score
cpu
m68k
m68k
m68302.h
1
14
15
* COPYRIGHT 1995 David W. Glessner.
16
17
* Redistribution and use in source and binary forms are permitted
18
* provided that the following conditions are met:
19
* 1. Redistribution of source code and documentation must retain
20
* the above copyright notice, this list of conditions and the
21
* following disclaimer.
22
* 2. The name of the author may not be used to endorse or promote
23
* products derived from this software without specific prior
24
* written permission.
25
26
* This software is provided "AS IS" without warranty of any kind,
27
* either expressed or implied, including, but not limited to, the
28
* implied warranties of merchantability, title and fitness for a
29
* particular purpose.
30
31
32
33
34
#ifndef _RTEMS_M68K_M68302_H
35
#define _RTEMS_M68K_M68302_H
36
37
38
* BAR - Base Address Register
39
* Section 2.7
40
41
#define M302_BAR (*((volatile uint16_t *) 0xf2))
42
43
44
* SCR - System Control Register
45
* Section 3.8.1
46
47
#define M302_SCR (*((volatile uint32_t *) 0xf4))
48
49
* SCR bits
50
51
#define RBIT_SCR_IPA 0x08000000
52
#define RBIT_SCR_HWT 0x04000000
53
#define RBIT_SCR_WPV 0x02000000
54
#define RBIT_SCR_ADC 0x01000000
55
56
#define RBIT_SCR_ERRE 0x00400000
57
#define RBIT_SCR_VGE 0x00200000
58
#define RBIT_SCR_WPVE 0x00100000
59
#define RBIT_SCR_RMCST 0x00080000
60
#define RBIT_SCR_EMWS 0x00040000
61
#define RBIT_SCR_ADCE 0x00020000
62
#define RBIT_SCR_BCLM 0x00010000
63
64
#define RBIT_SCR_FRZW 0x00008000
65
#define RBIT_SCR_FRZ2 0x00004000
66
#define RBIT_SCR_FRZ1 0x00002000
67
#define RBIT_SCR_SAM 0x00001000
68
#define RBIT_SCR_HWDEN 0x00000800
69
#define RBIT_SCR_HWDCN2 0x00000400
70
#define RBIT_SCR_HWDCN1 0x00000200
/* 512 clocks */
71
#define RBIT_SCR_HWDCN0 0x00000100
/* 128 clocks */
72
73
#define RBIT_SCR_LPREC 0x00000080
74
#define RBIT_SCR_LPP16 0x00000040
75
#define RBIT_SCR_LPEN 0x00000020
76
#define RBIT_SCR_LPCLKDIV 0x0000001f
77
78
79
80
* 68000 interrupt and trap vector numbers
81
82
#define M68K_IVEC_BUS_ERROR 2
83
#define M68K_IVEC_ADDRESS_ERROR 3
84
#define M68K_IVEC_ILLEGAL_OPCODE 4
85
#define M68K_IVEC_ZERO_DIVIDE 5
86
#define M68K_IVEC_CHK 6
87
#define M68K_IVEC_TRAPV 7
88
#define M68K_IVEC_PRIVILEGE 8
89
#define M68K_IVEC_TRACE 9
90
#define M68K_IVEC_LINE_A 10
91
#define M68K_IVEC_LINE_F 11
92
/* Unassigned, Reserved 12-14 */
93
#define M68K_IVEC_UNINITIALIZED_INT 15
94
/* Unassigned, Reserved 16-23 */
95
#define M68K_IVEC_SPURIOUS_INT 24
96
97
#define M68K_IVEC_LEVEL1_AUTOVECTOR 25
98
#define M68K_IVEC_LEVEL2_AUTOVECTOR 26
99
#define M68K_IVEC_LEVEL3_AUTOVECTOR 27
100
#define M68K_IVEC_LEVEL4_AUTOVECTOR 28
101
#define M68K_IVEC_LEVEL5_AUTOVECTOR 29
102
#define M68K_IVEC_LEVEL6_AUTOVECTOR 30
103
#define M68K_IVEC_LEVEL7_AUTOVECTOR 31
104
105
#define M68K_IVEC_TRAP0 32
106
#define M68K_IVEC_TRAP1 33
107
#define M68K_IVEC_TRAP2 34
108
#define M68K_IVEC_TRAP3 35
109
#define M68K_IVEC_TRAP4 36
110
#define M68K_IVEC_TRAP5 37
111
#define M68K_IVEC_TRAP6 38
112
#define M68K_IVEC_TRAP7 39
113
#define M68K_IVEC_TRAP8 40
114
#define M68K_IVEC_TRAP9 41
115
#define M68K_IVEC_TRAP10 42
116
#define M68K_IVEC_TRAP11 43
117
#define M68K_IVEC_TRAP12 44
118
#define M68K_IVEC_TRAP13 45
119
#define M68K_IVEC_TRAP14 46
120
#define M68K_IVEC_TRAP15 47
121
122
* Unassigned, Reserved 48-59
123
124
* Note: Vectors 60-63 are used by the MC68302 (e.g. BAR, SCR).
