Data Structures | Macros | Typedefs | Variables
m68360.h File Reference
Definitions for Motorola MC68360 Processor. More...
struct  m360MEMCRegisters_
struct  m360SCCRegisters_
struct  m360SMCRegisters_
struct  m360MiscParms_
struct  m360TimerParms_
struct  m360IDMAparms_
struct  m360SCCparms_
struct  m360SCCENparms_
struct  m360SMCparms_
struct  m360SPIparms_
struct  m360BufferDescriptor_
struct  m360IDMABufferDescriptor_
struct  m360_
#define M360_RCCR_TIME   (1<<15) /* Enable timer */
#define M360_RCCR_TIMEP(x)   ((x)<<8) /* Timer period */
#define M360_TM_CMD_V   (1<<31) /* Set to enable timer */
#define M360_TM_CMD_R   (1<<30) /* Set for automatic restart */
#define M360_TM_CMD_TIMER(x)   ((x)<<16) /* Select timer */
#define M360_TM_CMD_PERIOD(x)   (x) /* Timer period (16 bits) */
#define M360_RFCR_MOT   (1<<4)
#define M360_RFCR_DMA_SPACE   0x8
#define M360_TFCR_MOT   (1<<4)
#define M360_TFCR_DMA_SPACE   0x8
#define M360_SMCMR_CLEN(x)   ((x)<<11) /* Character length */
#define M360_SMCMR_2STOP   (1<<10) /* 2 stop bits */
#define M360_SMCMR_PARITY   (1<<9) /* Enable parity */
#define M360_SMCMR_EVEN   (1<<8) /* Even parity */
#define M360_SMCMR_SM_GCI   (0<<4) /* GCI Mode */
#define M360_SMCMR_SM_UART   (2<<4) /* UART Mode */
#define M360_SMCMR_SM_TRANSPARENT   (3<<4) /* Transparent Mode */
#define M360_SMCMR_DM_LOOPBACK   (1<<2) /* Local loopback mode */
#define M360_SMCMR_DM_ECHO   (2<<2) /* Echo mode */
#define M360_SMCMR_TEN   (1<<1) /* Enable transmitter */
#define M360_SMCMR_REN   (1<<0) /* Enable receiver */
#define M360_SMCE_BRK   (1<<4)
#define M360_SMCE_BSY   (1<<2)
#define M360_SMCE_TX   (1<<1)
#define M360_SMCE_RX   (1<<0)
#define M360_SPMODE_LOOP   (1<<14) /* Local loopback mode */
#define M360_SPMODE_CI   (1<<13) /* Clock invert */
#define M360_SPMODE_CP   (1<<12) /* Clock phase */
#define M360_SPMODE_DIV16   (1<<11) /* Divide BRGCLK by 16 */
#define M360_SPMODE_REV   (1<<10) /* Reverse data */
#define M360_SPMODE_MASTER   (1<<9) /* SPI is master */
#define M360_SPMODE_EN   (1<<8) /* Enable SPI */
#define M360_SPMODE_CLEN(x)   ((x)<<4) /* Character length */
#define M360_SPMODE_PM(x)   (x) /* Prescaler modulus */
#define M360_SPCOM_STR   (1<<7) /* Start transmit */
#define M360_SPIE_MME   (1<<5) /* Multi-master error */
#define M360_SPIE_TXE   (1<<4) /* Tx error */
#define M360_SPIE_BSY   (1<<2) /* Busy condition*/
#define M360_SPIE_TXB   (1<<1) /* Tx buffer */
#define M360_SPIE_RXB   (1<<0) /* Rx buffer */
#define M360_BD_EMPTY   (1<<15) /* Ethernet, SCC UART, SMC UART, SPI */
#define M360_BD_WRAP   (1<<13) /* Ethernet, SCC UART, SMC UART, SPI */
#define M360_BD_INTERRUPT   (1<<12) /* Ethernet, SCC UART, SMC UART, SPI */
#define M360_BD_LAST   (1<<11) /* Ethernet, SPI */
#define M360_BD_CONTROL_CHAR   (1<<11) /* SCC UART */
#define M360_BD_FIRST_IN_FRAME   (1<<10) /* Ethernet */
#define M360_BD_ADDRESS   (1<<10) /* SCC UART */
#define M360_BD_CONTINUOUS   (1<<9) /* SCC UART, SMC UART, SPI */
