#define | icmp_pptr icmp_hun.ih_pptr |
#define | icmp_gwaddr icmp_hun.ih_gwaddr |
#define | icmp_id icmp_hun.ih_idseq.icd_id |
#define | icmp_seq icmp_hun.ih_idseq.icd_seq |
#define | icmp_void icmp_hun.ih_void |
#define | icmp_pmvoid icmp_hun.ih_pmtu.ipm_void |
#define | icmp_nextmtu icmp_hun.ih_pmtu.ipm_nextmtu |
#define | icmp_num_addrs icmp_hun.ih_rtradv.irt_num_addrs |
#define | icmp_wpa icmp_hun.ih_rtradv.irt_wpa |
#define | icmp_lifetime icmp_hun.ih_rtradv.irt_lifetime |
#define | icmp_otime icmp_dun.id_ts.its_otime |
#define | icmp_rtime icmp_dun.id_ts.its_rtime |
#define | icmp_ttime icmp_dun.id_ts.its_ttime |
#define | icmp_ip icmp_dun.id_ip.idi_ip |
#define | icmp_radv icmp_dun.id_radv |
#define | icmp_mask icmp_dun.id_mask |
#define | icmp_data icmp_dun.id_data |
#define | ICMP_MINLEN 8 /* abs minimum */ |
#define | ICMP_TSLEN (8 + 3 * sizeof (uint32_t)) /* timestamp */ |
#define | ICMP_MASKLEN 12 /* address mask */ |
#define | ICMP_ADVLENMIN (8 + sizeof (struct ip) + 8) /* min */ |
#define | ICMP_ADVLEN(p) (8 + ((p)->icmp_ip.ip_hl << 2) + 8) |
#define | ICMP_ECHOREPLY 0 /* echo reply */ |
#define | ICMP_UNREACH 3 /* dest unreachable, codes: */ |
#define | ICMP_UNREACH_NET 0 /* bad net */ |
#define | ICMP_UNREACH_HOST 1 /* bad host */ |
#define | ICMP_UNREACH_PROTOCOL 2 /* bad protocol */ |
#define | ICMP_UNREACH_PORT 3 /* bad port */ |
#define | ICMP_UNREACH_NEEDFRAG 4 /* IP_DF caused drop */ |
#define | ICMP_UNREACH_SRCFAIL 5 /* src route failed */ |
#define | ICMP_UNREACH_NET_UNKNOWN 6 /* unknown net */ |
#define | ICMP_UNREACH_HOST_UNKNOWN 7 /* unknown host */ |
#define | ICMP_UNREACH_ISOLATED 8 /* src host isolated */ |
#define | ICMP_UNREACH_NET_PROHIB 9 /* prohibited access */ |
#define | ICMP_UNREACH_HOST_PROHIB 10 /* ditto */ |
#define | ICMP_UNREACH_TOSNET 11 /* bad tos for net */ |
#define | ICMP_UNREACH_TOSHOST 12 /* bad tos for host */ |
#define | ICMP_UNREACH_FILTER_PROHIB 13 /* admin prohib */ |
#define | ICMP_UNREACH_HOST_PRECEDENCE 14 /* host prec vio. */ |
#define | ICMP_UNREACH_PRECEDENCE_CUTOFF 15 /* prec cutoff */ |
#define | ICMP_SOURCEQUENCH 4 /* packet lost, slow down */ |
#define | ICMP_REDIRECT 5 /* shorter route, codes: */ |
#define | ICMP_REDIRECT_NET 0 /* for network */ |
#define | ICMP_REDIRECT_HOST 1 /* for host */ |
#define | ICMP_REDIRECT_TOSNET 2 /* for tos and net */ |
#define | ICMP_REDIRECT_TOSHOST 3 /* for tos and host */ |
#define | ICMP_ALTHOSTADDR 6 /* alternate host address */ |
#define | ICMP_ECHO 8 /* echo service */ |
#define | ICMP_ROUTERADVERT 9 /* router advertisement */ |
#define | ICMP_ROUTERADVERT_NORMAL 0 /* normal advertisement */ |
#define | ICMP_ROUTERADVERT_NOROUTE_COMMON 16 /* selective routing */ |
#define | ICMP_ROUTERSOLICIT 10 /* router solicitation */ |
#define | ICMP_TIMXCEED 11 /* time exceeded, code: */ |
#define | ICMP_TIMXCEED_INTRANS 0 /* ttl==0 in transit */ |
#define | ICMP_TIMXCEED_REASS 1 /* ttl==0 in reass */ |
#define | ICMP_PARAMPROB 12 /* ip header bad */ |
#define | ICMP_PARAMPROB_ERRATPTR 0 /* error at param ptr */ |
#define | ICMP_PARAMPROB_OPTABSENT 1 /* req. opt. absent */ |
#define | ICMP_PARAMPROB_LENGTH 2 /* bad length */ |
#define | ICMP_TSTAMP 13 /* timestamp request */ |
#define | ICMP_TSTAMPREPLY 14 /* timestamp reply */ |
#define | ICMP_IREQ 15 /* information request */ |
#define | ICMP_IREQREPLY 16 /* information reply */ |
#define | ICMP_MASKREQ 17 /* address mask request */ |
#define | ICMP_MASKREPLY 18 /* address mask reply */ |
#define | ICMP_TRACEROUTE 30 /* traceroute */ |
#define | ICMP_DATACONVERR 31 /* data conversion error */ |
#define | ICMP_MOBILE_REDIRECT 32 /* mobile host redirect */ |
#define | ICMP_IPV6_WHEREAREYOU 33 /* IPv6 where-are-you */ |
#define | ICMP_IPV6_IAMHERE 34 /* IPv6 i-am-here */ |
#define | ICMP_MOBILE_REGREQUEST 35 /* mobile registration req */ |
#define | ICMP_MOBILE_REGREPLY 36 /* mobile registration reply */ |
#define | ICMP_SKIP 39 /* SKIP */ |
#define | ICMP_PHOTURIS 40 /* Photuris */ |
#define | ICMP_PHOTURIS_UNKNOWN_INDEX 1 /* unknown sec index */ |
#define | ICMP_PHOTURIS_AUTH_FAILED 2 /* auth failed */ |
#define | ICMP_PHOTURIS_DECRYPT_FAILED 3 /* decrypt failed */ |
#define | ICMP_MAXTYPE 40 |
| #define | ICMP_INFOTYPE(type) |
