#include "opt_ipfw.h"
#include <stddef.h>
#include <sys/param.h>
#include <sys/systm.h>
#include <sys/mbuf.h>
#include <sys/malloc.h>
#include <sys/domain.h>
#include <sys/protosw.h>
#include <sys/socket.h>
#include <sys/time.h>
#include <sys/kernel.h>
#include <sys/syslog.h>
#include <sys/sysctl.h>
#include <net/if.h>
#include <net/if_dl.h>
#include <net/route.h>
#include <net/netisr.h>
#include <netinet/in.h>
#include <netinet/in_systm.h>
#include <netinet/in_var.h>
#include <netinet/ip.h>
#include <netinet/in_pcb.h>
#include <netinet/ip_var.h>
#include <netinet/ip_icmp.h>
#include <machine/in_cksum.h>
#include <sys/socketvar.h>
struct | ip_srcrt |
#define | _IP_VHL |
#define | IPREASS_NHASH_LOG2 6 |
#define | IPREASS_NHASH (1 << IPREASS_NHASH_LOG2) |
#define | IPREASS_HMASK (IPREASS_NHASH - 1) |
#define | IPREASS_HASH(x, y) (((((x) & 0xF) | ((((x) >> 8) & 0xF) << 4)) ^ (y)) & IPREASS_HMASK) |
#define | COMPAT_IPFW 1 |
#define | satosin(sa) ((struct sockaddr_in *)(sa)) |
#define | INA struct in_ifaddr * |
#define | SA struct sockaddr * |
#define | OPTSIZ (sizeof(ip_srcrt.nop) + sizeof(ip_srcrt.srcopt)) |
#define | RTA(rt) ((struct in_ifaddr *)(rt->rt_ifa)) |
SYSCTL_INT (_net_inet_ip, IPCTL_FORWARDING, forwarding, CTLFLAG_RW, &ipforwarding, 0, "Enable IP forwarding between interfaces") | |
SYSCTL_INT (_net_inet_ip, IPCTL_SENDREDIRECTS, redirect, CTLFLAG_RW, &ipsendredirects, 0, "Enable sending IP redirects") | |
SYSCTL_INT (_net_inet_ip, IPCTL_DEFTTL, ttl, CTLFLAG_RW, &ip_defttl, 0, "Maximum TTL on IP packets") | |
SYSCTL_INT (_net_inet_ip, IPCTL_SOURCEROUTE, sourceroute, CTLFLAG_RW, &ip_dosourceroute, 0, "") | |
SYSCTL_INT (_net_inet_ip, IPCTL_ACCEPTSOURCEROUTE, accept_sourceroute, CTLFLAG_RW, &ip_acceptsourceroute, 0, "") | |
SYSCTL_INT (_net_inet_ip, IPCTL_INTRQMAXLEN, intr_queue_maxlen, CTLFLAG_RD, &ipintrq.ifq_maxlen, 0, "") | |
SYSCTL_INT (_net_inet_ip, IPCTL_INTRQDROPS, intr_queue_drops, CTLFLAG_RD, &ipintrq.ifq_drops, 0, "Number of packets dropped from the IP input queue") | |
void | ipintr (void) |
void | ip_init (void) |
void | ip_input (struct mbuf *m) |
NETISR_SET (NETISR_IP, ipintr) | |
void | ip_slowtimo (void) |
void | ip_drain (void) |
struct mbuf * | ip_srcroute (void) |
void | ip_stripoptions (struct mbuf *m, struct mbuf *mopt) |
void | ip_savecontrol (struct inpcb *inp, struct mbuf **mp, struct ip *ip, struct mbuf *m) |
int | ip_rsvp_init (struct socket *so) |
int | ip_rsvp_done (void) |
int | rsvp_on = 0 |
struct socket * | ip_rsvpd |
int | ipforwarding = 0 |
int | ip_defttl = IPDEFTTL |
struct domain | inetdomain |
struct protosw | inetsw [] |
u_char | ip_protox [IPPROTO_MAX] |
struct in_ifaddr * | in_ifaddr |
struct ifqueue | ipintrq |
struct ipstat | ipstat |
ip_fw_chk_t * | ip_fw_chk_ptr |
ip_fw_ctl_t * | ip_fw_ctl_ptr |
ip_nat_t * | ip_nat_ptr |
ip_nat_ctl_t * | ip_nat_ctl_ptr |
u_char | inetctlerrmap [PRC_NCMDS] |
u_char inetctlerrmap[PRC_NCMDS] |