#define M360_BD_MISS   (1<<8) /* Ethernet */
#define M360_BD_IDLE   (1<<8) /* SCC UART, SMC UART */
#define M360_BD_ADDRSS_MATCH   (1<<7) /* SCC UART */
#define M360_BD_LONG   (1<<5) /* Ethernet */
#define M360_BD_BREAK   (1<<5) /* SCC UART, SMC UART */
#define M360_BD_NONALIGNED   (1<<4) /* Ethernet */
#define M360_BD_FRAMING_ERROR   (1<<4) /* SCC UART, SMC UART */
#define M360_BD_SHORT   (1<<3) /* Ethernet */
#define M360_BD_PARITY_ERROR   (1<<3) /* SCC UART, SMC UART */
#define M360_BD_CRC_ERROR   (1<<2) /* Ethernet */
#define M360_BD_OVERRUN   (1<<1) /* Ethernet, SCC UART, SMC UART, SPI */
#define M360_BD_COLLISION   (1<<0) /* Ethernet */
#define M360_BD_CARRIER_LOST   (1<<0) /* SCC UART */
#define M360_BD_MASTER_ERROR   (1<<0) /* SPI */
#define M360_BD_READY   (1<<15) /* Ethernet, SCC UART, SMC UART, SPI */
#define M360_BD_PAD   (1<<14) /* Ethernet */
#define M360_BD_CTS_REPORT   (1<<11) /* SCC UART */
#define M360_BD_TX_CRC   (1<<10) /* Ethernet */
#define M360_BD_DEFER   (1<<9) /* Ethernet */
#define M360_BD_HEARTBEAT   (1<<8) /* Ethernet */
#define M360_BD_PREAMBLE   (1<<8) /* SCC UART, SMC UART */
#define M360_BD_LATE_COLLISION   (1<<7) /* Ethernet */
#define M360_BD_NO_STOP_BIT   (1<<7) /* SCC UART */
#define M360_BD_RETRY_LIMIT   (1<<6) /* Ethernet */
#define M360_BD_RETRY_COUNT(x)   (((x)&0x3C)>>2) /* Ethernet */
#define M360_BD_UNDERRUN   (1<<1) /* Ethernet, SPI */
#define M360_BD_CARRIER_LOST   (1<<0) /* Ethernet */
#define M360_BD_CTS_LOST   (1<<0) /* SCC UART */
#define M360_CR_RST   (1<<15) /* Reset communication processor */
#define M360_CR_OP_INIT_RX_TX   (0<<8) /* SCC, SMC UART, SMC GCI, SPI */
#define M360_CR_OP_INIT_RX   (1<<8) /* SCC, SMC UART, SPI */
#define M360_CR_OP_INIT_TX   (2<<8) /* SCC, SMC UART, SPI */
#define M360_CR_OP_INIT_HUNT   (3<<8) /* SCC, SMC UART */
#define M360_CR_OP_STOP_TX   (4<<8) /* SCC, SMC UART */
#define M360_CR_OP_GR_STOP_TX   (5<<8) /* SCC */
#define M360_CR_OP_INIT_IDMA   (5<<8) /* IDMA */
#define M360_CR_OP_RESTART_TX   (6<<8) /* SCC, SMC UART */
#define M360_CR_OP_CLOSE_RX_BD   (7<<8) /* SCC, SMC UART, SPI */
#define M360_CR_OP_SET_GRP_ADDR   (8<<8) /* SCC */
#define M360_CR_OP_SET_TIMER   (8<<8) /* Timer */
#define M360_CR_OP_GCI_TIMEOUT   (9<<8) /* SMC GCI */
#define M360_CR_OP_RESERT_BCS   (10<<8) /* SCC */
#define M360_CR_OP_GCI_ABORT   (10<<8) /* SMC GCI */
#define M360_CR_CHAN_SCC1   (0<<4) /* Channel selection */
#define M360_CR_CHAN_SCC2   (4<<4)
#define M360_CR_CHAN_SPI   (5<<4)
#define M360_CR_CHAN_TIMER   (5<<4)
#define M360_CR_CHAN_SCC3   (8<<4)
#define M360_CR_CHAN_SMC1   (9<<4)
#define M360_CR_CHAN_IDMA1   (9<<4)
#define M360_CR_CHAN_SCC4   (12<<4)
#define M360_CR_CHAN_SMC2   (13<<4)
#define M360_CR_CHAN_IDMA2   (13<<4)
#define M360_CR_FLG   (1<<0) /* Command flag */
#define M360_SYPCR_SWE   (1<<7) /* Software watchdog enable */
#define M360_SYPCR_SWRI   (1<<6) /* Software watchdog reset select */
#define M360_SYPCR_SWT1   (1<<5) /* Software watchdog timing bit 1 */
