trees.c File Reference
#include "deflate.h"
Include dependency graph for trees.c:
struct  static_tree_desc_s
#define MAX_BL_BITS   7
#define END_BLOCK   256
#define REP_3_6   16
#define REPZ_3_10   17
#define REPZ_11_138   18
#define Buf_size   (8 * 2*sizeof(char))
#define DIST_CODE_LEN   512 /* see definition of array dist_code below */
#define send_code(s, c, tree)   send_bits(s, tree[c].Code, tree[c].Len)
#define put_short(s, w)
#define send_bits(s, value, length)
#define SMALLEST   1
#define pqremove(s, tree, top)
#define smaller(tree, n, m, depth)
local void tr_static_init OF ((void))
local void init_block OF ((deflate_state *s))
local void pqdownheap OF ((deflate_state *s, ct_data *tree, int k))
local void gen_bitlen OF ((deflate_state *s, tree_desc *desc))
local void gen_codes OF ((ct_data *tree, int max_code, ushf *bl_count))
local void scan_tree OF ((deflate_state *s, ct_data *tree, int max_code))
local void send_all_trees OF ((deflate_state *s, int lcodes, int dcodes, int blcodes))
local void compress_block OF ((deflate_state *s, ct_data *ltree, ct_data *dtree))
local unsigned bi_reverse OF ((unsigned value, int length))
local void copy_block OF ((deflate_state *s, charf *buf, unsigned len, int header))
local void tr_static_init ()
void ZLIB_INTERNAL _tr_init (deflate_state *s)
local void init_block (deflate_state *s)
local void pqdownheap (deflate_state *s, ct_data *tree, int k)
local void gen_bitlen (deflate_state *s, tree_desc *desc)
local void gen_codes (ct_data *tree, int max_code, ushf *bl_count)
local void build_tree (deflate_state *s, tree_desc *desc)
local void scan_tree (deflate_state *s, ct_data *tree, int max_code)
local void send_tree (deflate_state *s, ct_data *tree, int max_code)
local int build_bl_tree (deflate_state *s)
local void send_all_trees (deflate_state *s, int lcodes, int dcodes, int blcodes)
void ZLIB_INTERNAL _tr_stored_block (deflate_state *s, charf *buf, ulg stored_len, int last)
void ZLIB_INTERNAL _tr_align (deflate_state *s)
void ZLIB_INTERNAL _tr_flush_block (deflate_state *s, charf *buf, ulg stored_len, int last)
int ZLIB_INTERNAL _tr_tally (deflate_state *s, unsigned dist, unsigned lc)
local void compress_block (deflate_state *s, ct_data *ltree, ct_data *dtree)
local int detect_data_type (deflate_state *s)
local unsigned bi_reverse (unsigned code, int len)
local void bi_flush (deflate_state *s)
local void bi_windup (deflate_state *s)
local void copy_block (deflate_state *s, charf *buf, unsigned len, int header)
local const int extra_lbits [LENGTH_CODES] = {0,0,0,0,0,0,0,0,1,1,1,1,2,2,2,2,3,3,3,3,4,4,4,4,5,5,5,5,0}
local const int extra_dbits [D_CODES] = {0,0,0,0,1,1,2,2,3,3,4,4,5,5,6,6,7,7,8,8,9,9,10,10,11,11,12,12,13,13}
local const int extra_blbits [BL_CODES] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,2,3,7}
local const uch bl_order [BL_CODES] = {16,17,18,0,8,7,9,6,10,5,11,4,12,3,13,2,14,1,15}
local ct_data static_ltree [L_CODES+2]
local ct_data static_dtree [D_CODES]
uch _dist_code [DIST_CODE_LEN]
uch _length_code [MAX_MATCH-MIN_MATCH+1]
local int base_length [LENGTH_CODES]
local int base_dist [D_CODES]
local static_tree_desc static_l_desc
local static_tree_desc static_d_desc
local static_tree_desc static_bl_desc
◆ pqremove
#define pqremove (   s,
  tree,
  top
Value:
top = s->heap[SMALLEST]; \
s->heap[SMALLEST] = s->heap[s->heap_len--]; \
pqdownheap(s, tree, SMALLEST); \
◆ put_short
#define put_short (   s,
Value:
put_byte(s, (uch)((w) & 0xff)); \
put_byte(s, (uch)((ush)(w) >> 8)); \
◆ send_bits
#define send_bits (   s,
  value,
  length
Value:
{ int len = length;\
if (s->bi_valid > (int)Buf_size - len) {\
int val = value;\
s->bi_buf |= (ush)val << s->bi_valid;\
put_short(s, s->bi_buf);\
s->bi_buf = (ush)val >> (Buf_size - s->bi_valid);\
s->bi_valid += len - Buf_size;\
} else {\
s->bi_buf |= (ush)(value) << s->bi_valid;\
s->bi_valid += len;\
◆ smaller
#define smaller (   tree,
  n,
  m,
  depth
Value:
(tree[n].Freq < tree[m].Freq || \
(tree[n].Freq == tree[m].Freq && depth[n] <= depth[m]))
Variable Documentation
◆ static_bl_desc
Initial value:
{(const ct_data *)0, extra_blbits, 0, BL_CODES, MAX_BL_BITS}
Definition: clnt_tcp.c:92
◆ static_d_desc
Initial value:
{static_dtree, extra_dbits, 0, D_CODES, MAX_BITS}
◆ static_l_desc
Initial value:
{static_ltree, extra_lbits, LITERALS+1, L_CODES, MAX_BITS}