125
126
127
128
* MC68302 Interrupt Vectors
129
* Section 3.2
130
131
enum
m68302_ivec_e {
132
M302_IVEC_ERR =0,
133
M302_IVEC_PB8 =1,
/* General-Purpose Interrupt 0 */
134
M302_IVEC_SMC2 =2,
135
M302_IVEC_SMC1 =3,
136
M302_IVEC_TIMER3 =4,
137
M302_IVEC_SCP =5,
138
M302_IVEC_TIMER2 =6,
139
M302_IVEC_PB9 =7,
/* General-Purpose Interrupt 1 */
140
M302_IVEC_SCC3 =8,
141
M302_IVEC_TIMER1 =9,
142
M302_IVEC_SCC2 =10,
143
M302_IVEC_IDMA =11,
144
M302_IVEC_SDMA =12,
/* SDMA Channels Bus Error */
145
M302_IVEC_SCC1 =13,
146
M302_IVEC_PB10 =14,
/* General-Purpose Interrupt 2 */
147
M302_IVEC_PB11 =15,
/* General-Purpose Interrupt 3 */
148
M302_IVEC_IRQ1 =17,
/* External Device */
149
M302_IVEC_IRQ6 =22,
150
M302_IVEC_IRQ7 =23
151
152
153
154
155
* GIMR - Global Interrupt Mode Register
156
* Section 3.2.5.1
157
158
#define RBIT_GIMR_MOD (1<<15)
159
#define RBIT_GIMR_IV7 (1<<14)
160
#define RBIT_GIMR_IV6 (1<<13)
161
#define RBIT_GIMR_IV1 (1<<12)
162
#define RBIT_GIMR_ET7 (1<<10)
163
#define RBIT_GIMR_ET6 (1<<9)
164
#define RBIT_GIMR_ET1 (1<<8)
165
#define RBIT_GIMR_VECTOR (7<<5)
166
167
168
* IPR - Interrupt Pending Register (Section 3.2.5.2)
169
* IMR - Interrupt Mask Register (Section 3.2.5.3)
170
* ISR - Interrupt In-Service Register (Section 3.2.5.4)
171
172
#define RBIT_IPR_PB11 (1<<15)
173
#define RBIT_IPR_PB10 (1<<14)
174
#define RBIT_IPR_SCC1 (1<<13)
175
#define RBIT_IPR_SDMA (1<<12)
176
#define RBIT_IPR_IDMA (1<<11)
177
#define RBIT_IPR_SCC2 (1<<10)
178
#define RBIT_IPR_TIMER1 (1<<9)
179
#define RBIT_IPR_SCC3 (1<<8)
180
#define RBIT_IPR_PB9 (1<<7)
181
#define RBIT_IPR_TIMER2 (1<<6)
182
#define RBIT_IPR_SCP (1<<5)
183
#define RBIT_IPR_TIMER3 (1<<4)
184
#define RBIT_IPR_SMC1 (1<<3)
185
#define RBIT_IPR_SMC2 (1<<2)
186
#define RBIT_IPR_PB8 (1<<1)
187
#define RBIT_IPR_ERR (1<<0)
188
189
