#define | BIND_4_COMPAT |
#define | __NAMESER 19961001 /* New interface version stamp. */ |
#define | NS_PACKETSZ 512 /* maximum packet size */ |
#define | NS_MAXDNAME 1025 /* maximum domain name */ |
#define | NS_MAXCDNAME 255 /* maximum compressed domain name */ |
#define | NS_MAXLABEL 63 /* maximum length of domain label */ |
#define | NS_HFIXEDSZ 12 /* #/bytes of fixed data in header */ |
#define | NS_QFIXEDSZ 4 /* #/bytes of fixed data in query */ |
#define | NS_RRFIXEDSZ 10 /* #/bytes of fixed data in r record */ |
#define | NS_INT32SZ 4 /* #/bytes of data in a u_int32_t */ |
#define | NS_INT16SZ 2 /* #/bytes of data in a u_int16_t */ |
#define | NS_INT8SZ 1 /* #/bytes of data in a u_int8_t */ |
#define | NS_INADDRSZ 4 /* IPv4 T_A */ |
#define | NS_IN6ADDRSZ 16 /* IPv6 T_AAAA */ |
#define | NS_CMPRSFLGS 0xc0 /* Flag bits indicating name compression. */ |
#define | NS_DEFAULTPORT 53 /* For both TCP and UDP. */ |
#define | ns_msg_getflag(handle, flag) |
#define | ns_msg_id(handle) ((handle)._id + 0) |
#define | ns_msg_base(handle) ((handle)._msg + 0) |
#define | ns_msg_end(handle) ((handle)._eom + 0) |
#define | ns_msg_size(handle) ((handle)._eom - (handle)._msg) |
#define | ns_msg_count(handle, section) ((handle)._counts[section] + 0) |
#define | ns_rr_name(rr) (((rr).name[0] != '\0') ? (rr).name : ".") |
#define | ns_rr_type(rr) ((rr).type + 0) |
#define | ns_rr_class(rr) ((rr).rr_class + 0) |
#define | ns_rr_ttl(rr) ((rr).ttl + 0) |
#define | ns_rr_rdlen(rr) ((rr).rdlength + 0) |
#define | ns_rr_rdata(rr) ((rr).rdata + 0) |
#define | NS_KEY_TYPEMASK 0xC000 /* Mask for "type" bits */ |
#define | NS_KEY_TYPE_AUTH_CONF 0x0000 /* Key usable for both */ |
#define | NS_KEY_TYPE_CONF_ONLY 0x8000 /* Key usable for confidentiality */ |
#define | NS_KEY_TYPE_AUTH_ONLY 0x4000 /* Key usable for authentication */ |
#define | NS_KEY_TYPE_NO_KEY 0xC000 /* No key usable for either; no key */ |
#define | NS_KEY_NO_AUTH 0x8000 /* Key unusable for authentication */ |
#define | NS_KEY_NO_CONF 0x4000 /* Key unusable for confidentiality */ |
#define | NS_KEY_EXPERIMENTAL 0x2000 /* Security is *mandatory* if bit=0 */ |
#define | NS_KEY_RESERVED3 0x1000 /* reserved - must be zero */ |
#define | NS_KEY_RESERVED4 0x0800 /* reserved - must be zero */ |
#define | NS_KEY_USERACCOUNT 0x0400 /* key is assoc. with a user acct */ |
#define | NS_KEY_ENTITY 0x0200 /* key is assoc. with entity eg host */ |
#define | NS_KEY_ZONEKEY 0x0100 /* key is zone key */ |
#define | NS_KEY_IPSEC 0x0080 /* key is for IPSEC (host or user)*/ |
#define | NS_KEY_EMAIL 0x0040 /* key is for email (MIME security) */ |
#define | NS_KEY_RESERVED10 0x0020 /* reserved - must be zero */ |
#define | NS_KEY_RESERVED11 0x0010 /* reserved - must be zero */ |
#define | NS_KEY_SIGNATORYMASK 0x000F /* key can sign RR's of same name */ |
#define | NS_KEY_RESERVED_BITMASK |
#define | NS_ALG_MD5RSA 1 /* MD5 with RSA */ |
#define | NS_ALG_EXPIRE_ONLY 253 /* No alg, no security */ |
#define | NS_ALG_PRIVATE_OID 254 /* Key begins with OID giving alg */ |
#define | NS_MD5RSA_MIN_BITS 512 /* Size of a mod or exp in bits */ |
#define | NS_MD5RSA_MAX_BITS 2552 |
#define | NS_MD5RSA_MAX_BYTES ((NS_MD5RSA_MAX_BITS+7/8)*2+3) |
#define | NS_MD5RSA_MAX_BASE64 (((NS_MD5RSA_MAX_BYTES+2)/3)*4) |
#define | NS_SIG_TYPE 0 /* Type flags */ |
#define | NS_SIG_ALG 2 /* Algorithm */ |
#define | NS_SIG_LABELS 3 /* How many labels in name */ |
#define | NS_SIG_OTTL 4 /* Original TTL */ |
#define | NS_SIG_EXPIR 8 /* Expiration time */ |
#define | NS_SIG_SIGNED 12 /* Signature time */ |
#define | NS_SIG_FOOT 16 /* Key footprint */ |
#define | NS_SIG_SIGNER 18 /* Domain name of who signed it */ |
