadt <deraadt@fsa.ca>
3  * All rights reserved.
4  *
5  * Redistribution and use in source and binary forms, with or without
6  * modification, are permitted provided that the following conditions
7  * are met:
8  * 1. Redistributions of source code must retain the above copyright
9  * notice, this list of conditions and the following disclaimer.
10  * 2. Redistributions in binary form must reproduce the above copyright
11  * notice, this list of conditions and the following disclaimer in the
12  * documentation and/or other materials provided with the distribution.
13  * 3. The name of the author may not be used to endorse or promote
14  * products derived from this software without specific prior written
15  * permission.
16  *
17  * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS
18  * OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
19  * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
20  * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR ANY
21  * DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
22  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
23  * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
24  * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
25  * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
26  * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
27  * SUCH DAMAGE.
28  *
29  * $FreeBSD: src/include/rpcsvc/yp_prot.h,v 1.10 1999/08/27 23:45:12 peter Exp $
30  */
31
32 #ifndef _RPCSVC_YP_PROT_H_
33 #define _RPCSVC_YP_PROT_H_
34
35 /*
36  * YPSERV PROTOCOL:
37  *
38  * ypserv supports the following procedures:
39  *
40  * YPPROC_NULL takes (void), returns (void).
41  * called to check if server is alive.
42  * YPPROC_DOMAIN takes (char *), returns (bool_t).
43  * true if ypserv serves the named domain.
44  * YPPROC_DOMAIN_NOACK takes (char *), returns (bool_t).
45  * true if ypserv serves the named domain.
46  * used for broadcasts, does not ack if ypserv
47  * doesn't handle named domain.
48  * YPPROC_MATCH takes (struct ypreq_key), returns (struct ypresp_val)
49  * does a lookup.
50  * YPPROC_FIRST takes (struct ypreq_nokey) returns (ypresp_key_val).
51  * gets the first key/datum from the map.
52  * YPPROC_NEXT takes (struct ypreq_key) returns (ypresp_key_val).
53  * gets the next key/datum from the map.
54  * YPPROC_XFR takes (struct ypreq_xfr), returns (void).
55  * tells ypserv to check if there is a new version of
56  * the map.
57  * YPPROC_CLEAR takes (void), returns (void).
58  * tells ypserv to flush it's file cache, so that
59  * newly transferred files will get read.
60  * YPPROC_ALL takes (struct ypreq_nokey), returns (bool_t and
61  * struct ypresp_key_val).
62  * returns an array of data, with the bool_t being
63  * false on the last datum. read the source, it's
64  * convoluted.
65  * YPPROC_MASTER takes (struct ypreq_nokey), returns (ypresp_master).
66  * YPPROC_ORDER takes (struct ypreq_nokey), returns (ypresp_order).
67  * YPPROC_MAPLIST takes (char *), returns (struct ypmaplist *).
68  */
69
70 #ifndef BOOL_DEFINED
71 typedef u_int bool;
72 #define BOOL_DEFINED
73 #endif
74
75 /* Program and version symbols, magic numbers */
76
77 #define YPPROG ((u_long)100004)
78 #define YPVERS ((u_long)2)
79 #define YPVERS_ORIG ((u_long)1)
80 #define YPMAXRECORD ((u_long)1024)
81 #define YPMAXDOMAIN ((u_long)64)
82 #define YPMAXMAP ((u_long)64)
83 #define YPMAXPEER ((u_long)256)
84
85 /*
86  * I don't know if anything of sun's depends on this, or if they
87  * simply defined it so that their own code wouldn't try to send
88  * packets over the ethernet MTU. This YP code doesn't use it.