#define RBIT_ISR_PB11 (1<<15)
190
#define RBIT_ISR_PB10 (1<<14)
191
#define RBIT_ISR_SCC1 (1<<13)
192
#define RBIT_ISR_SDMA (1<<12)
193
#define RBIT_ISR_IDMA (1<<11)
194
#define RBIT_ISR_SCC2 (1<<10)
195
#define RBIT_ISR_TIMER1 (1<<9)
196
#define RBIT_ISR_SCC3 (1<<8)
197
#define RBIT_ISR_PB9 (1<<7)
198
#define RBIT_ISR_TIMER2 (1<<6)
199
#define RBIT_ISR_SCP (1<<5)
200
#define RBIT_ISR_TIMER3 (1<<4)
201
#define RBIT_ISR_SMC1 (1<<3)
202
#define RBIT_ISR_SMC2 (1<<2)
203
#define RBIT_ISR_PB8 (1<<1)
204
205
#define RBIT_IMR_PB11 (1<<15)
/* PB11 Interrupt Mask */
206
#define RBIT_IMR_PB10 (1<<14)
/* PB10 Interrupt Mask */
207
#define RBIT_IMR_SCC1 (1<<13)
/* SCC1 Interrupt Mask */
208
#define RBIT_IMR_SDMA (1<<12)
/* SDMA Interrupt Mask */
209
#define RBIT_IMR_IDMA (1<<11)
/* IDMA Interrupt Mask */
210
#define RBIT_IMR_SCC2 (1<<10)
/* SCC2 Interrupt Mask */
211
#define RBIT_IMR_TIMER1 (1<<9)
/* TIMER1 Interrupt Mask */
212
#define RBIT_IMR_SCC3 (1<<8)
/* SCC3 Interrupt Mask */
213
#define RBIT_IMR_PB9 (1<<7)
/* PB9 Interrupt Mask */
214
#define RBIT_IMR_TIMER2 (1<<6)
/* TIMER2 Interrupt Mask */
215
#define RBIT_IMR_SCP (1<<5)
/* SCP Interrupt Mask */
216
#define RBIT_IMR_TIMER3 (1<<4)
/* TIMER3 Interrupt Mask */
217
#define RBIT_IMR_SMC1 (1<<3)
/* SMC1 Interrupt Mask */
218
#define RBIT_IMR_SMC2 (1<<2)
/* SMC2 Interrupt Mask */
219
#define RBIT_IMR_PB8 (1<<1)
/* PB8 Interrupt Mask */
220
221
222
223
* DRAM Refresh
224
* Section 3.9
225
226
* The DRAM refresh memory map replaces the SCC2 Tx BD 6 and Tx BD 7
227
* structures in the parameter RAM.
228
229
* Access to the DRAM registers can be accomplished by
230
* the following approach:
231
232
* volatile m302_DRAM_refresh_t *dram;
233
* dram = (volatile m302_DRAM_refresh_t *) &m302.scc2.bd.tx[6];
234
235
* Then simply use pointer references (e.g. dram->count = 3).
