nis_tags.h File Reference
#define NIS_DIR   "data"
#define FOLLOW_LINKS   (1<<0) /* Follow link objects */
#define FOLLOW_PATH   (1<<1) /* Follow the path in a table */
#define HARD_LOOKUP   (1<<2) /* Block until successful */
#define ALL_RESULTS   (1<<3) /* Retrieve all results */
#define NO_CACHE   (1<<4) /* Do not return 'cached' results */
#define MASTER_ONLY   (1<<5) /* Get value only from master server */
#define EXPAND_NAME   (1<<6) /* Expand partitially qualified names */
#define RETURN_RESULT   (1<<7) /* Return resulting object to client */
#define ADD_OVERWRITE   (1<<8) /* Allow overwrites on ADD */
#define REM_MULTIPLE   (1<<9) /* Allow wildcard deletes */
#define MOD_SAMEOBJ   (1<<10) /* Check modified object before write */
#define ADD_RESERVED   (1<<11) /* Spare ADD semantic */
#define REM_RESERVED   (1<<12) /* Spare REM semantic */
#define MOD_EXCLUSIVE   (1<<13) /* Modify no overwrite on modified keys */
#define USE_DGRAM   (1<<16) /* Use a datagram transport */
#define NO_AUTHINFO   (1<<17) /* Don't bother attaching auth info */
#define TAG_DEBUG   1 /* set debug level */
#define TAG_STATS   2 /* Enable/disable statistics */
#define TAG_GCACHE   3 /* Flush the Group Cache */
#define TAG_GCACHE_ALL   TAG_GCACHE
#define TAG_DCACHE   4 /* Flush the directory cache */
#define TAG_DCACHE_ONE   TAG_DCACHE
#define TAG_OCACHE   5 /* Flush the Object Cache */
#define TAG_SECURE   6 /* Set the security level */
#define TAG_TCACHE_ONE   7 /* Flush the table cache */
#define TAG_DCACHE_ALL   8 /* Flush entire directory cache */
#define TAG_TCACHE_ALL   9 /* Flush entire table cache */
#define TAG_GCACHE_ONE   10 /* Flush one group object */
#define TAG_DCACHE_ONE_REFRESH   11 /* Flush and refresh one DO */
#define TAG_OPSTATS   2048 /* NIS+ operations statistics */
#define TAG_THREADS   2049 /* Child process/thread status */
#define TAG_HEAP   2050 /* Heap usage statistics */
#define TAG_UPDATES   2051 /* Updates to this service */
#define TAG_VISIBLE   2052 /* First update that isn't replicated */
#define TAG_S_DCACHE   2053 /* Directory cache statistics */
#define TAG_S_OCACHE   2054 /* Object cache statistics */
#define TAG_S_GCACHE   2055 /* Group cache statistics */
#define TAG_S_STORAGE   2056 /* Group cache statistics */
#define TAG_UPTIME   2057 /* Time that server has been up */
#define TAG_DIRLIST   2058 /* Dir served by this server */
#define TAG_NISCOMPAT   2059 /* Whether supports NIS compat mode */
#define TAG_DNSFORWARDING   2060 /* Whether DNS forwarding supported*/
#define TAG_SECURITY_LEVEL   2061 /* Security level of the server */
#define TAG_ROOTSERVER   2062 /* Whether root server */
#define IMPMEM_GROUPS   1 /* Implicit Membership allowed */
#define RECURS_GROUPS   2 /* Recursive Groups allowed */
#define NEGMEM_GROUPS   4 /* Negative Groups allowed */