89  */
90 #define YPMSGSZ 1600
91
92 #ifndef DATUM
93 typedef struct {
94  char *dptr;
95  int dsize;
96 } datum;
97 #define DATUM
98 #endif
99
100 struct ypmap_parms {
101  char *domain;
102  char *map;
103  u_long ordernum;
104  char *owner;
105 };
106
107 struct ypreq_key {
108  char *domain;
109  char *map;
110  datum keydat;
111 };
112
113 struct ypreq_nokey {
114  char *domain;
115  char *map;
116 };
117
118 struct ypreq_xfr {
119  struct ypmap_parms map_parms;
120  u_long transid;
121  u_long proto;
122  u_short port;
123 };
124 #define ypxfr_domain map_parms.domain
125 #define ypxfr_map map_parms.map
126 #define ypxfr_ordernum map_parms.ordernum
127 #define ypxfr_owner map_parms.owner
128
129 struct ypresp_val {
130  u_long status;
131  datum valdat;
132 };
133
134 struct ypresp_key_val {
135  u_long status;
136  datum keydat;
137  datum valdat;
138 };
139
140 struct ypresp_master {
141  u_long status;
142  char *master;
143 };
144
145 struct ypresp_order {
146  u_long status;
147  u_long ordernum;
148 };
149
150 struct ypmaplist {
151  char ypml_name[YPMAXMAP + 1];
152  struct ypmaplist *ypml_next;
153 };
154
155 struct ypresp_maplist {
156  u_long status;
157  struct ypmaplist *list;
158 };
159
160 /* ypserv procedure numbers */
161 #define YPPROC_NULL ((u_long)0)
162 #define YPPROC_DOMAIN ((u_long)1)
163 #define YPPROC_DOMAIN_NONACK ((u_long)2)
164 #define YPPROC_MATCH ((u_long)3)
165 #define YPPROC_FIRST ((u_long)4)
166 #define YPPROC_NEXT ((u_long)5)
167 #define YPPROC_XFR ((u_long)6)
168 #define YPPROC_CLEAR ((u_long)7)
169 #define YPPROC_ALL ((u_long)8)
170 #define YPPROC_MASTER ((u_long)9)
171 #define YPPROC_ORDER ((u_long)10)
172 #define YPPROC_MAPLIST ((u_long)11)
173
174 /* ypserv procedure return status values */
175 #define YP_TRUE ((long)1) /* general purpose success code */
176 #define YP_NOMORE ((long)2) /* no more entries in map */
177 #define YP_FALSE ((long)0) /* general purpose failure code */
178 #define YP_NOMAP ((long)-1) /* no such map in domain */
179 #define YP_NODOM ((long)-2) /* domain not supported */
180 #define YP_NOKEY ((long)-3) /* no such key in map */
181 #define YP_BADOP ((long)-4) /* invalid operation */
182 #define YP_BADDB ((long)-5) /* server data base is bad */
183 #define YP_YPERR ((long)-6) /* YP server error */
184 #define YP_BADARGS ((long)-7) /* request arguments bad */
185 #define YP_VERS ((long)-8) /* YP server version mismatch */
186
187 /*
188  * Sun's header file says:
189  * "Domain binding data structure, used by ypclnt package and ypserv modules.
190  * Users of the ypclnt package (or of this protocol) don't HAVE to know about
191  * it, but it must be available to users because _yp_dobind is a public
192  * interface."
193  *
194  * This is totally bogus! Nowhere else does Sun state that _yp_dobind() is
195  * a public interface, and I don't know any reason anyone would want to call
196  * it. But, just in case anyone does actually expect it to be available..
197  * we provide this.. exactly as Sun wants it.
198  */
199 struct dom_binding {
200  struct dom_binding *dom_pnext;
201  char dom_domain[YPMAXDOMAIN + 1];
202  struct sockaddr_in dom_server_addr;
203  u_short dom_server_port;
204  int dom_socket;
205  CLIENT *dom_client;
206  u_short dom_local_port;
207  long dom_vers;
208 };
209
210 /*
211  * YPBIND PROTOCOL:
212  *
213  * ypbind supports the following procedures:
214  *
215  * YPBINDPROC_NULL takes (void), returns (void).
216  * to check if ypbind is running.
217  * YPBINDPROC_DOMAIN takes (char *), returns (struct ypbind_resp).
218  * requests that ypbind start to serve the
219  * named domain (if it doesn't already)
220  * YPBINDPROC_SETDOM takes (struct ypbind_setdom), returns (void).
221  * used by ypset.
222  */
223
224 #define YPBINDPROG ((u_long)100007)
225 #define YPBINDVERS ((u_long)2)
226 #define YPBINDVERS_ORIG ((u_long)1)
227
228 /* ypbind procedure numbers */
229 #define YPBINDPROC_NULL ((u_long)0)
230 #define YPBINDPROC_DOMAIN ((u_long)1)
231 #define YPBINDPROC_SETDOM ((u_long)2)
232
233 /* error code in ypbind_resp.ypbind_status */
234 enum ypbind_resptype {
235  YPBIND_SUCC_VAL = 1,
236  YPBIND_FAIL_VAL = 2,
237  _YPBIND_RESPTYPE = 0xffffffff
238 };
239
240 /* network order, of course */
241 struct ypbind_binding {
242  struct in_addr ypbind_binding_addr;
243  u_short ypbind_binding_port;
244 };
245
246 struct ypbind_resp {
247  enum ypbind_resptype ypbind_status;
248  union {
249  u_long ypbind_error;
250  struct ypbind_binding ypbind_bindinfo;
251  } ypbind_respbody;
252 };
253
254 /* error code in ypbind_resp.ypbind_respbody.ypbind_error */
255 #define YPBIND_ERR_ERR 1 /* internal error */
256 #define YPBIND_ERR_NOSERV 2 /* no bound server for passed domain */
257 #define YPBIND_ERR_RESC 3 /* system resource allocation failure */
258
259 /*
260  * Request data structure for ypbind "Set domain" procedure.