#define | NS_NXT_BITS 8 |
#define | NS_NXT_BIT_SET( n, p) (p[(n)/NS_NXT_BITS] |= (0x80>>((n)%NS_NXT_BITS))) |
#define | NS_NXT_BIT_CLEAR(n, p) (p[(n)/NS_NXT_BITS] &= ~(0x80>>((n)%NS_NXT_BITS))) |
#define | NS_NXT_BIT_ISSET(n, p) (p[(n)/NS_NXT_BITS] & (0x80>>((n)%NS_NXT_BITS))) |
#define | NS_GET16(s, cp) |
#define | NS_GET32(l, cp) |
#define | NS_PUT16(s, cp) |
#define | NS_PUT32(l, cp) |
#define | ns_get16 __ns_get16 |
#define | ns_get32 __ns_get32 |
#define | ns_put16 __ns_put16 |
#define | ns_put32 __ns_put32 |
#define | ns_initparse __ns_initparse |
#define | ns_parserr __ns_parserr |
#define | ns_sprintrr __ns_sprintrr |
#define | ns_sprintrrf __ns_sprintrrf |
#define | ns_format_ttl __ns_format_ttl |
#define | ns_parse_ttl __ns_parse_ttl |
#define | ns_name_ntop __ns_name_ntop |
#define | ns_name_pton __ns_name_pton |
#define | ns_name_unpack __ns_name_unpack |
#define | ns_name_pack __ns_name_pack |
#define | ns_name_compress __ns_name_compress |
#define | ns_name_uncompress __ns_name_uncompress |
enum | __ns_sect {
ns_s_qd = 0,
ns_s_zn = 0,
ns_s_an = 1,
ns_s_pr = 1,
ns_s_ns = 2,
ns_s_ud = 2,
ns_s_ar = 3,
ns_s_max = 4
enum | __ns_flag {
ns_f_qr,
ns_f_opcode,
ns_f_aa,
ns_f_tc,
ns_f_rd,
ns_f_ra,
ns_f_z,
ns_f_ad,
ns_f_cd,
ns_f_rcode,
ns_f_max
enum | __ns_opcode {
ns_o_query = 0,
ns_o_iquery = 1,
ns_o_status = 2,
ns_o_notify = 4,
ns_o_update = 5,
ns_o_max = 6
enum | __ns_rcode {
ns_r_noerror = 0,
ns_r_formerr = 1,
ns_r_servfail = 2,
ns_r_nxdomain = 3,
ns_r_notimpl = 4,
ns_r_refused = 5,
ns_r_yxdomain = 6,
ns_r_yxrrset = 7,
ns_r_nxrrset = 8,
ns_r_notauth = 9,
ns_r_notzone = 10,
ns_r_max = 11
enum | __ns_update_operation { ns_uop_delete = 0,
ns_uop_add = 1,
ns_uop_max = 2
enum | __ns_type {
ns_t_a = 1,
ns_t_ns = 2,
ns_t_md = 3,
ns_t_mf = 4,
ns_t_cname = 5,
ns_t_soa = 6,
ns_t_mb = 7,
ns_t_mg = 8,
ns_t_mr = 9,
ns_t_null = 10,
ns_t_wks = 11,
ns_t_ptr = 12,
ns_t_hinfo = 13,
ns_t_minfo = 14,
ns_t_mx = 15,
ns_t_txt = 16,
ns_t_rp = 17,
ns_t_afsdb = 18,
ns_t_x25 = 19,
ns_t_isdn = 20,
ns_t_rt = 21,
ns_t_nsap = 22,
ns_t_nsap_ptr = 23,
ns_t_sig = 24,
ns_t_key = 25,
ns_t_px = 26,
ns_t_gpos = 27,
ns_t_aaaa = 28,
ns_t_loc = 29,
ns_t_nxt = 30,
ns_t_eid = 31,
ns_t_nimloc = 32,
ns_t_srv = 33,
ns_t_atma = 34,
ns_t_naptr = 35,
ns_t_opt = 41,
ns_t_ixfr = 251,
ns_t_axfr = 252,
ns_t_mailb = 253,
ns_t_maila = 254,
ns_t_any = 255,
ns_t_max = 65536
enum | __ns_class {
ns_c_in = 1,
ns_c_chaos = 3,
ns_c_hs = 4,
ns_c_none = 254,
ns_c_any = 255,
ns_c_max = 65536
__BEGIN_DECLS u_int | ns_get16 (const u_char *) |
u_long | ns_get32 (const u_char *) |
void | ns_put16 (u_int, u_char *) |
void | ns_put32 (u_long, u_char *) |
int | ns_initparse (const u_char *, int, ns_msg *) |
int | ns_parserr (ns_msg *, ns_sect, int, ns_rr *) |
int | ns_sprintrr (const ns_msg *, const ns_rr *, const char *, const char *, char *, size_t) |
int | ns_sprintrrf (const u_char *, size_t, const char *, ns_class, ns_type, u_long, const u_char *, size_t, const char *, const char *, char *, size_t) |
int | ns_format_ttl (u_long, char *, size_t) |
int | ns_parse_ttl (const char *, u_long *) |
int | ns_name_ntop (const u_char *, char *, size_t) |
int | ns_name_pton (const char *, u_char *, size_t) |
int | ns_name_unpack (const u_char *, const u_char *, const u_char *, u_char *, size_t) |
int | ns_name_pack (const u_char *, u_char *, int, const u_char **, const u_char **) |
int | ns_name_uncompress (const u_char *, const u_char *, const u_char *, char *, size_t) |
int | ns_name_compress (const char *, u_char *, size_t, const u_char **, const u_char **) |
int | ns_name_skip (const u_char **, const u_char *) |