236
237
typedef
struct
238
uint16_t dram_high;
/* DRAM high address and FC */
239
uint16_t dram_low;
/* DRAM low address */
240
uint16_t increment;
/* increment step (bytes/row) */
241
uint16_t count;
/* RAM refresh cycle count (#rows) */
242
uint16_t t_ptr_h;
/* temporary refresh high addr & FC */
243
uint16_t t_ptr_l;
/* temporary refresh low address */
244
uint16_t t_count;
/* temporary refresh cycles count */
245
uint16_t res;
/* reserved */
246
m302_DRAM_refresh_t
247
248
249
250
* TMR - Timer Mode Register (for timers 1 and 2)
251
* Section 3.5.2.1
252
253
#define RBIT_TMR_ICLK_STOP (0<<1)
254
#define RBIT_TMR_ICLK_MASTER (1<<1)
255
#define RBIT_TMR_ICLK_MASTER16 (2<<1)
256
#define RBIT_TMR_ICLK_TIN (3<<1)
257
258
#define RBIT_TMR_OM (1<<5)
259
#define RBIT_TMR_ORI (1<<4)
260
#define RBIT_TMR_FRR (1<<3)
261
#define RBIT_TMR_RST (1<<0)
262
263
264
265
* TER - Timer Event Register (for timers 1 and 2)
266
* Section 3.5.2.5
267
268
#define RBIT_TER_REF (1<<1)
/* Output Reference Event */
269
#define RBIT_TER_CAP (1<<0)
/* Capture Event */
270
271
272
273
* SCC Buffer Descriptors and Buffer Descriptors Table
274
* Section 4.5.5
275
276
typedef
struct
m302_SCC_bd
277
uint16_t status;
/* status and control */
278
uint16_t length;
/* data length */
279
volatile
uint8_t *buffer;
/* data buffer pointer */
280
m302_SCC_bd_t
281
282
typedef
struct
283
m302_SCC_bd_t
rx[8];
/* receive buffer descriptors */
284
m302_SCC_bd_t
tx[8];
/* transmit buffer descriptors */
285
m302_SCC_bd_table_t
286
287
288
289
* SCC Parameter RAM (offset 0x080 from an SCC Base)
290
* Section 4.5.6
291
292
* Each SCC parameter RAM area begins at offset 0x80 from each SCC base
293
* area (0x400, 0x500, or 0x600 from the dual-port RAM base).
294
295
* Offsets 0x9c-0xbf from each SCC base area compose the protocol-specific
296
* portion of the SCC parameter RAM.
297
298
typedef
struct
299
uint8_t rfcr;
/* Rx Function Code */
300
uint8_t tfcr;
/* Tx Function Code */
301
uint16_t mrblr;
/* Maximum Rx Buffer Length */
302
uint16_t _rstate;
/* Rx Internal State */
303
uint8_t res2;
304
uint8_t rbd;
/* Rx Internal Buffer Number */
305
uint32_t _rdptr;
/* Rx Internal Data Pointer */
306
uint16_t _rcount;
/* Rx Internal Byte Count */
307
uint16_t _rtmp;
/* Rx Temp */
308
uint16_t _tstate;
/* Tx Internal State */
309
uint8_t res7;
310
uint8_t tbd;
/* Tx Internal Buffer Number */
311
uint32_t _tdptr;
/* Tx Internal Data Pointer */
312
uint16_t _tcount;
/* Tx Internal Byte Count */
313
uint16_t _ttmp;
/* Tx Temp */
314
m302_SCC_parameters_t
315
316
317
* UART-Specific SCC Parameter RAM
318
* Section 4.5.11.3
319
320
typedef
struct
321
uint16_t max_idl;
/* Maximum IDLE Characters (rx) */
322
uint16_t idlc;
/* Temporary rx IDLE counter */
323
uint16_t brkcr;
/* Break Count Register (tx) */
324
uint16_t parec;
/* Receive Parity Error Counter */
325
uint16_t frmec;
/* Receive Framing Error Counter */
326
uint16_t nosec;
/* Receive Noise Counter */
327
uint16_t brkec;
/* Receive Break Condition Counter */
328
uint16_t uaddr1;
/* UART ADDRESS Character 1 */
329
uint16_t uaddr2;
/* UART ADDRESS Character 2 */
330
uint16_t rccr;
/* Receive Control Character Register */
331
uint16_t character[8];
/* Control Characters 1 through 8*/
332
m302_SCC_UartSpecific_t
333
334
* This definition allows for the checking of receive buffers
335
* for errors.
336
337
338
#define RCV_ERR 0x003F
339
340
341
* UART receive buffer descriptor bit definitions.
