irq.h
1 /* PCI IRQ Library
2  *
3  * COPYRIGHT (c) 2010 Cobham Gaisler AB.
4  *
5  * The license and distribution terms for this file may be
6  * found in the file LICENSE in this distribution or at
7  * http://www.rtems.org/license/LICENSE.
8  */
9
10 /* IRQ handling does not have so much with PCI to do, this library depends
11  * on the BSP to implement shared interrupts.
12  */
13
14 #ifndef __PCI_IRQ_H__
15 #define __PCI_IRQ_H__
16
17 #include <bsp.h>
18 #include <rtems/irq-extension.h>
19 #include <rtems/score/basedefs.h>
20
21 /* PCI Handler (ISR) called when IRQ is generated by any of the PCI devices
22  * connected to the same PCI IRQ Pin. This has been defined the same way as
23  * rtems_interrupt_handler in order for BSPs to "direct-map" the register
24  * and unregister functions rtems_interrupt_handler_install/remove
25  */
26 typedef void (*pci_isr)(void *arg);
27
28 /* Get assigned system IRQ to a PCI Device. If no IRQ 0 is returned */
29 extern int pci_dev_irq(pci_dev_t dev);
30
31 /* Register shared PCI IRQ handler, but does not enable it. The system interrupt
32  * number is read from the PCI board's PCI configuration space header iline
33  * field. The iline field is initialized by the PCI subsystem during start up,
34  * the ipin field is translated into a system IRQ and written to iline. The
35  * board's driver should use the iline field as the irq argument to this
36  * function.
37  *
38  * Arguments
39  * irq System IRQ number, normally taken from the PCI configuration area
40  * isr Function pointer to the ISR
41  * arg Second argument to function isr
42  */
43 RTEMS_INLINE_ROUTINE int pci_interrupt_register(int irq, const char *info,
44  pci_isr isr, void *arg)
45 {
46  return BSP_PCI_shared_interrupt_register(irq, info, isr, arg);
47 }
48
49 /* Unregister previously registered shared PCI IRQ handler
50  *
51  * Arguments
52  * irq System IRQ number, normally taken from the PCI configuration area
53  * isr Function pointer to the ISR
54  * arg Second argument to function isr
55  */
56 RTEMS_INLINE_ROUTINE int pci_interrupt_unregister(int irq, pci_isr isr,
57  void *arg)
58 {
59  return BSP_PCI_shared_interrupt_unregister(irq, isr, arg);
60 }
61
62 /* Enable shared PCI IRQ handler. This function will unmask the interrupt
63  * controller and mark this interrupt handler ready to handle interrupts. Note
64  * that since it is a shared interrupt handler service the interrupt may
65  * already be enabled, however no calls to this specific handler is made
66  * until it is enabled.
67  *
68  * Arguments
69  * irq System IRQ number, normally taken from the PCI configuration area
70  * isr Function pointer to the ISR
71  * arg Second argument to function isr
72  */
73 RTEMS_INLINE_ROUTINE void pci_interrupt_unmask(int irq)
74 {
75  BSP_PCI_shared_interrupt_unmask(irq);
76 }
77
78 /* Disable shared PCI IRQ handler. This function will mask the interrupt
79  * controller and mark this interrupt handler not ready to receive interrupts.
80  * Note that since it is a shared interrupt handler service the interrupt may
81  * still be enabled, however no calls to this specific handler is made
82  * while it is disabled.
83  *
84  * Arguments
85  * irq System IRQ number, normally taken from the PCI configuration area
86  * isr Function pointer to the ISR
87  * arg Second argument to function isr
88  */
89 RTEMS_INLINE_ROUTINE void pci_interrupt_mask(int irq)
90 {
91  BSP_PCI_shared_interrupt_mask(irq);
92 }
93
94 /* Acknowledge the interrupt controller by writing to the interrupt controller.
95  * Note that since it is a shared interrupt handler service, clearing the
96  * interrupt source may affect other ISRs registered to this IRQ.
97  *
98  * Arguments
99  * irq System IRQ number, normally taken from the PCI configuration area
100  * isr Function pointer to the ISR
101  * arg Second argument to function isr
102  */
103 RTEMS_INLINE_ROUTINE void pci_interrupt_clear(int irq)
104 {
105  BSP_PCI_shared_interrupt_clear(irq);
106 }
107
108 #endif /* !__PCI_IRQ_H__ */
#define RTEMS_INLINE_ROUTINE
The following (in conjunction with compiler arguments) are used to choose between the use of static i...
Definition: basedefs.h:135
Header file for the Interrupt Manager Extension.
Basic Definitions.