#define M360_SYPCR_SWT0   (1<<4) /* Software watchdog timing bit 0 */
#define M360_SYPCR_DBFE   (1<<3) /* Double bus fault monitor enable */
#define M360_SYPCR_BME   (1<<2) /* Bus monitor external enable */
#define M360_SYPCR_BMT1   (1<<1) /* Bus monitor timing bit 1 */
#define M360_SYPCR_BMT0   (1<<0) /* Bus monitor timing bit 0 */
#define M360_GMR_RCNT(x)   ((x)<<24) /* Refresh count */
#define M360_GMR_RFEN   (1<<23) /* Refresh enable */
#define M360_GMR_RCYC(x)   ((x)<<21) /* Refresh cycle length */
#define M360_GMR_PGS(x)   ((x)<<18) /* Page size */
#define M360_GMR_DPS_32BIT   (0<<16) /* DRAM port size */
#define M360_GMR_DPS_16BIT   (1<<16)
#define M360_GMR_DPS_8BIT   (2<<16)
#define M360_GMR_DPS_DSACK   (3<<16)
#define M360_GMR_WBT40   (1<<15) /* Wait between 040 transfers */
#define M360_GMR_WBTQ   (1<<14) /* Wait between 360 transfers */
#define M360_GMR_SYNC   (1<<13) /* Synchronous external access */
#define M360_GMR_EMWS   (1<<12) /* External master wait state */
#define M360_GMR_OPAR   (1<<11) /* Odd parity */
#define M360_GMR_PBEE   (1<<10) /* Parity bus error enable */
#define M360_GMR_TSS40   (1<<9) /* TS* sample for 040 */
#define M360_GMR_NCS   (1<<8) /* No CPU space */
#define M360_GMR_DWQ   (1<<7) /* Delay write for 360 */
#define M360_GMR_DW40   (1<<6) /* Delay write for 040 */
#define M360_GMR_GAMX   (1<<5) /* Global address mux enable */
#define M360_MEMC_BR_FC(x)   ((x)<<7) /* Function code limit */
#define M360_MEMC_BR_TRLXQ   (1<<6) /* Relax timing requirements */
#define M360_MEMC_BR_BACK40   (1<<5) /* Burst acknowledge to 040 */
#define M360_MEMC_BR_CSNT40   (1<<4) /* CS* negate timing for 040 */
#define M360_MEMC_BR_CSNTQ   (1<<3) /* CS* negate timing for 360 */
#define M360_MEMC_BR_PAREN   (1<<2) /* Enable parity checking */
#define M360_MEMC_BR_WP   (1<<1) /* Write Protect */
#define M360_MEMC_BR_V   (1<<0) /* Base/Option register are valid */
#define M360_MEMC_OR_TCYC(x)   ((x)<<28) /* Cycle length (clocks) */
#define M360_MEMC_OR_WAITS(x)   M360_MEMC_OR_TCYC((x)+1)
#define M360_MEMC_OR_2KB   0x0FFFF800 /* Address range */
#define M360_MEMC_OR_4KB   0x0FFFF000
#define M360_MEMC_OR_8KB   0x0FFFE000
#define M360_MEMC_OR_16KB   0x0FFFC000
#define M360_MEMC_OR_32KB   0x0FFF8000
#define M360_MEMC_OR_64KB   0x0FFF0000
#define M360_MEMC_OR_128KB   0x0FFE0000
#define M360_MEMC_OR_256KB   0x0FFC0000
#define M360_MEMC_OR_512KB   0x0FF80000
#define M360_MEMC_OR_1MB   0x0FF00000
#define M360_MEMC_OR_2MB   0x0FE00000
#define M360_MEMC_OR_4MB   0x0FC00000
#define M360_MEMC_OR_8MB   0x0F800000
#define M360_MEMC_OR_16MB   0x0F000000
#define M360_MEMC_OR_32MB   0x0E000000
#define M360_MEMC_OR_64MB   0x0C000000
#define M360_MEMC_OR_128MB   0x08000000
#define M360_MEMC_OR_256MB   0x00000000
#define M360_MEMC_OR_FCMC(x)   ((x)<<7) /* Function code mask */
#define M360_MEMC_OR_BCYC(x)   ((x)<<5) /* Burst cycle length (clocks) */
#define M360_MEMC_OR_PGME   (1<<3) /* Page mode enable */