342
* Section 4.5.11.14
343
344
#define RBIT_UART_CTRL (1<<11)
/* buffer contains a control char */
345
#define RBIT_UART_ADDR (1<<10)
/* first byte contains an address */
346
#define RBIT_UART_MATCH (1<<9)
/* indicates which addr char matched */
347
#define RBIT_UART_IDLE (1<<8)
/* buffer closed due to IDLE sequence */
348
#define RBIT_UART_BR (1<<5)
/* break sequence was received */
349
#define RBIT_UART_FR (1<<4)
/* framing error was received */
350
#define RBIT_UART_PR (1<<3)
/* parity error was received */
351
#define RBIT_UART_OV (1<<1)
/* receiver overrun occurred */
352
#define RBIT_UART_CD (1<<0)
/* carrier detect lost */
353
#define RBIT_UART_STATUS 0x003B
/* all status bits */
354
355
356
* UART transmit buffer descriptor bit definitions.
357
* Section 4.5.11.15
358
359
#define RBIT_UART_CR (1<<11)
/* clear-to-send report
360
* this results in two idle bits
361
* between back-to-back frames
362
363
#define RBIT_UART_A (1<<10)
/* buffer contains address characters
364
* only valid in multidrop mode (UM0=1)
365
366
#define RBIT_UART_PREAMBLE (1<<9)
/* send preamble before data */
367
#define RBIT_UART_CTS_LOST (1<<0)
/* CTS lost */
368
369
370
* UART event register
371
* Section 4.5.11.16
372
373
#define M302_UART_EV_CTS (1<<7)
/* CTS status changed */
374
#define M302_UART_EV_CD (1<<6)
/* carrier detect status changed */
375
#define M302_UART_EV_IDL (1<<5)
/* IDLE sequence status changed */
376
#define M302_UART_EV_BRK (1<<4)
/* break character was received */
377
#define M302_UART_EV_CCR (1<<3)
/* control character received */
378
#define M302_UART_EV_TX (1<<1)
/* buffer has been transmitted */
379
#define M302_UART_EV_RX (1<<0)
/* buffer has been received */
380
381
382
383
* HDLC-Specific SCC Parameter RAM
384
* Section 4.5.12.3
385
386
* c_mask_l should be 0xF0B8 for 16-bit CRC, 0xdebb for 32-bit CRC
387
* c_mask_h is a don't care for 16-bit CRC, 0x20E2 for 32-bit CRC
388
389
typedef
struct
390
uint16_t rcrc_l;
/* Temp Receive CRC Low */
391
uint16_t rcrc_h;
/* Temp Receive CRC High */
392
uint16_t c_mask_l;
/* CRC Mask Low */
393
uint16_t c_mask_h;
/* CRC Mask High */
394
uint16_t tcrc_l;
/* Temp Transmit CRC Low */
395
uint16_t tcrc_h;
/* Temp Transmit CRC High */
396
397
uint16_t disfc;
/* Discard Frame Counter */
398
uint16_t crcec;
/* CRC Error Counter */
399
uint16_t abtsc;
/* Abort Sequence Counter */
400
uint16_t nmarc;
/* Nonmatching Address Received Cntr */
401
uint16_t retrc;
/* Frame Retransmission Counter */
402
403
uint16_t mflr;
/* Maximum Frame Length Register */
404
uint16_t max_cnt;
/* Maximum_Length Counter */
405
406
uint16_t hmask;
/* User Defined Frame Address Mask */
407
uint16_t haddr1;
/* User Defined Frame Address */
408
uint16_t haddr2;
409
uint16_t haddr3;
410
uint16_t haddr4;
411
m302_SCC_HdlcSpecific_t
412
413
* HDLC receiver buffer descriptor bit definitions
414
* Section 4.5.12.10
415
416
#define RBIT_HDLC_EMPTY_BIT 0x8000