261  */
262 struct ypbind_setdom {
263  char ypsetdom_domain[YPMAXDOMAIN + 1];
264  struct ypbind_binding ypsetdom_binding;
265  u_short ypsetdom_vers;
266 };
267 #define ypsetdom_addr ypsetdom_binding.ypbind_binding_addr
268 #define ypsetdom_port ypsetdom_binding.ypbind_binding_port
269
270 /*
271  * YPPUSH PROTOCOL:
272  *
273  * Sun says:
274  * "Protocol between clients (ypxfr, only) and yppush
275  * yppush speaks a protocol in the transient range, which
276  * is supplied to ypxfr as a command-line parameter when it
277  * is activated by ypserv."
278  *
279  * This protocol is not implemented, naturally, because this YP
280  * implementation only does the client side.
281  */
282 #define YPPUSHVERS ((u_long)1)
283 #define YPPUSHVERS_ORIG ((u_long)1)
284
285 /* yppush procedure numbers */
286 #define YPPUSHPROC_NULL ((u_long)0)
287 #define YPPUSHPROC_XFRRESP ((u_long)1)
288
289 struct yppushresp_xfr {
290  u_long transid;
291  u_long status;
292 };
293
294 /* yppush status value in yppushresp_xfr.status */
295 #define YPPUSH_SUCC ((long)1) /* Success */
296 #define YPPUSH_AGE ((long)2) /* Master's version not newer */
297 #define YPPUSH_NOMAP ((long)-1) /* Can't find server for map */
298 #define YPPUSH_NODOM ((long)-2) /* Domain not supported */
299 #define YPPUSH_RSRC ((long)-3) /* Local resource alloc failure */
300 #define YPPUSH_RPC ((long)-4) /* RPC failure talking to server */
301 #define YPPUSH_MADDR ((long)-5) /* Can't get master address */
302 #define YPPUSH_YPERR ((long)-6) /* YP server/map db error */
303 #define YPPUSH_BADARGS ((long)-7) /* Request arguments bad */
304 #define YPPUSH_DBM ((long)-8) /* Local dbm operation failed */
305 #define YPPUSH_FILE ((long)-9) /* Local file I/O operation failed */
306 #define YPPUSH_SKEW ((long)-10) /* Map version skew during transfer */
307 #define YPPUSH_CLEAR ((long)-11) /* Can't send "Clear" req to local ypserv */
308 #define YPPUSH_FORCE ((long)-12) /* No local order number in map - use -f */
309 #define YPPUSH_XFRERR ((long)-13) /* ypxfr error */
310 #define YPPUSH_REFUSED ((long)-14) /* Transfer request refused by ypserv */
311
312 struct inaddr;
313 __BEGIN_DECLS
314 bool_t xdr_datum (XDR *, datum *);
315 bool_t xdr_ypreq_key (XDR *, struct ypreq_key *);
316 bool_t xdr_ypreq_nokey (XDR *, struct ypreq_nokey *);
317 bool_t xdr_ypreq_xfr (XDR *, struct ypreq_xfr *);
318 bool_t xdr_ypresp_val (XDR *, struct ypresp_val *);
319 bool_t xdr_ypresp_key_val (XDR *, struct ypresp_key_val *);
320 bool_t xdr_ypbind_resp (XDR *, struct ypbind_resp *);
321 bool_t xdr_ypbind_setdom (XDR *, struct ypbind_setdom *);
322 bool_t xdr_yp_inaddr (XDR *, struct inaddr *);
323 bool_t xdr_ypmap_parms (XDR *, struct ypmap_parms *);
324 bool_t xdr_yppushresp_xfr (XDR *, struct yppushresp_xfr *);
325 bool_t xdr_ypresp_order (XDR *, struct ypresp_order *);
326 bool_t xdr_ypresp_master (XDR *, struct ypresp_master *);
327 bool_t xdr_ypresp_maplist (XDR *, struct ypresp_maplist *);
328 __END_DECLS
329
330 #endif /* _RPCSVC_YP_PROT_H_ */
Definition: yp_prot.h:135
Definition: yp_prot.h:200
Definition: yp_prot.h:242
Definition: yp_prot.h:247
Definition: in.h:74
Definition: xdr.h:104
Definition: domain.h:45
Definition: yp_prot.h:108
Definition: yp_prot.h:151
Definition: yp_prot.h:156
Definition: yp_prot.h:94
Definition: yp_prot.h:146
Definition: yp_prot.h:141
Definition: inet.h:93
Definition: clnt.h:98
Definition: yp_prot.h:101
Definition: yp_prot.h:130
Definition: yp_prot.h:290
Definition: yp_prot.h:114
Definition: yp_prot.h:263
Definition: yp_prot.h:119