#define M360_MEMC_OR_32BIT   (0<<1) /* Port size */
#define M360_MEMC_OR_16BIT   (1<<1)
#define M360_MEMC_OR_8BIT   (2<<1)
#define M360_MEMC_OR_DSACK   (3<<1)
#define M360_MEMC_OR_DRAM   (1<<0) /* Dynamic RAM select */
#define M360_SI_SMC2_BITS   0xFFFF0000 /* All SMC2 bits */
#define M360_SI_SMC2_TDM   (1<<31) /* Multiplexed SMC2 */
#define M360_SI_SMC2_BRG1   (0<<28) /* SMC2 clock souce */
#define M360_SI_SMC2_BRG2   (1<<28)
#define M360_SI_SMC2_BRG3   (2<<28)
#define M360_SI_SMC2_BRG4   (3<<28)
#define M360_SI_SMC2_CLK5   (0<<28)
#define M360_SI_SMC2_CLK6   (1<<28)
#define M360_SI_SMC2_CLK7   (2<<28)
#define M360_SI_SMC2_CLK8   (3<<28)
#define M360_SI_SMC1_BITS   0x0000FFFF /* All SMC1 bits */
#define M360_SI_SMC1_TDM   (1<<15) /* Multiplexed SMC1 */
#define M360_SI_SMC1_BRG1   (0<<12) /* SMC1 clock souce */
#define M360_SI_SMC1_BRG2   (1<<12)
#define M360_SI_SMC1_BRG3   (2<<12)
#define M360_SI_SMC1_BRG4   (3<<12)
#define M360_SI_SMC1_CLK1   (0<<12)
#define M360_SI_SMC1_CLK2   (1<<12)
#define M360_SI_SMC1_CLK3   (2<<12)
#define M360_SI_SMC1_CLK4   (3<<12)
#define M360_SDMA_FREEZE   (2<<13) /* Freeze on next bus cycle */
#define M360_SDMA_SISM_7   (7<<8) /* Normal interrupt service mask */
#define M360_SDMA_SAID_4   (4<<4) /* Normal arbitration ID */
#define M360_SDMA_INTE   (1<<1) /* SBER interrupt enable */
#define M360_SDMA_INTB   (1<<0) /* SBKP interrupt enable */
#define M360_BRG_RST   (1<<17) /* Reset generator */
#define M360_BRG_EN   (1<<16) /* Enable generator */
#define M360_BRG_EXTC_BRGCLK   (0<<14) /* Source is BRGCLK */
#define M360_BRG_EXTC_CLK2   (1<<14) /* Source is CLK2 pin */
#define M360_BRG_EXTC_CLK6   (2<<14) /* Source is CLK6 pin */
#define M360_BRG_ATB   (1<<13) /* Autobaud */
#define M360_BRG_115200   (13<<1) /* Assume 25 MHz clock */
#define M360_BRG_57600   (26<<1)
#define M360_BRG_38400   (40<<1)
#define M360_BRG_19200   (80<<1)
#define M360_BRG_9600   (162<<1)
#define M360_BRG_4800   (324<<1)
#define M360_BRG_2400   (650<<1)
#define M360_BRG_1200   (1301<<1)
#define M360_BRG_600   (2603<<1)
#define M360_BRG_300   ((324<<1) | 1)
#define M360_BRG_150   ((650<<1) | 1)
#define M360_BRG_75   ((1301<<1) | 1)
#define M360_PB_SPI_MISO_MSK   (1<< 3)
#define M360_PB_SPI_MOSI_MSK   (1<< 2)
#define M360_PB_SPI_CLK_MSK   (1<< 1)
typedef struct m360MEMCRegisters_ m360MEMCRegisters_t
typedef struct m360SCCRegisters_ m360SCCRegisters_t
typedef struct m360SMCRegisters_ m360SMCRegisters_t
typedef struct m360MiscParms_ m360MiscParms_t
typedef struct m360TimerParms_ m360TimerParms_t
typedef struct m360IDMAparms_ m360IDMAparms_t
typedef struct m360SCCparms_ m360SCCparms_t
typedef struct m360SCCENparms_ m360SCCENparms_t
typedef struct m360SMCparms_ m360SMCparms_t
typedef struct m360SPIparms_ m360SPIparms_t
typedef struct m360BufferDescriptor_ m360BufferDescriptor_t
typedef struct m360IDMABufferDescriptor_ m360IDMABufferDescriptor_t
typedef struct m360_ m360_t
volatile m360_t m360