/* buffer associated with BD is empty */
417
#define RBIT_HDLC_LAST_BIT 0x0800
/* buffer is last in a frame */
418
#define RBIT_HDLC_FIRST_BIT 0x0400
/* buffer is first in a frame */
419
#define RBIT_HDLC_FRAME_LEN 0x0020
/* receiver frame length violation */
420
#define RBIT_HDLC_NONOCT_Rx 0x0010
/* received non-octet aligned frame */
421
#define RBIT_HDLC_ABORT_SEQ 0x0008
/* received abort sequence */
422
#define RBIT_HDLC_CRC_ERROR 0x0004
/* frame contains a CRC error */
423
#define RBIT_HDLC_OVERRUN 0x0002
424
#define RBIT_HDLC_CD_LOST 0x0001
425
426
427
* HDLC transmit buffer descriptor bit definitions
428
* Section 4.5.12.11
429
430
#define RBIT_HDLC_READY_BIT 0x8000
/* buffer is ready to transmit */
431
#define RBIT_HDLC_EXT_BUFFER 0x4000
/* buffer is in external memory */
432
#define RBIT_HDLC_WRAP_BIT 0x2000
/* last buffer in bd table, so wrap */
433
#define RBIT_HDLC_WAKE_UP 0x1000
/* interrupt when buffer serviced */
434
/* buffer is last in the frame */
435
#define RBIT_HDLC_TxCRC_BIT 0x0400
/* transmit a CRC sequence */
436
#define RBIT_HDLC_UNDERRUN 0x0002
/* transmitter underrun */
437
#define RBIT_HDLC_CTS_LOST 0x0001
/* CTS lost */
438
439
440
* HDLC event register bit definitions
441
* Section 4.5.12.12
442
443
#define RBIT_HDLC_CTS 0x80
444
#define RBIT_HDLC_CD 0x40
445
#define RBIT_HDLC_IDL 0x20
446
#define RBIT_HDLC_TXE 0x10
/* transmit error */
447
#define RBIT_HDLC_RXF 0x08
/* received frame */
448
#define RBIT_HDLC_BSY 0x04
/* frame rcvd and discarded due to
449
* lack of buffers
450
451
#define RBIT_HDLC_TXB 0x02
452
#define RBIT_HDLC_RXB 0x01
/* received buffer */
453
454
455
456
typedef
struct
457
m302_SCC_bd_table_t
bd;
/* +000 Buffer Descriptor Table */
458
parm;
/* +080 Common Parameter RAM */
459
union
/* +09C Protocol-Specific Parm RAM */
460
uart;
461
hdlc;
462
} prot;
463
uint8_t res[0x040];
/* +0C0 reserved, (not implemented) */
464
m302_SCC_t
465
466
467
468
* Common SCC Registers
469
470
typedef
struct
471
uint16_t res1;
472
uint16_t scon;
/* SCC Configuration Register 4.5.2 */
473
uint16_t scm;
/* SCC Mode Register 4.5.3 */
474
uint16_t dsr;
/* SCC Data Synchronization Register 4.5.4 */
475
uint8_t scce;
/* SCC Event Register 4.5.8.1 */
476
uint8_t res2;
477
uint8_t sccm;
/* SCC Mask Register 4.5.8.2 */
478
uint8_t res3;
479
uint8_t sccs;
/* SCC Status Register 4.5.8.3 */
480
uint8_t res4;
481
uint16_t res5;
482
m302_SCC_Registers_t
483
484
485
* SCON - SCC Configuration Register
486
* Section 4.5.2
487
488
#define RBIT_SCON_WOMS (1<<15)
/* Wired-OR Mode Select (NMSI mode only)
489
* When set, the TXD driver is an
490
* open-drain output */
491
#define RBIT_SCON_EXTC (1<<14)
/* External Clock Source */
492
#define RBIT_SCON_TCS (1<<13)
/* Transmit Clock Source */
493
#define RBIT_SCON_RCS (1<<12)
/* Receive Clock Source */
494
495
496
* SCM - SCC Mode Register bit definitions
497
* Section 4.5.3
498
* The parameter-specific mode bits occupy bits 15 through 6.
