poll.h
1 /*-
2  * Copyright (c) 1997 Peter Wemm <peter@freebsd.org>
3  * All rights reserved.
4  *
5  * Redistribution and use in source and binary forms, with or without
6  * modification, are permitted provided that the following conditions
7  * are met:
8  * 1. Redistributions of source code must retain the above copyright
9  * notice, this list of conditions and the following disclaimer.
10  * 2. Redistributions in binary form must reproduce the above copyright
11  * notice, this list of conditions and the following disclaimer in the
12  * documentation and/or other materials provided with the distribution.
13  * 3. The name of the author may not be used to endorse or promote products
14  * derived from this software without specific prior written permission.
15  *
16  * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
17  * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
18  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
19  * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
20  * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
21  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
22  * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
23  * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
24  * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
25  * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
26  * SUCH DAMAGE.
27  *
28  * $FreeBSD$
29  */
30
31 #ifndef _SYS_POLL_H_
32 #define _SYS_POLL_H_
33
34 #include <sys/cdefs.h>
35
36 /*
37  * This file is intended to be compatible with the traditional poll.h.
38  */
39
40 typedef unsigned int nfds_t;
41
42 /*
43  * This structure is passed as an array to poll(2).
44  */
45 struct pollfd {
46  int fd; /* which file descriptor to poll */
47  short events; /* events we are interested in */
48  short revents; /* events found on return */
49 };
50
51 /*
52  * Requestable events. If poll(2) finds any of these set, they are
53  * copied to revents on return.
54  * XXX Note that FreeBSD doesn't make much distinction between POLLPRI
55  * and POLLRDBAND since none of the file types have distinct priority
56  * bands - and only some have an urgent "mode".
57  * XXX Note POLLIN isn't really supported in true SVSV terms. Under SYSV
58  * POLLIN includes all of normal, band and urgent data. Most poll handlers
59  * on FreeBSD only treat it as "normal" data.
60  */
61 #define POLLIN 0x0001 /* any readable data available */
62 #define POLLPRI 0x0002 /* OOB/Urgent readable data */
63 #define POLLOUT 0x0004 /* file descriptor is writeable */
64 #define POLLRDNORM 0x0040 /* non-OOB/URG data available */
65 #define POLLWRNORM POLLOUT /* no write type differentiation */
66 #define POLLRDBAND 0x0080 /* OOB/Urgent readable data */
67 #define POLLWRBAND 0x0100 /* OOB/Urgent data can be written */
68
69 #if __BSD_VISIBLE
70 /* General FreeBSD extension (currently only supported for sockets): */
71 #define POLLINIGNEOF 0x2000 /* like POLLIN, except ignore EOF */
72 #endif
73
74 /*
75  * These events are set if they occur regardless of whether they were
76  * requested.
77  */
78 #define POLLERR 0x0008 /* some poll error occurred */
79 #define POLLHUP 0x0010 /* file descriptor was "hung up" */
80 #define POLLNVAL 0x0020 /* requested events "invalid" */
81
82 #if __BSD_VISIBLE
83
84 #define POLLSTANDARD (POLLIN|POLLPRI|POLLOUT|POLLRDNORM|POLLRDBAND|\
85  POLLWRBAND|POLLERR|POLLHUP|POLLNVAL)
86
87 /*
88  * Request that poll() wait forever.
89  * XXX in SYSV, this is defined in stropts.h, which is not included
90  * by poll.h.
91  */
92 #define INFTIM (-1)
93
94 #endif
95
96 #ifndef _KERNEL
97
98 __BEGIN_DECLS
99 int poll(struct pollfd _pfd[], nfds_t _nfds, int _timeout);
100 __END_DECLS
101
102 #endif /* !_KERNEL */
103
104 #endif /* !_SYS_POLL_H_ */
Definition: poll.h:46
