#include <sys/cdefs.h>
#include <sys/param.h>
#include <sys/socket.h>
#include <sys/sysctl.h>
#include <sys/time.h>
#include <sys/uio.h>
#include <netinet/in.h>
#include <netinet/in_systm.h>
#include <netinet/ip.h>
#include <netinet/ip_icmp.h>
#include <netinet/ip_var.h>
#include <arpa/inet.h>
#include <ctype.h>
#include <math.h>
#include <netdb.h>
#include <signal.h>
#include <unistd.h>
#include "err.h"
#include "sysexits.h"
#include <sys/select.h>
struct | tv32 |
#define | INADDR_LEN ((int)sizeof(in_addr_t)) |
#define | TIMEVAL_LEN ((int)sizeof(struct tv32)) |
#define | MASK_LEN (ICMP_MASKLEN - ICMP_MINLEN) |
#define | TS_LEN (ICMP_TSLEN - ICMP_MINLEN) |
#define | DEFDATALEN 56 /* default data length */ |
#define | FLOOD_BACKOFF 20000 /* usecs to back off if F_FLOOD mode */ |
#define | MAXIPLEN (sizeof(struct ip) + MAX_IPOPTLEN) |
#define | MAXICMPLEN (ICMP_ADVLENMIN + MAX_IPOPTLEN) |
#define | MAXWAIT 10000 /* max ms to wait for response */ |
#define | MAXALARM (60 * 60) /* max seconds for alarm timeout */ |
#define | MAXTOS 255 |
#define | A(bit) rcvd_tbl[(bit)>>3] /* identify byte in array */ |
#define | B(bit) (1 << ((bit) & 0x07)) /* identify bit in byte */ |
#define | SET(bit) (A(bit) |= B(bit)) |
#define | CLR(bit) (A(bit) &= (~B(bit))) |
#define | TST(bit) (A(bit) & B(bit)) |
#define | F_FLOOD 0x0001 |
#define | F_INTERVAL 0x0002 |
#define | F_NUMERIC 0x0004 |
#define | F_PINGFILLED 0x0008 |
#define | F_QUIET 0x0010 |
#define | F_RROUTE 0x0020 |
#define | F_SO_DEBUG 0x0040 |
#define | F_SO_DONTROUTE 0x0080 |
#define | F_VERBOSE 0x0100 |
#define | F_QUIET2 0x0200 |
#define | F_NOLOOP 0x0400 |
#define | F_MTTL 0x0800 |
#define | F_MIF 0x1000 |
#define | F_AUDIBLE 0x2000 |
#define | F_TTL 0x8000 |
#define | F_MISSED 0x10000 |
#define | F_ONCE 0x20000 |
#define | F_HDRINCL 0x40000 |
#define | F_MASK 0x80000 |
#define | F_TIME 0x100000 |
#define | F_SWEEP 0x200000 |
#define | F_WAITTIME 0x400000 |
#define | MAX_DUP_CHK (8 * 128) |
#define | SECOPT "" |
__FBSDID ("$FreeBSD$") | |
void | stopit (sig) |
int | options |
int | mx_dup_ck = MAX_DUP_CHK |
char | rcvd_tbl [MAX_DUP_CHK/8] |
struct sockaddr_in | whereto |
int | datalen = DEFDATALEN |
int | maxpayload |
int | s |
u_char | outpackhdr [IP_MAXPACKET] |
u_char * | outpack |
char | BBELL = '\a' |
char | BSPACE = '\b' |
char | DOT = '.' |
char * | hostname |
char * | shostname |
int | ident |
int | uid |
u_char | icmp_type = ICMP_ECHO |
u_char | icmp_type_rsp = ICMP_ECHOREPLY |
int | phdr_len = 0 |
int | send_len |
long | nmissedmax |
long | npackets |
long | nreceived |
long | nrepeats |
long | ntransmitted |
long | snpackets |
long | snreceived |
long | sntransmitted |
int | sweepmax |
int | sweepmin = 0 |
int | sweepincr = 1 |
int | interval = 1000 |
int | waittime = MAXWAIT |
long | nrcvtimeout = 0 |
int | timing |
double | tmin = 999999999.0 |
double | tmax = 0.0 |
double | tsum = 0.0 |
double | tsumsq = 0.0 |
volatile sig_atomic_t | finish_up |
volatile sig_atomic_t | siginfo_p |