499
500
#define RBIT_SCM_ENR (1<<3)
/* Enable receiver */
501
#define RBIT_SCM_ENT (1<<2)
/* Enable transmitter */
502
503
504
505
* Internal MC68302 Registers
506
* starts at offset 0x800 from dual-port RAM base
507
* Section 2.8
508
509
typedef
struct
510
/* offset +800 */
511
uint16_t res0;
512
uint16_t cmr;
/* IDMA Channel Mode Register */
513
uint32_t sapr;
/* IDMA Source Address Pointer */
514
uint32_t dapr;
/* IDMA Destination Address Pointer */
515
uint16_t bcr;
/* IDMA Byte Count Register */
516
uint8_t csr;
/* IDMA Channel Status Register */
517
uint8_t res1;
518
uint8_t fcr;
/* IDMA Function Code Register */
519
uint8_t res2;
520
521
/* offset +812 */
522
uint16_t gimr;
/* Global Interrupt Mode Register */
523
uint16_t ipr;
/* Interrupt Pending Register */
524
uint16_t imr;
/* Interrupt Mask Register */
525
uint16_t isr;
/* Interrupt In-Service Register */
526
uint16_t res3;
527
uint16_t res4;
528
529
/* offset +81e */
530
uint16_t pacnt;
/* Port A Control Register */
531
uint16_t paddr;
/* Port A Data Direction Register */
532
uint16_t padat;
/* Port A Data Register */
533
uint16_t pbcnt;
/* Port B Control Register */
534
uint16_t pbddr;
/* Port B Data Direction Register */
535
uint16_t pbdat;
/* Port B Data Register */
536
uint16_t res5;
537
538
/* offset +82c */
539
uint16_t res6;
540
uint16_t res7;
541
542
uint16_t br0;
/* Base Register (CS0) */
543
uint16_t or0;
/* Option Register (CS0) */
544
uint16_t br1;
/* Base Register (CS1) */
545
uint16_t or1;
/* Option Register (CS1) */
546
uint16_t br2;
/* Base Register (CS2) */
547
uint16_t or2;
/* Option Register (CS2) */
548
uint16_t br3;
/* Base Register (CS3) */
549
uint16_t or3;
/* Option Register (CS3) */
550
551
/* offset +840 */
552
uint16_t tmr1;
/* Timer Unit 1 Mode Register */
553
uint16_t trr1;
/* Timer Unit 1 Reference Register */
554
uint16_t tcr1;
/* Timer Unit 1 Capture Register */
555
uint16_t tcn1;
/* Timer Unit 1 Counter */
556
uint8_t res8;
557
uint8_t ter1;
/* Timer Unit 1 Event Register */
558
uint16_t wrr;
/* Watchdog Reference Register */
559
uint16_t wcn;
/* Watchdog Counter */
560
uint16_t res9;
561
uint16_t tmr2;
/* Timer Unit 2 Mode Register */
562
uint16_t trr2;
/* Timer Unit 2 Reference Register */
563
uint16_t tcr2;
/* Timer Unit 2 Capture Register */
564
uint16_t tcn2;
/* Timer Unit 2 Counter */
565
uint8_t resa;
566
uint8_t ter2;
/* Timer Unit 2 Event Register */
567
uint16_t resb;
568
uint16_t resc;
569
uint16_t resd;
570
571
/* offset +860 */
572
uint8_t cr;
/* Command Register */
573
uint8_t rese[0x1f];
574
575
/* offset +880, +890, +8a0 */
576
scc[3];
/* SCC1, SCC2, SCC3 Registers */
577
578
/* offset +8b0 */
579
uint16_t spmode;
/* SCP,SMC Mode and Clock Cntrl Reg */
580
uint16_t simask;
/* Serial Interface Mask Register */
581
uint16_t simode;
/* Serial Interface Mode Register */
582
m302_internalReg_t
583
584
585
586
* MC68302 dual-port RAM structure.
