nios2.h
1
13 /*
14  * COPYRIGHT (c) 1989-1999.
15  * On-Line Applications Research Corporation (OAR).
16  *
17  * The license and distribution terms for this file may be
18  * found in the file LICENSE in this distribution or at
19  * http://www.rtems.org/license/LICENSE.
20  *
21  */
22
23 #ifndef _RTEMS_SCORE_NIOS2_H
24 #define _RTEMS_SCORE_NIOS2_H
25
26 #ifdef __cplusplus
27 extern "C" {
28 #endif
29
30 /*
31  * This file contains the information required to build
32  * RTEMS for a particular member of the NIOS2 family.
33  * It does this by setting variables to indicate which
34  * implementation dependent features are present in a particular
35  * member of the family.
36  *
37  * This is a good place to list all the known CPU models
38  * that this port supports and which RTEMS CPU model they correspond
39  * to.
40  */
41
42 /*
43  * Define the name of the CPU family and specific model.
44  */
45
46 #define CPU_NAME "NIOS2"
47 #define CPU_MODEL_NAME "nios2"
48
49 /*
50  * See also nios2-rtems-gcc -print-multi-lib for all valid combinations of
51  *
52  * -mno-hw-mul
53  * -mhw-mulx
54  * -mstack-check
55  * -pg
56  * -EB
57  * -mcustom-fpu-cfg=60-1
58  * -mcustom-fpu-cfg=60-2
59  */
60
61 #ifdef __cplusplus
62 }
63 #endif
64
65 #endif /* _RTEMS_SCORE_NIOS2_H */
