#include <rtems/system.h>#include <rtems/score/isr.h>#include <rtems/score/wkspace.h>#include <rtems/score/cpu.h>
| void | _CPU_Initialize (void) |
| Performs processor dependent initialization. More... | |
| void | _CPU_ISR_Set_level (uint32_t level) |
| Sets the hardware interrupt level by the level value. More... | |
| uint32_t | _CPU_ISR_Get_level (void) |
| Return the current interrupt disable level for this task in the format used by the interrupt level portion of the task mode. More... | |
| void | _CPU_ISR_install_raw_handler (uint32_t vector, proc_ptr new_handler, proc_ptr *old_handler) |
| This routine installs a "raw" interrupt handler directly into the processor's vector table. More... | |
| void | _CPU_ISR_install_vector (uint32_t vector, proc_ptr new_handler, proc_ptr *old_handler) |
| This routine installs an interrupt vector. More... | |
| void | _CPU_Install_interrupt_stack (void) |
| This routine installs the hardware interrupt stack pointer. More... | |
| void * | _CPU_Thread_Idle_body (uintptr_t ignored) |
| This routine is the CPU dependent IDLE thread body. More... | |
| char | bsp_start_vector_table_begin [] |