587
* (Includes System RAM, Parameter RAM, and Internal Registers).
588
* Section 2.8
589
590
typedef
struct
591
uint8_t mem[0x240];
/* +000 User Data Memory */
592
uint8_t res1[0x1c0];
/* +240 reserved, (not implemented) */
593
m302_SCC_t
scc1;
/* +400 SCC1 */
594
m302_SCC_t
scc2;
/* +500 SCC2 */
595
m302_SCC_t
scc3;
/* +600 SCC3 */
596
uint8_t res2[0x100];
/* +700 reserved, (not implemented) */
597
m302_internalReg_t
reg;
/* +800 68302 Internal Registers */
598
m302_dualPortRAM_t
599
600
/* some useful defines the some of the registers above */
601
602
603
604
MC68302 Chip Select Registers
605
p3-46 2nd Edition
606
607
608
#define BR_ENABLED 1
609
#define BR_DISABLED 0
610
#define BR_FC_NULL 0
611
#define BR_READ_ONLY 0
612
#define BR_READ_WRITE 2
613
#define OR_DTACK_0 0x0000
614
#define OR_DTACK_1 0x2000
615
#define OR_DTACK_2 0x4000
616
#define OR_DTACK_3 0x6000
617
#define OR_DTACK_4 0x8000
618
#define OR_DTACK_5 0xA000
619
#define OR_DTACK_6 0xC000
620
#define OR_DTACK_EXT 0xE000
621
#define OR_SIZE_64K 0x1FE0
622
#define OR_SIZE_128K 0x1FC0
623
#define OR_SIZE_256K 0x1F80
624
#define OR_SIZE_512K 0x1F00
625
#define OR_SIZE_1M 0x1E00
626
#define OR_SIZE_2M 0x1C00
627
#define OR_MASK_RW 0x0000
628
#define OR_NO_MASK_RW 0x0002
629
#define OR_MASK_FC 0x0000
630
#define OR_NO_MASK_FC 0x0001
631
632
#define MAKE_BR(base_address, enable, rw, fc) \
633
((base_address >> 11) | fc | rw | enable)
634
635
#define MAKE_OR(bsize, DtAck, RW_Mask, FC_Mask) \
636
(DtAck | ((~(bsize - 1) & 0x00FFFFFF) >> 11) | FC_Mask | RW_Mask)
637
638
#define __REG_CAT(r, n) r ## n
639
#define WRITE_BR(csel, base_address, enable, rw, fc) \
640
__REG_CAT(m302.reg.br, csel) = MAKE_BR(base_address, enable, rw, fc)
641
#define WRITE_OR(csel, bsize, DtAck, RW_Mask, FC_Mask) \
642
__REG_CAT(m302.reg.or, csel) = MAKE_OR(bsize, DtAck, RW_Mask, FC_Mask)
643
644
645
MC68302 Watchdog Timer Enable Bit
646
647
648
#define WATCHDOG_ENABLE (1)
649
#define WATCHDOG_TRIGGER() (m302.reg.wrr = 0x10 | WATCHDOG_ENABLE, m302.reg.wcn = 0)
650
#define WATCHDOG_TOGGLE() (m302.reg.wcn = WATCHDOG_TIMEOUT_PERIOD)
651
#define DISABLE_WATCHDOG() (m302.reg.wrr = 0)
652
653
654
* Declare the variable that's used to reference the variables in
655
* the dual-port RAM.
656
657
extern
volatile
m302_dualPortRAM_t
m302;
658
659
#endif
Definition:
m68302.h:320
m302_SCC_bd
Definition:
m68302.h:276
m302_dualPortRAM_t
Definition:
m68302.h:590
m302_DRAM_refresh_t
Definition:
m68302.h:237
m302_SCC_bd_table_t
Definition:
m68302.h:282
Definition:
m68302.h:298
m302_internalReg_t
Definition:
m68302.h:509
Definition:
m68302.h:470
m302_SCC_t
Definition:
m68302.h:456
Definition:
m68302.h:389
