Timespec API. More...
#include <rtems/score/timespec.h>
| RTEMS_INLINE_ROUTINE bool | rtems_timespec_is_valid (const struct timespec *time) |
| Is timespec valid. More... | |
| RTEMS_INLINE_ROUTINE bool | rtems_timespec_less_than (const struct timespec *lhs, const struct timespec *rhs) |
| Timespec less than operator. More... | |
| RTEMS_INLINE_ROUTINE uint32_t | rtems_timespec_add_to (struct timespec *time, const struct timespec *add) |
| Add to a timespec. More... | |
| RTEMS_INLINE_ROUTINE uint32_t | rtems_timespec_to_ticks (const struct timespec *time) |
| Convert timespec to number of ticks. More... | |
| RTEMS_INLINE_ROUTINE void | rtems_timespec_from_ticks (uint32_t ticks, struct timespec *time) |
| Convert ticks to timespec. More... | |
| RTEMS_INLINE_ROUTINE void | rtems_timespec_subtract (const struct timespec *start, const struct timespec *end, struct timespec *result) |
| Subtract two timespec. More... | |
| RTEMS_INLINE_ROUTINE void | rtems_timespec_divide_by_integer (const struct timespec *time, uint32_t iterations, struct timespec *result) |
| Divide timespec by integer. More... | |
| RTEMS_INLINE_ROUTINE void | rtems_timespec_divide (const struct timespec *lhs, const struct timespec *rhs, uint32_t *ival_percentage, uint32_t *fval_percentage) |
| Divide timespec. More... | |
| RTEMS_INLINE_ROUTINE void | rtems_timespec_set (struct timespec *_time, time_t _seconds, uint32_t _nanoseconds) |
| Set timespec to seconds nanosecond. More... | |
| RTEMS_INLINE_ROUTINE void | rtems_timespec_zero (struct timespec *_time) |
| Zero timespec. More... | |
| RTEMS_INLINE_ROUTINE time_t | rtems_timespec_get_seconds (struct timespec *_time) |
| Get seconds portion of timespec. More... | |
| RTEMS_INLINE_ROUTINE uint32_t | rtems_timespec_get_nanoseconds (struct timespec *_time) |
| Get nanoseconds portion of timespec. More... | |
| RTEMS_INLINE_ROUTINE bool | rtems_timespec_greater_than (const struct timespec *_lhs, const struct timespec *_rhs) |
| Timespec greater than operator. More... | |
| RTEMS_INLINE_ROUTINE bool | rtems_timespec_equal_to (const struct timespec *lhs, const struct timespec *rhs) |
| Timespec equal to Operator. More... | |
Timespec API.
This include file contains API for manipulating timespecs.
