iotn45.h
1
7 /*
8  * Copyright (c) 2005, Joerg Wunsch
9  * All rights reserved.
10  *
11  * Redistribution and use in source and binary forms, with or without
12  * modification, are permitted provided that the following conditions are met:
13  *
14  * * Redistributions of source code must retain the above copyright
15  * notice, this list of conditions and the following disclaimer.
16  *
17  * * Redistributions in binary form must reproduce the above copyright
18  * notice, this list of conditions and the following disclaimer in
19  * the documentation and/or other materials provided with the
20  * distribution.
21  *
22  * * Neither the name of the copyright holders nor the names of
23  * contributors may be used to endorse or promote products derived
24  * from this software without specific prior written permission.
25  *
26  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
27  * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
28  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
29  * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
30  * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
31  * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
32  * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
33  * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
34  * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
35  * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
36  * POSSIBILITY OF SUCH DAMAGE.
37  */
38
39 #ifndef _AVR_IOTN45_H_
40 #define _AVR_IOTN45_H_ 1
41
49 #include <avr/iotnx5.h>
50
51 /* Constants */
52 #define SPM_PAGESIZE 64
53 #define RAMEND 0x15F
54 #define XRAMEND RAMEND
55 #define E2END 0xFF
56 #define E2PAGESIZE 4
57 #define FLASHEND 0xFFF
58
59
60 /* Fuses */
61 #define FUSE_MEMORY_SIZE 3
62
63 /* Low Fuse Byte */
64 #define FUSE_CKSEL0 (unsigned char)~_BV(0)
65 #define FUSE_CKSEL1 (unsigned char)~_BV(1)
66 #define FUSE_CKSEL2 (unsigned char)~_BV(2)
67 #define FUSE_CKSEL3 (unsigned char)~_BV(3)
68 #define FUSE_SUT0 (unsigned char)~_BV(4)
69 #define FUSE_SUT1 (unsigned char)~_BV(5)
70 #define FUSE_CKOUT (unsigned char)~_BV(6)
71 #define FUSE_CKDIV8 (unsigned char)~_BV(7)
72 #define LFUSE_DEFAULT (FUSE_CKSEL0 & FUSE_CKSEL2 & FUSE_CKSEL3 & FUSE_SUT0 & FUSE_CKDIV8)
73
74 /* High Fuse Byte */
75 #define FUSE_BODLEVEL0 (unsigned char)~_BV(0)
76 #define FUSE_BODLEVEL1 (unsigned char)~_BV(1)
77 #define FUSE_BODLEVEL2 (unsigned char)~_BV(2)
78 #define FUSE_EESAVE (unsigned char)~_BV(3)
79 #define FUSE_WDTON (unsigned char)~_BV(4)
80 #define FUSE_SPIEN (unsigned char)~_BV(5)
81 #define FUSE_DWEN (unsigned char)~_BV(6)
82 #define FUSE_RSTDISBL (unsigned char)~_BV(7)
83 #define HFUSE_DEFAULT (FUSE_SPIEN)
84
85 /* Extended Fuse Byte */
86 #define FUSE_SELFPRGEN (unsigned char)~_BV(0)
87 #define EFUSE_DEFAULT (0xFF)
88
89
90 /* Lock Bits */
91 #define __LOCK_BITS_EXIST
92
93
94 /* Signature */
95 #define SIGNATURE_0 0x1E
96 #define SIGNATURE_1 0x92
97 #define SIGNATURE_2 0x06
98
99
101 #endif /* _AVR_IOTN45_H_ */
Definitions for ATtiny25, ATtiny45 and ATtiny85.
